View Full Version : Forced Induction
- G-Body - Ebay Headers down and forward possible?
- First turbo build, had a couple questions
- put 317s on do I need retune?
- Opinions and ideas needed please
- Winter project ideas
- Heads and Cam for LSA Blower
- Multiple fuel pumps and check valves
- Dyno Results!
- Thinking of Ebay-Turbo over HCI
- Nova going in under the knife
- new best with 5.3 micro build.
- Boost gauge not showing boost?
- Pulled the trigger guys :)
- Muffler Recommendation
- 5.3 or 6.0 Turbo Build for Foxbody Swap
- flowtech vs cam motion. custom solid roller
- Huron Fbody turbo kit who is running a restrictor or pump?
- bigger intake on 1500 novi
- a ton of questions for 65 chevelle build . hope i can get it all in one post.
- Piston options for ~600 rwhp
- Dyno didn't go so good, HELP
- Btr stage 1 turbo cam with stock stall
- Boost reference?
- Valley Cover - Add 8 bolts instead of plugging DoD Towers
- Fuel recommendation
- Valve Cover Breather Bung Location
- Anyone have the Racetronix Dual Fan Harness Install sheet?
- Lmf 2008 5.3l
- Which map sensor for meth injection (boost leash or 3 bar )
- Scavenge pump recommendations
- Jon Capizzi new 1/8 SBE record
- 216/220 .560/.560 vs LS9 camshaft - which is the best for a budget?
- 317 to 243s by milling ?
- Borg Warner s400 compressor housings
- Turbo 5.3 sits at 5700 in high gear.
- Twin turbo with two widebands. One is lean. Video attached. Help
- E85 vs E98
- 4.8 s475 rcsb
- Compressor Surge w/ BOV?
- S472 too small for rear mount LS3?
- Holley Sniper Manifold
- Turbo LQ4 Mazda/Ranger build thread
- Holley Sniper Intake
- Huron Speed V3 A/C T4 Single Turbo Kit
- Intercooler pipe size with 2 intercoolers
- 06 5.3L "Hybrid motor"
- Ls 6.0
- 87 TA single turbo 5.3 build
- turbo drains
- Too much for the street?
- Goertz1 Sheet Metal Intake Manifolds
- when is a deka 80 truly done on e85
- Fully Built LQ9 Missfiring/Stalling/Sputtering/Backfiring At Any TP when warm
- Home ported LSA Heads
- What Rocker Arms? going to Solid roller
- F1r on a 2002 fbody Help
- “No prep” drag radial guys- what tire?
- L92 heads on LQ9 block
- LS3 head gaskets and ring gaps for boost
- Brian tooley, lil john camshaft help
- Blow-by?
- Turbo failure with pics and questions.
- Procharger i-1 question
- Aem wideband 30-4110 / hptuners - erratic a/f numbers all over on scanner
- Pics of what happens to your transmission after a sudden driveline failure
- Looking at Procharger kit, how does this look?
- At What point would you "Build" a 5.3
- Boost referenced FPR
- Boost drop twin turbo
- T6 front mount swap
- Supercharger for bracket racing
- C5 corvette single turbo kit
- Going turbo ?s
- How much oil - boosted w. stock pans
- Procharger FMIC bumper cutting
- Turbo exhaust header studs or bolts
- Meth Injection
- is there any gain in headers vs manifolds in the 600-700hp range
- Low boost tvs2300 new install
- help for a newbie on a 2500HD build
- Turbocharger + road racing - How to keep temps under control??
- What's everyone using for an oil pan? Having pressure issues at the track
- Turbo and PCV?
- Whats the best bang for buck turbo these days?
- E85 vs 100+ octane.
- Inline oil filter for twin turbo setup, with new engine??
- Chassis is working good, MWC stuff FTW
- 2000 SS D1sc Map/SD question
- Can I make 600+whp on a iron 5.3 lm7 boosted
- 4.8 76mm 7675 vs 67mm
- Quench area with boosted engines.
- tire advice plz
- vic intake over holley mid ram with boost
- 7.0 .. 427 ... where are the limits ?
- Looking for good gear choices
- Twin Turbo 4.8 Results / Single 80mm Build
- Edelbrock Pro Flow XT Fuel Rail HP limit
- 5.3 tensioner relocation?
- 1000 or no????
- C6 manifold turbo build
- Turbo cam, 9ish:1 non turbo 6.2 - a dog NA?
- IAT temp with D1SC / D1X
- FITech Ultimate LS Kit
- Yank PAS 3400 stall opinions needed
- Turbo Intercooled e85 Timing
- stock 5.3 bottom turbo choice
- Turbo options
- Boosting Dorman Ls2 intake
- knocking sound around supercharger
- converter flash on twin turbo 5.3
- Boosted 454 LSX?
- Restrictor or not on YSi Billet SC
- One Bent Pushrod/Valve. Any ideas???
- 4bolt vs 6bolt lsx 1000/1100rwhp
- Well she's to get tuned
- 5.3 vs. 5.7 vs. 6.0
- Spent lots of money.. still got problems. Need some help guys
- Crown Vic, 6.0, holley dominator, twin 70s, JFR cam, denmah tuned, 9.64@141
- Blow Through vs EFI Valve events
- on3 78/75 to borg 80/83 results.
- Jet Boat Procharger bracket question
- Going for twin GT35's. Hoping to use two stock passenger side manifolds...
- When do I need twin BOV
- new best but have some decisions to make
- Turbo upgrade time suggestions
- Is anyone running a Twin Turbo LT-1 setup where you were able to retain the A/C?
