View Full Version : Conversions & Swaps
- 97 vette LS1 swap. need help
- Carb'd Intakes
- LS engine in 240SX
- Oil Pan For A 6.0 Iron Block
- Computer and fuse box location
- VSS- 4L60E (LT1 style) sender mated to LS1 pcm
- question for ls1 carb guys!!
- LS1 Computers
- Speartech announces LS2/LS7 58X harness for automatics!
- ls1 harness on ls2 engine , engine not starting !!
- ls1 in a 97 lt1 car
- More pics of my LS1 Coupe.
- What is the stock LS1 engine angle?
- lsx t56 crossmember for s10
- LS1 into 2nd Gen TA NEED HELP FAST!!!
- Question for the mustang guys
- After market gauges in 2nd gen T/A
- s10 ls1 front brakes question?
- LS1 intake on a 5.3l
- 4th gen tank in 3rd gen car
- So here's the game plan 00 Mustang + LSx + huge turbo :)
- LS-1 In A Boat........
- auto temperature control
- FS: LS1 S&P headers & ATS T56 x-member for 1st gen Camaro/Firebird
- 6.0 lq4 in a 2000 camaro help
- T56 swap ? for my mustang
- Oilpan Comparison and Part Numbers
- Cranked up the LS1 notch over the weekend!!!! WOW!
- 350 in a 240 s14
- temp sender thread sealer ques.
- 2nd gen ls1 camaro
- Gas pedal for a 70 Nova w/a 5.3 4L60E swap
- Ls1 -s-10
- LS1 Dimensions
- Hummer H3 swap
- Took Frankn7 out for a spin
- To vent or not to vent
- Anyone need a C5 oilpan?
- Looking at this local 69 camaro for LS1 swap, whats it worth?
- ls1 s10
- ls6 in 1996 vette
- PCM A/C Fan question
- LS2 (Corvette or CTS-V) Oilpan dimensions in and out
- Throttle pedal and cable - 1st gen Camaro
- Best oil pan for 99-04 mustang with decent ground clearance
- LS1 to '85 Transam (V6)
- range rover swap
- LS engine in 2000 Silverado
- 1929 Model A with "LS1"
- Selling my 94 LS1 Mustang
- Conversion forum specifics/vehicle platform request
- i need help
- looking for headers for an 65 chevelle Ls1 swap car
- Anyone with an LT1 in a 69 Camaro? any websites?
- C3 T56 ???
- M12x1.5 male and 5/8-18 unf female fitting
- Pics of my LS6 into '90 Silverado progress
- 87 Trans AM LS1 swap video
- Question regarding LS1 adapter plates
- Need some help with 1978 Jeep CJ7 engine swap.
- gm pcm?
- gathering parts for an LSx swap in the 91....
- tow/haul/wiring
- Thinking about LS1 Swap into 81' Vette : Performance and MPG questions
- Help-going carb & want to keep my 6spd---AutoMeter Speedo Q?
- LS6 Supra
- new 6.0l in a 68 chevelle
- W2W Powertrain Heretic
- Headers for G-bodies
- 99-04 Mustang: LS1 swap which K member
- 68 LeMans
- ls1swap into a 2nd gen t/a
- Fuel Pressure Regulator
- Chevelle front springs
- LS1 block bellhousing pattern dimensions needed for adapter
- LS1 Mustang questions....
- '69 chevelle lq9 exhaust Q
- Porsche boxster ls1 swap???
- 02 C5 Corvette LS1 and Suspesnion in a 427 Cobra
- oil pan for 65 chevelle 02ls1 truck mtr needed
- 5.3 LH6 in a BMW 535iS--video link
- Carbed or EFI timing
- 95 Cavalier LS1???
- stupid coolent questions
- how much?
- Hunting/camping rig.
- LS1 truck, hybrid or just a swap?
- SUPER NOISY Walbro 255 INLINE pump, need to QUIETEN
- Clutch master cylinder bracket
- 6.2L VVT in GTO?
- Cadillac LS6 swap
- ls1 s10 supercharged???????????
- Anybody have a harness?
- LS2 4l65e what shifter?
- Ls1 in a 61 vette
- Front sump oil pan
- ECM connector part number
- Drive by wire + 98 harness
- swapping from truck to fbody oil pan
- oil pressure gauge sender hookup issue - 5.3
- ls1 intake on 4.8l
- Hey guys i think i might get a free 90 RX7!!! ITs LT1 time
- donor car, what do you think
- In-tank or In-line? 68 Camaro
- 350 turbo
- any where close to south carolina to have vats removed from computer?
- Engine frame bracket
- 5.3 on test stand
- Part #'s for swap...
- Datsun 240-Z Motor Mounts
- 6.0 in a jeep
- 5.3L El Camino Burnout video
- 56 Chevy & LS1->Wiring the harness->torque conv. disengagement
- Modified CTS-V oil pan
- LS-7 Dry Sump tank placement
- Took it for a ride
- Get rid of all existing wire when doing the swap?
- ImpalaSS LS1 conversion
- Lsx-lx....
- Location of oil pickup in pan
- 5000 lb conversion, what motor???
