- 317 heads + 15 psi = o-ring?
- what turbo might work?
- Street car, twin turbo, no intercooler... just meth inj?
- Magnuson 2300 sucks...
- Dynoed my setup and quite happy
- Supercharger Cams
- new member will this make 800 plus fwhp
- Used STS turbo worth it !!!
- Spal fans loud?
- Looking to go FI which of the 2 kits do you suggest
- Who runs a TCI Flexplate?
- Innovative West 8" crank Pulley questions
- Did you ever regret adding a ATI procharger?
- new build, 5.3 vs 6.0
- Excessive Blow By
- Best SC Compression Ratio Street/Strip Car
- how do you know if your back-spinning a turbo?
- Another update on my 10.5 outlaw trans am
- HELP fuel RETURN LINE OR NOT!!, hobbs switch ???
- h/c recommendations for maggie ls2
- LT1 383 Blower Build
- How Much RWHP/TQ LS7 Supercharged???
- turbo math, airflow reqs
- Anyone used this ebay kit?
- 1967 Nova Build (LQ4 6.0L Turbo) need some advice
- thinking of selling my Mahle pistons what is fair buy?
- 408 Forced induction waffle:
- FWD 5.3 LS4 Turbo 11.01 @ 126MPH
- is a procharger head unit off of a gm truck the same as a camaro????????
- Edelbrock ultra low profile elbow
- Speed Inc Twin Turbo Kit
- Rear mounted Ice/water tanks
- How would this cam be for my 421?
- Eforce Supercharger
- which intake?
- anyone have hks or tial bov?
- Anyone used Procomp 3019 heads?
- After Market K-Member VS Solid Mounts
- intake elbows
- how to plum turbo coolant lines
- 93-97 lt1 camaro protubo kit gen 2 hotparts
- Best 4 bolt head
- SC type sc'er...how on earth does the oil not burn up fast......
- TURBO LS1 BUILD help
- Help me pick a Muffler/Resonator for FI
- what size wastegate do I need?
- TVS2300 on stock 05 GTO auto
- what pulleys for 8 psi procharger?
- jgs bov flange size?? will a hks adapter fit?
- Will this cam work on my setup, help!
- custom griffin rad
- Spark Plug Question
- Pro/Con of using Phenolic spacer on pd blower
- P/I Ls7 Heads Results
- need advice on my cam,pully choice
- Procharger n the stock MAF?
- Pushed A headgasket out have ?'s
- Hp rating
- lq9 turbo questions
- Selecting a turbo for a fast spool 421ci 1000whp
- would this cam work well for a turbo set up???
- Rear-end for turbo, s/c cars (kinda relevant to FI section I think)
- turbo kits for vette
- Who's making 1,000 hp on a stock cast crank?
- lt1 turbo kit fit an ls1?
- Twin Turbo Kit
- I need a catch can diagram
- good turbo header ceramic coater?
- Which Procharger is good for 35 PSI?
- 417 motorsports Twin KIt Help
- got the turbo mounted
- made a new merge what do you think?
- Ls1 turbo kit
- 5.3 with a turbo ?
- What sponsers carry Precision Turbos?
- head bolt question
- Can a TH350 survive an 8.6X 1/4 mile pass at 3800# in turbo car?
- Killed my Turbo - STS says I "Overspun" it - Does that compute?
- Problem with Pulley/Bracket on D1SC
- Can someone school me on Boost reference fuel regulation?
- 364 or 370 for boost?
- NA to Single Turbo ?'s and kick in the butt...
- D1SC vs heads/cam dyno graphs
- Too much for stock bottom end?
- lt1 Turbo camshaft
- want to buy s480 turbo
- Proven single turbo system for sale
- cam suggestions for 02 LS1, N/A now, turbo later
- cam for turbo ls1
- Getting Ready To Install Procharger..Just Have a Few Questions
- 2000 WS6 F1A Build thread!!!
- whats a good turbo cam?
- Few Procharger Questions (GTO)
- Oil pressure at turbo?????
- Intercooler piping..
- Would 2" primary headers hurt a D1SC procharged 347
- new best for the season
- turbo motor upgrades
- rotor-master identification?
- Have a few questions on turbo build
- gto and f-body pulleys?
- Review/Refine my plans
- Rocker arm question
- Air fuel ratio
- 370 and 80-88mm turbo
- 383 lt1 vortech supercharged?? on crank
- BW s480
- Procharger, twin cooler = front sway bar still fit?
- fast intake leaks
- heads
- Bare bones turbo 5.3L hp?
- STS turbo vs H/C?
- What is a decent price for a d1sc install w/injector and pump?
- Comp 918's enough spring for my FI setup?
- Safc 2
- ls1 98-02 f body/ help!!
- msd6010/6012 boosted timing tables? anyone care to post some?
- Horizontal A2A IC(s)
- Piston Oil Squirters
- TrickFlow/TEA 220cc Turbo Heads?
- FI Motor
- crossover pipes?
- harrop supercharger 408ci - 450rwhp!!!
- Yeah i did it with a frozen boost ic!
- 4.8l turbo
- The better engine for D1 procharger??
