- Top speed challenge vid
- For best reliabilty, should i swap out LS6 springs for Pat. dual golds on Blown Z06?
- Which coilpacks to run for boost?
- Procharger help needed
- lq9 patriot heads..compession drop..
- any one use this for eliminating belt slip?
- Magnacharger kit on LS1
- Crankcase Evacuation Kit
- MAFless Procharger question
- Stenod Performance "Red Rocket" Update
- When is water or meth injection used??
- how far can i push the tr6's?
- Which will make more power 8.5.1 or 10.1 on pump gas and boost
- Super Chevy show TT 69'
- TURBINE housing swap?
- In need of procharger ls1 Advice
- turdblow
- turbo people....what muffler???
- Max Boost On Stock LS1 Bottom end?
- Looking for a supercharger
- D1sc
- Opinion on what to do
- 6.0 gmpp single plane and PCV
- Vortech Supercharger Problems
- silicone 90* from tb to maf housing?
- header wrap
- Air filter for Procharged F-Body?
- Sorry, question on roots/screw in an FBody
- Procharger pulley help
- NEED an Oil pump for Turbo set-up?
- Procharger
- magnacharging
- turbo question
- thinkin about the future of my build...
- what is about the most HP a stock CubicInch turbo ls1 can make on pump gas
- 98 ls1 block- is it ok for turbo apps??
- moving fuse boxes - question for you turbo guys
- blowing oil help?
- best price for T76 ?
- compressor housing?
- Misfire in #2 after boosting
- Dump after turbo
- Would I benefit from taking off....
- ???'s about custom turbo set up?
- quick turbo question
- Anyone running mac's with a procharger? or USED to at that?
- mpe racing fab anyone know anything about them
- Going FI, rebuild my 427 or get a new 402?
- Progress is made, track update...
- Can you hear your Wastegate?
- does anyone have ground zero turbo kit?
- Update on my Twin-T67, 408 Build
- Bored, thought I'd post a few pics :)
- Need to upgrade MAF?
- fmic on trans am
- Vacuum line from Bypass valve to what???
- who has my old kit???
- A2W Chargecooler... how big ??
- which fmic intercooler?
- I want budget FORCED INDUCTION! How much for 5-8psi? Procharger or STS!
- where to find hot parts
- STS plus STS EBC *?*
- Few ?'s about the LS1
- mmmm heads are shipping
- Turbo ?
- Stopped by Hi Flo today...
- Procharger oil change...
- Anyone have pics of TTI Street kit installed?
- will these truck manifolds fit a lt1?
- Wideband / Narrowband A/F
- Can I have a 60-1 convertered to a T76 compressor?
- Ok need some motor upgrading advice.
- Turbo'd Do you run coolant through your turbos?
- Is a T76 too big for my car?
- BOV differences?
- Which Would You Run?
- Mock up pics of my CAS
- 4.8/5.3 turbo idea
- Loctite when installing new crank bolt?
- What do u think feels fastest? supercharger,turbocharger or Heads/cam?
- Blower pricing
- H/C combo or FI
- SD-Concepts
- Rear Pulley Sizes on S/C Vettes
- Audi story, not LSx
- Boost Ref. cutout
- pcv for SC'd 6.0 blocks
- Boost...A/F....
- 2001 silverado 5.3 6.0 heads question.
- Where can i get a alternator relocation kit?
- Fabbed aluminum elbow noise? ..ringing
- ovaled pipe for clearance?
- ATI bracket question?
- Boost an Lt1?
- Upgraded ICs for Incon kit?
- Ati #'s 5 Psi
- ATI blow off valve
- Blow-off Valve Question
- Intercooler help...
- Is a T 70 a big turbo?
- Just ordered my WG and BOV!
- Well looking forward to being in the forced induction club soon with my 99 ta.
- supercharger torque converter
- ati pulleys
- Vortech vs. ATI for cars with stock bottom end..
- what sensor?
- turbo question or 2
- phamspeed kit help?
- Speed Inc Twin Turbo Kit - Finished Pics
- need a wye and exhaust manifold flanges for o2 z28
- GMR Kit?
- ported MAF and blower?
- How do you measure exhaust back pressure?
- NHRA and STS
- Turbo cam
- WHAT TO DO TO PCV SYSTEM 4 Boost???
- Forced induction engine and internal choices?
- guys with SC and N20
- Who sells Master Power turbos?
- sequential turbos?
- STS Turbo setup
- I have two sets of heads. Which set should i use.
- FI injector ?
- Need Help--Someone to Dynotune
- Determing how many rpm's the blower is spinning...
- Loud Screeching Noise on Startup???