- fuel fitting mystery
- My LS1 Xcab S10....many pics!
- cad
- LQ9 in 98 Camaro
- LS2 manifold pipe connections
- lt1 in a 85 iroc
- chevy motor in mustang frame
- 5.3L 4L60E Swap Question PNP Switch Needed?
- please someone help me out with this question
- ls1 starter
- LSX into LT1
- My early Christmas Present for myself....
- wireing harness price????
- Flipped Truck manifolds in a G-body?
- 93+ RX-7... LS1 swap rear subframe
- 70 Chevelle SS
- Ls6 Engine Kit For 01 Z28
- 4L60E - Tail housing - Torque Arm Mount??? C4
- What do you guys think of these low cost setups for making factory harnesses work?
- FS: LS1 Conversion motor/tranny mount for 2nd gen RX7
- Here is my malibu wagon
- my 81 notch LSx swap project...
- Any LT1 G-bodys here??
- HEY 1st Gen Camaro LSx guys
- ls1 in a cadillac catera
- Sell me on an LSX
- LS7 in Third Gen Camaro
- Alternator help
- ls2
- Fuel injected or carburated in my 90 notch?
- Help with conversion
- Pics of the ol "ROCK"
- What to do with cannister purge solenoid?
- Finally fired up the AC Cobra
- Suspension / Chassis deisgns...
- A couple pics from my LS1 Wrangler project
- Can a driveshaft be lenghtened ?
- 1st Gen Camaro + Truck Accessories?
- What LT headers are you running?
- cold air for LSx in a 69
- 2nd gen F-body cruise
- American Touring Specailties is hiring!
- Silverado swaps
- New here doing a ls1 240sx race car
- What Is On Your 2007 Wish List For New Products??
- Anybody have a RUNNING LS1 swap Mustang with STICK shift AND AC and EFI?
- ECM/PCM Compatibility
- Anyone know if an 02' 4l60e tranny with ls1 will work right
- 6L80e in 69
- Speedometer Surgury
- ODB2 port problem?
- ThirdGen (F-Body) Swap help
- sparkplug wires?
- For those running a carb.
- Lq9
- Bolt torque
- Almost got my LS1/T56 today dammit
- so you think you have a badazz hybrid?
- Need Help Please.. 1964-1967 Chevelles...
- LS1 & 4l60E into 81 Malibu, Need Help!!!!
- Ox-senser location...
- LQ9/LQ4 vs. LS1/LT1
- Chevelle dipstick ???'s
- 5.3 To A 6.0?
- stock ls1 hp
- Just finished LS1 swap into '97 Jeep
- LS1 Computer, Harness, Intake, Fuel Injection...
- 5.3 iron blocks bored= 5.7??
- driveline/transmission/pinion angle?
- ls1 mustang track times
- My conversion and restoration is almost done
- 6.0 Computer Needed
- LS2 into 4th gen F body?
- help! water temp running at 250*
- LS1 rack in a LT1 car...
- Zo6 wheels on 71 Chevelle
- 3rd gen rear
- RX7 loses it's soul-427 swap begins
- Dash swapping
- My LS2 Monte Lives!
- LSX in '75-79 X-Body Nova/Skylark/Omega/Phoenix
- Need some help with my LS1 Fueltank...
- My 6.0L S-10
- LS motor in an BMW E36...who has done it?
- PS Thread Pitch
- if you have swaped in a 64-65 chevelle..
- LS2 carb setup - pros and cons
- noisy motor help me ??
- Post your pics/progress '94-'98 TA/Z28 conversions
- Fbody exaust manifolds fit chevelles & A bodys
- ls1 in 72 nova need help
- 04 gto alternator wiring question
- Does anyone drag race in here
- Hood Clearance
- Whats needed for LS6 + BOP 350 turbo in T-bucket??
- Help with Speedometer and Tach, please!
- bad a$$ LS7...'07 tahoe
- Willing pay someone to come up with engine and transmission mounts for s14!!!!!
- Engine Harness from Scratch?
- Some pics of my conversion 1967 camaro
- Still having speedo issues... Interfereance?
- Twin Turbo LS1 Volvo Wagon
- 02 trailblazer I6 to 6.0L anybody
- Has anyone measure their bellhousing?
- Need pic of casting #. PLS HELP!
- any ls1 Jimmys/Blazers out there?
- Ls1 E28
- Gas Tank intake theory help
- Not sure if I'm in the right spot....
- WTB: C5 engine stands
- Throttle Cable Question
- cost of ls1
- need a VERY narrow header
- LS truck motor
- I need quick advice on a price for an LS1
- Exhaust System Welding Advice
- It woke up tonight!!!!!!!
- 4-door sleeper.
- A/C Brackets
- 98 computer problems
- Looking to hire: Experienced Fabricator/ Weldor in North Dallas area.
- 4.8L in a Jeep?
- LS1 S10 swap help needed
- LS1 into an LT1 car.
- Carbed SBC vs Carbed ls1 - miles per gallon battle
- Wiring questions
- Fox Body Swap Header & Crossmember
- newb oil pickup o-ring Q
