View Full Version : Forced Induction
- Building boost, suspension ride up (vid)
- Need help identifying this turbo set up
- Post up your timing maps
- Is my cam OK for boosted LS3?
- Lsx vs Dart shp...4 inch vs 3.622 ....daily driver Nova
- need a little help with boost issue
- Windshield Washer Fluid For Meth
- Update Video on my 1000 horsepower WS6 Street car
- turbo lq4
- Help me understand my JGS wastegates
- HP Gain
- HELP! Stumped! Need some help! 26lbs of boost and still slow!
- KoolRayz Racing - Data overlay - Asphalt wars E1 pass
- [VR] 388 LSX/Kenne Bell 4.2/ProEFI/4L80E build - 8.915 @ 152mph in testing!
- Turbo downpipe + Mufflex Catback ?
- New to boost
- Supercharging my 07 Z06
- Why is there no such thing as twin 80mm on a LSx?
- A pair of boosted 370s from Dyno Day
- Turbo 5.3 head gasket HELP!
- Turbo Pipe Material ?s.
- Fuel system base pressure - How low is too low?
- S10 Build
- Boost referenced FPR
- S480 Comp wheel
- What race fuel??????
- PTK/Ebay Turbo kit Airfilter mounting location?
- Fox Turbo Kit Comparison (ON3 vs. CX Racing vs. Huron Speed)
- 5.3 aluminum block bored to 347
- Turbo newb need some help
- question? are ptk turbo kits still available and are they good?
- building forced ind street c5. should i go procharger or a hurron speed twin turbokit
- [VR] Chevrolet SS WORLD RECORD - YSI Supercharged SS Sedan
- Cam comparison question for turbo 346
- Supercharger or turbo for street racing a 6 speed ?
- Long run of vac/boost tubing to trunk.
- holley hiram surge.?
- PT88 and 60E = 9.1 @158
- Is a T60 turbo to small for a 4.8?
- 3" Downpipe limitations on 6.0
- Stock aluminum block modifications
- Parts for my Single Turbo Build
- Let's Discuss Turbo Camshafts
- Where can I find a legit 3/4 fitting for oil drain?
- Faster on low boost then on higher boost
- MAX Boost - Stock L94 Short Block w/ E85?
- Head gasket/head selection help
- How much does it REALLY cost to go Procharger
- 83 GMC shortbed. Twin turbo 5.3, TH350 build
- Moser 9 inch with Wavetrac?
- LSA Supercharger front snout
- Belt length for F1-a
- Gear ratios and boost
- Hardcore street car (video)
- How much can backpressure effect hp and turbo spooling?
- Pre-turbo methanol injection results (vbox results)
- How Close is to Close...Hot Side / TB & Fuel Rails
- Does this look like spark blowout?
- Cruise AFR and timing
- S10 Build
- Possible hints to spun bearings
- 1972 SWB Chevy, LY6 S480 build
- Odd ball turbine wheel to housing stuff and how would it work out
- 6.0 F1a
- mazda b2200
- flowtech manifolds or similar
- Adjusting VE tables
- Does Edelbrock make a supercharger kit that will work on a 2006 GTO?
- EBay 3 inch cutout.....installed (pics)
- LQ9/S475 83MM T4/LS6 CAM E85 dyno results
- High Compression Build on Corn
- On3 non ac kit w 78/75, Tick ls2 Stage 2 Cam, E85 Build ** Updated 5-22-18 **
- 6an fitting to flared hard line with oring ?????
- Need help on turbo flange...
- Holley Turbo Manifolds
- head bolts to headstuds question
- Twins vs single turbo
- 414 f1a procharger issues with upper end misfire please help
- Going lean @WOT
- Gains from increased voltage?
- Turbo 5.3 question
- Stock bottom LS3 Turbo results
- Cam guys i need some help
- Wastegate position and exhaust
- Turbo recommendations
- Killed a thrust bearing on new forged 6.0, opinions wanted
- 2004 gto fuel system Components for tt 1000rwhp?
- What made you switch from procharger to turbo?
- Is it possible to have a new turbo that is bad? What can be wrong with them?
- Driveshaft and Transmission Do Not Line Up After New BMR K member Install
- midwest turbos
- Ls9 Head Gaskets
- D1-SC bracket
- Recommendations for in stock turbo cam
- serialnumber
- RPM sporadically drops during track passes...
- fuel system testing runs.
- What's the deal with breathers?
- Finally have my 427 LSX built, have a question.. *made some progress
- I need options on cam specs from some experts
- Updated build list looking for suggestions
- UMI K-member available clearance
- what's the secret
- Turbo ls1 problem
- Twin turbo ly6/lq9 build
- twin turbo lq4
- Huron Speed Branded Billet 78/75?
- New PB sbe 6.0 stock 80e 76/75 9.58@141
- Pinning the hood down.....anyone have pictures of this...?
- random lean spot in boost
- Nitrous Outlet Interspooler
- Has anyone tried the FItech 70050/70051
- Death wish? 4.8 turbo build
- Seeking advice on rotating assembly and block for 62mm twin turbo setup
- Help me decipher my timing map
- Straight thru bullet muffler, how close can I get off the turbine?
- Better Wastegat? TurboSmart WG40 or Precision PW40?
- Budget running thin , need help on cheaper stuff that flat out works !
- Is this BOV and Meth Placement OK?
- How To - Threaded IAT sensor in Intake
- Converter for turbo?
