View Full Version : LT1-LT4 Modifications
  1. Funny clip...
  2. Correct Oil pan gasket?
  3. dumb question, brace yourselves.
  4. Ebay find
  5. LT1 parts sponsors??
  6. AS&M TB Gasket Question
  7. Intermediate Pipe Help..
  8. Horsepower Engineering
  9. oil weight?
  10. Trickflow GenX Heads, Compression?
  11. Old opti-spark caps needed for the Shootout trophies.
  12. Should i go LTs or Electric Cutout?
  13. ? about cam swap
  14. Would cast be ok or do I need forged?
  15. ob2 to ob1
  16. 4l60e ?? converter ??
  17. Vids of my junk going down the track...
  18. 10's on stock bottom ends
  19. What mods would you do to an LT1 with $1000???
  20. ob1 tuning???
  21. thought on AI 226/234 cam kit?
  22. LS1 Rockers on LT1
  23. what it takes to run E85
  24. Polished her up and took some pics.
  25. pros and cons
  26. Spirited driving
  27. what converter?
  28. lt1 max amount of nitrous ??
  29. gmpp springs for 847
  30. a couple of simple questions
  31. 30# injectors, stock pump
  32. going 1st gen sbc need help
  33. Cam question for Emissions Counties???
  34. No spark! ideas?
  35. 4000stall on LT1
  36. Oil pan/Timing chain cover gasket... HELP!
  37. A4 to M6 swap help please
  38. true duals?
  39. bottom end
  40. Iron Vs. Aluminum
  41. 1.7rr?
  42. Help bent opti rotor
  43. what pushrods???
  44. 4.56 gear, 325/50, stock ecm will it make it?
  45. time to get my T/A back on the road....
  46. Who is gonna be first to the 8's with a nitrous LT1????
  47. Ctrique My Mod Wish List Please
  48. cam advice please!
  49. ABS inoperable
  50. help with Y-pipe
  51. possibly trading vehicles. opinions?
  52. What size injectors to go with
  53. 96 ta-ws6
  54. Where can I find a good Timing Set Up?
  55. Final Opinions: 383 Cam
  56. suspenion issue
  57. longtube hitting
  58. how much hp can a stock cluth take?
  59. Moser, Strange,12bolt 9" etc.
  60. Finally got started on the mods!
  61. My hotcam numbers are in.
  62. LT1 will not Start..No Spark..Need help.
  63. Smoking LT1
  64. LT1 Racecar Wiring
  65. Any way to drop 60's?
  66. My clutch went boom!!!! Pics inside
  67. Need help
  68. 1LE Drive Shaft
  69. LS1 DS Installed
  70. Should I replace the rear main seal?
  71. 396 & ATI FluiDampr
  72. thinking bout goin carb... questions on the intake
  73. water temp gauge help
  74. My dyno #s
  75. Injector help!!!
  76. too many choices!
  77. Wrong shift rpm
  78. Rods, pistons what else?
  79. autometer fuel pressure question ????
  80. Damn!
  81. Arp Head studs or bolts
  82. msd ignition box
  83. Autometer ES Guages?
  84. FYI: Header Insulation Engine Compartment Temps
  85. How much torx need?
  86. Help!
  87. Your opinions!!!!
  88. What did I do wrong
  89. LT4 valve springs
  90. Time for a spool!
  91. quick stock crank and I beam rod question
  92. Whats the trick for getting the door bars out??
  93. Can anyone identify these springs
  94. Rebuild Questions
  95. Comp Pro Mag 1.6 RR problems
  96. lt1 power limit
  97. Horsepower estimates
  98. Hit and Run
  99. Cam Installitation help
  100. if i turbo
  101. lots of ? on bolt on performance
  102. Which Turbo System???
  103. EGR Removal
  104. Well... I'm not doing that again...
  105. Anyone know where I can find
  106. Do I need to up idle or cam surge?
  107. 0 reading from o2's???..
  108. dyno #'s with trickflow lt1 heads
  109. 4.10s with a4 and say a 503,306 cam
  110. best clutch for 400hp?
  111. Rear end going out?!
  112. Fuel Injectors
  113. dilema: nitrous or supercharger for LT1
  114. what size injestors?
  115. Help help again, another acting up lt
  116. Running rich in open loop? heh..
  117. Step Cooler Plugs
  118. Finally got some Pic's!
  119. valve springs
  120. lt1 383 wont start need help!!
  121. Does anyone know lt1 rebuild ?
  122. headers. pacesetter LT's and ORY? or maybe LPP
  123. LT1 with 3" SS hood.
  124. what does it take to go to a monoblade TB?
  125. cam or spray first?
  126. Suspension or nitrous?
  127. lt1 dyno tuner?
