View Full Version : LT1-LT4 Modifications
- Aftermarket Tach in 93 Camaro, having problems...
- Budget-ish Headers
- vibrating/shaking at idle
- lt1 cam in an olds 350 rocket?
- question
- Going Long Tubes! Need Some Pipes!
- 450 hp possible with this set up
- Rear main Seal
- Ever snap a header bolt? I did...
- Car was running mint, then died in 24 hours
- stroker
- Waterpump and coolant flow with pics
- Back and running!
- Vortec/LT4/LS1 head building question
- weighed my car tonight
- Lt1 swaps....
- will a 97 long block work in a 95? please help
- AC don't work, how bout a shorter belt?
- Runs like cr@p - why?
- Help with idle problem
- most hp with stock pcm? are they limited?
- C4 LT1 Waterpump replacement.
- flywheel suggestions??
- I can't take it anymore!
- Stainless Work CatBack
- Post up your LT1 gauge overlays...
- 9:5:1, 2 bolt main 383 stroke ported heads and intake!! what is your HP guess??
- Belt Length
- braided fuel line
- Port & Polish Z28
- Valve covers
- Ported Heads and Intake
- help
- Need input!!!
- No 02's how will it run
- EGR Valve and air pump
- race prep intake
- LT1 fuel line mod
- Rear Brake question
- help needed
- piston/valve clearance with cc306?
- Plugs?????
- supercharger
- Fuel line adapter
- I got the SHAKES!!
- switching heads
- 1053 forged crank
- ls1 plastic tank swap
- old sbc heads to lt1 questions
- No fire from coil.....
- Callies Stealth Crank
- reverse flow heads
- Spring install
- igniton problems on my Z
- high RPM vibration
- Help With "Baby" Crane 227 Cam??
- 700R4 swappable with a T-5?
- 700R4 or T-56?
- Bring on the 1320
- cc306 on stock 1.5RR?
- How much power can 2-Bolt Mains hold?
- Injector flow rate question
- Electric water pump problems
- Forged internals
- Need Help!!!
- coil to opti wire
- Help please! I need computer files
- broken valve spring
- Emergency, help me please.
- NEW to LT1 scene and want to know what cam/ mods to go with.
- pinging noise when not warmed up
- Fuel Pump install ???
- 1st Thought on MSD Opti
- 12 bolt ABS question?
- head swap gaskets...
- School me about heads!
- Ordering a cam?
- idle hesitation
- 3.73 ?
- First time on the dyno and the last time for a while
- New to LT1 Group! Some questions if I may (Yes I read the stickied)
- ss dash plaque
- 97 Ws6 Into 93 T/a
- Rocker arm stud and head bolt questions
- exhaust question
- Best Header Gasket for LT1
- code 36 high resulotion
- having problems with the crankshaft pulley?
- Exhaust Poping
- Poll: If your Opti went, what would you do?
- LT1 forged?..
- 96 lt1 camaro tune need help!!
- Hey Guys Will This....
- ARP head bolts
- Catted 3" y-pipe for LT's?
- Tps
- what is this?
- What Cam for my rebuild?
- DTC P0300 Random Multiple Cylinder Misfire Detected
- Stage 8 Header Bolts for an LT1?
- Stage 1
- Who has the best price on ATI Super Dampers
- header Qs
- anyone w/ aeromotive FPR? & coolant sensor ?
- Ok, my car sucks right now.
- lean= Runing Hot? and some other Q's
- What Pistons for Eagle 383 Stroker Kit???
- fuel PSI problem
- LT1 Formy/Z28/TransAm Weight Differences?
- Drag Radials Slowwing Me Down??
- smog legal cam!
- F'in security light
- reliability suggestions?
- ignition problem pissing me off. HELP!
- Z06 Brakes
- AFR 195s
- procharger
- got my z28 DYNOED today!
- Changing plugs on the #2 and #8 cylinders
- Pinion seal replacement..Help!