- 5.3 vs 6.0 compatability
- 5.3 twin turbo, are catalytic converters needed for a street car?
- Jegs swap pan oil pressure woes
- Best pulley combo for novi1500 / t trim plz vote
- VSRacing T4 1.25ar 80mm Billet 96x88
- Low boost problems
- Injector spacers
- The Chupacabra. Quad Turbo Vette Kart.
- Do I have an intercooler problem or an air flow problem?
- Post up what ring gaps you guys are running
- Anyone delt with Forced Inductions Alabama?
- F1-x 427 lsx
- Ls2 sbe with a turbo?
- 6.0 keeps breaking ringlands
- Will my setup be a turd or put some #s on the board??
- Spent the day at the dyno..*Video*
- 1079 rwhp SBE 5.3 706 heads
- Timing for pump 93 in boost
- Custom AC line help, ideas??
- Pt7675cea claims 1200hp ?!
- Clocking Turbonetics 11760-BB
- turbo headers for gbody
- Info on hot side for twin 61s 6.0
- Mondo vs. Maxflow Mini Race Bypass Valve
- LS3 cable throttlebody
- Lets talk water intercooler pumps!
- Huron Speed left over v2 twin hotsides CERAMIC
- Crossover Pipe
- Supercharged Fbody!!
- Where is a 7-second street car?
- Turbo help
- Who wants to fabricate me a single turbo hot and cold side for a 2004 Pontiac gto?
- Help a guy just getting into FI
- 5.3 aluminum vs 6.0 aluminum block for turbo
- Reading plugs when running Ethanol
- Pressure drop through intake manifold?
- Interesting intake
- 1 Final Build LS3 416ci Twin Comp 7275s (Went Crazy) Long Thread
- People with maggies or who have had maggies please come in
- Where do you get your info?
- Let's talk head(s)
- 317s or Ls3 heads for Twin 62/68s on lq9?!
- Ring seals on a turbonetics turbo.
- Ring gap and cut down holley hi ram questions..
- turbosmart hypergate 45 question
- Flex couplers
- Bw s480 ls1
- High idle issue (need help)
- Which Turbonetics would be best?
- help with sensor pin in on ms3 gold box
- Microsquirt yay or nay?
- 04 silverado 2500hd vs7875 work truck
- Built LS1 Turbo questions
- Transferring internals to another block, stock ring gaps huge.
- Can I do anything more to help this turbo spool on the t-brake?
- My 97 S10 at the track
- Boosted short motor build help
- Iat help
- LS1 Turbo Power guesses
- Street only L33 turbo build
- 1986 bmw 525 l33/60e/70mm
- 5.3 LS Twin turbo exhaust building: flex pipe or bellows?
- 80 lb inj setups
- Turbo oil feed line restrictor question
- Turbo power blowing through my converter ?
- TURBO Gen 3 LM7 2005 GTO build
- Fuel pump and injectors question
- ls3 head valve?
- Boost solenoid set up?
- S480 Torque Specs
- Turbo Camaro 10s stock junk 5.3 S475
- Do you E85 boosted guys check your ethanol content when you fill up?
- LS Turbo headers
- 370 turbo question
- Maggie Tensioner
- Any reason not bore an LM7 to 346?
- Stupid oil feed question.
- making boost but power is low
- Has Anybody Used These Yet
- Any issues venting a recirculated BOV?
- Filter part number
- Will these parts work together
- Ls2 + FI, what's ideal compression ratio.
- 5.3 e85 eaton m122 12psi, custom intake on a budget
- First street pass in my ls1 billet VS 78/75
- LSA charger on an LS2 - educate me
- My first build! 5.3, 2 .68/70s, upgraded cam, springs, rods
- Wiring ALT UP?
- Procharger
- Tvs1900 on 402/408 stroker
- 3 Bar map sensor reading 2psi boost at idle, intermittent
- how do i get rid of this question box?
- JE piston ring gap for turbo
- Anyone running the Vortech LS Swap kit?
- pro charger vs turbo for my application?
- How many RWHP does a 5000lbs truck needs to run 6 sec in the 1/8th??
- Boosted LM7???
- Need help picking a PCM for mild turbo build
- 600rwhp with lsa blower?
- Water air intercooler air bleeding/expansion tank routing help
- Coolant in oil, head gasket?
- Reducing turbo outlet for smaller FMIC inlet
- Fan for cold air intake
- Huron Speed FOX BODY mustang LS turbo kits
- New setup has me worried
- Main and rod bearings?
- Running lean on meth/ water
- Power goal, 500 rwhp on 93 with a turbo, street car
- Heavy Duty Tensioner
- STS help 2002 z28
- 5.3 block
- Going turbo. Help
- Pre compressor cooling - What mixture and How did you mount your nozzle?
- From boost control to none and huge creep
- Huron Speed - Your #1 Turbo Source for Kits AND Components! Turbonetics Precision etc
- Boosted e85 guys. I need good injectors that don't break the bank!
- Need help calculating compression ratio
- Meth ait location and harness question
- Upgrades for 5.3l turbo
- Aftermarket Intake Manifolds
- Lsa
- New Project: Turbo LS HACKSAW Blazer
- D585 coil upgrade, now the car won't start, help please
- jgs 400r V-band spring replacement
- Boosted ls1 build thread
- BW s400 ball bearing kits??
- 408ci , s484, e85 th400 dyno numbers...UPDATED
- FEAD definition?
- 99 c5 w/ vortech. Fuel requirements?
