- build thread...good news
- RF/EMI Effects on a computer.......cool stuff check this out
- LT1 Goes under the knife...again
- hyd roller vs flat hyd lift numbers?
- Helpful mods
- Overheating Issue
- Ignition System....Gauging Interest....Opinions Please
- 1996 Formula revived.
- Timing Issue With New Stroker Build
- Can i use this steering wheel?
- LT1 Starter wiring probems
- Fun Twist on Throttle Body Plates
- LOOKin FoR a New Opti
- My LT1, bye bye.
- Help my car has a weird squeak!
- Wiring Question
- Oil pan help
- Shortys vs. Long Tubes
- suspension and frame set up
- Scanner not responding
- Probe dish pistons vs Flat tops
- 383 who can tune it?
- Split BLMs with closed throttle
- Cam selection question: Is this cam that I'm looking at fit my goals?
- Ghaaaa Optispark!!!
- which suspension mods??
- fog lights
- LT1 Carb Setup
- 2002 slp loudmouth and y pipe
- URGENT: Chamber size, CC's for 1995 LT1 heads
- LT1 Head Gasket Replacement Parts list
- 94 Z28, Is it a sin to modify (see photo)
- It's alive!
- Please tell me I've figured this out....
- For the love of God, Please help with misfire, stumble problem
- Aligning k member when reinstalling
- Confused, tiny gasket leak maybe?
- LPP y-pipe doesn't fit right
- Bullets or XR1
- Smallest Mini Starter for Shorty Headers
- compadibility of pcm's?
- Bare minimal to hear the car run??
- Local LT1 Stock Eliminator Car
- 11' camaro wheels on my lt1?
- Ac prof. charged still nothing???
- TPS in need of adjustment?
- What size serpentine belt?
- Low Profile Oil filter and why brand of Oil
- lt1 to ls2
- Best place to buy an assembled ahort block?
- reving up and down????
- Water Pump Noise? Video Inside. Help.
- A little over heating problem!!
- LT1 ram air box with non-ram air hood?
- factory tach calibration?
- New 255 walbaro fuel pump
- Just arrived to Cocoa Beach FL, Patrick AFB, Need Alignment and tune FAST!!!!!!!!!!
- HELP! BRAKE light stuck on, not the switch!!
- What Cam will get me into the 11's? if I can with my mods..
- Has any used the Be Cool Radiator on an LT1?
- Why is this Happening?
- Almost ready to start...few ?'s
- Need help finding Cat Look-a-likes
- 1997 Z28 wouldn't start temporarily
- Leak Down Testing
- did I trash my pcm?
- What vendor sells NGK TR6
- qestions on Rear mount turbo LT1
- forged or not
- Canton Valve Covers, PCV fresh air tube????
- Where Is The Coil Pack and How Do I Replace It??
- First time at the track
- This Tstat, yay or nay? Crap or gold? Good or scam
- 550 hp lt1??
- Cnc-motorsports.com
- 95 LT1 ignition issue
- Got EGR delete question.
- ac compressor
- what are the symtoms of a leak in the header gasket?
- E-85 qestion
- How high should I go with my Compression Ratio?
- ECM reading 1350 F. on Cats
- Removing and reinstalling a starter
- 94 lt1 going into 96 V6 car
- Little Help? A/C Q's
- '95 LT1 breaking up at all RPMs
- DIY head porting question
- new twin turbo project
- Scorpion vs Proform 1.6rr SA
- Oil pump drive?
- coil harness problem when engine is hot?
- Name that bracket
- Car Is Running After H/C Swap - Down On Power
- Which Opti???
- Scorpion 1.7 Rockers For Sale
- motor swap
- 93-97 camaro
- Stall converter
- Do i need a tune?
- Crank Removal Question...
- playing with compression calculator
- Fuel pumps
- Miss/stumble
- 24x guys come in, cam sensor/dowel question
- M6 Console insert?
- Plugs and n20
- Help please!!!!!!!!!!!!!!!!
- Installing LTCC
- 1997 z28 electrical problems
- Can a head gasket leak oil?
- lt1 5.7 sleeper caprice 13 second run?
- Turbo LT1 guys turbo drain pics?
- Turbo 383 Build.. AGAIN
- Heads gasket
- DO I need upgraded injectors with this combo:
- Lt1 removal Help please
- Best way to remove a cam pin?
- Difference between 95 lt1 vs 97 lt1
- E85 Timing advice, E85 experts in please!
