View Full Version : Forced Induction
- Twins or no twins?
- anyone has the modular Kmember system?
- T Rex fuel pump making louder than usual buzzing
- Need turbo suggestions - Pros and vendors
- 44mm Wastegate on a S475?
- BOV Upside down okay?
- A2W Intercooler Setup for the Street
- FBody Kmember BMR orrrrr ??
- Using 2 x 38mm Wastegates or 1 60mm ???
- l33 or ls1
- What type Muffler on a FI set up?
- 383 rear mount questions
- MAF or no MAF on turbo street car
- 5.3 turbo estimated rwhp
- ***Worlds Fastest ZR1 Corvette By Late Model Racecraft***
- EPP cam on LQ4 with LS3 Heads
- Anything sound Funny about these 317s before I buy them
- 427 LSX & GT-55 Turbo
- How important is equal length??
- How much HP can my -NEW- IC support?
- Wastegate on a Procharger?
- Will this combo make decent power ?
- Is a TU2 to big for a 364?
- turbo manifolds
- How much power out of 6.0
- whats everyone doing for oil pans? if stock is anyone plugging bypass
- c6 manifold & flange not even close to lining up.
- Headgasket new one or rebuild?
- 390 or 408?
- 402+Novi 1500 results
- 346ci stk bottom end turbo build..HOPEFULLY
- Iron 408 Solid Roller/F2/A2W/BS3 Build - What to expect
- BOV location
- 1000hp auto car
- F Body (trans am) Turbo mount location
- what vortech do i have?
- ***LMR ZR1 Slayer Video***
- Thinking about putting this on my boat
- Front mount single kit XMAS deal!!!
- 364 cu in, AFR 225's or 235's?
- boost or cube's
- LS1 vs LS6 vs BBK intake for FI and 500rwhp?
- My machine shop is wrapping up my engine build; have a few questions
- Best Forced Induction Piston?
- Budget friendly turbo kit for LSX Mustangs
- 76gts, pt88 or something else
- Project 2012 x275
- oil return
- 600RWHP doable on this setup?
- Documenting my build
- Turbo oil question
- would you run this engine FI?
- S485
- 408/or bigger
- best deal on tial wastegates..where to buy
- Top Mount F1C Camaro Build
- Procharger and water loss?
- Positive displacement superchargers.. where are they?
- Which plot is best?
- F.A.S.T intake manifold and throttle body , with Pro Charger S/C problem
- Built Stage 2+ 317 heads with upgraded valve train
- Will active fuel management work on an FI setup?
- ls2 turbo g body
- What's this turbo best suited for?
- Question about boost
- help with supercharger.
- Who has a stock rear axle w/ a Procharger?
- what head gasket... cometic or mls
- looking for realistic expectations; 370 TT
- gt45-y2004k turbo?
- I just lost 130+rwhp
- Considering removing 2300 for TT
- Which sponsors sell S475
- LG G5X3 cam with turbo
- BSFC on Turbo LT1?
- Alkycontrol & D1SC J-Bracket Q&A
- Which turbo?
- Wanting to go turbo
- where does everyone run there gages that have a bar for the cage in front of piller
- Compressor flow map calculator
- tvs2300 sweet spot on a 427?
- procharger race valve or bullet valve?
- High compression 402 with a D1SC?
- What engine and who to build it?
- Educate me on Scavenge/Vacuum Pumps
- Nitrous to Turbo
- which spring in oil pump?
- **LMR C6 Twin Turbo Kit INSIDE**
- 2006 Cadillac STS-V
- meth injection
- ultra street turbo lsx mustang build
- forced induction ballers
- '00 z28 procharger build list, need opinions
- 212/212 56X/56X 112 or 222/226/596/598 116
- 1-5/8" or 1-3/4" primary tubes for TURBO????
- Bringing the WS6 back to life front mount build thread with pics.
- head studs with no gasket change :)
- A question on Turbo Header Durability
- tensioner of supercharger Magnacharger
- Alternator bracket with race water pump
- 2.5 bar map question
- 317 vs stock LS1 heads cylinder pressure
- Got a few questions for the boosted small cube 346-347 guys.
- cams prolly not ideal... but will it work ok?
- Any "better" year 5.3's for FI?
- Another "what cam" thread... please point me in the right direction!
- Member for 6.5 years. First post. L33 plans. Build underway. 9/4 Update
- Twin turbo intercooler
- New dyno numbers! With in car video!!!
- Ebay twin turbos, edelbrock carb, going to work?
- garrett turbo question..
- Who is launching off foot brake?
- Incon turbo
- Front Mount Turbo Kit?
- 5.3 turbo foxbody....Vids inside
- New ProCharger F-3 RaceDrive
- How far has anyone pushed a LS1 manifold?
- new build help
- LS3 Oil Return
- 4 bolt UMI throttle body question
- procharger issue
- 5.3 turbo cam help
- pulley belt slip?
- Max out 5.3
- Bosch 160lb injectors
- Homemade M112 for my LS1 BMW
- Follow Along with Tick Performance as we A&A SUPERCHARGE Michael's C6 Vette (PICS)!
- O-ringed block, what head gasket?
- 73 ventura, paper head gasket 5.3, th350, microsquirt, gt45, 10.70@130 16psi
- Question about blowers...
