View Full Version : Forced Induction
- LT1 stay MAF or go SPEED?
- LT1 Turbo Help
- New PB in the turbo Firehawk
- Intake elbow
- Any venders here or reliable places to buy Tial MV-R44 wastegates??
- AEM TruBoost doesn't hold low boost
- LS3 or maybe ls2 conversion guys any problems with PO327 knock sensor code?
- what blower to replace my v9 with??
- procharger guys. post up your ETs
- Aps TT HELP
- 2011 CTS-V 2 door coupe pic/vids
- Turbo Sizing???
- excessive crankcase pressure????
- Help identifying a supercharger bracket
- LT1 just some advice for a D1SC not a build thread yet sorry
- I need turbo 5.3l efi advice !
- What PSI spring to start with?
- Whats you procharger set up?
- recommended bearing clearances and ring gaps for turbo motor: 1000rwhp
- Engine didn't last a summer/ new build time
- keyed lt1 hub???
- procharger ducting q's?
- My Build - 2002 TA 408 - Twin 67's
- supercharged or all motor?
- Procharger j bracket install
- New setup runs 5.81 @ 123 HD video inside :-)
- intercooler
- new pb and lifted a head 9.03@146 updated with pics
- Limits of sdce and aster
- 5.3L Monte SS
- Thanks Ohio Boys
- ? for tubo guys running the 1/4mile in the 9.5 to 10.5
- 20+PSI and stock Brake boosters?
- Where to place wideband on downpipe?
- 383 sbc to turbocharged 5.3 swap questions
- Twin waste gate setup
- Virginia speed build...
- who has the white trans am in the current gm high tech?
- what do you guys think?
- 60mm Eboost2 mount for trans am
- High miles and boost
- going forged now have some questions
- 16lbs on a 2 bar map?
- Heads and cam combo!! for D1SC pls help!
- Wha size turbo
- Vortech vs procharger
- bad placement for oil return pump?
- daily drive turbo fbody
- Starts Then Dies Immediately - Intermittent
- Truck manifolds with V-Bands
- Procharger 8 rib belt woes
- Should the supercharger "free spin"?
- lsx block question
- help with procharger setup, adding bov
- 3.9 k1 crank, k1 6.098 rods, what pistons
- What power are you making with your 6.0, and how much boost did it take?
- procharger guys need help
- Gapping for boost
- Can somebody let me know the proper A/R?
- Help fix my c5 frc with a vortech
- midframe 78 made it in now need some input!
- Supercharger + boost leak? plz help!
- Ok fellow auto aps guys what are you doing for trans cooling..?
- Help me read my TR6 spark plugs
- need help!!!!
- m112 on ls1
- Filter Screens?
- 1/8 results turbo lq4 PICS&VID!!
- Altenator pulley issues
- Pushing water through copper HG
- looking to buy p1 d1 or f1 !!! suggestions
- Pin crank from front or side with ati dampner?
- Oil Scavenge Pump ... Anyone Tried This One
- Turbo smoke?
- Getting weird knock
- KY turbo Build: Stock Btm End
- few questions
- Built shortblock but from who???
- Those of you with FMIC that removed "bumper support"
- What happened to LM Speed?
- What kind of HP numbers can I expect?
- What should I dyno?
- Ebay intercooler and HP
- What cam?????
- Seat pressure with XER cam with boost at 20+ pounds?
- anyone here with a garrett gt budget turbo with a 1.23 a/r looking for a 1.08?
- Ideas for street strip build with an f1
- In the 10's on 8lbs with videos
- how much boost?
- super charger trade
- fixed exhaust leak, no boost
- Maggie vs Whipple 4th Gen Fbody
- IATs with painted factory intakes????
- My Z06 Transformation Video
- Paging Nashville Tennessee
- Supercharged under 9 psi?
- blown 5.3
- Vortech Power cooler question...
- Any videos on procharger enclosed race valve?
- making boost but still making power?
- Decided on a D1SC. Few questions about the setup
- Turbo specific oil system?
- Looking for dyno graphs or results on 370ci PT88 combos.
- Let me see where you relocated your cruise control box to...
- fouled plugs
- EPS 234/246 with boost?
- Thoughts on my wastegate placement?
- ls2 corvette whipple kit
- Work In Progress: '98 F-Body TVS2300
- Procharger or turbo on 6.0
- 98 camaro ss will this procharger kit fit my camaro
- Turbo LT1. What max coolant temp is ok?
- IN need some advice !!!!!!!!!!!!!!!!!!!!!!
- rea mount turbo, change oil weight?
- 3.905" forged piston help?
- Vortech v1 mount question!!!
- Turbo piping question
- New fuel pumps: What do you guys think?
- Throttle body placement, how does it change when...
- Post your PCV system pics
- Anyone have their catch can hooked to their exhaust?
- Procharger + LT1 w. HotCam?
- KY Build
- I need to relocate my vertical PS lines to clear crossover/DP - question
- Any turbo'd stock 5.3l mpg results available ?
- Intercooler Questions
- P1sc-1
- lunati stealth cam
- Hurting rings??????????
- 62 bel air turbo 5.3 project
- Twin turbos on a LS3/LQ9
- BOV or NOT?
- weird bov?
