View Full Version : Forced Induction
  1. APS Fbody Kando water lines VS stock APS
  2. anyone willing to share their fast XFI program...inj size does not matter
  3. what stall with procharger
  4. turned up the boost, but don't feel it
  5. What reducer coupler for LS1 TB and 3" intercooler plumbing?
  6. Co2 Help... Need the right bottle
  7. procharger and MS4 cam??
  8. turbo
  9. Front bumper trimimg for FMIC
  10. eBay fmic setup for p1sc Procharger on 99 ls1 formula
  11. Anyone running two fuels/tunes?
  12. 95 TA rear mount build thread
  13. magnacharger 5.3L truck tune
  14. Turbonetics T76 AR housing????
  15. 370ci e85 1100-1200rwhp
  16. lm7 turbo question
  17. front sway bar question
  18. Green top 42's how much rwhp
  19. Procharger BOV flange
  20. Forced Inductions
  21. Help with SDCE Tensioner
  22. Those with Griffin 25241-X...radiator hoses?
  23. 891 RWHP with Vortech & LTX
  24. NHRA turbo ProMods at Bristol Saturday in a "strange" DA.
  25. Looking for D1SC Cam Specs for Street Car
  26. 2003 zo6 v2 sc kit
  27. LSX alternator relocation kit
  28. High Compression FI 408 on E85???
  29. d1sc 359 cam ?
  30. What do you think. Am I wasting my time?
  31. Our Turbo 5.3 and new stock bottom end record attempt (video)
  32. Need a specific Hobbs switch
  33. Idle Video 6.0 EPP Cam
  34. Need advise on what heads to go with!!!!
  35. e-force supercharger
  36. Turbo Virgin
  37. Vacuum Line Diagram
  38. What are the biggest injectors the stock computer can control?
  39. Can the stock or Fast polymer intake be used with a turbo
  40. TVS2300 With a Twist! Flywheel dyno results attached.
  41. Overheating f1a 408 2002 t/a
  42. Champion ttix camaro dyno
  43. 402ci d1sc only makes 5 psi.. Help
  44. 408 cogged F1c Procharged Camaro 796rwhp/707rwtq
  45. 91mm 2 step timing on e85
  46. 5.3 turbo with room to grow?
  47. gt35/80 turbo
  48. will an ECS blower cam do well in a turbo app?
  49. i wana start a turbo build for my ls1 camaro
  50. low HP/TQ on STS LS2 GTO?
  51. Dyno Results and Video - 847rwhp
  52. LPE + MSD 2-step GROUP PURCHASE IS A GO! PRICING INSIDE!
  53. Paxton S/C Question
  54. Turbo motor BS3 issue
  55. Building a a/c turbo kit with manifolds need pics guys.
  56. ls1 stainless works headers
  57. custom "APS" style turbo kit
  58. Electric Actuator?
  59. My custom C6 91mm turbo build thread! DYNO VIDEO ADDED!
  60. Pumping Losses question
  61. Eboost 2 can I get to 20psi on 7.5 psi gate springs
  62. stock water pump and high hp?
  63. What's the best way to hold the MAP sensor in a FAST 90 intake?
  64. Magnacharger MP112 + low mile LS2... What heads?
  65. S475 Turbo LY6 '69 442
  66. goal for 2k11, i want to hit 1000flywheel. do able?
  67. Where are the big dogs at?
  68. Catch can
  69. S/C Intake?
  70. what turbo to go with ?
  71. few noob questions
  72. Crankcase Ventilation on LT1
  73. Are 60#ers enough for this setup?
  74. Cam imput needed on 408 F1C
  75. What compression ratio will I be at?
  76. Build thread: '98 Firebird: '02 LS6 +E85 +Turbo (c6 manis, keeps AC/radiator/Ram Air)
  77. Turbo FMIC people...where did you mount your trans cooler
  78. e85 timing
  79. Dilemma with 4.5 intercoolers
  80. Selling my Turbos
  81. Size question HELP!!!!!!
  82. Best place for S85 rebuild??
  83. Newb to F/I
  84. Building boost on line??
  85. Race Proven Motorsports Escalade
  86. What kind of rods are these and will they work for my setup?
  87. Cofused about turbo sizing
  88. Turbo Advice Needed...
  89. Considering FI..
  90. Turbo vacuum lines HELP!!!!!!!!!!
  91. Where to buy a super short 6-rib belt??????
  92. I have three short questions
  93. Which Spal Fan to Replace 16" Procharger Fan
  94. what 2-step?
