View Full Version : Forced Induction
  1. Help with turbo specs
  2. holset h1c question
  3. which turbo cam?
  4. Thinking of going turbo.....Need some Input
  5. Single feed or duel feed to the rails on turbo 6.0L for e85
  6. Need help picking turbo
  7. 5.3 LS9 gaskets and ARP bolts
  8. Need help with part selection. Turbo LQ4 build
  9. do I have to run a catch can for pcv setup?
  10. lsx 376
  11. Killed the 5.3.... pics/video inside..
  12. whats your timing table look like from spool up to max boost on a run?
  13. Ebay gt35 twins??
  14. To close to head???
  15. single or twins for a reliable bracket car
  16. AiResearch Garrett Turbo
  17. 6.0 with a 4.8 crank
  18. Throttle Body sizing
  19. Tc78 ar?
  20. rear turbo bracing options
  21. Someone school me on the Turbo + Nos setup
  22. Need cam advice, Ls7 cam in 5.3 turbo? Specs inside
  23. Has anyone maxed out an ebay gt45?
  24. A&A/Procharger/Supercharger Rebuilding in Canada
  25. On3 turbo woe's
  26. Stock Crank or Forged
  27. Rebuild on my Whipple'd forged LS3 has begun.
  28. 2nd speed inc TT LSX typhoon completed!(dyno vid)
  29. Pro Comp/KMJ head stud torque-Copper Coat Head gasket ?
  30. Turbo Headers
  31. 370 build advice needed
  32. a couple q's for you pros
  33. Good place to start on tune.
  34. What to expect from a BONE STOCK lm7 or l33 turbo on pumpgas only?
  35. Crank Selection! HELP
  36. 38MM to 44MM Adapter for wastegate?
  37. Cost of ceramic coating turbo parts. Jet hot?
  38. ebay twin 57mm third gen camaro 9.70@142mph first outing
  39. looking for nice thick heads that will fit on a small bore motor.
  40. Methanol 403 LsX -"Torque Stopper" intake 101mm Turbo - BMF Racing '87 GN 2013 build
  41. How To: Remove a 1300hp LS3 in 6 Minutes
  42. How To: Remove a 1300hp LS3 in 6 Minutes
  43. LSA ZL1 supercharger on '06 LS2 GTO
  44. Single Turbo Merge at Flange
  45. F1R procharger 4.8 build
  46. Turbo ls1. What springs?
  47. Manifolds for 1st gen Bird
  48. lq4 build in Grand National
  49. Would a 99 5.3 be a wise choice?
  50. turbo or super charger
  51. Yet another Turbo LSx Fairmont. 4.8/Borg Warner S375 Junkyard Dog (Denmah Style)
  52. WS6 S475 official build thread.......
  53. Who to talk to @ PTC Converters
  54. About to start a turbo build/build a bottom end and would like some opinions!
  55. P1SC procharged 5.3 which cam?
  56. overheating under boost only ?
  57. Good picture of my 1/8th mile Wheelstand in my IRS Corvette!
  58. ls9 cam
  59. High compression with turbo questions
  60. lsx test firing stand complete!
  61. Turbo Vs. Procharger
  62. good headstud and gasket combo?
  63. Huron speed Nov group purchase
  64. I finally got anti lag to work!
  65. weld ell manifolds
  66. Fuel pressure drops instantly right befor boost 100-105kpa!!!
  67. 5.3/micro2 mild anti lag test
  68. Hollow ls3 and inconel ly6 valves in an lsa head?
  69. question for the rear mount turbo guys
  70. Vertical radiator and pusher fan ?'s
  71. 2002 TA build: 383 ls6, s480, th400
  72. Who has an eboost street setup?
  73. Pics or LARGE FMIC on Corvette needed, plz
  74. Phenolic Spacers anyone?
  75. Headgasket Qs
  76. another 5.3 turbo build, have a few ?'s.
