View Full Version : Forced Induction
- Help, need advice on gauges and pod
- M10 and M24 TT
- Should I Powder Coat or No??
- Blowby & Oil out Breathers...
- 6psi to 8psi how much more power
- Ebay Turbo Kits
- Anyone got a 2.25" coupler there not usin?
- Spark Plug damage > Opinions? * Pics *
- boost and fuel presure gauges?
- So the term "aftercooelr" only applies to superchargers?
- Video ......
- Add an intercooler = how much more psi?
- AWD and boost question
- Anyone w/ a PT70? HP est. 5-10#psi
- Help... Cobalt boost gauge purple wire came out...
- Started Mounting the Intercooler
- controlling boost
- Any pics of a GT67 turbo?
- Boostaholic's Top Gun FI List
- compression decrease to boost increase ratio?
- Stenod Performance is starting another project car...
- WTF STS?! Look at this...
- Multi Boost Levels?
- Max boost w/ motron 60s?
- TRUE STREET - At the Year One Experience Apr 22-24
- Missing Boost Where It Counts....
- Turbo filter
- What's the cupon code for HTS?
- Updated pics of GT55 Turbo build up
- how much boost can i run
- Price wise, what would I be looking for a D1 and bracket?
- Latest Round Of Buildup Pics
- Few progress pics, D1SC/FMIC
- PTK LT1 car finall made a track pass with T88
- Spark plug gap?
- Who has made over 1000rwhp with FI and an LSx motor...THE LIST
- Lower price for my blower!!!!
- Will a Corvette Procharger work on an F-body?
- Identify this exhaust housing!
- vortech and nos??
- I NEED some HTS STuff!
- New radiator/fans necessary?
- Turbo AND Nitrous
- electric supercharger on ebay
- .69 A/R Exhaust housing on STS to help with stock stall
- Anyone Know Anything About This Turbo Kit
- Ken's STS/Cartek GTO running 10.68@122MPH
- Help!! Car Wont Idle
- Compressor surge?
- cam
- Meth or N2O
- Whats the fastest FI ET record on 17inDRs?
- map sensor question
- How much boost can I run???
- best compression for twin turbo
- whats the highest Hp turbo/blower setup seen to date.
- Twin Turbo LS1 **of a different color**
- Incon Guys - Replace FPR - What Size Connection??
- head gaskets??
- Turbo 347"..... What part GM # MLS head gasket??
- I need some advice!!!
- How deep do you drill when pinning crank?
- Turbo VS SC
- Anybody here running a CoolingMist system?
- FI Engine Break In?
- supercharger rating system?
- Procharger???
- Phamspeeds budget turbo kit
- Update Pics-Procharged W2W 408 Installed
- Turbo Accessories
- help, i have a 408 with t76, what mod next?
- Turbo or supercharger??
- Phamspeeds's new kit - is it worth the $$$?
- S/C queestion
- Overboost = 906rwhp/975rwtq
- New Banks Power Twin Turbo
- How to trigger fuel pump?
- Turbo or Blower
- More updates on the project
- Help with procharger kit
- FI newbie, got some ?s on procharger setup?
- Bryan Wilkinson Pics of your radiator
- 98 MAF Max
- HKS BOV question with ATI kit
- Not exactly forced induction related but...
- Sdce Fmic
- TTi LS1 turbo kit help
- Whats the fastest FI GTO so far?
- weiand roots type superchargers
- turbo 4.3l questions...?
- Synergy Production FMIC kit....
- ProTurbo has released a new line of turbo kits....hehe
- STS Oil pump Problem * HELP * ?!?!?!?
- D1SC Kit: Where/what to buy?
- STS Turbo Installation w/ 3" to 4" IC
- orange hose off the D1, Dyno last night, results inside.
- Cost of Building Forged 346 vs 408 for FI?
- Anyone blown a Forged Piston or cracked a Ringland?
- Procharger Help
- Custom turbo on STS
- Corteco Gaskets - Anyone heard of them???
- what turbo???
- 42 Or 60lbs Injectors
- LS1 with 6.0 heads - What gasket?
- Turbo/Open header-going to exhaust shop today
- Vertical Flow FMIC's
- MAP Sensor identification
- Tial 50 MM Question
- Question about FMIC...
- How many miles...
- When is a BOV needed?
- Two questions on mounting a turbo...
- which Turbo kit ????
- FS: Motron 60# Injectors
- Where can i find a 10psi Procharger pulley?
- blowby?
- Just recieved my twin kit from Phamspeed
- Sts Turbo System For 99 Ss M6
- For those that have called about the Pro Turbo System sale...
- Ls6 Cam Not Enough?
- Guys 650+ rwhp . . . What Plugs?
- Hot parts routing
- Rockers, Lifters, for Turbo app??
- quick question please read
- Procharger pics?
- How much boost will an LS7 be able to take on pump gas?
