View Full Version : Forced Induction
- Just watched Richard H's Big Bang on a 5.3, What Holley is this he's using?
- What parts interchange between LSA and LS9 Superchargers?
- Lq9 with this turbo and .81 exhaust housing
- Fast Fuel Injectors 30857-8
- What Injectors?
- 5.3 80mm turbo build
- First track day. 10.55 :( video inside
- Air intake temps on street car
- 408 vs 5.3 turbo
- PB Goal reached! 69 camaro ss SBE 5.3 8.95@150
- Mysterious noise on rebuilt engine.
- Whats a complete engine/turbo/exhaust dropout worth?
- 3" On3 Intercooler vs. 4.5" Treadstone, abbreviated review/un-scientific test
- Power limits of the LS3 block
- Pod filters
- N00b Launch questions, Track day 10/11
- turbo ls1 breaking up
- Oiling fix for Incon
- Single to twin turbo
- Procharger water intercooler
- Anyone use this kit from tps before?
- Twin turbo gt35’s too small?
- Tapping dipstick hole
- How long do you think my engine will last?
- 5.3 turbo options
- what kind of plugs and gap for 20-25psi on procharger setup...
- Fan for Griffin 25241
- Turbo A-body headers
- Huron Speed twin kit with on3 BOV/wastegate
- Turbo car, how high do your IAT's get at WOT?
- 1/4” return with a 255 or 340 pump?
- Bosch 210’s for a street car
- Updated EBC Options
- Twin S366 vs S257 SXE
- Crazy UPS Delivery - Have any idea how this could happen?
- 66 Nova SS TT project
- Finally got to do my cast Gen1 VS 78/75 to billet Gen2 VS 78/75 comparison
- Low power for a 408 stroker/F1R?
- First time out on new setup (not totally disappointed)
- My 10 bolt is still alive... how does that work
- LS1 Block reliability
- Ls9 blower On 2015 Camaro SS
- Standard 30a relay temps with AEM400 fuel pumps?
- Aftermarket water pump with Aster bracket
- 18k to spend... let’s make 900rwhp, auto
- Pistons / rods / heads mild daily turbo truck
- Picking turbos for my 370ci motor
- Old School 671
- Turbo dimensions
- super MILD boost build advice needed
- Should I put main studs on a 416 stroker
- Motor Of The Month!! Check it out
- Having a lean issue on blow thru carb
- Du Hast 2.0 104mm Turbo (stick shift) Datsun
- Fan wiring
- *Sale* Huron Speed APS Style Twin Kits
- Intake manifold video
- Budget twin turbos?
- Boosting a LY6
- Supercharged LQ4 oil leak
- What's the largest ring gap you've ran?
- anyone run ebay gt3582 on 5.3?
- Big HP aster bracket users
- Hotside piping and velocity
- Just bought a P1SC Kit, what do you think of my setup?
- Thinking about another sloppy build - input?
- External pump pref.
- Need some help
- M1 and 93 pump gas
- Holley Modular low-ram VS LS6 intake?
- Holley dominator tuning with boost
- 1973 Camaro w/twins, 4l80, Flex Fuel, Yada Yada
- Trouble fitting Nitrous Outlet's spare tire bottle bracket
- LS1 intake questions
- Converter stall
- Swapped boosted Lincoln LS + Magnuson Heartbeat on trucks
- New turbo log manifolds
- 55’ Chevy Truck - Turbo Time
- Why not Garrett?
- Exhaust with procharger
- Cam swap? Btr/cam motion
- ECU's with boost in mind for 2020
- Stroker ls1 or piston and rod ls3?
- What size LS for a single GTX5518R
- Upgrading my S475 T4
- Help with boost leak
- I ordered these turbo flex. Any input before they get shipped today?
- Manual Trans LQ4 Turbo Setup in 1959 Truck
- New best with 3350lb car with shearer a/a and 39 psi on 5.3
- 5.3 head sel. for boost
- LS9 cam for centri 5.3?
- Who is using the Summit Stg. 4 (237/234) turbo cam?
- 4 1/4 to 3 Silicone Reducer for Pro Flo, who makes one?
- Using a 3 bar sensor for a 2 bar OS?
- Anyone run a single gt35 on a 4.8L?
- IAT difference - dyno tap water versus in car performance?
- Plan "B"...
- My LS1 E36 M3 Sedan Drift Build
- Sbe 5.3 going twin. What size suites it.
- 1969 Chevelle Supercharged safe without a intercooler?
- What intake do I have, need help?
- Huron Speed Single V3 T4 Turbo Kit
- Gen6 Sunroof Leaking?
- E85 and steel tank
- C3 Boost friendly cathedral port low intake + TorqStorm supercharge fitment?
- So, tossed another belt. Any idea why?
- GT55 front mount...pictures
- Wastegate Placement, which is my better choice here?
- Supercar System
- Forged 5.3 to.. sbe 6.0? EDIT 1000+ WHEEL BABY
- Went to the track for test n tune night.
- Slow Spool Billet 7875 1.25AR normal?
- Single Layer fire jacket, 22 psi on a tune run, 4 port Mac.
- How can I get my 2 step to build boost turbo 4.8
- How far have you gone on pump gas? Boost wise
- Electric Water pump folks and steam lines?
- Holley Cathedral Lo-Ram for boost...
- Ring & bearing question.
- P106 - boosted
- What's the Highest RWHP single turbo "Street Car" F-Body/Vette.....????
