View Full Version : Forced Induction
  1. Need question answered about a LT1 rad???
  2. t4 gasket questions?
  3. Crank pinning?
  4. Turbo Sizing Question
  5. Thinking of Changing my setup
  6. can a regular mortal change one turbo seal?
  7. SDCE Tension
  8. Need Help S.o.s(( Aps)) Guys !!
  9. Need help with what setup to run
  10. Accufab throttle cable is now loose!!
  11. Looking for a little help w/OFI cold piping
  12. F1A or F1C for 427 LS7 F Body
  13. Just fired up my APS 35th LE today
  14. BOV swapped but getting more boost
  15. What boost can I run with a 98 pcm using HP tuners?
  16. LSXtreme Trans Am jumps into the 8's
  17. valve springs
  18. Prime New motor
  19. Turbo Fbody = worst investment ever!!
  20. Add Nitrous or go with bigger Snails?
  21. OFI hot parts group buy
  22. What Cars/Trucks use pusher fans?
  23. APS inlet drivers side hose rubbing issue???
  24. Will Procharger make enough CFM??
  25. Finally got the vid of 9 sec pass 408 pt88 pump gas 13 psi
  26. Building my own rear mount setup
  27. any one using the alky control methanol kit?
  28. Value of a Turbocharged LS1/T56 fbody???
  29. Two BOVs a benefit??
  30. Progressive boost controller?
  31. front mount and BOV procharger questions
  32. Forced induction eventually, what to do right now?
  33. JGS bov...
  34. OFI turbo headers
  35. Power falling off above 4psi
  36. Tuner won't tune car cause of Po103 ?
  37. FINALLY GUYS!!Pics of my APS 35th LE
  38. Oil Restriction
  39. intercooler fitting???
  40. MP GT45 V-band flange?
  41. 8 Rib Upgrade and Meth Kit gettin installed
  42. 2800 stall for DD sts
  43. Yank SS3600 stall and boost?
  44. Gotta slow it down...
  45. The real difference between A/r .68 and A/r .96?
  46. What size injectors for procharger?
  47. Question About Supercharger
  48. Playing with some low 12 sec cars on 13 psi
  49. Need explanation of boost bleed off
  50. Check out what I got today!
  51. 1036 HP @ 13.5 psi !!!!
  52. Those with beck intake & boost
  53. Lowest 402 dyno #'s ever
  54. Dune Buggies are cool right!
  55. Best Budget Injection Combination?
  56. Pics of Oil Feed and Oil Return
  57. Hmmmm question....ST 80
  58. How much boost for a 9:1CR 402?
  59. Thinking about a Boosted 5.3L IRoc
  60. Turbo, SC or NA to go 11's?
  61. Need Help Selecting A Turbo
  62. Dyno Video 76MM S-10 on 7lbs
  63. Forged LS3 preliminary numbers 722ftlb @ 4,500rpm by Rick @ Synergy
  64. Melted 6 spark plugs - what would you do?
  65. Will stock Mass Air Flow Sensor be fine?
  66. Its alive!!!
  67. Speedway / Turbo Make your own header kit
  68. Supercharging the FireHawk?
  69. APS emblem !!!
  70. question about charge air.............
  71. Congrats Ohio Boys (Turley and Brown)
  72. 3" vs 2.5" crossover, any difference in performance?
  73. turbo dumping oil out exhaust side
  74. stock ls1 springs?
  75. Blower lifespan
  76. Procharger Specialists
  77. Need some pics of the Hi-Flo intercooler mounted.
  78. best place for oil feed on lt1?
  79. Turbo motor longevity, is it a problem??
  80. Do everyone get oil mist from breather?
  81. Tial 50 w/ centri
  82. Motor advice... What would you do?
  83. Anyone running truck intake pipe on procharger like Bob@EPP???
  84. Overheating concern
  85. I think my manifolds are 5.3, not 6.0...
  86. Truck Manifold people
  87. will the stock ls1 ignition be fine for 850rwhp+?
  88. Any Turbo stores/shops in the Houston, TX area?
  89. what turbos for a stock ls1
  90. Boosted 383. What to set for red line.
  91. stock motor with procharger d1-sc race kit? safe?
  92. finally got the rear mount done and dyno'd.
  93. Are you guys running aftermarket pulleys for strength?
  94. lt1 with p1sc need combo idea's
  95. anybody change out all there aps clamps?
  96. Scavange pump
  97. 4.0 pulley on a T-Trim?
  98. bad pass on the track
  99. Bleeding off boost
  100. LS2 403 D1SC Procharged 'street driver'.
  101. .81 a/r
  102. STS Oil Restrictor/Pump Install How-To (Fix for oil in intake/exhaust pipes)
  103. Homemade Single Turbo Kit
  104. tranny cooler location?
  105. blower tuning
  106. Blower grind cam from A&A
  107. how much ignition retard per psi boost ?
  108. Those with ProChargers & Aftermarket Cooling Fans, come on in..
  109. Quick question about alky control kit
  110. Two ST76s
  111. Compression And Boost Question
  112. Made a few 1/8 mile passes last night @ 15psi
  113. Who has tested there turbo back pressure?
  114. 347,364,383 cam choices for procharger
  115. How do you size an intercooler?
  116. Valve Chatter
  117. Advantages of boost controller
  118. ST80 track results
  119. Alternatives to BFGs or MTs?
  120. LSX is ready to be dropped in tomorrow (PICS!)
  121. Soon installing Mocal pump and restircotr to STS....input appreciated.
  122. A2A or A2W?
  123. 06 vette APS kit Cooling problems !!!