- Anyone running an 85mm MAF?
- possible misfire?
- Can't get starter out, Y-pipe welded on
- Lets Talk Exhaust Sizes.
- Need help on buddies 94 Z28
- Parking Brake Sensor?
- Lt1 97
- lookin for someone to tune my lt1......
- Evap delete
- intake, cam and head qestion
- turns over and thats it
- Did I die, go to hell, and not realize it? 97 TA (beater) having start/run problems
- Quick question
- 3rd gen camaro LT1 swap, need cam help
- Will a 160degree Thermostat help me in any way? i've heard about doin it.
- Where to buy M6 shift boot
- oil leak
- P0372 help please
- need some other opinions
- stock bottom heads/cam
- best shifter th400
- Scat I beams
- Urgent-Fuel Problem Help Needed
- how to disconnect M6 from LT1
- Starter access with Long tubes. Ebay and Pacesetter
- MAF Translator Pro?
- need help again...
- Results from the track last weekend!
- 1600-1900 Vibration???
- Spark plug
- E-85 383 LT1 Questions?
- These wheels gonna help over stock??
- Mid-level lifters?
- I'm torn between cat-backs
- 396 LT1 build
- Happy Medium Drag radials and skinnies ???
- 1995 z28 start up noise and idle problem
- Any hoods fit a lid without any modifications?
- cali emissions
- Looking for a "doable" forced induction setup. Just starting out.
- oil leak
- I need lt1 help please
- distributer button.
- ticking coming from # 8
- tripometer doesnt work
- LT1 Rebuild in New Mexico (Las Cruces Area)/El Paso, Texas
- lt1 wont start!!!
- lifter talk. no, not ls7 lifters
- Lt1 X-pipe
- Long tube headers and oil level sensor
- 94 F-Body Transmission in a 97 GMC truck
- TDC and Lash?'s
- Anyone had cam/crank sensor sync problems with the EFI Connections 24X conversion?
- Opti spark
- Clickin, Tapping, Knocking? WTH is it
- Where did this freakish random knock retard come from???
- Please help car is stressing me out
- il pay someone to adjust my stuff
- Best turbo for stock lt1??
- New motor build
- flexplate, converter bolts part#
- New old stock parts
- Intake elbow, where to get one??
- Fuel problems
- Do I need this?
- Towing questions
- LT-SS intake
- 89 corvette with ls1 24x pcm swap problem
- Berger Panel Ideas
- pro kit looks like sport lines
- How much HP from C/I/E LT4
- need some gasket pt numbers/links
- Urgent help! Broken starter nosing.
- timing set option?
- Jet Hot vs Hooker
- Anyone running the trufiber SS hood?
- misfire
- 94 z28 driverside valve help!!
- Competition Clutch
- Starting Issue
- 96 camaro Rs
- 95 Z: LS1 front end, wheels, and fresh paint (pics inside)
- VATS resistor bypass help inside please
- Clutch problem
- Possible Optispark Issue?
- throttle body gasket?
- Water pump seal
- head gaskets
- Pacesetter LT's to kooks catted Y ?
- questions on putting motor back in
- vacuum leak 97 camaro
- Tune question
- Input shaft seal?
- pushrod question
- How to or can you clean..
- Best spark plugs for stock LT1?
- Did i hurt my fuel pump?
- I need a new hood
- 97 z28 cat removal
- Stock HP ratings
- Window Switch
- Shim Gasket Pics
- PLEASE READ: 95 Z28 ignition problem
- what music do you listen to while under a car
- What mods next?
- Head Gaskets
- Bolt on tune?
- anybody running duals with a chassis mount torque arm?
- Dumb question about brake pedal.
- cam swap gaskets?
- EGR Delete questons
- o2 sensor PITA
- New guages...
- Clutch acting weird..
- Cam/Ported Heads & Intake/LTs price
- OK what is this thing, Shbox.com doesnt list it or have a pic
- aIR removal question
- Pics of Y pipe with cats...
- will 94-97 fuel lines work on a 93 Camaro?
- 94 Z28 gear question
- Which ATI or BHJ balancer?
- Low voltage causing a stumble?
- Update..got the stroked/turbo and nitrous 97 ss tuned ...
- water pump fittings move??
- ugh, people do stupid things to cars...
- let me see pic of cai delete's
- I know B-bodies use iron heads, but what about the intake?
- Anyone ever try a "Pypesmouth?"
- M6 LT1 drop
- Die Out Question
- Stock pushrods ????