  77. Procharger guys... Header wrap ?
  78. Heads ok for 76mm build?
  79. ECM and Harness for Turbo 408
  80. valve cover breather mods
  81. Manual boost contrller
  82. Need an intercooler, where to buy?
  83. Anyone ever use a Tial Blow off valve for a Procharger?
  84. o2's
  85. Cam/Spray or FI?
  86. Which forced induction option.
  87. What turbo for my 390ci (T6 Flange)
  88. Victor JR setup??
  89. Lsx 6-71
  90. Turbonetics 7675
  91. TFS 245s or PRC 237s ? Kinda new to FI
  92. 5.65@124 - stock 317's, AC, pump gas, s480 towing a trailer ;)
  93. front vs rear mount turbos ?
  94. D1SC 347 forged - which Compression ?
  95. Mesh filter for procharger....
  96. Free BOV with turbo purchase!!!!! good until the end of JAN2013
  97. My ls1 Foxbody t76
  98. Piston/ Rod Suggestions for Boosted Applications
  99. Looking for some imput/direction
  100. practical downpipe limit???
  101. Procharger 5psi mph gain?
  102. Ring gap for turbo motor
  103. MP112 cam?
  104. Pontiac G8/Maggie 1900/AI ported L76 heads/Tick Custom cam
  105. Opening up the combustion chamber on ls3 style head??
  106. magnum xt80 or s475/83 both in T4... which will flow more?
  107. Another turbo selection thread...
  108. LQ4 alternator relocation bracket
  109. TTI 4th gen twin kit 777rwhp @10lb's
  110. help with turbo kit for lq4
  111. New motor fallinf on face
  112. cts-v manifolds ?
  113. Turbo help!
  114. Fuel Promblems, Turbo Camaro *NEED HELP*
  115. MD-104 BOV pic/vid/narlz
  116. Need help with wiring zr1 map
  117. Motor swap TT build - Intake manifold measurement Questions
  118. turbo 4.8/5.3 setups, what RPM stall are you running?
  119. My Project for tx2k13.....
  120. My LS1 S2000 76mm On3 turbo build
  121. d1 procharger bracket
  122. Twin 58 mm vs twin 62mm turbo.
  123. Need help sounds like a 2step at 3500rpm
  124. gm price increase on l92/ls3 heads
  125. 835whp new comp ct5 88mm
  126. Camaro Twin Turbo Kit
  127. twin turbo vette scavenge setup
  128. I'm bout to buy.......... Turbo K-member... BMR or who????
  129. LSA Heads / Components Questions - please help!
  130. Under boost piston quetion.
  131. What vendor for built bottom end short block ?
  132. Tell me why I should not fill my ls3 block?
  133. Huron Speed - Turbosmart Dealer!
  134. Would you rather?? Electric or boost activated cutout.
  135. e85 vs meth? or both
  136. truck manifolds non egr?
  137. Twin turbo LS7 Z06 guru help please!
  138. Just another 5.3L S480 Build Thread (with prices for parts)
  139. Cam choice Turbo LQ9
  140. Need help with 98 Mustang LS/turbos swap
  141. 3 bar map
  142. What stall to use?
  143. twin 6165 vs. twin 6162
  144. Poor man's dual stage boost controller(GM boost solenoid)
  145. Project s10
  146. turbo 4.8 ?'s
  147. Oil pans for turbo setup
  148. putting together longblock for boost, need help
  149. street driving with turbos mounted in grill
  150. Old school blower setups on an ls1
  151. Cam for 6.0 TT in a Jeep?
  152. Need help choosing a turbo for 370ci
  153. Iron versus Aluminum when you do have a problem?
  154. vortech rebuild
  155. Turbo Cartridge question
  156. s10 sudo ls6 turbo m6 build thread
  157. Injector size??
  158. Injector sizing E85
  159. Sources for stainless & aluminum tubing?
  160. ~GUESS HOW MUCH BOOST I'LL MAKE THREAD~ (procharger 4.50 pulley)
  161. How much power left on the table...?
  162. F-body Procharger w/Iron Block 6.0L - ????????
  163. Help me build a monster street cruizer
  164. If I was to ditch my HX60..
  165. Bolt on Power Steering line setup for Turbos?
  166. Fbody procharger rebuild possibility question
  167. FMIC piping fab guys.
  168. Making sheet metal fan shroud for procharger?
  169. cam doctor! please help! Houston area..
