- Hooking up aftermarket tach
- Timing Tricker Question
- question....
- LS1 edit read files
- LS1-edit Tuning Suggestions
- running lean...why?
- Best Rev Limit for stock T\A LS1
- Need help fast!! huge problem.
- Paging NoGo, WTF?
- htpp111 wast of money???
- AutoTap will not connect (that's a new one right)
- 5.3 L heads.....11:1 CR.....What timing is everyone running?
- Made a few WOT runs with a Tech II today - feedback please
- Questions for EFI Live...im a new user...
- Cam Tuning With MAFT on a Dyno with Wideband
- New Autotap version 2.04!
- My ABS/INOP and E-Brake Lights won't go off
- p0172 p0175 codes
- cheap way to pull timing???
- Diagnostics Port not working????
- Fuel Trim question
- LS1Edit Wizards, simple question...
- How does this data look? New to predator.
- predator owners enter please,
- PROBLEM WITH MY BOYS MUSTANG
- changing WOT PE table for ATI P-1SC
- how long to flash
- PACE MAF? Screen or De-screened
- Drilling a bypass hole in the thermostate?
- Disable CAGS with LS1 Edit?
- Can't get EFILive to connect to vehicle
- SES code translator on this page does not work
- injector offset question again
- a/f ratio leaner in lower gears?
- TH400 is in, tuning questions
- Having problems with connecting to autotap
- Traction Control and The Dyno
- What are the limits of ls1edit horsepower wise?
- Problem with Idle after Converter install.
- uhhhh?????
- temp gage-timing retard
- LS1 gurus needed!!!!
- 160* thermo?
- Autotap for DOS
- how bad is it
- Pin # of 12 volt air-cond. input?
- New w/ ls1edit..first ?? Cat Overtemp
- Stupid question- do our cars have a factory rev. limiter?
- How do I look at diff. cells
- Why are my IAC counts always at 0???
- New headers, SES light??
- changes to your MAF
- NEW AT PREDTOR PROGRAMMING
- shift points with hpp3 and rev limiter
- Could a MAFT pass the sniffer?
- Major loss of HP at dyno
- Rev Limiter
- Need help with light throttle sputter.
- Throttle Position Sensor and WOT
- this damn "service engine soon" light...?
- Heater Circuit
- MAF question
- shift kit
- Will this Laptop support Atap & Edit??
- Do LS1's run lean with !maf screen?
- How to get big cam to idle in A4 with stock tune?
- What is the difference between LTFT banks 1 & 2
- tr224-a4 shift rpm?
- Which one HPP3 or Diablo?
- Please, help with adding fuel.
- Getting rid of the EGR SES light without LS1 EDIT.
- can predator be unlocked from my car??
- P0102 MAF Sensor Circuit Low Frequency ?
- Hot to determine what the gm/cyl is with Aututap?
- what fuel tables to use for larger injectors??
- Disabling VATs and security system
- How difficult is HPPT3 to use?
- laptop cutoff in middle of programming pcm
- P0332 Trouble Code
- Autotap & EFI Live Pro - example of data file needed
- Tranfering MAFT WOT settings to Edit?
- What Fuel Trim Cells To Average In AutoTap
- Questions reqarding A/F determination (Autotap v. wideband A/F meter)
- maft translator question
- Part throttle tuning
- EFI Live question (registration)
- DTC P0420? malfunction in cat?
- Have Idea, LS1edit Cags mod prevent 3rd to 2nd misshift
- SES Light + Engine Noise
- Almost ready
- O2 Sensor and O2 Sensor Heater Codes and SES Light
- Big fat thumbs up for the MAFT
- What are the MAFT differences in versions?
- Does anyone know anything about FAST engine managment
- DTC's P0405 Whats up here
- temp. gauge acting up
- Timing gurus inside for 01- 02?
- What is code P0135?
- PASS Key issues (car won't start)
- Which of these laptops for Autotap and PCM tuning?
- Can anyone read an 02 truck file and export it o Excel for me?
- question about efilive
- is this possible? To flash pcm out of the car?
- Low octane map for bad gas?
- Need PCM help. Explanation within.
- Did I damage the PCM?
- SO CAL GUYS - GP FOR LS1 EDIT TUNING!
- cags/diablo
- Wierd PCM issue, looking for info
- Need alternative shift light hookup feed!
- Blank PCM
- has any body figured out the high idle problem?
- predator&cam
- Group purchase on Predator
- dyno tuning near tampa
- Car too lean. MAFT?
- Troublecode 1416....help please
- EFILIVE OR AUTOTAP ?
- Max. Pressure and Volume for 98 Vette Fuel Rail???
- Need help tuning a 98 M6 car with cam
- EGR and AIR delete?
- Atap logging problems.