- who has the best custom rear mount write up looking for a little help PLZ
- 100% synthetic oil filter for Chevy engines [VIDEO]
- Vertical IC(s)
- Future mild Procharger build
- My new custom 6 bolt aluminum block
- STS turbo questions
- Procharger Surge Valve
- Edelbrock E-force on a 408 LS3?
- Suggestion of heads for turbo build
- did i go too lil on my turb 5.3 cam?
- Mike Brown's quickest ET in his CE Trans Am?
- BEST TRANS for turbo build
- HpTuners, Procharged D1SC, Which Map?
- crank case ventalation
- winter build plan....LS camino is getting some boost!
- Air to water on street
- Cooling with my aps some ideas?
- Paxton Novi 1200
- Valve springs for 10 psi LS1
- Anyone sell a DIY turbo it?
- 2001 LS6 cam for turbo 5.3?
- Pressure drop with this style intercooler?
- No more smoking!
- Procharged LS1 Civic =)
- Ideal twin rear turbos, built stock cube ls6 for a street DD
- boost on 799 casting heads
- Cooling requirements on turbo 5.3
- been thinking about my d1sc to tc78 swap.
- 2010 Camaro, Va Speed 427, Procharger F1R(updated 1130hp)
- Virginia Speed-your forced induction specialists
- TB placement with a blower
- Turbo size suggestion for 347 ci 6 speed car
- Turbo/LSA head cam help please.
- procharger install help
- To O ring or not to O ring
- Looking for a procharger
- Camshaft question/recommendation
- cars overboosting after repair
- First time on dyno w/ new setup 792/700
- 67mm Turbo
- Looking for a Procharger 6 rib crank pulley
- Have any of you guys have expereince with this?
- 1,738 HP - 424ci RHS & 106mm Turbo
- New Turbo Build....Need Some Insight
- Went front mount and built forged motor, how much boost can I run?
- Wanting to upgrade to turbo but need help.
- who and where do i call to repair my Procharger
- When is 3" cold side needed over 2.5"
- how much power have you made with C6 manifolds?
- ls6 cam install ?
- Tc78 vs pt88
- Twin Vertical IC's?
- Custom spec'd turbo cam...Would you run it or try another?
- Need a impeller for my D-1sc procharger
- A2W and A2A Intercoolers. Is bigger always better?
- Wideband ? AEM UEGO vs Innovative LC1
- Just how far has a stock computer been taken?
- Who wants to go on a 7 second ride??? Vids inside!!
- misfire/sputtering entering boost
- Race Proven Motorsports Twin Turbo 4L80E C6Z06
- Typical help me pick my turbo thread lol
- ***LMR 2000hp Corvette Initial Start Up Vid***
- running a stock motored turbo car na
- Need some help
- Help with vacuum lines
- Forced Induction ? and stock components
- It's a good time to buy a new ProCharger!
- turbo headers primary tubes
- Twin Turbo intercooler routing
- Best sound?
- Is there a better turbo than a tc 78 that's the same size?
- turbo size for a 5.3l ?
- Kenne Bell 4.2L Supercharger
- twins with no FMIC?
- stock tb on turbo setup
- convertible c5 goes 8.71 at 159mph
- will my merge collector work pics inside
- What type wastegate spring is this? its in my tial..
- Which engine route?!
- 1k hp guys help on set up
- cheapest forged rod/piston combo for 5.3?
- Routing boost gauge tubes/wires through the PCM Grommet?
- Part number for Cobalt 2.5 BARIAT/MAP Sensor
- Virginia Speed F body single turbo hotside
- 370 w/S91 spooling question
- Magnacharged LS1/6 Guys
- Twin 67's..too small?
- Want pics of AMS 1000's installed.
- how much power
- ***HPE supercharger bracket shake down passes runs 8.75 @156.8MPH***
- 7K Mile TearDown
- New PB with APS w/LG turbos (M6 to 4L80 swap)
- fitment issue with flipped truck manifolds
- 370 vs 347
- 2 step help.
- Precision Billet 6262
- My Procharger Build- Need help/parts 02 Camaro STOCK
- Lt1 turbo time, what is recommended by the turbo guys?
- lq4 rod bolts stock bottom end
- 402 YSi on the dyno vid!
- Truck Manifold ABS lines
- truck intake
- aps
- "LETHALZ" puts down 968rwhp/814rwtq - *Vid-Graph* Inside
- oil pumps.. high pressure Vs. high volume
- Where can I get a CO2 kit for a boost controller?
- Oil pan fitting for return line
- APS LG TT 408/4L80e setup...oil pressure ???
- mpt70 5.3/4l80 e85 have a few ?'s
- FI motor question
- eboost2
- ERL motor questions
- Ring gaps and bearing clearances helppppp
- Here is a little video I whipped up... let me know what you think...
- Newest member of the air conditioned 9 second club.
- Need opinions
- Race Proven Motorsports "Sleeper" Package #2
- New Alternator Mount Option
- forced induction tunning
- what size fmic?
- 87 Trans Am 5.3L w/ 76mm build, in under 3 weeks!!
- Has anyone ever seen Twin prochargers?
- APS - Megasonic BOV Fitment
- what is too high of mileage to turbo a stockish lq4?
