View Full Version : LT1-LT4 Modifications
- exhaut question
- LT1--need shortblock or Used bottom end
- 93 crane lt1 cam in 96 motor
- AS&M Intake
- question
- 112 LSA on Automatics??
- please help!
- backfiring and breaking up off throttle
- Coolant Hoses Pics
- Car died...Need some helpful info.
- Quick question ???
- tb bypass?
- Need TTS datamaster scans to read
- lt1 cam and 350 block
- Threaded oil drain?????
- I am sorry that I am stupid.
- This might sound very newbie, but.....
- air filter??
- Nitrous Oxide
- Cam Advice Needed
- DTE, Dynotech Engineering, were they in Texas at one time?
- is a mass air flow sensor worth the $$???
- the right short block
- HP gains from Cc305 and bolt-ons????
- Anyone put a distributor in a LT4 intake?
- LS1 injectors on an LT1??
- Problem With Power Supply
- Uh, oh ! Somebody was busy this weekend..
- Help, Can 96 Lt1 Fit Into 89 Iroc Z
- buildup on a budget... 355???
- Roll Cage??
- Whatcha Think?
- new guy
- 1993 corvette to mass air conversion?
- 1996 Camaro SS..Nice exhaust system?
- trouble code
- spark raddle
- Clearance issues with header studs?
- help with msd and shift light
- fog lights
- Serpentine Belt size help
- le1 owners?? how is i?? Lt-4 HotcamTimes??
- Catback?
- Pics of new setup!!!
- Front End
- Would the 98-02 pro kit work on 94-97?
- Timing Chain Help.
- Six speed Gains with 4.10's in the 1/4
- Shift Light Pics Please
- Need Some Help With a Project - good comparisons of LT1 and LS1?
- lt1 parts
- Heads
- Anyone running Trickflow heads?
- what kind of blower?
- Oops broke somethin....
- Running high temp???
- headers
- ANYBODY GOT PICS OF LOWERED CAMARO'S & SUSPENSION?
- Suspension mods?
- building a 383 stroker
- ok guys need ur help!!
- Surging in an LT1
- What size standard equals 13mm?
- gears
- dyno, should i be disaponited? pics
- 94 TA - when the car warms up, and you jump on it, it runs great. But try it again, and it falters.
- Stock Fuel lines. How much power they good for? *fueling issues*
- Suspension.. snap crackel and pops... can i get rid of it?
- Budget Build Questions
- Are my lifters bad? pics inside...
- which plugs???
- Will JB Weld work for this?
- What times are you 383 guys gettin
- Killed at wot
- HP gains from hotcam and bolt-ons????
- horsepower gain
- optispark dowel upside down??
- lt4 knock sensor for 95 TA?
- 1.5's or 1.6's Rockers?
- Main stud tourqe
- ABS light and some times engine light but it gos away
- What do you guys think of LT1 Edit
- Curiosity....
- Changing Gears (2.73 To 3.42)
- Black Ignition Box?? Underhood??
- lookin for a hood
- p1807 for a 97 lt1a4
- tci super street fighter
- Stock Block Rev Limit?
- HELP!!!!! Accel DFI Gen 7/ LT1
- Finally a 93-97 to 98-2002 front-end conversion tutoral
- Tranny question, but mated to a 396 LT4...
- code 16
- LT1 engine build up at Exotic Performance Plus
- best heads for LT1
- Cailfornia Smog Laws
- Can I use this True Dual setup?!COME IN!
- which stall converter??
- dont know where to connect this hose
- so what brans do u guys have for air foils?
- LT4 Hot Cam Kit vs. Crane 210/224 w/springs & rockers
- LT4 Hot Cam with 1.7 RR's. Valve Spring?
- Cc305
- abs light with ss led light???????
- Looking for forged crank advice.
- what hardware do i need?
- Best 1/4 Mile times w/Full Exhaust & Spray??
- Stage 8 bolt sizes HELP?
- HELP! High RPM ignition missfire/breaking up issue
- Big Solid Roller, and my heads??
- Wierd high rmp issue
- 95TA vs. 97TA
- Scattershield?
- Engine Cleaning?
- Abs Inop
- 355 buildup....?
- will trade.
- good choice?
- HPs #, out all motor 396?
- Crane 210/224 Or Lloyd Elliot 2 Cam?
- FUEL PRESS Gage HELP
- lifters...
