View Full Version : Forced Induction
- Anyone use BTR LS9 head gaskets?
- Coil harness wiring and China pressure transducers
- water to air / air to air intercooler question
- 416 D1SC Trans Am
- 1979 Zephyr -4.8L S485 - 5.15@135 -pistons/rods 243 heads- Update
- Huron Speed kit unboxing question
- Efi Live vs Hptuners for Flex on C5 Corvette
- l77 cam and boost limitations?
- Folks Using The Hooker Turbo Manifolds - Please Come In
- Motor keeps melting plugs and pistons. NEED HELP!
- RIP kp
- What stator to start with?
- ProCharger Sale at Brute Speed!!
- I want "Mo' Powa' Babay"
- Concept Performance LSR - anyone used?
- 6.0 LQ9 w/ 4.0L whipple Boost Question
- I wanna go fast, drag and drive 5.3 turbo f-body
- Is this turbo lag or something else? Video
- WG questions
- And so it begins.6.0 ly6 build
- CO2 or manifold pressure for boost control
- Boost and 11:1+CR
- Boost gauge not reading
- wastegates and intercooler
- Let's talk about onboard air
- Ring Gap for Boost
- 2.00 1.55 stainless valves
- 4.0L whipple - newb question
- Aluminum block for 1200 rwhp
- Oil cooler ? Should I be running one ?
- First turbo build, 70 GTO...
- My first turbo build, need help please! Fueling issue?
- Something a wee bit different.
- Start up tune needed?
- Holley 4 bar. style intake vs Edel. for boost
- Selecting gauges
- 5.3 Turbo. S480 t6 1.10 vs gen 3 7875 question
- CRT Billet Turbos
- Huron speed twin kit
- Huron Speed 21'-22' Group Purchase ~ BIGGEST SALE OF THE YEAR! ~
- having trouble controlling boost
- Help with wastegate diagnosis - found it
- 4.8 twin turbos
- More Cubes or More Boost?
- VS 61/62 .82AR twin remote 5.3 setup?
- On3 T6 turbos
- LS6 intake...Where to find one?
- 5.3 carnage, time to upgrade
- High compression 408...t4 turbo?
- TBS 6-71 Lower pulley question
- Lysholm supercharger
- 2nd gen fbody ls turbo builds
- L9h 6.2 twin t04e twin hx40
- 408ci, w/Whipple 2.9 boost numbers?
- Terminator X Boost Control question
- What rpm and boost are you leaving the transbrake on
- fuel rail kit for truck intake and bosh 210
- Stock 4l80 / LY6 w/ LSA ?’s
- PTFE hose inside diameter?
- Huron Speed 8th Annual Turbo Kit GROUP PURCHASE Announced! ~11/26~ Black Friday
- efi ls intake on 5.3 with turbo
- Best turbo size for 5.3 for instant boost
- Holley manifold up pipe size
- Sbe oil pans
- 2.02 1.57 valves in a stock bore 5.3
- E85 surge tank lift pump
- FAST intake question.
- 1969 full custom firebird single turbo lq9
- Final stages, Turbo build checklist
- Dyno'ed the Hornet yesterday
- The ultimate Head debate thread !!!
- TruBoost AEM Setup
- 5.3 and forced induction option’s
- Turbo LQ4 Fuel pump(s)
- early 862 heads with the notch for relief
- Cracked 317 heads
- nnbs intake for boost
- horsepower limit 2" OD hotside (1.78in ID)
- 1 (1/2” head stud) with other stock head bolts
- LQ4/LSA Blower
- Griffin 1-58241-XLS Radiator Cap
- Help me with my Meth issue
- Billet s372sxe on 5.3 Sierra?
- 3" DP to 4"DP, and back to 3" End of season track test (updated 11/8/21)
- Which turbocharger should I go with?
- Spec My Build Request, Check My Thinking
- Rear gears -street car
- On3 turbo kit boost controller recommendations
- Hot side tubing/bends
- 8's with a D1SC Procharger?
- Going LS1 Ws6 FI TVS2300
- Turbo 427 ls suggestions
- LSX376 Users - Come In
- Turbo 5.3 Build
- Roots style Supercharger Options on 4th Gen Fbodys
- Procharger bracket
- Air to water hose inlet size
- injector and regulator help
- Anyone use the Summit 103mm TB??
- Whipple 2.9 or 3.0 for Yukon 6.2
- LS9 Headgasket - 4.130?
- Need advice for power before boost
- VSR 7875 G2.5 vs NextGen?
- 2006 GMC 2500HD turbo advice, pictures, do's, don'ts???
- tps sensor on a csu blow through and terminator x
- Oops Wheelie
- Boost Controller
- Another "China TB" Thread. Leaking at linkage.
- Boost Building Tips - 5.3 big cam and 91/103
- Terminator X Boost Control Using the MAP Sensor Signal
- 2.02 valves and 5.3
- How screwed is my motor.Turbo lq4 pushing oil
- E85 Turbo Spark Plug
- Rod bolts and main studs
- Air filter for turbo application?
- E85 timing
- 1/2" wide T bolt clamps?
