- Bullseye 7687 turbo looking for some opinions
- Will this ebay turbo work OK with Huron Speed AC kit?
- Most power thru a single 3" catback?
- Ordered a TVS2300 for the GTO
- Need a recommendation in Houston, TX
- Forced induction turbo book for reading
- LS3 swapped 98 Camaro
- LS turbo project
- MPH Drop on shift?
- Huron V1 kit Radiotor
- Best C.R. for 30psi boost
- Bottlenecks & Performace
- Turbo LQ4 questions
- Alternator hitting procharger pulley
- Bent wastegate actuator rod - problem or no?
- Crankshaft pinning tutorial
- Trans AM WS6 with LSX428 Boost Engine - Which Procharger
- PSA: UMI k-member and Huron Speed turbo kits don't play well together
- Sizing a turbo for setups
- Best Valve upgrade for Ls3 heads 821?
- Suggestions for my Heat Exchanger Shroud; Opinions are Welcome
- Talk about timing
- Ls3 max boost/KPA
- Where to drill/tap turbo compressor for boost port?
- Twin Turbo setup
- Intercooler question
- ATI Race Bypass - Failed Diaphragm
- D1SC sounds "not normal" Video inside
- ls stall converter that may be in stock
- Compression ratio for boost.
- Procharger F1A Jagged Boost Curve - But not belt slip?
- Whats a good C.R. for 30psi?
- How fast have you been on a footbrake???
- Compressor Map VS Real world
- L9h twin turbo Escalade build intro
- Help choosing a turbo for a daily
- Opinions on different meth/spray kits
- best single ebay turbo for 5.3 ls
- Head stud swap
- TR7IX with washer ok to use??
- We still doin things the same way?
- High rpm voltage vs duty cycle
- Procharger
- Magnuson Belt Issues
- What its need to build a boosted engine?
- Supercharged LSX bogging worse - hpt log included
- Vacuum pump on turbo?
- Cam choice for whipple
- Higher revving turbo 5.3
- Foxbody turbo 6.0/4l80e swap
- Smallest pulley
- Cooling Stack Fan control
- Bosch 210 or ID2000 on E38 ECM: Rich idle
- Need a good turbo rebuilder
- Comp oiless turbo grease
- Recommended top end for SBE Procharger
- 6.0 Boosted Build - LS3 Intake Porting and Rods
- Aluminum tig guys in here please
- Awd c10
- converter for blower application
- Single turbo ls
- Johnson 2110 Preload Questions
- Turbo Ideas
- anyone have the holley 550-903 in stock
- Lifter/cam failure. Ebay LS7 lifters at fault or did I use them out of their realm?
- Steering rack bellows/boot heat shields?
- msd6014 and d585 coils
- Gearing for turbo 408
- Torqstorm Supercharger (Fbody)
- Teenage Sloppy S10 lol another one.
- Another Turbo Sloppy Build lol 1st Gen S10
- best heads for boosted 5.3
- Aster v new style ATI bracket
- Question for the LSA/Roots Supercharger guys; Low or No boost?
- Using two WB02 sensors with holley EFI
- Boost on aluminum 6.0
- Meth injection after throttle body
- Slightly unusual turbo cam question
- SBE guys in the 5s over 3500lbs please come in
- ZR1 Map
- Too much back pressure?
- Help ID'ing this heat exchanger
- Remote mount MEZWP319 water pump?
- Can someone with a high mount F BODY LS1 alternator share a measurement?
- Broken weld on the intake
- anyone using a terminator x with a blow through
- 388 Twin s485 Build.
- 3 bar map sensor and maf sensor to get car running?
- F1A-94 camshaft
- Think I inadvertently found out why I torched some pistons last Fall.
- best ls coil for turbo
- 3 bar MAP sensor
- Mp112 kit from gto on 4th gen
- 87 octane and boost
- smartspark for turbo applications
- Super tight clearance for intercooler inlet/outlet. Cobra head?
- theory discussion: tracking down the root cause of poor performance
- Max safe boost on ls6 intake
- Slowly losing base fuel pressure
- V2-Ti potential HP
- Twin turbo drain ideas.
- Procharger Complete Kit tuning
- Is this turbo mounted too close to the harmonic balancer?
- Supercharged 4th Gen with LSX/LS7 engine
- LQ9 Turbo Build Question
- Turbo LQ4 Fueling Questions
- Huron speed long term review
- Oil Cap AN adapter question
- Please delete
- F1D and the rest?
- Twins for 1st gen Camaro (VSR 62/62 DBB billet)
- Help picking a turbo
- How far to space FMIC from radiator?
- This makes my head hurt....horizontal turbo mounting
- Upping boost to maintain tq to redline?
- Low cost CAD program?
- Detoxx Is Twin Turbo Now!!!
- “Safe” timing at higher boost levels.
- High boost TVS2300...belt tension too high?
- VSR 44 mm wastegate springs
- This cam on a turbo application?
- 5.3 s475 build questions
- what do you guys think of my new idea?
- Single Turbo C5: LS3/rear mount/4L80
- Intercooled intake manifold question.