- Holset compressor map
- Which vacuum lines need check valve to avoid boosting?
- BMW e46 swapped Ls 370ci 4L80 BEP 91mm (UPDATED 6-5-12)
- Fall new best *part two*
- LS1 D1SC Bracket? Electric Waterpump?
- critique this cam
- Need help!!!! ASAP!!!
- new pb 9.19@146 tc78
- Looking for advice for heads/turbo combination for next years setup (race only)
- Anyone using generic head studs on their FI engine?
- 2 step, with timing retard or not?
- Boost/vacuum line distributor?
- stock 5.3 strong enough?
- LQ9 vs LQ4 for turbo-build.
- is 11.1 comp to much
- Twin turbo and e85 guys what wideband for tuning?
- I need some input
- 02 Z28 Procharger Project
- my plans: how long will it last/what i need?
- NEW PROCHARGER F1X replacing F1R
- boost question with H/C setup
- twin turbo thread?
- Time to talk about new motors....Bigger ones!
- Question About Compression, Piston and Heads.
- How would u make 700rwhp?
- 100mm single too big for a 4.8 build?
- looking for ebay twin turb opinions for a 5.3 dragboat project
- STS Turbo on built 383
- Evans Waterless Coolant
- how realistic are my goals?
- front accessory drive question
- turbo for max effort stock shortblock 5.3?
- 61 chev 383 LS1 S475 build
- can I push it even further!!??
- Another LS6 cam question...
- should i go vortech v9 or turbo
- anyone running an electric water pump on the street?
- supercharged 5.3
- Turbo in my 93 Z28 Camaro?
- Good bye Twins hello Single front mount!!!!!!
- 1954 Studebaker LM7/T56 MP76
- looking for dyno# 370 0r 383 s475 83mm 110 ar
- Turbo Vs. Supercharger (Cliche Title)
- turbo setup help
- looking for pics and ideas on how to move the whole radiator forward for clearance
- turbo build
- "turbo guys"
- which heads for boost
- 6.0l turbo stang project coming along...
- TT LS2 dyno - power falling off
- Everybody and their mother has a tur-blow....LETS SEE SOME BLOWERS!!!!
- Gm screw in IAT
- So I am confused as to what turbo to move up to....Help please
- Vertical Radiator Fan Average CFM rating
- 2004 GTO - from STOCK to NOT - a Tick Performance ProCharger Build!
- Stick with LS1 or go LQ4?
- Winter 2011-2012 turbo build
- Help me decide on the induction side of my FI build. Holley+PRC LS3 or Edelbrock+AFR?
- Magnum Turbos
- why is my boost falling off?
- Anybody Running 5.60's or Faster At 3300lbs?
- 370 or 408 ?
- wastegate 38mm tial
- Tial WG diaphram crimped/ Is this causeing boost taper?
- Dear Santa, please have Burkhart send me...
- Can I use a 6 rib belt on a 8 rib F1 Procharger?
- 9.5" or 10.25" TORQUE CONVERTER FOR 1000HP TURBO??
- can i put boost on a carbed 370
- Ati damper install help!!!!
- can i pull a 02 sensor to check back pressure
- Can someone help me pick a new turbo out?
- Which GT45s turbos do I purchase?
- Alternator on the Ac place?
- 5.3L build 862 vs 317 heads (compression)??
- S400 T6 LQ9 Mustang Turbo Build (5.85 @ 118mph)
- Can I run more boost??
- Wastegate ?'s..Can U manually open valve?
- Well I finally got some pics of my 370 and its ready to go in
- New PB..6.0@116mph....9.6@126mph video!
- First F1R LSX in the 7s
- Any one with a turbonetics t76
- Yet...another reason to run a got-dang INTERCOOLER!
- pics of turbo build.
- Strange cooling fan electrical issue
- new set up ??
- spooled up, whats up
- Considering Procharger
- cog
- recommend a gear ratio for my procharher combo please
- Vac line question and more
- supercharger boost leak?
- 7.4L exhaust Manifold ?
- 6.0 turbo 4l80e harness ecm suggestions
- With the right stall and cam would I notice any lag from a 91mm?
- lq9 with t6 turbo.?
- Ls7 lifters?
- Trans am 5.3 turbo build
- P0102 code after supercharger install
- How far would you take a stock crank?
- L92/vvt 6.2 motor and boost
- Twin rearmount turbo exhaust for S10
- TC76 aussi engine '99 camaro
- victor jr elbow
- modify a DS 1
- Turbo Cam NEEDED - 6.0L
- 1999 Firehawk Build - 402 and F1A
- How do I run vacuum lines turbo motor new style ls6 valley cover?
- Supercharged WS6 - Poly or Solid Motor Moutns
- Deck height with 6.125 rod
- Check out the 5.3 I just bought for $100!
- gear drive/crank snout question
- ebay vendor---->GT-45's..guesstimate my fwhp
- Motor Plate and Procharger LSX Transplant Cog Bracket (Madman's Version)
- lt1 turbo builds
- compression ratio help please
- Fuel problems up top
- Guys running Snow kits-where do yall mount the pump/resevoir in fbody?
- Tube to replace Mas Air Sensor?
- lq4 FI set up?
- Our little 370 Paxton powered GTO goes 8.99
