View Full Version : Forced Induction
- Turbo manifold that clears stock steering shaft
- Connecting rod orientation
- Ceramic coating inside old dirty manifolds
- LS2 Throttle Body to LS1 Adpater
- Need help for P1SC
- Best price on a turbo k member
- alky control users: pump location on 99 camaro
- Pics request ebay forward facing turbo headers!
- Huron V2 A/c kit
- Cam opinions for S/C LS6
- Best factory motor for boost
- Meth Injection Control MS3/pro vs. Alkycontrol
- Attention CHEAP Fbody owners. Ebay turbo kit success story.
- Down sizing intercooler while increasing power to help engine cooling
- Turbo Nova
- Foxbody turbo
- Ddnspider's D1SC Build Thread- Screw Turbo's!!!
- Twin GT35 remote on AMC Hornet issues
- 6.0L Twin's Turbo and cam advice
- Turbo or procharger
- Rotella t6 changed formulas
- Vs/on 3 88/83 any results?
- '96 lsx Camaro 370/s480 Build
- Anyone using a single BW S369SXE ?!
- What are you guys doing to measure back pressure?
- Trim Ring or Grommet for 3" charge pipe passing thru inner fender panel?
- Sensor/Bung Locations for Hot/Cold Piping?
- Hot pipe question
- Huron Speed V3 GROUP PURCHASE Sale! BIGGEST SALE OF THE YEAR!!!
- Lots of cool go fast parts....no motivation to install them.
- Wiring the CS130 style alternator.....?
- Rod bearing clearance
- Would you guys run this turbo like this??????????? Billet s480 Race Cover
- Need help, which route to take on turbo lq4 6.0
- Looking for RDS blower spacer feedback
- Water meth spray ring on compressor outlet
- 06 Silverado 4.8 f1 procharger or lsa conversation?
- C5 corvette lq9 turbo build need recommendations
- Drain line really short and easy.
- Manual Trans IRS Sedan, 5.3 Turbo: 9.25 @ 154mph!!!
- super cheap turbo 5.3 dodge aspen
- Dorman ls6 replacement intake
- lm7+turbo use 317s? or use my TSP 5.3s?
- Looking for some installed pictures on Huron Speed V2 a/c turbo kit
- Gen 4 4.8 turbo sizing
- LY6 On3 Turbo Question!
- lc9 turbo combo.....
- Best ls turbo Intake
- compression for a twin turbo 427ci 6 bolt LSX build
- Rear main seal leaking (round two)
- Mightan
- TV7101 exhaust housing options
- Boosted solutions BOV?
- carbed lq4 is built, now which direction to go for boost
- turbo and nitrous users
- 10% off all billet products CBM Motorsports
- 5.3 T56 Turbo Choice
- Procharger pulleys
- Bumper mount/forward facing turbo guys PICTURES PLEASE
- New build. Turbo recommendation help
- Ls2 cam with 4.8
- PTE billet 7675 or PT88 for my setup?
- Will this air filter be ok?
- Can wrong offsets for map cause erratic idle
- Zr1 map wiring?
- Deposits inside exhaust manifolds?
- T series 7875 or borg warner s400 series
- F1a-94
- Turbo layout led to small radiator, opinions please.
- high Torque build for 408
- Head gasket for high boost
- How much power on LS3/L92 heads
- ptv l92 question?
- Which injector for Microsquirt E85 1520psi boost LS?
- Vs racing phone number
- Rick crawford
- Turbonetics new turbos
- Best ARP head stud for boost?
- Vs 78/75 mounting position
- Blew a charge pipe coupler in half!!
- 1/8 or 1/4 npt tap block off plate? Turbo takes 4an
- Twin ebay turbos
- Worth going from 83mm 1.25 ar to 87mm wheel?
- 6.0 lq4 or 6.2 Ls3 short with an Lsa headed turbo motor ?
- Magnuson IAT Relocation
- Trying to decide on an intake manifold...
- LQ9 Turbo question
- Question on intake/tb setup
- Cold side removal to run N/A
- How to build a Hobbs switch wiring harness from a Racetronix hotwire kit.
- what gate size with chinese billet 78/75
- Huron Speed ~NEW~ V3 Line-up of Turbo Kits RELEASED!
- Truck manifold & crossover pipe . What's to big?
- Where to buy PT67mm tubos?
- borg cast vs billit spool .
- Turbo for 5.3
- Waste Gate and Boost Control Strategy - Discussion
- ATI Super Pulley 45tooth- Diameter?
- RPM Black Friday/Cyber Monday Sale 10% EVERYTHING!!
- 2" piping too small?
- Idle vacuum on 5.3 with Stage 2 turbo cam
- twin turbo air research t04
- 3.08 or 3.42's?
- Simple 5.3 build, which turbo
- 7 sec CTSV
- 4005 LB *Manual Trans, *IRS, *Sedan 5.3 *Turbo: 9.57 @ 145.3 Mph
- Whipple 4.5L information
- good turbo for 416ci motor for 1000whp
- 93 Fox Body Notch Twin turbo Street Car
- 2 bar map sensor issues
- 408 stroker procharger
- Limited balancer space supercharger options?
- Tig welding formed collectors to primaries
- Cam guru's wanted
- Help with 4" down pipe
- The never ending quest....
- Recommendations on turbo supplier
- on3 front mount ls1 w/ A/C and factory radiator in a 93 firebird
- Exhaust size off TC78
- PTE CEA 7675 too small for 6.0 ?????
- 2016 WCF Qualifier video with data overlay; 7.12/194mph
- Switch to 243 heads or keep 317s?? Up compression worth it?
