View Full Version : Forced Induction
- Height of CTSV supercharger and adapter plates?
- LSA blower LY6 fuel system help
- Need help: Base tune for a 6.o/80#injecs/69mm, e67 ecu/stageII ljms cam, meth inj
- Gen 2 on3 7675
- boost questions...
- MPG Thread with MS3 on a 6L LQ4 Turbo 5spd Fiero or any Boosted Car.
- tune help
- Is this the correct way to plumb the Boost Controler for twins?
- Ideas to quiet down a Big Red BOV on the street.
- 6.0 S480 Combo low power and dropping off early. Help. Please.
- Holley soleniod fill side pressure source
- Can Turbo Replicate the Feel of Natural Aspiration?
- Boosting my L92, too much cam?
- LSA with A/C??
- 1956 chevy 5.3 7875 turbo
- Anybody running a converter dump valve? Having problems after installation.
- Huron Speed twin trubo bumper exit help needed
- fitech
- l59 cam wiped out.....
- Best intake for BOOST?
- Forged, twin 61s, E85, '90 300zx just about done
- The whipple blues (finally getting somewhere...)
- EV6 to EV1 adapters
- Ls7 Intake Opinion
- Procharger d1sc retain stock ram air box
- 7.75@181 street car wheelie machine. 60 and 330 work needed.
- Changing a supercharger impeller
- 2014 ss lsa advice
- LS 368 TT Air Boat Direct Drive
- Ws6 ls1 Turbo project (s480) spooling ?
- Truck Manifold vs Edelbrock/Holley
- 6.0 vs480 t56 g35 coupe
- finally out of the 12s lol
- Sloppy base tune twin turbo 4.8
- vortech v9 brackets
- Took the car to dyno day.... not good.
- Three head choices........anyone have opinions on which is the best choice.....?
- Parameter list ls1
- LT1 BOOST question!
- Low Fuel PSI
- Billet 76/65 dual bb vs billet 69/73 sxe s369 vs Billet 78/75
- Anyone smashed -12 into the timing cover. S475 drain.
- P1SC Procharger Upgrade
- Could running Y block from fuel pump to each fuel rail, hurt flow?
- Twin gt35 5.3, couple questions regarding the ar
- Switching turbos - twin s256 to something single
- Oil pressure turbo oil feed lq4 block
- 10 second truck Project
- 6.0/80e/vs480/explorer rear dodge Dakota gold box 995whp
- Methanol Injection Nozzle Angle
- Opinions on tuning Holley dominator with standalone (alkycontrol) meth system
- Turbo Sizing LSX 427
- Stock gen 4 lq4 piston source.
- Converter locking on 4l80e causes RPM to drop and kill the car on highway
- BTR stage 4 turbo cam help
- LT4 6.2L Procharger Bracket........
- Sleeved Blocks
- Two black brackets that come with the Ebay style manual boost controller
- Maf code p0101
- looking into cam swap
- L33 Aluminium Block Power Handling
- The friendly ghost 99 z28 turbo 6.0l build and questions
- Cheapest place for 4" mandrels??
- pressure sensor in the cylinder head to see if pushing water?
- AEM Methanol Kit questions!?
- Stock twin turbo ls1
- Twin turbo exhaust note.
- what's the limit of my fuel system?
- Turbo leaking oil issue.
- Huron Speed F-body TT builds?
- Misfire at high boost and after wot pull
- 6.11@238 New LSX record.
- TT Ls or procharger bbc
- Turbo sn95 guys here! On3 fox kit on sn95!?
- Lunati voodoo rods
- Short block options
- 3" full exhaust hurtin turbo spool?
- TURBO headers SS header studs loosening...ugh
- F-body aps twin kit dkt/precision 6266 upgrade
- Fuel cut problems
- Rumor or Fact...2-Step Shortens Turbo and/or Engine Life?
- Hell yeah.. got her running! Added video :)
- 2011 LC9 for Boost?
- Dynamic Compression Ratio Turbo
- Anyone using Magnafuel boost referenced regulator?
- Happy with the cars performance today (2 new personal best) vids inside
- LS9 or LS1 headgaskets: ISO today's opinion
- cranks but wont start
- Looking for Vortech V7-ysi pictues
- help selecting twins for a 5.3
- The daily goes 6.30 @ 118.
- turbo problem
- Removable radiator support? ('bird owners please!)
- Price check for a D1SC
- 2010 camaro ss tvs 2300 looking for new personal best
- Which Gauges
- Huron speed truck turbo kit
- CAM - Stick or Twist?
- Intercooler size/cfm question
- 6sp twin turbo 5.3
- just need a confirmation before i potentially put a hole in my new oil pan for turbo
- Anyone running Sloppy stage 2 cam
- DIY supercharger
- Biggest turbo on an On3 kit ??
- 60mm HKS WG instructions?
- derale fans on a turbo car
- Whipple drive questions
- spark blowout (?) after changing plugs from TR6s->BR7EFs e85 TL;DR AT THE BOTTOM
- Opinions on this Cam??
- GT55 88 to 94...how much fuel should I add initially? Any guesses?
- Turbo Ls e85 afr and timing
- 1981 zephyr sloppy 4.8 turbo build
- Turbosmart EBC - Method 1 or Method 2??
- proper shipping methods need help
- Garrett Intercooler Core came in today
- Up goes another lq4 *video*
- Silverado Torqstorm Supercharger kit!! $3100
- Low on power
- Another oil supply and return question. On3 kit
- Boost leash issues
- Check valves?
- tbss dimensions
- Max Low-End Torque for LSA Blown Tow Vehicle
- Turbo car faster, hot off the street at the track.