- Turbo AR Effect on Drive Pressure
- How do engines fail under boost
- Cast vs Billet wheels on twin turbo
- Rebuilt stock heads with future boost
- Need pickup solution for a 32g fuel cell!
- Looking for guidance on a quality intake manifold.
- A body turbo questions.
- 408 Stroker with D1X Procharger
- Switching my On3 to Vsr..what to expect from .96ar to 1.25ar
- Advice on LSA supercharger intercooler plumbing from scratch.
- Flowmaster 70?
- Gen4 camaro 6.0 huron turbo kit PT 76/85
- Ls 408 ProCharger
- Holley CAN I/O module
- Got the VS Racing S480 clone installed.
- 900-1100rwhp folks what psi radiator cap are you running?
- Trick Flow 220s: No valve seals?
- Loss of oil pressure when boosted
- Gen 2 LTX Turbo Dyno
- Been two years since I ran the Nova
- blow by
- Sleeved destroked twin turbo 5.3 possible?
- Looking for insight
- STS-V Blower on LS
- DOD tower delete: Valley o-rings enough?
- F-1A-94 Is Aster Bracket a must?
- What Size Wastegate With Nex Gen VSR Turbo
- Procharged fan replacement can it be replaced with procharger installed
- Magnuson actuator modification ??
- Supercharger build plan for 2000 C5
- To 5.3 or not to 5.3, that is the question...
- How much RPM will a 4.8 crank get you?
- Air 2 Water intercooler questions
- VS 78/75 2.5" cold side
- JY LS build question about cams
- Borg Warner secret part numbers
- Holley Term X Max users
- Octa-turbo Mustang....
- Single turbo front crossover pipe for AC
- Water Injection Question
- Tahoe Hybrid Performance Help
- Wideband sensor ground?
- LSA supercharger filled with engine oil
- Leaning out in boost after driving a while
- ‘04 RCSB Chevy Single 7875 T56 Magnum build
- Need a new spal 16 inch fan to replace procharger supplied fan
- Twin turbo kit??
- opinions on build, i have no idea what to expect
- Holley dominator boost control
- Water cooled turbos?
- Turbo help
- Intercooler choices
- PT76 Upgrade
- Log Manifold Size?
- 2008 Corvette Z06 Twin Turbo Build
- VS Racing s480 billet 1.32 a/r on a 4.8 capable of 1100w??
- Remote turbo in Tacoma LS1 swap (need a little help)
- 102mm TB adapter plate?
- Borg Warner Turbo Identification
- LSA Gasket rivets
- Best flowing compact turbo for 5th g on3 kit?
- Single Plane 4150 Elbows
- 5.3 vortec turbo spool times
- -6 VS -8 Trans cooler line?
- New intake set up sniper fuel injection whats your thoughts??
- SBE LS1 P1SC-1 Build - Replace Head Gaskets?
- gen 3 6.0 max hp
- Spark plug wires
- Looking for cleanest, high quality turbo kit for 6.0 L96 engine in GM A-body
- 950hp stock 6.0 gen3.5, which cam?
- 20-23 psi on a sbe blow through app
- RaceTCS = the Racelogic traction control equivalent
- Recommendation for fuel injectors anyone? Budget
- Planning first booost build e-85 question
- Pinned balancer removal
- 5.3 vortec on3 vs gt45 questions
- Brake booster vacuum hose
- 77/79 trans am build 6.0 vs7875 4l80e
- Post Your Homemade Turbo Hotsides
- Billet S480 Dual Vband 1.30
- Getting more fuel and spark at high RPM and boost
- Braided SS push lock hoses?
- T4 gt35 equivalent to comp oil-less
- Another Turbo Lq4 question...
- Twin turbo A2A intercooler suggestions
- How to add a Intake temperature gauge
- 799 heads, Holley, what cts fits
- procharged ls fbody fan upgrade
- E67 boost cylinoid control hp tuners.
- Tuning Question
- Turbo T Bucket
- Turbo T Bucket
- VS Racing 7875 Gen 3 Turbo
- Oil pump for twin turbo setup
- Turbo cam?
- Dominator boost control
- Talk me OUT of turbocharging my truck :)
- Barrel style intercooler
- Twin s366 down pipe size
- ws6 hood with Porcharger system
- S475 t4 VS s475 t6 size differences with pics!
- Anyone tried this filter on a VS 78/75?
- Advance cam a few degrees or swap it?
- 5.3 best head gasket for boost?
- Looking for good 8-9-10" oem electric fans
- Cut to length plug wire recommendations
- Twin gt35 sbe 5.3
- Divided T6 to dual 3" CNC transition flange
- Turbo exhaust
- How often you empty catch cans
- better rods and pistons in a gen 3 5.3
- Boost new guy map sensor question
- just tested my 4.8 with twin 3582 tonight
- Injector cleaning
- Summit FB Friday Noon EST. Livestream with DDNSpider!
- VSR 7875: G2.5 vs NextGen?
- Flowtechs and steering shaft clearance questions?
- 5.3 turbo slower at track after HG replacement, plug pics
- Heat exchanger and A/C condenser
- How bad is the AEM400 Check valve? (worse than you think!)
- Brackets for TBSS + LSA
- Twin Rear Mount Setup
- Frostbite Intercooler experiences