- Who Sells A Twin 450 fuel pump?
- 1 5/8" or 1 3/4" headers?
- Tune Feedback 4.8 S475
- Stock 5.3 internal turbo guys, post here. Longevity thread.
- F1D vs D1SC ?
- Opinions on mystery engine noise UPDATE
- Tis the reason I want an automatic (footage I took today)
- Will an LS3 Intake fit my LQ4 with 243 heads?
- Matt Happle
- Making the switch.... Turbonetics to On3
- 55 degrees...PERFECT turbo car weather!!
- Looking for help selecting turbo/turbos
- 2000 camaro turbo build, 9 or 10 second build??
- In need of tuner in SE PA, NJ, DE
- Need different ideas for bov/wg/bc routing
- wiring advice needed
- On3 billet 84 thoughts
- 240Z LS3, 8 second turbo build.
- Silverado and supercharger
- Turbo clocking questions
- Any mid-level power guys (750-800rwhp) using a Th350?
- Feed and return all in one..?
- 99 c5. What cam with A&A vortech kit? S trim
- 4.8 w/317s Timing Advice - Plug pics
- MS3 releases CO2 boost control
- holley HP or factory ecu
- 79 Malibu first time track (Videos)
- Fuel system winter upgrades
- LSA Blower and Turbo?!
- Turbo Trans Am purchase opinions
- 408 cam in 427LSX Block
- cam any good.
- Haven't seen this style FMIC used, what do you think?
- Routing oval exhaust under k member.......???
- ls turbo kit on3 performance
- No boost no rpm no bueno
- IAT "anti-lag" switch, looking for pointers, HPTuners user.
- Astor Bracket
- Callie's Dragon slayer crank......
- SBE Record 7.92 and still going!!!
- Pulled the trigger: Mild H/C to street turbo set up (3rd gen) - 6.9@101mph
- Upgrading my setup, how big and what turbos should I go with?
- Boost question as it relates to cubic inches.....
- Twin Turbo 33 pickup
- Plastic intake and boost
- D1SC to F1? for my Silverado
- got a new personal best... 8.86 @ 156
- Need some ideas to fix a broken ls6 intake(back part) for boost
- ball bearing vs. journal bearing turbo spool time
- idle and PCV question
- LQ4/6.0 Build Turbo questions
- On3 intercooler
- Fresh Build. Help with high MATs!!! Air/Water/Ice Intercooler
- Sexy arctic white Turbo Ws6 at the track video!
- T4 to vband elbow/adapter w. waste gate pipe
- Hopefully this helps my low powerband issue
- Truck intake-injector conn. removal
- AD244 Case Alternator and Procharger?
- Turbo rebuild recommendations
- Is the 100mm turbine available yet for the borg warner turbo?
- S400 slip discharge
- Need advice on motor build please!
- Turbo ls1 tailpipe smoke between shifts.
- Need help with twin turbo selection
- Twin Billet S369 SXE ??
- block hugger headers
- AFR goes real fat after hot...why?
- 01 ws6 huron turbo kit questions
- Catch can for rear mount turbo setup
- dont shoot!!.....pcv question...
- Turbo size
- Big thanks to TJ and Baker eng.
- Wiseco GFX ring gaps help
- 2011 chevy silverado 5.3 w/ vortech v2
- AFR vs valve float question
- Huron Speed Twin Turbo Corvette - 427 LSX Twin, 68/70 Precisions
- Turbo LSX "Work Truck"
- LSA S.C. on LQ4 or LS3
- Went 6.88 with 76mm Forced Induction Turbos
- A little goofing off today (vids inside)
- Interesting cam timing observation
- Stock LS1 turbo ideas
- BD-11a needs rebuilt.
- First passes in a year
- BEI Shop Truck 10.7@127
- L33 Silverado ECSB 4wd, Stock 4l60E, S366 Single, 400-450whp
- sts, procharger or what?? stock ls1
- Twins on SBE LQ9 - BWS366's, ON3 70's, ??
- What gear for a turbo car?
- t88-33d single turbo spool on stock 5.3
- Retarding timing for building boost at the line?
- 4.8 Chevy Cylinder head question in 2006 van?
- Lm7 5.3 single turbo noob questions
- O2 sensor locations
- L92 and boost
- Holley efi 3 ports...
- Closed loop boost control table
- Maybe FiTech learned LS engines matter? :)
- 427 LS7 whipple charged build questions?
- Diameter Transitioning, Hotside
- MPT70 on LQ4, worth it?
- What thermostat for turbo motor???
- Upgrading an on3 kit to a T6 8Xmm turbo
- treadstone intercooler help!!
- ebay t72 or on3 t70 for twin 4.8
- Looking for a decent on3 writeup?
- Air to water vs air to air
- Which of these Turbo 5.3 cams would you choose and why?
- BMW e30 LM7 Singleturbo
- Thinking about doing twins
- What pistons yall running for boost?
- on3 78/75 5.3 new build track times.
- Downpipe sizing (twin sxe s369)
- LT4 Short Block for Boost Proper Build?
- FINALLY hitting the Dyno, Tune Advice Please, 370/S480/E85
- Water cooling turbos
- Turbo Bird
- Turbo Cam vs Current Cam
- Microsquirt/Megasquirt people please help
- ATI D1 SC blow off valve
- Twin GTP38's on a LM7
- Radiator and fan options with an on3 kit
- best location for backpressure sensor
- Ls1 Iroc Swapping to Turbo - billet 78/75 and A/W
- EBay/ off-brand turbos
- Type of turbo? Questions about it??
- Anyone running twins on stock 5.3?
- Are my cylinder heads hurting my power?
