View Full Version : LT1-LT4 Modifications
- ls1 air lid on caprice classic 94 lt1
- Head Gasket Required. Anything else?
- 1997 LT1 Camaro Won't Idle - Could It Be EGR Valve/Solenoid Line?
- Project Minwage (Picture heavy)
- Need help building a 350-400hp lt1
- Higher than normal idle after cam swap
- Oil leak under load
- which is better for programming software?
- Need help on pcv/ccv problem on 95 z28
- Can Someone Look Under Their Hood and Let Me Know How These Go Please?
- What happened to the TSP longtubes for 93-97 fbodys?
- best clutch for 6speed camaro??
- Lubing new cam.
- Jumping RPMs
- Lt1 not staying cranked
- Error trying to flash PCM (pic)
- Procharged 396 LTX (ellwein engine)
- Bent PS lower rear shock tab, what to do?
- What damper is everyone using?
- Racetronix AIR pump wiring kit
- 94 caprice classic wagon LT1
- quick help and suggestions needed
- 24x shift light
- Lt1 issue. Need help
- Another lt1 build on a budget...
- Starting Issues
- throttle body hole
- LT4 a/c bypass/delete
- 94 lt1 key on chime
- Rich at Idle/Low RPM - Fuel Pressure Regulator?
- Piston ring gap for forced induction
- Parking BRAKE light staying on...Fix
- Power loss after one pull
- arp main bolts
- converter size
- LT1 copper header gasket
- Best head, intake, timing gasket?
- Best Deal on New Front Brake Rotors
- Lifting engine by jacking up by the oil pan--what am I missing?
- Max compression ratio on 93?
- Z28 SS need help
- Roll fenders or nah with 315s on 17x11?
- Lt1 car that is shade proof. (I do not own this car)
- Green Dragon Burnin Rubber
- Hot Cam rockers
- 93 LT1 no start, possibly opti?
- 93 trans am wont start!!!
- 1995 Camaro Z28 5.7L V8 dies on me at stop???
- Maybe my fuel pump?
- Need Help on LT1 Camaro Z28
- spark retard need help
- Turn signal lever issues (FIXED!)
- Starter failure
- what other factory radios fit in 95 camaro?
- Anyone in NOVA have a spare tire and Jack for sale?
- 97 SS with 13K miles
- Spectra 1486 Radiator Help
- IAC, idle to high.
- GM 1.6 rr's with cc305
- Tire and rim setup for firebird
- wiring harness
- Fiero/Jeep Slave Cylinder on LT1 T56
- Heads worth?
- Meziere ewp or summit?
- lt4 Knock Module
- New heads, cam & valvetrain. Now checking PR length...Solid lifter?
- Mystery oil leak
- Mystery oil leak
- Lt1 misfire backfire
- Lt1 heads question
- TRE fuel pump
- Torque specs for rockers and intake - 94 Trans Am
- 24x Install - Tuning on 93-97 car.
- LT1 install question
- Overheating problem...
- '95 LT1 won't start
- Help Trouble shooting Please
- can a 94 motor/opti work in my 95 Trans Am.
- Lunati 73925k5 spring kit
- What piston rings would i need for lt1 rebuild??
- Tune/PCM swap
- Misfire and running rich
- lt1 in 98-02 v6 car?
- Please Help Me Find Parts
- First drive with the new cam and t56
- Engine Code P0303 and Oil on #3 Spark Plug (PICS INSIDE)
- What Shifter do you prefer for your T56?
- barely beating a stockish 4.6
- 1993 one wire O2 sensor question
- Check the opti next?
- Interior lights will not to turn off!!
- 94 firebird
- have experience in building race version LT1? come in
- Stock bottom end connecting rod torque to 45 lbs???
- Whats a good set heads for lt1?
- 400 horsepower
- Trans Being a PITA!!!
- CC503 has a tune
- 1994 Trans Am Revival
- CC 981 Valve Springs
- First time on 1/8 mile track
- To Shim or Not to Shim?
- Help me choose valvetrain parts
- high rpm vibration
- engine install
- Clutch and driveline question hurry...LOL
- time for the round of upgrades
- Just thought I would share my car.
- Ai 385ci stroker build street/strip
- you can carb a gen 4 camaro with both wipers
- What is a good price for ac compressor replacement?
- Aftermarket radio only sometimes works??
- What's my next mod?
- Reccomendations for Torque Convertors
- Racetronix / WB 255 and e85
- Cam question "cc305"
- First Testing w/nitrous
- Not shifting at WOT, fuel problem?
- LT1 Nightmare from hell
- * UMI* What Else For My Suspension and UMI Billet Black Sway Bushings?
- Lt1 hard start
- ObdII tuning
- part number for AC Delco battery for 1996 impala SS?
- Starter issue after conversion
- Cam bearing came out with cam!