- how many qurts does the lt1 take???
- coil conversion nightmare please help
- O2 Sensor and Cutout Help
- Lt1 elbow
- Where To Find Motor?
- Lt1 Timing Chain
- help or suggestions please
- lt1 starter issues
- Best Cam To Run In A 383 Stroker?
- im noob
- New pics of the WS6, finally set the ride height :)
- what website is this car off of?
- ? Gm 847CAM where to buy and how is it ????
- Black smoke form exhaust......
- Dynatech Headers
- Help needed with drive shaft bearing/center support!!!!
- BBK Vs Holley
- Need Help Fast!!
- North Charleston shops?
- predict times with cam and spray
- S&W 8 point roll bar
- How fast are STI's?
- Ok, need some help
- To resistor or not to resistor...I'm new
- Air pump for engine important/affect performance?!!?
- Cams / Crank etc
- Pic's of my new heads...
- is this a good deal for a 396?
- Fastest bolt on times,
- Electric Water + Opti Spark = ??QUESTIONS?? have you done one. . .?
- CC306 Idle Video
- Wider tires slower times?
- lt4 intake direct port fogger 4 sale
- Typical Oil Pressure
- Help w/ my LT1 CSR waterpump!!!
- 323Gears MAX SPEED
- 93 to 94 gauges
- Which Cam and Tune?
- help help
- Slp dual cat shortys help!!!
- Does this sound like a bad torque converter?
- Idle problems
- 97+ gauge cluster swap
- "Cadillac Cam"?
- Minimum cam dowel pin length?
- Mcleod Clutch
- Adjustable Master
- nitrous question?
- Ported TB or MAF???
- 355 or 383
- HELP oil lines
- me vs eclipse
- if your car wont start, start here
- Fans will not kick on at any temp, need help to diagnose?
- LT1 Exhaust
- Stock internal 96k+ mile LT1 goes 11.67
- real quick question....how much is stock fuel pressure?
- Help HOT
- Will this spring hold cc306 lift??
- doing rebuild! 355, 383, 396?
- looking for a guide for headers install
- BBK mid headers? Anyone?
- Which cam?? for 3.73 and 3000 stall?
- Help 383 Carbed In 97 Ws6
- 383 build questions
- Ignition wiring question, need help
- Couple install price ?'s
- Give me an idea of the power for these mods?
- 95 corvette exhaust
- Car will not start after rain, Opti?
- what times with 230/236 cc
- Gas Mileage improvement?
- Hotcam/CC305 owners, what times are you running?
- Thoughts on Mac cat-back
- How difficult to replace the "Optispark" on a 95?
- wanting to upgrade from lt4 intake to carb intake help
- LT1 to LS1 swap ??????
- cheap horsepower
- 306 cam And check these valvertrain????
- What Mod Next?
- Valve Spring/ Retainers
- lt1 oil pump & head gasket????
- Hp Estimate
- HPE 383 Shortblock
- Noisy Valvetrain
- Taste Test...
- What cam should I run
- Anyone running a CC503 on a 114LSA?
- 1990 corvette
- GM847 vs. cc305 for a daily driver
- Pacesetter Header Questions
- Catalytic Converters
- ____3000 stall how is it with 306 & 3.73??___
- 355 6 Speed goes 10.49 @ 130.4 NA
- finally got the bottle in the car and got a few pics for ya guys on my 93 LT
- throttle body airfoil
- smog pump lines were do they go
- LT1 with no spark at coil
- What is the RPM rang for CC306?
- starter issues
- Any tips/guides for cleaning the MAF?
- How the hell do i tell?
- Header/Y-Pipe Combination Question for '97
- Cooling a high HP 383 LT1
- Max lift on 986-16 valve springs
- Muffler...
- 30# Ford SVO red tops
- lt header question?
- Which cam for Ported LT1 heads??
- what couldi get
- Will a clogged cat prevent a car from starting?
- Someone lend a hand
- Any HPE guys in here???? Rick???
- lt1 block interneals = sbc internals? yes no?
- Vibration from exhaust. Any help?
- How hard to get 400rwhp from LT4?
- coil wire
- tunning
- what should i expect?
- Recommendatons on Y-pipe
- header and exaust install parts?
- what kind of numbers should i see with this cam?
- Post pics of your longtubes and y-pipes please!
- so i raced an 05 GT...
- Help Needed LT4 Valves
- Compression