- Turbo Notch 5.3 build
- LS2 Procharger Owners Manual
- Hot Rod Magazine Turbo Test
- Just an update on my build
- lsx 396 vs lsx 427?
- Truck manifolds seem to have warped
- help can i make a merge pipe out of a Flomaster Y collector
- I have a sneaky idea on how to have a T6 AND a T4 turbo mount on the same crossover!
- HPS 1005RWHP-RHS 427/F2 Cog C5 Vette Dyno
- 98camarod's twin turbo build
- My turbo build. 5.3/t56 with a GT45
- help with fuel system
- got a 5.3 and wanting to turbo
- anyone catch the Hot Rod article on the 1200hp 4.8?
- 04-07 CTS-V Procharger questions?? (GTO Procharger Kit)
- How many turbo'ed Ls1's running oil coolers?
- Full Boost....when?
- Lowering IAT's
- Turbo Help and Advice
- spark plugs
- how to install anti surge valve?
- Cracked Oil pan from wheelie first outing. Setup adv needed.
- Any interest in 6-71 through 14-71 blower kits?
- Steve Morris ProVolute
- What gauge (thickness) stainless tubing should I use?
- Finally a video of my D1SC with front mount.
- Follow along as Vengeance Racing assembles an RHS 427/TVS 2300 C6 Z06
- LT1 Camaro Intercooler help.
- Trans Am Intercooler Options
- Victor Jr and elbow on a C5
- Modifying Procharger j bracket? Good idea?
- I'm not sure how I managed this, but . . .
- 5.3 bore to 5.7 then turbo, or stay at 5.3?
- FI sensors?
- josh says ~4 weeks ill be joining the FI'in fun.. KY turbo!
- Are there any companies making a sealed supercharger similar to the Powerdyne?
- Best way to mount pusher fans?
- Made it out to the track for some test hits **New Updated 9.114 @ 151.8
- Boost gauge t-fitting question
- which map sensor to use for a big turbo lt1
- Ls1 drilled crank vs 6.0L solid?
- finished a few things this week pix inside
- Should I take out some fuse on injectors so can prime up engine for my new turbos?
- What heads and headunit question
- Which Block?
- truck intake or ls intake for a 5.3 and 75mm turbo
- STS fuel problem
- rear mount feed line...where to buy?
- first time to the track, surprised myself!
- Some Advice Would Be Nice
- 1991 Nissan 240sx – T76 LQ4 with T56
- BOV & WG Vac Lines
- 5.3 turbo keep stock 5.3 heads or use my ported ls6?
- Price increase coming from ProCharger August 22nd!
- just another idiot trying to kill a 5.3
- Best Supercharger for 02 WS6??
- Race Proven Motorsports Facebook!!
- Forged 5.3 turbo build shooting for 1000+ wheel I'd like your help/suggestions guys
- What to expect from this setup
- Power steering delete and Alt relocation, belt?
- Need your input on a few things...
- Whats th best MAF to use with boost?
- Stock LQ4 and boost build advice
- **Late Model Racecraft at GM Aero Wind Tunnel**
- help with wastegate and BOV choice
- which boost piston??
- Manual tensioner wont work
- Turbo LM7 Advice/Build List Nitpick (RX-7 Content)
- GMPP intake vs Ls6 intake for turbo
- Baby steps on twin turbo build
- Update on my 98 SS Build for 2011 - With pictures
- Procharger not seeing boost??!
- Is this LS3 Blower cam ok for a Maggie?
- What is the best Aluminum Race Radiators for lumina 2006 like gto
- DIY Rear Mount FMIC...Feedback wanted
- 260z LQ4 maggie- fuel pressure not holding
- DIY piping kits?
- 6061 Intake Elbow????
- Cleaned up stock manifolds?
- i got the turbo now trying to figure out the rest
- What #s are stock cars with rear mounts putting down?
- Instrument cluster not working?
- really considering going FI with procharger..
- what exhaust clamp for pt88?
- wideband sensor install?
- Compressor wheel damage ?
- 68 Camaro AES 410" LSX F1R Build
- intercooler choices
- Vortech vs Procharger
- eBoost2 users, step inside.
- need advice on lt1 build
- Fuel system for TC78 on LSX Mustang
- ABody Folks with ProCharger LSX Transplant kit - PS fit?
- how are these turbo ? T72 link posted inside what equal to them or better ?
- Jgmtday
- *Dyno runs*... 454LSX,TFS245, Twin billet wheel 67's
- t-bolt clamp vs regular hose clamps, and other questions
- bob is this the right filter?
- 4500 what can i get?
- What hotpipe kit should I get?
- What type of tune is best for a turbo build?
- Which meth system and why?
- They're here! Motovative N383 Billet Alternator Relocation Brackets
- 370 CI Twin Turbos with AFR 245's Build Thread
- Anybody with stock cubes & T6 78-85mm turbo I have ???s
- Intercooler questions
- Swapping in the new ERL Powerplant...
- new toy
- PT88 Oil questions
- Will Racetronics in tank pump support 8# boost?
- wrapping exhaust pipe wet?
- small turbo bad?
- Fbodyjunkie's Build Thread PTE76GTS, 4L80E, Moser 12/video/6.61@110!!!
- Cam Question for Turbo
- TC78 owners come in!
- help i need help with boost piston choice
- Going For Broke-n.....Twin Turbonetics T76 5.3