  124. It arrived!!!!
  125. who makes bigger then 160# injectors
  126. Hard Pipes and IAT?
  127. meth versus race gas
  128. So here is what the new combo is starting to look like.
  129. where to get lt1 hot parts?
  130. need advise with this boost controller
  131. 3.5" to 3.0" reducer, where did you find one?
  132. Supercharger question
  133. sts help
  134. Acceleronics Versafueler Driver Box any good???
  135. Dynoing tonight, any estimates for combo...LSx/S95
  136. Magnuson question
  137. Any Interest In Cheap TB/Intake Elbows?
  138. Lingenfelter 2-step installed
  139. My Latest Video
  140. Turbo guys how much power have you put down thru a 3 inch ypipe and cutout?
  141. Vac/Boost..
  142. new boost controller
  143. Vacumn leak in cylinders 2 cylinders causing injectors to max out?
  144. My new plate showed up today.
  145. Will this cam work with a F1A
  146. Who has installed a gm 3bar sensor on ls6intake?
  147. supercharger suggestions
  148. boost and ping probs ...
  149. Trans Am intercooler size
  150. Looking for a Reichard Racing 4.100" 8 rib Procharger pulley
  151. Alternate place to mount a turbo.
  152. How many T's in a single vacuum line?
  153. Are boost control solenoids polarity sensitive?
  154. Meth nozzle placement...how far is too far from iat?
  155. Turbo LS1 Powered 1999 Mustang
  156. STS LS1 GTO- 6psi = 460whp & 500trq.
  157. Possible APS 427 tt kit. Need help and opinions.
  158. ProCharger piece parts
  159. X pipe on a twin turbo setup? yes or no
  160. What is a good ring set for a boosted street engine ?
  161. Building twin turbo motor...... IDEAS?
  162. Pressurized gas tank?
  163. 1 or 2 BOV's for my TT setup.
  164. speed Inc. F1A results
  165. Supercharger vs. Turbo
  166. well here it is at the track
  167. please tell me what turbo i have turbo experts help (pics included)
  168. lt1 truck manifolds?
  169. 98 pcm
  170. Blowing oil out rear main
  171. Anyone here with A&A's Vortech supercharger?
  172. Where is the oil level line at?
  173. LPE 2-Step Installed
  174. Aftercooler leaks water into intake!
  175. Is it ok to run alternator with just 2 front bolts, no back bolt/brace?
  176. Low numbers on turbo
  177. Who's running an OFI 4" downpipe?
  178. Aps Help
  179. D1-SC, leaking oil when the car is off, 1800 miles on it..
  180. Good beginner turbo kit
  181. Maf Location
  182. Anyone have the Instructions for the PTK kit?
  183. Maggie equipped A4 C5 has weird fuel trim issue
  184. Aftercooler heat exchanger?
  185. Relocating alternator?????
  186. what's the best thing to for building boost off the line?
  187. Best Intake Manifold for Turbo app.
  188. Mild Vs. Stainless
  189. Baller on a Budget (pic's) C5 TT
  190. max power d1sc?
  191. ???? About trim letters and turbos
  192. Hook Y pipe Fit my APS down pipes perfect
  193. Check out my coil relocation !!!
  194. My DIY C6 mani turbo kit
  195. Synchronic Wastegate
  196. 230/236 comp
  197. RMT t-70 awesome on 3-5 ehh in 1-2
  198. Help
  199. Is anyone using Granatelli zero ohm wires
  200. Best starting point
  201. Turbo or Supercharged
  202. Got a turbo M6, I want a choppy cam
  203. i need pics of how the ptk kit runs on the drivers side
  204. Looking for a manual for an innovative msbc-1
  205. procharger or big turbo for my lt1 m6 car
  206. Max Boost on a LQ4???
  207. Rev Limiter? What do you use?
  208. gen tt f-body guys
  209. Gt67
  210. Looking for a oil drain flange for a pt88
  211. About to order some stuff and wanted to know...
  212. Finally releasing our Idler pulley for Super Chargers
  213. FI engine build (800 HP), required.
  214. Finally got an intercooler
  215. Been a while since my last update...FI98X turbo build
  216. Changed mind on the corsa idea!!
  217. What gears for F1A 355
  218. aps and ams 500 controller
  219. Belt Size: 8 Rib, D1SC, 3.7" Pulley
  220. best buy turbo kit for 2002 LS1 Z28?
  221. Should i bump up the boost?
  222. First time FI, have a question
  223. Cog pulleys
  224. Intercooler piping
  225. What size waste gate is good for me?
  226. My Home made true dual exhaust on APS kit
  227. Should i totally delete my PVC on my APS?
  228. CME or Corsa on my APS Camaro?
  229. what gauges for turbo setup?
  230. Y2K'S ON ls1'S ????
  231. manifolds
  232. Which pusher fans should i buy for turbo setup?
  233. what head gasket to go with?
  234. just got my cam specs for my 402 ls2 turbo
  235. Xylene Plus Mystery Oil in Gas?
  236. Sts turbo kit LT1 questions
  237. Open vs Closed bypass...whats the difference?
  238. building first FI engine
  239. Whats the most(FI)power made with an LSI Intake?
  240. LS2/402/AFR unported heads w/ProCharger F-1A = over 400 ft lbs of torque at 2300 rpm
  241. i think i popped #7, leakdown results inside
  242. twin turboing my 99 corvette
  243. LT1 PCV... what do you F.I. guys do to keep it from popping out under boost?
  244. Countdown has begun :)
  245. Intercooler Question?
  246. had a problem with sts kit today on a drive
  247. Alfred's car... High mounted 101mm
  248. Engine build suggestions
  249. for everyone running f1a's and over 800rwhp. what fuel system are you running?
  250. FI vs. N20