- ****Need Help Finding ****
- Where to find a good Heat Exchanger manufacturer?
- Valve springs for FI
- Phamspeed vs. ProTurboSytems!!!!!
- changed trans settings=lost boost
- boost numbers???
- forward sweeping headers install...help
- Master Power GT45 V-band clamp kit finally....
- Maximum boost I can run?
- Ptk Kits
- Few D1SC progress pics
- Whipple install in Denali - update
- just took my orange dryer hose off the D1 and made a test run!!
- v band flange
- Intercooler for WS6 Trans Am
- found my problem, (blowing oil/vapor out the oil cap and breather)
- need STS pics for a project
- C5 engine accessories fit on F-body?
- Look what arrived in my garage yesterday!
- Boost controller for BS3? Kurt?
- Brenteb02 11.0 Video
- Pass smog w/ Turbo?
- Mounting the Procharger like C5 kit?
- Tial Blow Off Valve
- magnuson roots 4 f-body
- Pro Turbo Systems is having a 1 week Easter Sale!
- Opinions on Turbo setup
- turbo cam in N/A motor?
- Really Need Asap For Twin Turbo!!!
- Easter Sale
- easiest way to tune supercharger
- little help needed in cam specs
- Newbie 6.0L Whipple question
- How important is the bov?
- The Dreaded STS "Cat came apart and went through my turbo"
- T/A and Forumula people... Mesh to make IC grill, where did you buy it?
- Intake for D1SC...other than intake hat. Size Filter?
- Serpenteen belt problems w/Vortech
- Sheet metal intake manifold in the works. details inside
- q's about the big turbo setups/outlaw
- how much to expect to pay?
- Anyone using the TSI (Australian) Aftermarket PCM?
- How much $ for D-1SC, F1, and F1R
- Solid or Poly motor mounts with a 9 second car?
- Redyno of APE 370ci, Incon TT
- procharger or phamspeed turbo
- another thread
- supercharger ???
- I need some STS intercooler pics
- what is your timing on lt1 s/c cars?
- NON_SPONSOR kit
- Just Wondering.....
- *** new best STS turbo gto 11.0@122 mph***
- Many questions about my Radiator
- BOV sounds
- Phamspeed/Procharger Hybrid?
- need help with heads and cam w/ t-63
- Poll: My Stock Bottom End Lives With ## RWHP
- New Era Performance is now carrying STS Turbo Systems !!!!
- Can you or has anyone pinned a stock crank pulley?
- How many using MegaSquirt?
- Bolt ons to complement STS turbo
- LS1TECH Project "HOSS" - which power adder?
- how much boost can you run on a D1?
- boost controller
- building a blower motor, need input opinions
- LT1 - Phamspeed Kit
- Armageddon's car with the Phamspeed video...........
- Wastegate Actuators
- WTB: ATI Procharger Head Unit
- pics of F-2 on sbc
- How about this cam with my turbo?
- Procharger?
- How Much Boost? From 346 -> 370
- sts turbo with cats?
- single turbo
- Congrats to...
- T-18??
- 8-rib?
- Street tune turbo AFR? 11.5 or 12.5?
- rear mount vs. traditional turbo
- ATI Prochargers rattling cam bolts loose...
- STS Turbo?
- Phamspeed kit with a T76GTS
- PTK turbo kit
- Dyno #'s for Nelson's truck; 600+.
- Opinions on best boost controller? e-boost?
- what would need to be done to turbo/super charge the t/a
- LT1 Cam Choices
- 2004 Z06 head gaskets?
- Questions - going FI !
- anyone see the two guys garage, turboed ls1
- Which Cam to get? and head suggestions..
- Price for the CAS TT!!!!
- Upgrade ATI headunit, anyone do an exchange?
- turbo project for the trailblazer I-6
- SC Gatorback Belt Opinions..?
- pics of single turbo set ups
- Just Dynoed my car with a 408 and P1sc
- Pics of A2W intercooler we just finished
- STS installers PCV question
- Types of belts!
- Lunati's Pro Mod Rods?
- Best Blower Cam!
- Turbosmart E-boost GP is on......
- D1SC pulley change
- New motor w/ turbo on dyno need help
- STS, Vortech and ATI discounts available!
- Pics - Duke's Blue Vodoo
- Any interest in a CAS Twin Turbo??
- where can I pick up a turbo...
- Injector sizing please advise
- Check out this RX7 we just finished
- O-ringing cost?
- Innovative T76 or Phamspeed custom GT42???
- Finally got the FMIC on and the car got slower!
- Twins on a 2004 Z06?
- Who else is overheating?
- Turbo on the stock bottom end...
- Why turbo?
- which turbo site?
- Will this cam be a bad choice for ATI Procharger?
- BOV for P1-SC questions
- TA / Formula guys - what did you use to cut out the license plate area for your FMIC
