View Full Version : Conversions & Swaps
- 6.0l in a 3rd gen camaro
- 4 cyl Fox LS1 swap.
- pacesetter long tubes
- LS1 S13 Nissan 240sx swap..header info
- LS1 Versus SBC Oil Pans
- need 70's water temp sender for ls1
- LSx in a BMW 5 series (E39)
- Finally got my harness
- Progress on the LSX Harness Conversion
- Oil pressure and water temp gauge
- what would you guys do for headers?
- Any front bracket/drives for alt. only?
- truck intake to ls6 intake write up
- Lets talk about the S&P modified oil pans for 1st gens...
- stainless works headers (From Sticky Section)
- ls1 in a v-6 car?
- Engine bay mock-up trick
- What thickness steel for motor mounts
- videp
- stock air boxes lying around? for sale
- CRX Swap
- Shifter mod/relocate options?
- The ABC's of putting a LS1 in my 1969 Corvette
- aftermarket oil pans, how to close up bell housing
- 240/LSx fuel system questions!
- Quick walkaround of our Miata
- 6.0 Backfiring
- Some more pics of the Corvetter filter/FPR
- ls1 in a fox body, blah blah blah
- 3.8 turbo mustang with a glide
- Thinking about putting an LS7 into my e46 M3
- 240 swap guys
- Which ones can be connected to one fuse?
- LS1 for my 66 nova
- Ls1 with th400
- Drove the LS1 Coupe Today!!! *PICS*
- LQ4 / LQ9 - Request Vehicle List
- Getting started, questions. 67 ElCamino/5.3L
- 2nd gen a/c questions
- 57 Belair LS1
- are there any finished gtm's?
- temp sender adapter (might have good news
- Good M6 harness
- rx7 build
- LS1 swap into my Transam
- truck harness
- LS1 in a 96 Impala SS
- '88 Firebird with LS2
- pcm pinouts for a 03 4.8L
- Converted Ferrari anyone?
- Harness Extension - Wire Source???
- ?corvette alternator substitute?
- Can I do a "Limp Home" mode on purpose?
- body swap 97-98+ HELP!!! please
- Drive by wire conversion to throttle cable?
- v6 to ls1
- LS1 Fox oil pan?
- Straight Radiator Hose
- Wierd issue with my LED check engine light...can someone check theirs??
- Anyone fabbed their own uprights or suspension?
- torque converter cover
- s10?
- my 73 formula lsx so far
- Clutch Master Cylinder ?
- wanna know
- Any C4 vette LS1 swaps?
- LS 402 Into a 78 C10 2WD ?
- PCM & BCM Question For S10 Swap
- gtp motor in a camaro?
- 1st gen with ls1 (power steering hose)
- jeep swappers, couple questions
- Done with install, need help troubleshooting
- For those of you who have put 98-02 front ends on 93-97 camaros
- OEM F-body AC compressor
- Kit Car Build with an LS1
- LM7/4L60E swap to 68 Vette, few ?'s
- ATTN: Foxbody swap guys, I need all of your help....
- It's Aliiiiivvvvve!
- ls6 into a 96 lt1 camaro
- ATS Spindles
- Got a new car today, S14 now i need to find a LS1
- another chevelle pic
- G-body LSx swaps, any useful links?
- Makes guage problem a breeze
- CI Speedometer issues
- 69 Chevy W/ A 4.8 Liter Need Help
- 6 Cyl Camaro Swap
- 1st Gen Camaro LS1 Motor mount options
- Supplier for fuel tank for 66 Impala w/pump
- anyone catch musclecar's alternatives for lsX into 1st gen camaro
- New Project - Fairmont
- 93 Rx7 Ls1 6spd Conversion
- 3rd gen ls1 wiring harness
- A/C Compressor on 2nd Gen Camaro
- anyone know much about STi center diffs?
- Got my Harness done..
- thermostat/ waterpump
- Building your own harness for presmog vehicles
- ls1 rambler
- Need some advice/second opinion
- LS2 to LS1 swap
- 'alternate', alt/pwr steering bracket 69 camaro
- need... more... traction...
- Whats your Redline, the real run it up to all the time one
- LS1/LQ4 front cover conversion to LS2 front cover
- best s14 conversion I have ever seen
- Considering an RX-7 build, quick question.
- Anyone have the pinouts for the fuel tank plugs???
- anyone using autokraft engine mounts
- My 240sx / S14 LS1 Swap - Progress *56k beware*
- 60 Impala LS1 questions
- 5.3 Wiring harness ?
- Needed Belhousing drawing and crank centre line diamensions ??
- what all do i need
- what oil pan? lt1 in 86 monte
- stock jeep wrangler 4.0L radiator good enough for LS1?
- Help me identify this.
- Question for you LS1 FD guys...
- fuel system for lt1 in 86 monte
- f-body y pipe info
- How do I wire the fans?