  95. WB bung too close to turbo?
  96. Turbo advice
  97. Enclosed Race BOV Procharger, vid/sound wanted!
  98. TU1 vs. TU2
  99. Best belt for Prochargers.
  100. Vibrant Performance Vacum Manifold
  101. What pulley & what plug?
  102. oil in kenne bell intake?
  103. Vic jr
  104. What bore & stroke for twin turbo 1300hp
  105. Vertical radiator with an AC condenser
  106. The better head for my build.. Mast Motorsports or AFR?
  107. Compression with twin turbo?
  108. Engine Power Systems
  109. ATI P600b on LT1
  110. Felpro or gm exhaust manifold gaskets.
  111. Has anyone used this?
  112. aps stainless wire ties where to get them
  113. 3 bar map
  114. Turbo 5.3L S10 Questions
  115. hi comp low boost
  116. pac 1518 springs enough?
  117. corvette power steering pulley options?
  118. Opinions on water pump for a custom a2w setup
  119. Coils Coils Coils - Best ones and pics of placement
  120. Turbo 370 guys, what's your oil pressure?
  121. Dual 1900 12 rib pulley set up
  122. Race Proven Motorsports TTIX C6Z "Sleeper" Package
  123. New LS WORLD RECORD!!
  124. Anyone running similar cam? Might need VE table
  125. A/C mount alternator relocation bracket?
  126. What to do?? Change shortblock? Redo mine?? Cheap!
  127. Project: Disposable Turbo/blowthrough 5.3.
  128. o2 sensor location on log turbo setup...?
  129. Where is everyone getting their aluminum for charge pipes?
  130. 8 psi made only ~410 rwhp ????
  131. SI-Trim-Capable of 190mph?
  132. What is the best flowing air filter for max boost?
  133. 6-71 question
  134. Intake/TB help
  135. 408 twin turbo - which cathedral head?
  136. TTiX Need some help!
  137. turbo cam needed asap. cant get a call back
  138. Dinged Turbo
  139. 92mm fast intake
  140. Procharger MAF Delete help!
  141. Help with bottom end
  142. G8 Twin Turbo Build - My Own 'KIT'
  143. Prochargers New Front Mount Kit - Camaro SS Install with Pictures
  144. 408 CID Twin turbo build
  145. Need help identifying TPS sensor needed for BMI 90mm TB
  146. Aps install
  147. 78 vs. 90 vs. 102. vs 4150
  148. Blowoff valve on intercooler instead of TB charge pipe?
  149. Which location has better crankcase breathing? Valley or Valve Covers??
  150. STS turbo
  151. Anyone have a race valve they dont need?
  152. forced induction cam???
  153. Supercharger Seals gone?
  154. Forged LS3 Twin PT66 Trans Am Build
  155. who should spec out a procharger cam for me?
  156. Turbo monte carlo build
  157. Too much boost....she is smoking bad!
  158. which tensioner pulley for LSX procharger?
  159. HELP!!! Low Vacuum Low Boost
  160. Turbo help
  161. New forged 347 with sinngle 76mm smoking on decel :(
  162. Master Power Turbos
  163. Mounting a TURBO in the back seat???
  164. Tips/tricks/hints for doing fab work
  165. 8 Rib Procharger ?
  166. turbo pcv routing
  167. LS1 supercharger
  168. best cam for PD roots blower?
  169. turbo cam question. specs inside
  170. Supporting mods for brutespeed blower cam?
  171. Who's boosted a stock 4.8L?
  172. 7.88@183 last night at Milan Heads up
  173. "Stand Alone" Meth Tank?
