View Full Version : Forced Induction
- Joining the boosted family- buying nasty's kit
- check this out
- what size CI motor are yall running?
- Digital Boost gauges...
- Installing STS mon.
- Hey SDCE anything on the FMIC
- Does anyone sell just a bracket for Centrifiguls
- Anyone compare 50/50 Water/Alky vs. 100% Alky?
- Alcohol - Methanol injection nozzle
- What kind of guy am I????
- What one of these cams should i run
- For those that have purchased the OBX FMIC.
- Post your Boost Gauges and Controller Pics Here!!
- how much oil for turbos?
- turbo exhaust setup
- STS qusetion
- T-trim installed on 382ab
- Racing vids. 2004 Yamaha YZF-R6
- Turbocharger or supercharger
- The QMP Kit Rules!
- New Numbers
- Will this PCV setup work on turbo car?
- Intercooler Testing??
- Effects of Primary Size on Turbo Motors
- Rear mount right after headers
- STS Kit
- Will a 60-1Turbo be too much for...?
- please post if interested in sdce gp
- Interesting source for tubing and some related stuff
- Anyone sell the tubing and OBX Intercooler complete for STS turbos
- Need some advice on my Intercooler plumbing
- STS Turbo kits are they good?
- benefits of FMIC over Vortech's aftercooler on big blower?
- High flowing heads - benefits with FI
- Man I hope this TT kit will be worth it!!!
- I need a tune anytuners............
- Icon Twin Turbo set up
- Turbosmart controller vs. Innovative
- incon y-pipe question
- h/c forged shortblock
- who makes the best turbo kit for the ls1
- ANOTHER SPEED INC CAR IN THE 140'S mph
- Question about my cam for a blower?
- No STS dealers need some sort of sponsor?
- STS Turbo kit questions
- 214-224 115+3 deg blower cam with Turbo?
- Chime in on this theory...
- Need advice on BOV selection.
- what rpm are my stock valvesprings good to with my vortech?
- It's alive! after over a year!
- reverse pattern cams??
- Procharger D1SC vs Vortech V9SQ pro's and cons?
- twin turbo montecarlo (pics)
- 500rwhp with a lowly stock 4.8
- Turbo Cam??? Recomended!
- Perplexed - Fouled plugs + three melted/missing tip ends....
- TT Fuel Systems
- Help! Need some input/advice....
- HPE "S" Cam w/turbo
- FS: ATI D1SC Procharger kit, very low price, must sell asap!!!
- Gains/losses with the FAST 90 with forced induction?
- TT v6 capabilities
- Blower cam...what do ya think? (specs inside)
- FS: ATI D1-SC, SDCE Spring Tensioned 8 rib, FMIC
- forgotten track vid found!
- Vortech guys please come in
- LS1 PTK turbo kit???
- Where to get TTi kits?
- Whats the maximum boost you can run on pump gas?
- Cheap Insurance or Waste of Money
- any LS1 guys local to us looking for mods?
- SDCE tensioner with ATI 8 rib
- NEW GP's
- Couple D-1 ??
- A little bit about us...
- Anyone Want to sell their car??? got money! :)
- whats the trim
- who sells a larger dia crank pulley?
- WOT tuning help
- SDCE now a sponsor????
- Stock Bore + O-ringed 6l heads = what gaskets?
- STS questions for NE1 with a Turbo
- AFR 205 66cc with 224 XER: thinking of a little boost later.
- Wastegate question
- whats the max timing i wanna have?
- Fmic ?????
- SDCE Group purchase
- no more maf limit for me
- aeromotive A1000 pump anyone using?
- Need some advice on fuel system
- Multiple misfire at idle only
- F.A.S.T Controler with MAP sensor
- vortech cold start in UK - 240 volt engine block heaters?
- Compression ratio ?
- Vortech Super Sale - beat the price increase!
- Methanal Injection
- FI cam FS cheap
- Which gear to run with my new Twin Turbo setup??
- i think ive finalized my turbo setup
- No more spray for me;mod list
- pics
- How much will 4lbs raise my compression?
- CAS owners chime in
- advise on gears???
- Where to go from here?
- Turbo or Supercharger
- What size injectors with blower?
- So the season is done for me, Goal of 10s wasn't accomplished.
- Looking For..... Jz 97 Ss 1500
- New STS kit
- Z06 Cam
- How much meth do you use???
- Black oil before and after my vortech?
- STS turbo on LT1
- STS turbo boost What compression???
- Turbo sputter
- Wastegate V-band or flange?
- looking for a turbo or supercharger
- Where to get good priced air/liquid coolers?
- Few races then Waste Gate falls off? WTF
- Need help with intercooler piping!
- Not getting the boost I should be getting.
- Just got my kit today... have a few questions on injectors, plugs and pump.
- 38mm Tial BOV for sale Brand New
- Boost and a stock Mass Air
- fmic what size piping?
- Anybody want to sell there CAS Intercooler?