  128. 98+ center console
  129. Rwhp estimate!!!!!!
  130. Clutch question...
  131. I need some guidance
  132. thepartladi
  133. coil conversion kit
  134. lt1 cam
  135. coolant question
  136. 96 camaro Plugs and Wires
  137. Crane Gold NSA 1.6RR
  138. Anyone Runnung this cam ?
  139. fastest lt1 6 speed?
  140. electric pump or standard
  141. Thinking of parting out project....
  142. Your opinion here
  143. lt1 underdrive crank pulley w/o the different alternator pulley?
  144. Well Guys Parts are In
  145. ati super damper for lt1
  146. GMMG: which headers?
  147. Best head/cam combo for stock bottom end?
  148. opti?
  149. Opti
  150. built supercharged t/a almost finished few ?
  151. CC503 & 3.42s with M6...
  152. Any one know this guys set up?
  153. H/C Parts List. Do I have everything I need?
  154. black or silver zr1's
  155. How do you preoil a fresh engine?
  156. How hard is it to remove the LT1 PCM???
  157. redneck racing converter?
  158. 355 build opinions
  159. happy birthday to me!!
  160. 400-600 Shot
  161. LT1 Header question.
  162. 10sec allmotor LT1! questions
  163. Hypertech programmer worth the money??
  164. Lt1 engine problems
  165. LT1's riding Bumpers FTMFW!
  166. Who can name the weakest part??
  167. studs or bolts...
  168. So i pulled the trigger on a VFN Reg Sunoco pin on hood 2day!
  169. lt1 missing problems
  170. Jegs Wire set???
  171. Best Sounding LT1 Exhaust????
  172. what headers for 4" exhaust?
  173. Correct ARP Headbolts?
  174. Those without Power Steering and Factory Rack...
  175. Trick Flow 21 Degree LT1's - Info & Pics
  176. 355 or 383
  177. Transgo shift kit
  178. LT1 Canfield Heads arrive ...
  179. rim question backspacing
  180. Nitrous Question
  181. Cannot remove crank balancer bolts
  182. air liq (98-02)camaro v6 into a camaro lt1
  183. No power after engine swap...
  184. 69 Camaro with 95 lt1 cam help
  185. Whats the low down on Optispark?
  186. Pro mags and valve covers
  187. Happy Birthday to me!!!
  188. Leaking transmission fluid
  189. Trouble Code P0134
  190. Official answer to oil filter adapter gasket question???
  191. Lets talk/rant about coolant hoses
  192. New H/C Set Up
  193. New guy here and I have a question.
  194. high rpm wot cracking noises
  195. Proliance Radiators
  196. can a ls1 SS spoiler fit a lt1
  197. Bolt On LT1 Times Inside
  198. Stock lt1 injectors are rated @ X PSI?
  199. Anyone running these???
  200. TEA 220cc vs AI 200cc on a 383
  201. over the valve cover spark plug wires?
  202. LT1 heads ?
  203. 02 sensors bad already?
  204. Bumper Support
  205. Looking into true duals
  206. can someone look at me datamaster files and tune?
  207. How to tell
  208. Popping noise while turning
  209. What's this worth?
  210. Dyno'd my turd.... :)
  211. tuning questions
  212. What sponsor sells EGR blockoffs cheap?
  213. AIR delete quesion
  214. header bolt help
  215. front needs raising
  216. K&N CAI Problem
  217. The Big Suck
  218. Anyone else have this issue with Hot Cam
  219. auto tap who likes/dislikes it and why?
  220. 383 need cam , some advice
  221. What a great night...
  222. Help
  223. 388 LT1 guys in here
  224. Will this X-Pipe fit my 1996 lt1?
  225. lt1 into a 1995 v6 camaro
  226. new setup, question about injectors?!?!?!?
  227. Another LT1 tuned by PCMForLess...
  228. lets hear how much power you stock 4l60e can handle
  229. Lt-4 km
  230. T56 dust cover bolts
  231. chiltons manual...
  232. gm847??
  233. Occasional misfire in High RPM under load
  234. Injectors
  235. Is this typical?
  236. Please help,my g-body failed smog,high Co and HC with pic of report!
  237. What's this worth?
  238. Should I buy?
  239. Are the Vortec 4.3l V6the only ones?
  240. true duals or stick wit cat back?
  241. Griffin Radiator for stand up
  242. Who all has removed the bracket that connects the alternator to the intake?
  243. GMHTP LT1 Build...
  244. New PB AGAIN!! 10.84@124
  245. Next mod before headers?
  246. Lt1 Question
  247. LTX VS Stang on PINKS NOW
  248. New Best - 11.18 @ 120.33 N/A
  249. gm847
  250. help