  174. D1SC set up with IPS tune finished
  175. SpeedInc rails/FAST 102---injectors popping out under boost?
  176. Starting my turbo jet boat build!
  177. Any idea how much boost with f1a and 5.25 pulley and 7.25 Crank pulley?
  178. 2- step for roll racing?
  179. Replacing APS ruber intake with aluminum tube, 3" or 3.5"
  180. Turbo builders
  181. Any value to using meth without meth tune?
  182. 95 ta intercooler fit question
  183. First hits on new budget magnum turbos - BIG THANKS TO MODULAR TURBO!
  184. My 3.3L Whippled Cadillac CTS-V
  185. slp oil pump OR melling for turbo
  186. Latest update pictures of my 10.5 outlaw Turbo Trans Am
  187. Video : TT C6 Z06 Vs Alpha 9 GTR
  188. 1969 Camaro convertible LS-2 6.0 TT
  189. what map sensor?
  190. tuck/c6 turbo kit piecing together
  191. Speed Inc Alternator Upgrade?
  192. ?
  193. Too much lift for FI?
  194. Racing at Milan for Heads Up Friday 6/3/2011
  195. Single Turbo 408 Chevrolet Caprice
  196. Looking to buy an oversized crank pulley
  197. Help me With My Possible Turbo Buil
  198. Carbureted, 11.3-1 compression and 7 lbs of boost. can it be done?
  199. Guys w/ 600-625 turbocharged HP, what's your setup?
  200. N/A guy looking for cheap solution to release excess exhaust backpressure
  201. **LMR TT Corvette runs 231mph Video**
  202. makin a 5.3 to 5.7 for boost, CR?
  203. Vortech V2?
  204. Where to drill hole in oil pan for turbo
  205. Is my LS1 worth messing with?
  206. Destruction starts my 408 project...opinions welcome
  207. Ls6 cam and 1.85 rocker arms
  208. powerdyne on 11.25comp
  209. Best prices for kenne bell s/c's??
  210. Cathedral port whipple
  211. Questions about Install of ATI Damper, And Timing
  212. turboed ls1 smoking out of breather?
  213. **LMR TX Mile 244mph Video**
  214. First run with powerglide need some opinions
  215. Speed Inc SC2 cam
  216. Need to know safe boost on this motor:)
  217. keep 370 OR just build the 408
  218. Best supplier for 304SS 4" Mandrel Bends?
  219. bypass valve question
  220. ready to cam my TVS1900 g8...
  221. no search luck - please explain boost referenced fuel regulator?
  222. LT1 383 = D1SC boost questions
  223. 2011 Goal 8's on 275's... Will this make it?
  224. 94mm True Steet Turbo Build
  225. So what actually destroys the motor?
  226. Best turbo size for lt1
  227. Maximum Potential?
  228. Procharger low boost question
  229. Any of you guys use the 80# Racetronix High Impedence Fuel Injectors?
  230. ***Late Model Racecraft now Holds New TX Mile Record***
  231. D1SC lsx376
  232. induction question
  233. Our New Boost Referenced FPR!!
  234. Everyhting is welded but...
  235. APS TT back to INCON TT with pics!
  236. Procharger pulley = ? boost
  237. A/W intercooler and whats needed?
  238. GTO Gen-TTR on E85 with dyno results
  239. Procharging 98 LS1 Z28 6spd
  240. F2 blow through on a LS2 in first gen camaro
  241. Good Plan - Keep AC, 500hp/500tq?
  242. Look what I did at work today: Prototype LSx supercharger
  243. Help me pick my 408's turbo
  244. LS1 Tech, Advice on new blower cam
  245. New Build! 408ci + GT91 + 6 speed street car = 200 mph
  246. Is my brand new T4 flange warped from welding?
  247. Gauges for pro charger car
  248. Another Question for Meth Users:
  249. ???help with injectors for my combo???
  250. E85 or stick with pump gas?