  170. Opinons on wastegate placement.
  171. air to water intercooler
  172. 6-71 blower questions
  173. D1 G8 630hp
  174. Cast turbo manifolds
  175. What's 1 7/8 headers worth over 1 3/4 on a procharged car making 15psi?
  176. boost & nitrous timing?
  177. Smartfire injectors
  178. Header/log manifold build
  179. Best spot for the O2 sensors in my crossover?
  180. Turbo LS engine builders in the Southeast?
  181. Ls1 with aviaid 3 stage pump lower left
  182. Slow Ride's twin turbo vette build
  183. Which turbo would be better for my 390?
  184. high hp stock short block guys... question
  185. Trans Am 88mm Turbo Build
  186. Motor mounts
  187. 39x ish with twin turbos
  188. My Procharged truck made it in Truckin' Magazine this month
  189. Need help picking a motor for my TVS1900
  190. Pros and cons on TT vs ST?
  191. Truck manifold gaskets
  192. Need help with Cam selection
  193. the Mighty LS6 cam.post your combos
  194. 2012 ProCharger Rebate 3 Days Left
  195. plugs after 2000 miles tell me what you think.
  196. Fuel feed line size
  197. Paint, powdercoat or anodize my IC
  198. Anyone run the K1 Billet Rods?
  199. 2k turbo project
  200. 1025rwhp f1r tbss!!!
  201. 5.3l turbo build
  202. WG not hooked to boost reference?
  203. 1118 RWHP Twin Turbo CTS-V
  204. Who makes baller drag spoilers?
  205. Best block for forced induction ?
  206. Ebay Turbo build?????
  207. How many of you guys run your oil feed off the oil pressure sender?
  208. project 1951 chevy fleetline ls1 (aka BOOSTLINE)
  209. Need some rear mount help.
  210. Turbo cam gurus please answer
  211. Sleeper......or Custom?
  212. Who all is running a carb setup?
  213. Heard the vic jr does not like rectangle ports....?
  214. Maggie Cog Drive Video
  215. Keeping A/C in new turbo build.
  216. What size Ebay intercooler and piping to get???
  217. DIRT CHEAP: LQ4 Turbo carb yadda yadda Need advice!!!!
  218. ls1 magnacharger to fit l99
  219. FrozenBoost??
  220. Ebay Turbo Kits???
  221. increase power but not boost?
  222. Lq4 +F1r
  223. 6spd FI guys and no lift shifting (lingenfelter lnc-003)
  224. HS turbo kit with alternator relocation???
  225. Merry christmas fi people
  226. Anybody have procharger pullies?
  227. Boosted 5.3
  228. Head/Intake question w/boost
  229. no intercooler
  230. What do you guys think about the Huron turbo kit on special for my build.
  231. 69 Firebird LS2 Twin Turbo HELP!!
  232. Which is better turbo build, LQ4 or 5.3. Need pros and cons.
  233. Guys I need some help
  234. Perfect gears for turbo M6 setup
  235. Who Is Running a GT91?
  236. Crank Question
  237. NYC Tri State area
  238. turbo sizing definition!!
  239. Pro Flo XT...install help needed.
  240. Need help identifying a turbo kit???
  241. stock truck cam?
  242. Second cable attached to throttle?
  243. Looking for wrapped truck manifold pics
  244. Opinion on "refresh" of a stock 5.3
  245. 11.5 compression and boost-why not!
  246. Help! Will my current cam work with a supercharger?
  247. s475 on untouch ls1, what to expect with 9psi
  248. STS turbo build soon!!
  249. STS Kit Build????
  250. TT + 390ci..........which turbos....Modular Turbo CBR F2....