- 93 trans am
- PCV setup with Boost questions
- Gear Oil Quick Question
- After 7 years, I have an answer for my bucking problem
- Help!
- Oil weight on a 97 lt1 (0w40?)
- away..... but NEVER gone....
- EB Porting 185cc heads For Sale
- Key Doesnt Work In Either Door
- A little initial disappointment with moroso oil pan
- White Smoke and Coolant Loss-Help Needed
- BBK 58mm TB in Classifieds
- Does nobody make off the self pistons for 5.85 rods on a 383?
- Best size drag radial for stock setup 94 z28
- Upgrade PHB from stock to 1/2" bolt
- Ls1 lid hurt performance?
- P0121 (TPS code), how do I fix it?
- Polyurethane sway bar bushings
- Looking for Tuning Advice (High Idle BLMs)
- MAF Issue
- Check These Prices For Rear End (Car Will Be Done Monday)
- Finishing up my build
- opinions on best place for a short block?
- t76 turbo m6 lt1
- Good tranny for the street/strip on lt1??
- CC503 Question
- LPE 211/219 Cam
- Lt1 low oil pressure
- Towing with a modified LT1
- turbo 355 m6 build
- v6 to lt1 swap wiring question
- Vibration. Clutch? Or engine?
- 94 lt1 smokes when revving?!??
- help with leak.
- O2 Sensor wiring - still ok?
- lt1 running rough
- Second Best Clutch for 400 RWHP?
- Would this be enough to cause high fuel trim? (pic)
- Fog Light Wiring...
- Need advice on 95 lt1. Power less with new cam
- Good cam for 94 lt1 Camaro?
- Rough Idle?
- Fuel Trim Woes...chart and data - please advise!
- Tank Neck Replacement
- Speedo Cluster isnt working.
- 96 Z28 - Kooks headers
- 1996 wreck camaro wiring questions
- Roller lifter
- removing transmission
- LT1 swap bad idea?
- Third gen trans am
- Fuel Injector Question
- Walbro 255 Lph fuel pump
- Carbed LT1, What Next????
- Bay area dyno shops????
- Need help sizing injectors
- Gauge cluster not working
- Pulled the fuel rail to check injectors and found this:
- puddle of coolant under car
- Lt1 trans am idle issue?
- High rpm power problem:Injector DC/Intake restriction?
- Pcm problem!
- Is this my fuel line Schrader valve?
- Howard's racing cams pistons
- Quick spark plug question?
- Ok fixed my boil over problem but it's still..
- Issues with tail lights/reverse lights
- LT1 Alternator Relocation
- Will this camshaft kit work with the LT1?
- Converting to E20
- Header Wrap question???
- L98,LT1 and LT4
- Cross hatch gone on thrust side. Re-hone/re-ring?
- Head Bolts Loosening
- So I Decided to Sell My AFR 210 Heads & LE LT4 Intake
- WTB 93 Fuel Rails
- Looking for Scat forged crank
- First startup....Solid Roller 396 w/Torqhead 24x
- Running Wires Into Cabin
- LT1 swap runs for few seconds, dies
- Oil Pressure Sensor Wires Cut Affecting Fuel Pressure?
- HVAC Vacuum Line Help
- Let's play a game: guess what went in my new to me cars motor :)
- Recent troubles with my LT1
- Anybody driift an F-body?
- Lt1 hesitation/screech when starting
- SES Codes and symptoms - need help!
- LT1 Boost Build Questions
- Lt1 idle issues/hesitation
- New Headers
- Loose spark plug - pic - thoughts?
- LUK clutches, how are they?
- Dropping Motor - Body Lifting Points?
- Oil leak from gasket. Can I still seal it with gasket maker?
- 24x reluctor and hub bolt info needed...
- FYI, LT1/LT4 buildup......
- OBD1 LT1 Swap to OBD2 car
- Lt1 388
- 97 Z28 long start, system lean
- Oil Analysis
- ISO LT1 Waterpump Coupler
- 1996 LT1 shut off while driving
- Random LT1 Chirp/Squeak
- t56 swap, flywheel concerns!!! URGENT
- Stock Crank 355 Build - Opinions Welcome
- need a lt1 block
- Weird misfire
- Fuel pump Issue,HELP
- baby lt1
- Which valve locks - Manley Nextek beehives
- Wheels and tires dilemma
- In search of LT1 parts
- Confirm Blown Head Gasket
- Market for forced induction LT1 bottom end?
- Lt1 383 build ebay rotating assembly advice
- magnaflow muffler is so quiet!
- Complete 1994 Trans Am Restoration
- Is this header repairable?
- Another OPTI thread.
- Cam Components Questions
- 93 lt1 turbo build
- 95 4L60E in 94 Firebird?
- Reviving my 97 Z28, Knuckles.
- Educate me on LT1 Weaknesses
- Stock injectors on 383?