- Supercharger cam and turbo recommendation?
- Is the gen3 5.3 iron BLOCK as strong as gen4?
- Engine Pro rods
- sudden boost loss
- Disposable twin turbo 5.3
- AWD t56 - Maxed out on3 78 - What would you do next
- Run it or junk it?
- Thoughts on this 68-72 A-body turbo kit ???
- Turbo build advise...
- rich on decel
- When buying a S475 or S480, what size piping ?
- BlueChuChu Silverado Build Thread
- What RPM to launch at with 3400 converter??
- 99 Camaro LS1 T56 S475 shooting for single digits!
- new best
- Turbo up pipe sizing
- Looking for magnecores for flipped truck manifolds
- Nitrous to turbo
- New to the ls
- electric boost gauge issues
- Couple questions about my twin turbo 408 build
- Hi Flow Cats and restrictiveness
- Tensioner pulley on p-1sc-1 on a 06 gto
- 416 F1A ProCharger, Dyno results Fun 2.O
- Boosted ERL 434
- ProCharger GM Catalog
- Spark plug gap
- Crazy Blowby?? Twin Turbo LSX427
- Most Efficient Turbo = Less Heat?
- Procharger Fan Wiring on Fbody
- Can I rear mount turbo my centri supercharged 5.3?
- 5.3 on TH350. Starter jamming on flexplate
- Critique My Winter Build Plans (D1sc 408)
- Scr for street boosted
- Thoughts on 5.3 w/ TBSS Intake for Turbo
- My 67 back from the dead! (Well she will be soon!)
- Turbo 5.3 not making the power it should.
- 2007 LQ4 - ok?
- 427 twin 85mm 69 camaro finally done
- LSA Swap, plugs read rich, o2s/wideband reads lean?
- Major Kudos To EFISource & EFI Analytics
- Burning plug wires
- 6.82/198mph last weekend in testing.
- Help me pick out my turbos!
- All You Budget/China Builders (I'm guilty), this may change
- 4.37 pass in testing
- Ls swap
- Turbo 5.3 cam profile
- any 4 link gurus in here? need some opinions
- Strange issue @ 4500 rpm....
- What aluminum blocks have 3 holes for 98-02 procharger bracket
- Weird Fuel pressure Alternator volt issue need ideas
- New PB on this years combo. 8.28@173
- 3 bar map sensor trouble
- Making the jump to FI
- strange piston failure?
- First LM7 tt set up need info
- Which injectors for 5.3 tt fbody?
- New PB, met the 150 goal!
- Bosch 210 injectors
- Question for you Huron Steed TT Fbody guys
- Really weird puff of smoke on hot start only
- Dumbfounded - lost significan rwhp
- My Huron V3 T4 (non-ac) Kit Install Experience
- Which type of boost gauge, Boost or Boost/Vac Gauge for turbo kit?
- Build Input?
- Billet 7875 Results thread
- Crazy Twin Turbo or Subtle Supercharger?
- 5.3L or 6.0L with pricing
- Torqstorm vs lsa supercharger on 5.3
- LQ9 LSA budget build cam options
- Who can help me spec out a turbo?
- ISO 317 heads in good shape
- Lsa throttle body to DBW wiring help
- I wanted to run turbo and Nos on my new LSX B15.
- Is it necessary to run same WG spring pressure on dual WG setup with boost controller
- Fuel pump and injectors, how far can they take me?
- Junk nittos, from dig
- Out of fuel, Suggestions
- OLD 10.5 mustang to no prep terror street car
- Best recipe for 800rwhp ? Turbo 5,3
- LSA Cathedral Port LS6 vs LS9 cam
- Timing changes between pump gas/meth & c16
- Road race/autox 5.3 turbo suggestions
- 01 Z28 Turbo Build
- How much power do you think I'll make?
- Is this cam to much?
- Eboost 2 users, I need some help with boost by gear
- blow thru carb on ls
- Lq9 LSA Supercharger Questions
- Incon TT LS6 - Scavenge Pump Died, Oil Everywhere
- CSF 2 Row Aluminum Core Size: 12 1/2" x 28 1/4" x 2 1/16" enough for turbo LQ4?
- Can I supercharge mi high compression engine.
- Turbo Size for LSS454 (sort of) 0411 BBC Chevelle
- Scraping my cx racing intercooler. What's next?
- 2000 trans am project huron speed V2 ac turbo kit
- Bosch 210 Spacer length?
- Where are y'all getting your rings
- Solid rod ended Lca or poly
- New Project/35th LE SS
- Heat Exchanger For LSA 6.2 SC
- Recommended oil pump for twin turbos and double roller timing setup?
- Change Procharger rotation/ Bob u out there?
- 98-02 Tubo Fbody coolant overflow!
- Lightweight Battery Options...
- What's there to gain?? Turbo swap
- Trying to contact huron
- C16 or Meth Injection?
- Turbo selection for 408 m6
- boost pressure drop during run
- Insight on supercharged 5.3
- World's 1st D1X ProCharged Corvette
- vacuum source
- 80 c10 turbo build, need some advice.
- Educated Con-s of my build?
- Powerglide with turbo 5.3
- Some passes after multiple changes finally
- 408-VSR Billet 80 Nova first track outing
- M6 fbody turbo gear
- Lsa blower question.
- Feedback on my New Build PC'ed 370.
- Proven LS7 heads for boost?
- First outing (kind of a mess)
- Procharger/vortech set ups
