View Full Version : LT1-LT4 Modifications
  1. Header question
  2. Making a stand alone harness (LT1)
  3. Reclocking LS1 steering shaft
  4. First time at the 1/8th mile - Times inside
  5. 1\4 mile run?
  6. How do I put this back togeather?
  7. Replacement Power Steering Pump
  8. constant heavy miss
  9. Fuel injector impedance
  10. shomespeed dual kit
  11. Can't connect to PCM
  12. This cam with stock valves & springs?
  13. stock Exhaust?
  14. Water Pump?
  15. Back to the ls side
  16. newby need help w lt1 build
  17. Trans leak e
  18. Coilovers installed..eh
  19. Who has done there own Dual Exhaust?
  20. LT1 Misfire Issue, running out of ideas...
  21. Oil question
  22. Removing intake manifold
  23. Need help routing A/C and battery lines/cables
  24. 24x Re-pin Question
  25. Need advice on this LT-1
  26. Interchangeable vortech parts
  27. throttle body question
  28. DTC p1441
  29. new lt1 owner, need advice.
  30. o2 sensor issues
  31. 40 months now what to do
  32. what size pushrod?
  33. Intake manifold oil leak.....any advice?
  34. More HP(:
  35. Made it into Camaro Performers
  36. What size band clamps for pacesetters?
  37. fuel regulator related engine light
  38. Data logging with tuner pro RT.. got questions
  39. Bolt on WS7 vs Bolt on 01 Cobra
  40. 95 formula slower than a 95 trans am?
  41. What do yall think about garret turbos for ls/lt1s?
  42. Can a stock Lt1/T56 handle a turbo and how much boost is safe?
  43. Aftermarket Flickering Gauges modification?
  44. can you run an fitting for a type two power steering pump??
  45. Are 60lb injectors going to be enough for E85?
  46. Vortech v2 head unit
  47. Is there any fix for my EGR besides deleting it?
  48. my car wont stay in reverse
  49. Found out why my Z28 was ticking.... now have a question
  50. 95 Camaro 355 Lt1 Rearmount On3 76
  51. Mod advice
  52. lt1 tapping noise
  53. need help (Something Clicking)
  54. le2 build, help wanted
  55. got antifreeze in my opti!!!
  56. Opti or something else?
  57. Having one of those years!
  58. Car heats up when cruising
  59. Tuner or no tuner
  60. Couple 1/8th Strip Questions
  61. unknown problem wiring???
  62. Dumped bullet exhaust?
  63. knock retard
  64. Start issue
  65. Tuner in southern California
  66. #7 cold individual cylinder fuel trim
  67. what is the best heads package for the money?
  68. Z28 having some issues...
  69. Racecraft or PA racing F body k members
  70. Fuel Pressure Question
  71. HVAC box delete ?'s
  72. E-cutout wire length?
  73. Hacks!
  74. Oil pressure problem
  75. Which gasket to use for stock manifolds?
  76. Screenshots of my tune
  77. Patriot spring bases wont fit over valve seal seat??!
  78. The LT1 car is gone, enter a 2002 Vette
  79. MSD distributor optispark
  80. Mild Blot-On 93 Camaro, What Next? Questions About Best Cam
  81. A/C lines
  82. 1997 Transam, is it worth it?
  83. Broken crank bolt and extractor
  84. After bolton mods / what to do next
  85. lt1 rough idle will not rev
  86. tick after header install and custom y.
  87. Misfire When Cold, Smooth When Warm?
  88. Throttle cable for Whipple
  89. Jet tuning problem..
  90. Ram air hoods
  91. Hypertech Programmer Hack
  92. I am installing headers an have ran into a problem
  93. oil light/engine light/temp?
  94. fuel injector question
  95. Changing oil after rebuild
  96. 95 z28 running rough
  97. Lean cylinder 2 and 4 help?
  98. Exterior Camaro Color Options
  99. water coming out sparkplug hole!!!
  100. Misfire question
  101. 396 LTX For sale.720hp NA Built For Nitrous!!!
  102. How does this sound?
  103. After 2 years... The motor is in
  104. LT1 383 Clayton Racing Ripoff
  105. '95 Camaro Starting Issues
  106. Valve covers
  107. Ground Strap Missing...
  108. Speedo Problems
  109. ICM cooling mod quick Q's
  110. 1995 firebird formula egr delete.
  111. 1995 firebird formula ac removal
  112. HELP... oil cooler adapter housing
  113. WTF happen to my car...
  114. Shootout Tow Vehicles
  115. Horse power help!!
  116. vortech v2
  117. What's the going rate for untouched 1993 LT1 heads casting #10128374?
  118. does any one know how to test a coil?
  119. 1.7 rocker questions
  120. Advice Needed.
  121. Kooks Y pipe question/Stainless works questions
  122. Looking for a base cc306 A4 bin file?
  123. lt4 carbed intake? where or how?
  124. jet performance chip?
  125. anything else i can try??