- TEFLON COATING LSA blower Question
- TDI Turbo from Jose @ Forced Inductions
- Re-purposing the Procharger F body dual intercoolers
- 400 or Glide
- Looking For VSRacing Billet 485 Feedback
- terminator x map sensor chart
- Problems after turbo install
- Huron speed Fox Body Turbo kits sale!
- Radiator Pressure?
- House of boost bracket
- Procharger and 4 bolt heads
- Turbo lq4 going lean under boost
- injector and throttle body help
- Twin Ebay 78/75's vs On3 107 turbo...
- terminator x and intake to use questions
- Pistons from Aluminum block work in Iron Block??
- Tuning Questions
- 4" DOWNPIPE swap...How short, is TOO SHORT? *UPDATED*
- 78/75 single turbo 3” exhaust limits
- Summit pistons, rod length vs boost
- 6.0, 78/75 Chyna Turbo, 3" downpipe still making smiles
- Took the Z28 out to stretch it's legs ....
- Good T4 to T6 comparison (78/75 VS T6 S480)
- brian tooley head gasket oreintation
- Help
- 5.3 turbo/timing questions
- What arp head stud to use for 20lbs of boost
- Cam for 5.3
- Head Gaskets Turbo HELP
- D1X and 4.5" twin procharger intercoolers
- LQ4 Turbo and Cam Selection
- block fill and pushing water issues
- L33 main discoloration.
- How to determine new boost from pulley change
- The best engine for Boost 🙂
- Twin turbo rear end help
- Frostbite FB603 IC'er
- Ls3 with a whipple 2.9. Best upgrades and advice
- Pistons and ARP?
- Truck alternator hitting d1sc pulley bolt
- New turbo and smoke
- holley terminator x with blow through
- Bought a unfinished project. Help me with newb questionsb
- Squarebody long bed 10.8sec on 90 octane
- Turbo 66mm
- Single turbo stock ls3
- 408/v7 ysi
- VS Racing 7875 billet Gen 2 .96ar - best engine displacement
- Twin Turbo Full Kit for $994.00 Anyone Tried it yet?
- tps on a holley terminator with blow through
- 5.3 downpipe size
- Fuel Regulator
- Turbo lsx s10 running out of rpm
- BTR cam choice
- Truck intake, rails, fuel pressure regulator for boost
- lsa supercharger on any ls
- where did my boost go?
- How wide (and low) can the powerband be?
- 5.3/TH400 7875 turbo falling on its face
- Minimum hose size for catch can
- 2nd ring
- LS 700 RWHP+ Build. NOOB
- LQ9 91 octane turbo
- 2step air fuels & timing
- "Ecoboost LS" - BB torque for tow from a small LS?
- Procharger IAT PN
- Special Annoucement. Denmah Matt Happel on Summit FB Livestream Friday Noon EST
- head gaskets for ls and boost
- 400k twin turbo 5.3
- D1SC Driveability
- spark plug opinion
- Lsa Ls3
- Lsa Ls3
- 5.3 s475 slow spool
- Hy guys doing my first turbo kit need some help
- Some advice on the direction of my D1SC f body
- spark plug help
- LS Rocker Arms
- Boost oscillation - What is the likely culprit?
- Map 2 bar efilive cos3
- Controlling boost
- what kind of turbine drive pressure should I have
- Pistons and rods
- BTR .660 spring limits
- shearer or tick a2w
- Best way to kill power at launch
- AFR's look normal, but plugs say rich
- Give me the bad news (hopefully not)
- 1999 WS6 - Original LS1 - Huron Speed T4 AC Retaining Kit
- 1999 Camaro Idle Tuning Help
- Afr per lb of boost
- VSR 92/103 with 6.0 lq4
- First LS build, can I get a review?
- Cortex EBC Controller/Support Excellent
- meth injection method
- Under drive pulley with forced induction
- Supercharged 4.8L
- turbo/SC early planning
- How do you guys cool your engine with intercooler covering radiator
- Review my tune
- Starting turbo LS 6.0 Build - COMP Water cooled turbo?
- tuning on a ls 5.3 non intercooled on e85
- 408ci twin turbo size?
- Chevelle LS swapped turbo build
- Aster bracket 8.65 crank and 3.9 pulley
- Hey Huron Speed V3 AC Turbo Kit owners - PTFE Fuel Line Routing
- Front mounted A2W or intake mounted A2W
- So, no .96 to 1.25 housing swap for me
- MMI Turbo Manifolds
- Square port heads
- 150lb injectors and microsquirt
- Should I supercharge my 427?
- Stock ecu antilag
- Alt bracket
- 4th of July sale. 20% off all CBM brand billet parts and accessories.
- Second stage of meth
- X Max vs stand alone boost control
- Ls7 head to ls3 intake adapter? Anyone use
- Bullseye 7687 turbo looking for some opinions
- Will this ebay turbo work OK with Huron Speed AC kit?
- Most power thru a single 3" catback?
- Ordered a TVS2300 for the GTO
- Need a recommendation in Houston, TX
- Forced induction turbo book for reading
- LS3 swapped 98 Camaro
- LS turbo project
- MPH Drop on shift?
- Huron V1 kit Radiotor
- Best C.R. for 30psi boost
- Bottlenecks & Performace
- Turbo LQ4 questions
- Alternator hitting procharger pulley