- Bov vacuum line connection question
- SD Tune Help... Can't get it to start
- LSA/5.3 in OBS C1500
- Regular truck to TBSS intake
- Denmahs gt45 Irv’s racing 7875
- Cam help! Tick Stg2 LS2 turbo cam in 5.3?
- CO2 setup info
- Twin turbo water lines, any harm in restricting heater core flow?
- Gettin Belt Slip could be dirt and oil around crank area!!
- C.I for Big Single
- Lq9 twin turbo build for 77 TA
- lq9
- VSR 75mm Billet 96x88 Turbine 1.32ar T6
- Ring Choice for 5.3 Turbo LM4 - Stock Pistons
- pinning ATI Balancer
- from 4.40s to a broken Head..but a great pic...
- ls2 with Torqstorm Dyno numbers
- lsx 376 injectors
- Turbo"d now pushing oil out the valve covers help please
- 3.87@198
- Godspeed hotside
- Track day vid
- Check those spark plugs plus side gapping = wow
- Gen III Vs Gen IV Exhaust Manifold Compatibility
- Stock C5 ls1 a&a v3 ti. What pulley size and fuel system?
- those with low mount blower setups....upper radiator hose?
- Cam bering
- So, I got a "Free" Powerdyne BD-11A
- Plumbing twin turbo waste gates
- Anyone install a LSA with Holley high mount ac bracket
- F1A & 346 Questions
- eBay FMIC
- Fuel system set up
- Need some Help A/R Hot side sizing - Turbo Updated on Page 2
- Boost controller vacuum routing for twins?
- Procharger sdce belt alignment
- Dyno numbers are in!
- Best Ls1 engine setup for a "street legal" car
- Calling all turbo daily drivers
- On3 Non AC kit questions Chime in please
- Running vacuum manifold to multiple sources, BOV, gauge, transmission
- RELIABILITY,Me No Wants a Blow Up
- How far will this Charger go?
- First Day Out 1.119 60ft 4.49 158.50 in x275 trim..Video also..
- School me on my turbo boost issues
- Gears....
- Oil catch can idea
- Heads, TFS, Mast, PRC, AFR, Edelbrock, other ?
- are these gen 4 rods in my 5.3?
- Lq4 setup revision time for twins
- New personal best (vid)
- nitrous plate for meth injection?
- Huron speed V3 T6 missing part and clearance issue
- sanity check for timing? LY6, s480, pump gas
- 4032 and 2618 Pistons For The Street
- Anyone know this car?
- Pipe with Procharger BOV flange already welded
- lsx 376
- 4.8 or 5.3 with a procharger , anyone?
- Maggie on an LS3
- Supercharger vs Turbocharger on a 99 TA LS| Auto Trans
- Where to pickup a T-bolt clamp SW Houston
- LS2 LQ9 compound turbo upgrade
- Turbo advise on built 6.030. Thanks
- AEM Wideband Install
- Low Boost Turbo - What Spark Plugs?
- VS Racing 7875 - Restrictor Needed?
- Suggestions for SC for 417ci LS3
- E85 2006 Truck 6.0 Fuel System for LSA <10lbs boost with OE parts possible?
- Huron speed TT kit and UMI 2320 clearance?
- 30-0300 or 30-4110 AEM wideband?
- Turbo LS1 w/ LS6 valley cover PCV install
- So I changed my fuel filter.....
- Torquer v2 with boost?
- Holley tune for 5.3 with S480
- Building Spare turbo motor, cam help
- Turbonetics T4 turbine housing vs Mid-frame T4 housing
- [VR] H/C/I/P 6th Gen ZL1 makes 716rwhp!!!!
- [VR] Bolt On 6th Gen ZL1 makes 692rwhp!!!
- Map sensor help
- Standard bore 5.3 rings?
- 3 bar map question
- motor is in... video of 2 step , 88mm, 2000 hp, sounds amazing
- ProMod chassis and a stock LS1?
- Help w/ Choosing PCM Controller
- Lsx turbo o2 signal modifier
- Turbo recommendation
- Stripped
- Apparently I'm retarded! Can't control boost???
- Piston & rod combo in LS9 blown L92 block
- F1R on 2002 fbody question.
- Microsquirt with 210 injectors
- pushing coolant
- 2008 C6 Z06 YSI Build
- Pusher fans besides Derale 16925
- How much HP can these rails support.....?
- Holley or Fueltech. On 25.2 twin turbo build
- 408ci TT New Edge Mustang Project
- Turbo Discussion IN HERE
- Perfect junkyard ring gap?! vid inside
- LS3 480 -adding a Maggie, drive kit?
- 4.40s here we come..New 388 done, New 12.5 wide custom wheels done!!!
- Procharger rebuild Questions and Aftermarket Impeller.
- Pressurized coolant quandary
- People running F1a-94 with aster bracket in F-body
- lq9 : ported 317 or L92 cam selection for FI
- boostin the trans am
- Snail's Pace 1500HP Iron Insanity 4.8L Build
- Vsr or on3??
- New Records
- Best block to build a boosted motor
- Compression Ratio.....
- Boosted 5.3 Options
- Twin s366 on a C5Z 370 or 408
- Modular LSX Turbo Manifolds
- $20 DIY bump box
- Yo my EE homies I need a lil help
- 99 Formula LSA build
- Another VS racing vs Borg thread
- [VR] 416ci 5th Gen Camaro SS w/ D1-X makes 838rwhp and 688rwtq!!!!!
- Spark plug reading gurus
- Looking for used Turbo / Cam and other L33 parts
- On3 78/75 or VS racing 78/75?
- LSA SC'er accessory drive pulley system......on an LQ9 engine.....anyone done it?
- Water pumps?