- First time out disappointed need help
- Oil Feed NPT Sealant
- First time out at the strip with the Twins
- Holley boost control
- RMCR supercharger kit vs. Procharger
- LS3/F body
- LQ4 build for boost
- Which turbo 6.0 C-H-I-N-A
- Turbo selection help!
- Installed a TVS 2300 on a '99 Trans Am...video inside
- boosted LQ4 or LQ9?
- How often to change spark plugs on supercharged car?
- 2 wastegates or 1 - plumbing back into downpipe, looking for ideas
- Turbo 4.8 cutting spark need HELP!
- In need of a turbo oil sump
- bought p1sc c5z, catch can filling FAST
- Turbo 4.8 blowing out spark HELP!
- Turbo spool noise and a full exhaust
- How much bore is to much?
- O-ring style 50mm BOV maintenance?
- Alky Control Issues- Procharged 4th gen F-body
- Budget China 66/73 vs borg warner s366s
- Do turbos affect engine temps
- Anyone use a SINGLE PUSHER fan, instead of dual?
- Measuring blow by
- Turbo LS1 Build Advice Needed - Fuel Injectors??
- Twin 67/66 Lazy...Help
- When are factory fuel rails maxxed out?
- Cam Guys, Evaluate this turbo cam timing
- GT45 Turbo "Siren" Noise and Leaking oil
- Will this collector work
- Huron speed v1 fender exit?
- What trucks have 706 heads
- 6014 msd box. Max boost with turbo
- c6 corvette with fsp log manifold ?'s
- 416CI 11.7:1 with Zr1 blower? E85
- cant make gate spring psi
- Triple Walbro 450s in fbody tank with fuel level sensor . (Video)
- Procharger guys chime in, all welcome
- First time out with new hand controls with upgrades to 5.3, Huron kit and Jose Turbo
- Turbo’d 6.0 in a 1953 Lincoln
- Throwing accessory belt
- Thinking of a new project, more punishment, lol.
- ATI crank pin kit
- Boosted 5.3 2000 WS6 upgrade questions
- 3 or 3 1/2 Down Pipe?
- Forged 5.7 and twin 6871
- Frozen Boost Aie to Water Intercooler
- Newer on3?
- Oil Restrictor
- Width of flowtech turbo headers installed
- Turbo smoke 6.0
- Divided hotside vs open gen2 7875
- comp xr265hr 15 in a turbo 4.8
- Is this a stupid idea?
- Nick Williams 103mm on 102mm SC inlet
- 6.0 s488 not making power like it should, send help
- Looking for ls7 short lower intake manifold to run a shearfab intercooler top
- Huron Speed F-body T6 Kit And Transmission Cooler Question
- Help with misfiring
- Finally tuned
- Hydraulic roller LS record
- Summit Racing STG 2 (shim advice)
- Hooker Cast Blackhard Manifold Fitment Forward/Down
- 09 6.2 Silverado whipple 2.3 stock flex fuel 54LB injectors?
- Quickest time/trap on VSR S480?
- Hot side pipe thickness?
- Anyone go from VS Racing CAST 78/75 to their NEXT GEN BILLET 78/75?
- 6.0 which ebay twin turbo
- How's the spool with a VS gen 2 7875?
- Taurus Fan- E-motor temps?
- Afr turbo 5.3 video.
- Spool too fast?
- New motor w/D1SC setup using oil?
- 5.3 carb turbo. Timing. Compare. 6014 msd box
- OPEN Crossover use DIVIDED 1.24AR, or OPEN .96AR?
- Better top end or bigger head unit
- Boost break up
- 6.0 twin China turbos.
- HELP!! Crate LS3 motor that i want to add twin turbos too
- Will this hotside fit an fbody
- CTS-V Exhaust Manifold For Turbo Setup
- Biggest "Cam only" HP gain on factory long block 5.3?
- Need a schematic for LSA blower
- Turbo 5.3 power loss at 5k
- Turbo or not on LS3
- 255's or 275's to go 9's
- How many bars is the map sensor
- Raced a street car event last weekend with my old Chevy
- Breaking Up in Boost 10+lbs
- Finally! Got to dragstrip test my new turbo setup
- Mild steel v bands
- Cam for 5.3 S480
- roots blower on stock rotator l92 with high compression?
- Turbo headers
- Keep A/C Twin Turbo Exhaust Headers
- Oil restrictor to turbo with high volume oil pump
- Twin 44mm wastegate single turbo
- Bought a new Dorman LS6 intake to replace my busted LS1 intake.
- Cruising Temps
- Twin throttle body intake?
- Breaking up in upper RPM
- First time in the 500s!
- E85 on gas scale holley efi
- New regulator
- first runs with complete new build
- Stainless to aluminium exhaust?
- A2W questions, street car heat exchanger
- How good are the ebay 78/75 Turbos?
- Setting up knock sensors
- FIC 1700cc Ls1 injectors
- Inline style blow off valves?
- Ls2 with ls3 top end turbo
- Timing curve with 93 pump gas
- 5.3 to 6.0 am i Wasting my time ???
- Spark Plug question
- VS Racing 6262 mirror image turbos
- Autometer Boost Controller
- Which SBE ?
- Procharger F1A-94 ANYONE!!
- Twin turbo choice for 416 LS3
- ebay ls truck intake
- 5.3 s475 turbo. Bov ? Slow. Car. Please help.
- Aluminum 5.3 to 3.80” bore
- Coan transmission
- LS376/525 New PROCHARGER P1SC1 - Idle HELP!
- 4.8 Boost Build Help
- TVS2650 tensioner
- A2W (no ice) vs A2A ?
- Spark Plug Question
