- weird supercharger problem...
- Turbo flow: inlet reducer vs changing compressor
- AR help,
- Which turbo for Autocross?
- Cheap blow off valve??
- high hp motor which poweradder
- Turbo Build Suggestions
- *** I DID IT !! Smashed the 8-second Zone today ***
- Why would a throttle body be ON the turbo inlet?
- My New Turbo Build!!!!!!
- Turbo kits
- need a cam
- Cool dyno vid....91X on a BMW
- 2003 Z06 with A&A vortech kit
- Lets see some results for the TC-78...
- Now imagine this technology once it hits mainstream turbos..
- anyone have plans for one of these
- Cheap Ebay Turbo Kit?
- Best heads for Turbo ls1?
- mocal scavenger pump
- Patriot Dual Spring Failure
- belt driven scavenger pump
- how do i wire a scavenge pump and alky pump?
- New turbo on order
- Turbo, supercharged,or nos
- Block recommendation for street/track car
- Are ARP head bolts enough?
- Newbi help stock botom
- 402 ls2 with d1 /m6 GTO
- Truck manifolds
- Fuel system question.
- single turbo blowin through a carb
- Couple questions on finishing up my build
- Screen or No Screen FMIC???
- Forced induction head gaskets
- cross over length? is it important?
- Reliable intake setup for boost
- Pillar pod paint matching.
- Eboost 2 got one coming install questions tips and tricks..
- Procharger F1-C pls help me ????
- diesel turbo
- will i need it re-tuned
- magnacharger mp112
- Turbo hotside from ebay what you think ?
- after-turbo exhaust dumps, can we see some pics?
- carb style intake question
- Finally Got Some Dyno #s For the 408 & F1
- Is anyone using any Knock Off Wastegates or BOVs?
- LSX or Iron Block
- 2-step?????
- Dope style with a ram air twist Trans cooler
- Incon Wastegate Actuator Questions
- LS2 block cylinder walls max boot psi/hp/start to balloon Any info on dry sleeves to?
- Stock car (Turbo or Supercharger)
- Good info maybe even should be stickied.Concerning smoking or oil burning from turbo.
- Its Back?!? 218/228 Hot Chili Cam + BOOST?
- My custom FMIC setup thread
- Procharger tensioner bearing seizing!
- Conpression of 347
- Quench question
- what size wastegate and bov?
- Turbo Size sugestions
- master power turbos
- eboost2 on twin turbo..do I kneed two solenoids?
- JDM Ebay Turbo....who has them???
- Help a Honda buddy pick a turbo?
- is a kenne bell in f body possible??
- Quench with a Supercharger
- Bypass valve questions
- T4
- 6-71 looking blower for ls1?
- Question regarding loss of coolant on my Turbo car...
- 2000 vette 5.7L(head gasket?)
- Fuel system
- Procharger pulley size
- LSX Block's!!
- spool time
- Our cog drive with reinforcement brackets
- Opinions or experiences with this intercooler?
- T3 turbo rebuild
- Cam for Magnacharger build...
- CAST PTK TopMount manifolds
- timing chain.
- Procharger VS Turbo Dyno Graphs
- turbo kits ?
- good streetable cam for supercharged 408
- 2 turbo questions. Turbo size and manifold
- Blower, Cam, and not HEADERS??
- Turbo swap on 91 Syclone with pics
- what valve springs you guys recommend?
- APS guys number eight plug and wire changing?
- S400 Too Big?
- How to Mount an Intercooler
- oil feed question
- these kits any good ?
- help getting 2bar
- Anyone using the Speed Inc Alternator Relocation Kit? Need feedback =)
- Turbonetics TNX-122
- Edelbrock Supercharger???
- Turbo feed/drain question
- New turbo
- Boost refrenced Fuel PSI Regulator for Turbo
- Procharger exchange?
- too low of compression..7.9 to 1
- Problem solved!
- procharged 490bbc lost oil pressure
- A1000 or A100 platinum???
- New APS track results (stock shortblock)
- any destroked builds out there
- Oil Pan Recomendation???
- Blown Motor caused by OIL STARVATION!!
- 440ci Z06, Ebay "PTK" kit; some results, some questions.
- JGS Wastegate and BOV
- Car running better with new PCV setup..
- cat-back on TT 427
- what kind of power u guys making
- At what point is a 4" Downpipe a noticable restriction
- Finally got into it.
- LS1 Forced Induction Hall of Shame
- Finally made it to the track with my A&A C5Z
- Open Down Pipes Bad???
- Need turbo recommendation LQ4/9 6.0
- 06 GTO - SC M6 vs TC A4? FI Gurus Talk To Me Please
- Mild Steel Manifold Flanges?
- need help!!!
- Bov placement question?
- will these work and big enough?
