View Full Version : Forced Induction
- Searching for a hose coupler
- holley hp help
- Turbo 5.3 gt45 '93 trans-am build.
- procharged, maf question
- Are there any Turbo LT1 guys in here?
- Head casting porosity ?
- Boosted 383 spark gap on lt1
- PT88 vs PT8285 vs ???
- Callies Compstar crank 1000whp procharged??
- 2.25 v bands or 3 bolt flange?
- Universal Downpipe Sources?
- Allpro Cathedral port heads ???
- The Blower Shop LSX
- 9.0 at 163 on true radials(not drag radials)
- Tryin to fit s476 with t4 V2 huron kit HELP!!!
- My LS-Turbo build thread : 98 formula
- What heat wrap for your hotside?
- HP Tuners issue
- Procharger guru's, I need some advice.
- 1998 vortec with Whipple SC throwing code for 17 years?!
- f1r procharger kit
- When do you have too much injector?
- $2000 Turbo Kit
- Loud alarm on STS turbo
- Procharged forged ls1 oil problem in boost
- Bearings
- 5.3, on3, 4th gen; started last week, won't start now .hpt attached
- Fmic
- Rx7 TT "Dyno and discussion" thread.
- meth vs bigger injectors?
- Catalytic converters and forced induction
- lq4 turbo help
- turbo oil feed?
- Stainless Works LS Turbo Headers
- 80mm gt45 compressor discharge
- Does this procharger torque curve look typical?
- 1 bar vs 3 bar question
- Oil inlet on turbo leaking
- Thoughts new intake for N/A 468 other than fast
- Removing intake fitting
- compression ratio advice
- LS Boat Motor help!!
- 5.3 turbo with truck rails and adjustable fpr ???
- Forged 370 guidance
- turbo too small? for twins on 418
- 230-240 ECT while cruising? boosted ls7
- s13 hatch turbo lq4 a/c????
- 98-02 F-Body Turbo Sway Bar HELP!
- Need a new intake for boost. what one though?
- 30GPH methanal injection, please post tune.
- I WANT 600HP!Whats your advice
- plugs lookin lean.. thaughts?
- List your fuel system setup
- Huron speed Group purchase?? anybody got kits
- procharger hat
- ebay turbo buid looking for some help.
- Live your car dream through me! Need help!!!
- Track Results from a PT7675 CEA to a PT8285 CEA BB
- could this reference port & line be too small causing hesitation ???
- What to expect forged/supercharged ls3 15psi
- First turbo car initial startup?
- what size and brand intercooler for 1000whp
- turbo 4.8 compression ?s
- F1A verse the F1A-91??
- any one have any experience
- First fire of Alchemist 3.0.
- P0106 map code help
- TT Ranger mega truck
- looking for wastegate and blowoff
- What size injectors should I run. need advice
- Any Run Harris Performance Controller or HPC for Methanol Injection?
- injector size suggestions for TT 6.0
- 900whp turbo auto car... what tires?
- fascia removal cx racing intercooler 4th gen trans am pics
- Steam lines / Surge tank?????
- FI build
- LSA Crankshaft
- My Build
- N/A vs Nitrous vs FI cylinder heads
- Help pls, forged 5.3, gtx45, low power figure
- Turbine Inlet Gasket
- Looking for reviews on Brian Tooley's cam
- Modifying stock oil pan
- Size of fuel line for FI
- Tap stock oil pan or buy an aftermarket one?
- High HP Procharged guys, need advice!
- Sponsors need help on cam for supercharging my 2007 silverado please help!!!!
- Bottom end options for LQ4?
- boosted ls1 heads
- Should I open the ring gaps on a non intercooled E85 turbo 5.3L?
- Consensus on IAT Sensor Placement on Meth
- Gear selection for procharger
- boost controller
- To stroke or not to stroke. That is the question.
- 900whp+ outa t4 onna 400+ CI motor
- 377"/PRC 260cc LS3/D1SC@13psi/93 octane=773/665
- Fuel rails for TVS1900?
- What should target lambda be?E10+30gph methanol
- what tires do you guys use/suggest?
- FI heads advice needed
- turbo questions
- Cant get the timing down
- turbo build
- sts-v supercharger on ls1?
- Help me pick rear mount oil less
- 10:5 compression on E85. How can I get more boost?
- Thompson Motorsports 370 baseline ECS 2500 Dyno
- Best MAP to use for 20 psi
- Solid mounting Rad and Intercooler??
- Wrapped downpipes, how close to fuel lines?
- 66 chevy II,twin turbos or a whipple?
- Moran's Billet Atomizers with Holley fuel rails?
- Low cranking compression. Possible causes?
- 4.8TT/T in z32
- which pulley should i get? for F1Procharger
- Anyone seen a belt come apart like this?
- Daily driver
- Opinions please
- My car is making this sound ???
- Ball Bearing Turbo Allowable Shaft Play?
- Huron tubo
- cat diesel turbo
- Tricks to help large cubes with small turbo breathe
- does e85 make more power vs 91? same tune. also 60# vs 80# data
- Boost to Pulley Size Question
- My car is a turd! - maybe not
- Water tank and no radiator on the street?
- 370/Ls3 F1a dyno results
- Turbo inlets for Precision S cover APS Kit
- tick performace cams
- Using Factory Fuel Feed Line for Return. What to do with stock filter
- Need help with Boost
- Backpressure issue help.... ugh...