- CAGS and reverse lockout plugs swapped!!!!
- Service Vehicle light????
- Compatibility between 00 and 02 program??
- Can I use a 00 computer in my 99 ?
- MAFT
- Woodbridge Dynotech, anyone know anything about them?
- NC or SC Autotap anyone
- ETC problems need help
- P107 low map input voltage??
- hot start problem - how / where to adjust??
- What the hell did I do? Help!
- What is Burst Knock?
- service engine soon?
- What should my injectors be set at at engin start up
- Need help with Yank TC shudder and EDIT tables to fix it.
- AIR System, Bank 1
- Question for Camaroholic
- Timing Tuner and other such products. Are they reliable??
- Do you set P0155 and/or P0135? If so how often, and what headers do you have?
- ASR shuts itself off
- My Engine Sensor fuse blew twice in less than 200 miles; need help to diagnose :(
- Battery HELP !!!!!
- 85mm MAF cable
- how much timing for 8psi and 35shot?
- Service engine soon light???
- a/f ratio tuning based on load/gear
- Possible to disable TCS via Edit??
- 160* stat-under 210* temps?
- MAFT Tuning (Problem?)
- how to get my new 422 to idle ??
- dyno results: opinions please.
- '03 Z06 - 383RWHP - will tuning help?
- Would resetting the computer...
- Tech II Device Needed for Camshaft Position Sensor Relearn??
- How Do I Perform a Crankshaft Sensor Relearn Procedure?
- Speedometer correction -- front or rear tires?
- 11.4 A/F ratio at WOT?
- Help...Jimmy wont start
- Adjusting timing tables to 98 spec on an 02
- opinion of dyno results
- What's Wrong With a Little Pinging?
- Dyno results. 2000 WS6 M6 w/Macs
- EFI Live and ATAP PID's
- Need Help with idleing problem
- Autotap O2 sim readings
- LS1 edit
- HELP with misfire!!!!!
- LS1 edit WOT tuning?
- hyPERTECH SETTINGS
- Car is too lean. What to do?
- SES code page
- Atlanta Area PCM help
- A4 Shift points/rev limiter with 3.73s (hpp3)
- 160* stat and HPP3
- Anyone Selling the Hypertech??
- Destroyed blue connector on PCM!!!! (long)
- wide band 02
- Question about Custom Edit tuning + MAFT
- i need help bad!!
- Idle surge since tc installed
- Tuning with the Timing Tuner....
- Do I still need my HPP3 if I get custom tuned at MTI?
- Aftermarket MAF??
- AutoTap questions
- Help with tach wire
- NOT READY status for state inspection -- need help!!!!
- Quick question about ASR
- Shift Light
- MAF Translator
- Would you adjust the MAF table any more?
- WOT Voltage
- Do you have to disconnect the MAFT when resetting the pcm?
- fluids, oils, and filters what do you guys use.
- How much total timing?
- SES light but no code thrown wtf?
- What should your A/F Ratio be at WOT?
- Where do I get LS1edit?
- How will my car run?
- I need to find a POWERBAND dealer ASAP, can anyone help me??
- LS1 tech? Is there a book or video?
- LS1
- Need a stock 2001 LS1 A4 edit file please.
- ls1edit/idle question, not cam related :)
- What does it all mean? ATAP #s
- I need help with starting and idle?
- How to tune Cam with LS1 Edit?
- Secondary Air Injection Malfunction??
- SES light came on the went off
- How hard will it be to get a 228/228 .588/.588 112 cam to idle?
- programmers
- bad sensior?
- Any APEXi, real-time data displays for LS1?
- How to check air/fuel ratio via Autotap?
- Predator??????
- TCI tranny controller???
- who makes the MAF translator?
- Anyone local with ls1edit??
- MAF sensor - ported or not
- need original files to set up my ls1edit
- LS1 Edit can elim rear O2's and EGR?
- Guage help please !!
- Emissions checked on the computer?
- How can you tell if the PCM is running the low octane program?
- need ls1 edid program files for 2000 camaro
- Anyone ever had an ASP Underdrive Pulley go bad??
- How to contact ls1edit crew?
- What does disabling AIR actually do?
- Help... Idle in "R" surges
- What can cure the shifting lag in an A4?
- Question about Injector Offset Table in LS1-Edit
- A/F gauge install
- Idle Help with 112 LSA Cam in A4
- Secondary AIR injection malfuction
- Knock sensor
- shift points with 28" tire/4.30 gear
- Can someone link me to LS1 edit instructions?
- Question about uploading a tune..
- Tuning a stock LS1 a waste of time???
- Adjusting LTERM's w/LS1-Edit
- Possible tranny/tuning problems?
- Bank 1 O2 readings way off, & LTRIMS won't move from 0