- Question
- How can I lower the compression on my Cartek S2 heads for FI?
- Is he crazy or am I wrong?
- F1 pulley ???????
- Suggestions for a m6 99 blown hawk
- Which would you go with?
- Meth injection: Consistant vs. Progressive
- can i get away with this?
- Guys running the LQ9 heads...
- A few noob FI questions :)
- Will my cam work?
- New 1/4 mile best today, getting there..
- corvette master cylinder ....
- Turbo--good for FM?
- Novi 2000 Brackets?
- went to dyno friday
- 408 turbo build up?
- Single big or twins?
- WTT:wilson 105mm for a 90mm
- Testing a Fast 90 or LS6 vs Victor with FI
- ATI belt is too SMALL...HELP!!!
- Help with blower cam selection
- How far are you willing to boost?????
- Congratulations Kyle!
- My New 408 And T88 Turbo Setup Pic's Inside
- Cam question on current combo...
- Can it be done?
- Teaser pics Hi Flo Twin Turbo
- Damage Report!!
- how Much ignition Advance are you at WOT?
- ? on diamond piston
- need a mean turbo cam
- wastegate maintenance?
- where to buy aluminum pipe and silicone hose? - silicon replacement?
- ls1 edit version needed
- big cam or custom rear turbo?
- W2w Shortblock....
- why so much oil befor i hit boost??
- Cam?
- Does anybody have the part # for 3 bar map?
- Is this cam to big for a turbo?
- turbo?
- What stall w/daily driven turbo setup???
- turbo question
- What are the best heads to use for my FI car?
- new turbo toy : new gen wastegate
- Whipple 3.3L tuner kit or GT80 turbo?
- Powerdyne on a STREET only car
- supercharger price?
- Speed Inc. Custom Twin Turbo Pics!!
- Plans for the car.....questions though.
- Stock bottom end + intercooler + 6.0L heads..how much safe boost?
- Harlen: Stock crank for turbo motor, iron block? 4.7 / 5.3 / 5.7 / or 6.0?
- which is faster supercharger or turbo
- sequential twin turbo idea
- Lingenfelter or EPP???
- intercooling piping
- need some boost controller help
- Quick intake question.....
- victor intake?
- Incon exhaust, dual Bosch pumps, custom tank install pics.
- what kind of engine prep work for 900hp ls1
- Kenne bell in an fbody?
- 9.3 Compression?
- AFR's with methanol
- New Sponsor! Squires Turbo Systems
- IS IT WORTH THE REBUILD?? plz respond
- blow off valve- DONT LAUGH!
- Info on LS1 supercharger; Firehawk; ?
- Some dyno results.. newly Procharged. (pics, 56k take a nap)
- Dyno results
- Would this be a good cam for turbo?
- Procharger Reliability??
- Nitrous Jet fitting
- Corvette Forced Induction kits?
- incons meth methanol alky tests
- Alt. relocation prob, screw hitting oil filler neck *pic*
- Recommendations for a 94 Z28
- new pics of twin turbo setup
- Anyone got (or info) Turbo Technologies Street kit??
- My cam and a blower?
- SLP - LS1 F-body radiator?
- best charger??
- turbo help needed
- Big single, or twins?
- What do you guy's think of a 871 on top of a LS1?
- New Pics of "FEAR" stage 2 GN
- I'm looking for recommendations concerning my goals for FI :)
- WILL THIS REAR MOUNT work???
- Got a question for you FI guys about a race my buddy had in his z06.
- Is This A Good Deal?
- Python clamp???
- ATI balancer "Pinning" instructions...HELP!!
- Bad day for Ohio Boys Formula
- First pass bs3 datalogs...need help
- 5-in Downpipe
- Post pics of 4" down pipes
- kyle any update on the Maf T Pro
- Twin ATI Intercoolers
- What Intake Manifold for TT 370?
- Pulleys
- 408 and T88 Turbo almost done Now I need a Tuner
- what BOV and WG are you using?
- Edelbrock int & elbow pics.....opinions.
- Vortech head unit.
- Making progress on phamspeed kit
- New 1/8 mile best today
- Few TT LS1 59 Impala pics
- Procharger Question...
- New turbo kit on the market soon
- What cams are you turbo guys running?
- superchargers blow head gaskets?
- Curious if any gmr kits have reached customers yet?
- LT1 twin turbo
- Camshaft for Supercharging Poll
- Adapting a Procharger Kit
- dyno question
- Twin turbo pics!
- STS problem solved..well sort of
- First Track Day For The Turbo Formy
- t76GTS with 317 heads turbo car pics!almost there!!!!
- Mystery rev limiter
- BOV sounds?
- ProCharger Kit Parts List