- rod bolts
- C5 Z06 V3 T Trim Dyno
- Need a little help...build almost done
- What's up with Forced Inductions website ?
- Who needs a brand new Huron Speed v2 T4 kit? Best price out there...
- TT 408 numbers
- What are you guys using in your Methanol tanks
- Denmah - MS tuners need some advice
- LS1 / TVS 2300 / 8.8 / T56 Miata When more is too much
- n/a vs. fi comparison
- Header Material
- Best turbo for DD stock LS1 w/ T56?
- How much power are you making through your boosted Gen III 5.3L??
- tc78 rebuild
- What Cam To Use? (Built 6.0, single 80mm)
- Methanol Injection
- 5.3 supercharge on a ls1?????
- need advice from cam guru's
- How much HP is too much for a t-top car (structurally)?
- Need more ooomph!
- Build a JY LS Turbo Competition Thread!!!
- Question about wastegate vacuum..
- [VR] Flex Fuel Corvette C5 Z06 - YSI Supercharged - 1,090whp - Pics and Results!
- Who has run a 2000HP A2W intercooler?
- [VR] Corvette C6 Grand Sport - A&A Supercharged - Pictures and Results Inside!
- 55 Bel Air 5.3 Turbo (Newbie questions)
- 5.3 with T6 S480 or S475 ???
- T4/T6 Frame Turbos. Largest still able to keep A/C?
- 2001 Camaro ss turbo dyno results
- finally got to dyno my rx7
- Quick Lq4 s475 cam question.
- Ways to Keep Boost In Check via a Tune...S/C
- Boost Creep after Eboost2
- Who has the highest HP on a single S366?
- Need some engine advice!
- Turbo size for 280hp 800cc 2 stoke
- Some more custom LS pans for turbo cars
- Lq4+milled 243+On3 78/75 turbo=?
- 1981 Caprice LC9 Twin Turbo Updates
- Huron Speed V2 & K member clearance
- Huron speed alternator instructions?
- Hot side ?
- silverado 5.3l turbo header on pontiac gto?
- Motor not legal for x275 so F1X is sold!! Big changes now!!
- questions about s475 before I purchase
- WHAT pro charger pulley?
- Chevy k5 aka raptor killer
- Fox Mustang 5.3 S400 88mm Build
- Gearing Calculator (since F-body.org.gears is gone)
- Huron speed 60mm wastegate any good?
- need some help with setting up fuel system
- Choosing an electronic boost controller? Here is a good run-down...
- Crankcase evap into exhaust not working
- Question about scabenge pumps
- 2012 l99 camaro and cx racing 76mm 1.15 a/r problems
- what turbo do i need
- DD turbo 5.3 questions???
- Balancing the rotating assembly
- PT3000 A2W intercooler question
- Best turbo for me
- Eboost Street BG Switching
- Which Lifters ?
- 2step/tbrake tunning with HPT. Help me spool up quick!!
- ebay (clone) bosch 044???
- Valve covers & SW up/forward headers, what covers fit?
- Midwest Chassis K-Member with Huron Speed V1 DP doesn't work...
- e85 fuel cell vent
- Crankcase evac
- How to remove damaged balancer
- Target 8.5 160+ Ysi c5 street car
- t6 vs t4 size
- ARP 625's in stock anywhere ?
- 3.5 year Old Hoosier Drag Radials....Safe at 180mph?
- Is Cartek no longer in business?
- 76mm T4 turbo on 5.3?
- Help with sluggish running and back fire.
- 1 of 2 wastegates pulsing / fluttering
- Anyone running 325# injectors?
- Studs too short
- Opinions on 5.3 Nova build
- In tank fuel pump choices for 1000+rwhp on E85?
- lq9 and zl1
- Is this a good deal for supercharger kit
- Mathematically, on paper, will 14.7 lbs of boost double hp
- What are my options for my AC box? (turbo build)
- Boost loss from bypass valve? general questions
- 8 Second Turbo C6Z
- e-85 injector size needed for twin 64mm 390ci
- Holley efi+boost, those with early ecu's
- Powerdyne bd-11a 500rwhp
- Trying to size turbo
- THE Build Thread
- #7 twice
- LS1 Procharged Trans Am question on some parts
- Shaved Gloss Black Pro Flo
- Supercharged 370ci CR
- HAs anyone mounted their radiator where the fuel tank used to be.
- Need a 16 injector harness for HP EFI
- s480 vs s480 billet
- Any one taking apart their A/C or know which o-right go where
- This is why you are better off with a spring loaded tensioner.
- Turbo 4.8 Idle issue/running lean.
- 1994 Toyota Supra 25.5 Twin Turbo LSX
- if you were to pick a cam
- Boost leak around injector orings?
- Lq4 78 mm
- Best head gaskets??
- Best Chinese Turbo for twins on 5.3
- Dry Sump FI
- S475 1.32 96 or 1.10 83??
- F1C US 275 build
- Motor doesnt like meth/water - now it seems to
- Chassis Dyno With 4.88 Gears???
- New build Keep A/C or? Lq9 Procharged
- turbo recommendation
- Carnage Pics from my 9.03 on a SBE
- Fresh air tube from valve cover to throttle body on boosted car