- 3.4 to LS1 swap...time for go fast
- install questions
- Corvette Exhaust Manifolds
- GTO oil pan , oil sandwich adapter..help
- Help! Mate LS1 to Audi trannny
- Fuel System Help???
- Check This Out!!
- PCM connector screws
- connectors for LS1 F-body fans
- 68-73 Nova LSx swaps
- have some f body parts left over if anyone needs them
- sticky?? mustang swap
- Finally started for first time in 1.5 years
- Which serpentine to go with??
- 2006 6.0L PCM Pinouts
- 5.3 Vortec manifold to hood clearance
- Where to get motor mount bolts??
- 2005 PCM pin
- some Kmember info for you ls1 fox-swaper's
- Question for Dakota LS1 swap..
- attn 1st gen guys
- fuel pump request from ECU
- How hard to do a LS1 swap in a 3rd Gen?
- Quick question about chassis.
- column shift LSX in 72 Nova?
- 5.3 Vortec in Jeepster Commando
- Accessory mounting help
- s13 ls1 conversion + smog question
- LS1 in a 240SX
- drilling the passenger head for a guage
- post foxbody LS1 pictures please
- It Runs!!
- oops!! lol
- will these heads work?
- Muffler advice
- Oil pan clearance
- Have M6 harness need A4 harness (Trade)
- Drive by wire 5.3-700r4 trans question
- found an 03 4.8 at the junkyard .....$700?
- How should the fans be wired?
- tach signal-4 pulse to 8 pulse??
- ls1?
- icantdrift's LS1 S13 corner weights
- Any fox swap's with a th400?
- Sneek peek at turbo headers for Chevelle
- PCMAmerica, Current Performance
- 1971 Chevelle SS LS1
- e36 BMW swap progress pics
- Intake Elbow
- ID Please Fuel, Intake & Radiator
- T56 w/ Z-bar ???
- 1998 Z28 ls1 to a 2000 Rs
- Crank and Cam inputs
- Which K member for an ls1/fox swap?
- 6.0 Escalade motor in my 59 impala have ?s
- Chevelle Cowl Induction
- Any opinions on my LS1 build so far?
- Anybody got $68,000 lying around?
- New cam for LQ9 in 78 trans am
- 5.3 L fuel pump specs?
- Pin Diagram
- stock injector flow rate
- Is there a thread for a v6 to v8 conversion?
- Do I Need To Keep The Flanges Attached To My Exh Manifolds
- Fox swap guys.......anyone running a big aluminum Ford based Radiator????
- Foxbody swap guys: QA1 Caster/Camber plates, Double adjustable control arms
- LS2 swap into 2001 Mustang GT
- Fuel System Setup
- 66 gto w/ t-56 conversion help please
- help tranny questions
- Computer Harness Problem
- EPP Ferrari 308 LS2 project car!
- Help 95 Firebird with LS1
- Master Cyl w/ ATS bracket on 1st gen camaro
- 400sbc with my TPI or LS1/4l60e swap???
- Shorter 02 sensor?
- C5 torque tube removal
- LS1 '91 240sx Hatch vs. LS1 '90 RX7
- pcm differences
- Whats the Lightest Car Anyone Put a Lsx into?
- Transmission Lines in '56 Chevy
- 2008 Challenger
- Toyota tach help
- emmisions????????????help
- What headers & a/c comp fit?
- IRS solutions?
- X-member height adjustment: 1st gen F body w/ T56
- Has anyone ever.....
- O2 sensors
- LQ4 w/ 4L80E Wiring Harness Question
- How hard is an lsx swap in a 3rd gen fbody?
- SBC swap
- Total Performance King-T "LSx vs. SBC1"
- G-body headers
- Custom fuel lines... quick connect flare tool?
- need some help
- o2 sensor question
- Newbie needing help
- ETC problem on 02 LQ9
- Header question
- 10 sec. 1/4 mile pass...video
- LS1 S13 drift car vid
- worried about wiring.. any input?
- LS1/T56 - while it's out
- Info on 73-87 GM K-series
- Please Post Your Conversion Pics
- LS1 Swap for an 87 Iroc-Z
- Photos of my conversion
- LQ9/TH350 Swap, guide me to a good harness!!
- Got my swap done... *Vid*
- 68-72 Suburban - LQ9 swap
- 68 Camaro LS1 first startup
- LS1 in 89 chevy pickup
- fuel pump: how many gph are needed to run an ls1
- FINALLY...LS1 S10 video
- power for tcc
- LT1 in a 1980 Vette
- Another LS1 RX-7
- Went through the stickys I need header info
- LS2 won't run
- Current Pics 68 Chevelle 6.0 4l60e
- Motor mounts?
- Source for weatherpack factory connectors?
- 350 turbo help
- fuel pump ???'s
- 6L80E in an 03 Yukon XL 5.3 2WD
- Update on my 65 Chevy II
- Kiesler bellhousing depth
- need help msd ls1/ls6