- ls1 turbo build
- Coolant hoses
- Dual oil coolers?
- Sold off the Formula
- Burkhart Radiator setup for FI
- Finally ... My nine second six speed.
- What should i do? Pulled the ARP Head Stud out of block.
- Whats the best year ls6 cam to go with?
- Manifold differences....
- Best for my application?aps twin turbo or procharger
- Truck Manifolds?
- sts turbo set up
- Where to go next?
- clutch problems
- should I upgrade my fuel system
- need help (PETER APS)
- Front mount swap how much hp gains
- I finally took the FI route...
- APS KIT/ TTI @ 1000rwhp possible????
- .224/.232 114 lsa good cam for forced induction with l92 heads?
- 2 bar MAP?
- Last runs of the season: Car goes 170+ mph
- Adapter, Tial 38mm to 50mm Jgs Wastegate
- t3 manifold change to t4?
- ProCharger Pulleys, Where to buy..?
- Good cam for 383 LT1 supercharged
- what cam for 408 t-trim supercharged!!
- diesel turbo?
- front bumper
- How can I get a fail safe MAP signal?
- stock ls1 coils
- Mike Brown in hospital with brain aneurysm
- Having it balanced?
- intercooler question
- New parts is coming pic :) .
- Anyone have pictures of PT-88 Turbo?
- anyone running the PTK kit *read*
- LS9 Crate Engine Next Fall!!!
- boosted oldschool
- Rear mount oil return ???
- Where to go from here.
- HELP with setup
- Ok aps guys with speed density what size silicone to eliminate the maf?
- spark to boost with cam 110
- looking for the right cam
- Custom Rear mount turbo
- ProCharger rebuild begins!
- Best Turbo Header gaskets?
- Well, Not the quickest-but maybe the fastest SC C5? 148.58?
- honest anwser should i just build a n20 car for a daily driver!
- does it make a difference?
- How much spray can you add to a single turbo set-up?
- Corvette goes Boom!
- Holset HX40W
- Turbo VW Bug Build
- PCV Layout Question
- Twin Holset Ls1
- Incon Check Valve Placement???
- Quick Compression check calculation
- ceramic coating or just header wrap??
- best tb and maf for t-trim vortech?
- My KYTP build
- LS1 turbo TB/Intake
- LS3/L92 head gasket?
- W2W twin turbo camaro?
- P1sc or F1A
- LS1 Custom Turbo wanting advice...
- Tuning timing for boost, msd 6010
- Looking to go turbo LQ9
- anyone know someone with a kenny bell on a ls1 camaro or trans am
- New To boost some questions
- i want a turbo or super charger need help
- How much boost will a stock 6.0 handle?
- Keeping AC, And Alt In Stock Location
- Sts Fmic Kit
- No way! More bad luck for ninetres???
- Anyone got problems with fluid dampr ??
- Zombie's 3 speed Th400 over drive solution
- Kinda random question about rear-mount turbo systems...
- Aps turbo f body guys tips ,tricks and questions thread.
- If 600rwhp was your end goal, would there be a downside to a rear mount.
- Blower Cam
- Where to have GMPP intake plumbed and ported?
- A 383 OR 355 Supercharged?
- Where to relocate fuse boxes
- i broke it...looking for imput/suggestions
- Procharger RACE blow off valve few questions and cheapest place to buy one
- 9.21 Letting out... *video*
- Turbo Opinion from Yall
- Who all have deleted the power steering cooler?
- Anybody have a Large frame Precision PT101ish off they can take some measurments of?
- Best budget head for boosted 408?
- What oil weight for the tt.....
- MS3/Procharger
- Major #1 Qualifier @ Orlando World Street Nationals.
- Package Turbo kit for LS1?
- TTiX stock motor 10.2@142 in car video
- 99 Turbo Ss Camaro 402 Need Help
- Car acting up Help!
- What does your 3bar map read
- 2048.9 hp/1507.1 lbsTq 400ci LSX
- Anyones serpentine belts affected by piping?
- LS1 Forced Induction Hall of Fame
- Question for you turbo guys
- Aps buds what size is the blow offs..20mm or 25mm
- cold pipe question.
- turbo 346 LS1 camaro
- Incon Install Help
- procharger question
- ebay "ls1 turbo kit"
- New ZR1 At The Track.
- Got a TH400 with brake....how to launch?
- upgrade stock 317s or get PP stage 2
- How much power is my fuel system capable of?
- injector size 427
- Are there any 6 Speed STS/Rear Mount Turbos in the 9's?
- Head gasket for twin 70 build
- Built a turbo civic, now I want to boost my T/A :)
- Everyone like T-netics TC testing.
- Patriot Duals the best spring for FI?
- A couple more runs with EPP Formula last night
- Twin Turbo and aluminum flywheel