- K-Frame replacement
- le2 track times
- LT1- How much power and track time will i gain
- Too good to be true..LT1's suck balls.
- Does anyone know if the new LS7 race lifter from SDPC will work on LTx engines????
- 383 N/A Plugs
- Heating problem fixed..
- 252.3 Rwhp
- Double roller guys come on in...
- Traction???
- car no start/ fuel related
- Help me with a few questions(ignition coil, and exhaust)
- Idle help
- SS Cold Air Intake
- need some flow numbers????
- need a pic of the plug for the alternator
- IntakeElbows.com
- how much does the LT1 weigh??
- LT1 !Wire Mod question
- How much wheel hp, will a k and n intake give an lt1
- Wheel
- Whats the Part #???
- Freshly painted 95Z
- exhaust question
- Engine Wiring Harness Question
- Cheapest place to buy a TF elbow?
- lt1 valve springs
- what is the best CAI for LT1
- opti install ? 94 opti to a 95 block? change cam gear?
- Port-Matching Heads and Intake
- How much $$$????
- Car dies at start up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
- VFN pic on car
- Lt1 Cam Bearings Help Please
- what kind of increase on power
- tuning a LT4 conversion....
- Were can I find a LT4 intake??
- Optispark question
- Some recent photos
- Pacesetter Ceramic Coating
- Want mild street/strip setup
- Actron Autoscanner
- Lt1 bucking
- HELP P1441 Powertrain Code
- FS: Comp Cams XE 224/230 cam (CC 503) and FREE 987 springs
- Full Exhaust Question
- LS1 Brake Conversion
- Fast Xfi?
- LT1 Alternator Question??
- Error codes
- did our cars come with vette servos
- LT1 main caps
- Help. Need links
- Wrapping Headers
- RR and springs
- LT1 pull from top
- Anybody running an aftermarket tranny cooler?
- cc306 or gm847
- Were To buy LT1 SS Hood?
- torque converter
- Keep Emissions?
- OBDII Data cable
- opti spark question
- My plan...need your advice
- oxygen sensors
- maf sensor throwing code, replaced,still not working?
- how do i know what gears i have
- Removing Cruise Control
- what header to get
- 355 guys post your dyno #s
- bolt-ons
- Your opinion on Trans. TH350 vs. TH400
- callin all magnaflow and dynomax videos
- airfoil
- uncoated headers
- starter question(what wire where)
- how much is it worth
- Goals, mid 12's
- 383 stroker guys... need help!
- lt1 to Ls1 conversion
- anyone have pictures of single turbo LT1 setups?
- another green 94
- SJM ABS Delete Kit
- 350/383 crank?
- tach not working after intake install?!
- Starting Suspension..
- new mod list, am I missing anything?
- Anybody know much about this 396 Package?
- What is it Worth
- leaking head studs
- finally 11s with budget 383
- car bogging?????
- Loudmouth Install
- electric waterpump
- Need Some Help with my LT1
- Our LT1s and colder weather!
- Different Intake Question. LT1 big dogs come in.
- is there a way to test a pcm to see if its fired??
- big problem, car shut off *help*
- Opinions on setup...
- Icm
- AC Removal Finished
- difference in F-body lt1 heads???
- car doesnt run, think the PCM is fried?
- LE2 vs. Portpros Stage II
- 1997 Trans Am WS.6
- Fuel Pump
- Car doesn't want to stay running
- Do you guys think this could work?
- Check out my 94 Camaro Z28!
- First impressions: GM847, stock bottom end, M6 car
- Need suggestions
- Difference between a z28 & SS
- Scanmaster locations
- Oceanside, CA?
- Horse Power?
- 383 Almost done
- Gears Question?
- Aftermarket intakes? Not LT4
- this is new....
- LT1 Died Today
- Fiberglass hood question...
- Gauge cluster bulb and socket questions, Pic
- Jet Fan Switch
- volt meter jumping around?
- 1'st day ever at the track!
- Ground Effects
- new guy
- AC System Complete Removal..
- check out my Z28