- PSJ- New info on the Eaton SC for F'ers???
- Anyone Using The Carb Manifold With EFI and Turbo/SC?
- Anyone moved tha AC to the driver side of the engine?
- STS Kit and My H/C LS1
- intake selection
- does altitude affect times with a turbo inducted car?
- go with cometic or felpro 1074
- Clog or 8 rib
- ATI Superdampner Unerdrive or not?
- Cams and Turbos
- Turbo or no?
- Need some advice??
- wastegate and BOV size
- Rear mount oiling...advice requested
- vortech G-trim supercharger
- Still trying to decide Custom Turbo VS nitrous...
- What size of turbo for 408 LS1?
- 02 C5 with Magnuson - Before / After With LG Motorsports G5X-B cam
- 02 C5 with Magnuson/G5X-B - before and after with QTP Headers
- What boost control should I go with for under $400???
- vortech supercharger oilfeed
- What needs to be modified to fit XX trim Vortech
- Any prob running a TurboXS BOV with a D1SC
- How many you turbo guys running these parts?...
- SpeedInc VortechYSI Eliminator kit & cam 4 sale $4300
- Procharger Idler Pulley
- Aussies are taking over ls1's? :p
- $7000 a good price for Vortech installed?
- Ordering Blower tommorow
- Turbo with carburetor - info needed
- Incon Turbo cam ?
- 96' vette LT1
- What's the best Turbo setup for the money
- Twin turbo setup: oil feed/return for turbos, where and how?
- Props to Vortech from a ATI Guy
- C6 Teaser
- Who all has removed EVAP?
- Road Race with FI setup?
- Ford 8-rib Idlers?
- OBX on TTI Street Kit ?
- Anyone doing the LS2 mani swap yet?
- Looking to up the boost in my JGP
- 4.3 - 4.5" Ultra-grip pulley
- Any pic for a STS intercooled?
- G-trim supercharger 4sale
- Need recommendation for Titanium?
- 8 rib PS pullies
- TT LS6 sandrail
- 7 sec rumor! Its true!!!!!!!!!
- FI videos...
- What kind of blower speed are you guys seeing...
- Took a ride in an STS car
- Good N/A engines with FI?
- Where can I get parts to assemble...
- Does anyone have any STS Turbo track results?
- Twin high flow intercooler worth the upgrade?
- Vid of my custom turbo setup...
- 90mm lsx worthwhile over 78mm LSX on turbo car?
- D1SC on the way ...
- anyone interested in twin T-44's?
- Vortech maintenance? Can u email me a manual?
- Intercooler question
- what's a good cam
- cam question
- ATI steel J-bracket
- eldelbrock heads
- 26 Mpg!!!
- Nasty performance Turbo manifolds?
- ATI SDCE 3.7 8 rib s/c pulley f/s $70
- FS: GT45, OBX intercooler, Turbo blanket, Misc.
- 80mm Pro-M on a 408 with 18psi?
- anyone had thier vortech head apart?
- STS under glass
- has anyone seen this before????
- Question for SDConcept users?
- Speed Inc. Shop Car 427ci, GT88 preliminary dyno results
- FI on a C5......
- Light The Afterburner With An STS Turbo (poster)!
- Pics of my fuel system supporting the Vortech YSi setup
- Worried about getting a STS kit because of Water?
- which one of these turbo setups are enough to support power to a built 408?
- Boost referenced regulators
- ATI + 370 + Synergy Motorsports =
- STS stock injectors maxed out at 5500 rpm?
- STS on pump gas?
- Can someone explain to me why headers are no good for STS kits? (STS Dealers!)
- compression ratio
- Fmu?
- BOV vs Surge Valve.
- Fuel system for ATI?
- Upper radiator support?
- Intercooler/Turbo Tubing
- Header material choices...experts inside
- Intake for IF
- STS GTO and SS Camaro at the proving grounds, SEMA
- Twin C5 setup from Pro Turbo Kits
- STS BASIC vs ATI P1SC?
- What kind of boost gauge are you running?
- What is a 76mm Turbo head unit worth barly used
- Don't these intercoolers sound small??
- Twin Screw blower on the way for the LS1
- SC vs Turbo at ½ throttle daily driving
- ATI D-1SC Prereqs?
- Talk to me about STS Turbos
- Where to buy individual parts for procharger
- F/S: ATI Crank Pin Kit
- Whos running Inconel exhaust valves instead of stainless?
- Most Power Made With Unported 317 Heads W/turbo?
- Truck manifolds backwards?
- Water/alky?
- can i run an FMIC with an underdash A/W???
- ATI install Dallas & South Texas?
- Belt Length, D1SC, 3.4" Pulley
- New motor, STS kit on and running...
- Vortech Question
- F1 Header Query
- turbo selection
- Orange Spark plugs
- CAS Twin Turbo Stg 2 or T76 Tuner kit???
- Help me out
- Update on the ATI 8 rib setup.
- Why is this car running such high duty cycles?