  126. Gm 847???
  127. ICM movement
  128. optispark????????????????
  129. 1994 Pontiac Firebird Formula
  130. 24x Conversion
  131. Fuel Pump Question!
  132. Had an oil analyses done
  133. LM1 Wideband - RPM and MAP signals?
  134. throttle sticking after engine is warm?
  135. WTF harmonic balancer issues?
  136. still looking for a '94 f-body 4L60E
  137. 2 bolt mains
  138. Anybody running a 4150 nitrous plate?
  139. Lt1 Miss,high rpm cut out......
  140. Approximate quench clearance on stock LT1
  141. please help me with this issue!
  142. Late 4th gen 10 bolt rear end on early 4th gen?
  143. Which heads are better?
  144. What wires should I buy?
  145. need help with my egr
  146. Question
  147. Floor soaked.
  148. Running
  149. Tuning software
  150. 95 z28 died while driving
  151. Fans question
  152. Cam question
  153. LT4 measurements, anyone know?
  154. To buy or not to buy: what would you do about this car?
  155. what is all of this stuff
  156. misfire question
  157. Going to look at a 97 TA today.....
  158. Code for Knock sensor, AIR after coolant flush
  159. T56 Trade
  160. Oil gauge
  161. help me pick rockers set up
  162. Help!! Oil Cooler
  163. Blow this car up!!! I have had it...
  164. Procharger question
  165. padding to wedge between y pipe and frame
  166. Need help finding a 1LE interior part..
  167. Well got my dyno #s
  168. Help With droping my LT1 in to my 63 Belair
  169. obdII to obdI conversion issues
  170. Single plane intakes
  171. New guys saying hi
  172. Lets see your oil breather catch can set ups!
  173. cam only lt1
  174. Can you throw off optispark timing
  175. Is there anything I can wrap around my wires so the headers dont melt them
  176. PCM fuel cut-off and supercharger - lean risk?
  177. Car is randomly shutting off PLEASE HELP!!!!
  178. Oil drain issue - quik95lt1 chime in please
  179. Absolute cheapest deal on LT1 pacesetter headers anywhere
  180. NEED HELP with some problems
  181. Need a cam gear compatible with the lt4 hot cam
  182. Code P1361 - Please help.
  183. what kind and length 02 extensions
  184. lt1 painless wiring harness
  185. Anybody have luck with aftermarket coil's
  186. what's next
  187. Vac ports/ plugs and pcv plugs
  188. AS&M Headers - where to buy dual cat Ypipe?
  189. im lost
  190. Switched to EV6 Bosch
  191. this %*$#* car is going to put me in the crazyhouse
  192. 3.4 to lt1 swap, swap dash harness?
  193. Bog/Misfire in closed loop
  194. Regular opti shoppers
  195. my 383 cranking compression
  196. need advise on buying a z28
  197. Ground circuit 97 trans am
  198. At what point is a vacuum pump needed???
  199. A little advice on a Vortech SC
  200. what will my hp be on my LT1
  201. What upgrade next
  202. Lt1 Software
  203. getting headers in place
  204. Clutch fork issue.
  205. Lt1 problem
  206. Le2 for a 383?
  207. T top guys need pix please
  208. egr air hoses
  209. LG motorsports coilovers
  210. Nothing to do with LT1 but need help
  211. Battery relocation engine ground location
  212. manfiold removal issue
  213. looking for a different cam
  214. Lt1 help!!!
  215. Any south Carolina guys??
  216. My new lt1 383 eighth mile times
  217. LT-1 Corvette & Caprice SS HELP
  218. 97 Firebird LT1 - Looking For EVAP Diagram
  219. 96 lt1 to ls1 swap
  220. Car cuts up and feels low on power
  221. no start
  222. checking bearing clearances rod/mains
  223. Fuel System
  224. lt1 question for a new mwmber
  225. -92 vette lt1 vs -94 trans am lt1?
  226. i hate parts classifieds
  227. obdI-obdII ?
  228. New engine - runs 200 degrees, higher temps at speed or in traffic
  229. Blow of valve VS MAF sensor
  230. 350 cc306 AFR PCM tuning thread
  231. How much damage do you guys think this is?
  232. Someone has got to have their air pump fittings still
  233. 94 z28 turning off
  234. stock 94 LT1 OBD1
  235. Induction discussion :)
  236. LT Custom Grind Camshafts from COMP Cams
  237. Lt1 M6 Safe Idle range?
  238. LS1 lid conversion, couple quick questions
  239. Procharger install manual
  240. Intermittent Starting Issues
  241. No Start After Walbro Pump Install... HELP!!!
  242. 96 z28 and i'm freakin stumped! help!
  243. Anyone know where OBX headers can be found?
  244. LT1 extended crank to start after a few hours of sitting, ECT?
  245. HELP!!! oil pump went out
  246. Exhaust leak or rocker noise?
  247. 95 z28 temperature gague does not work
  248. Time for heads....on a budget
  249. Name that sound...
  250. Posi is dying, what to do
