View Full Version : Forced Induction
  1. New build: 2010 Camaro | X275 88 | TH400 | street car UPDATE: 03/03/13
  2. Lq4 turbo coldside and waste gate help
  3. Ls1 S366 buggy build
  4. help with twin turbo chevelle
  5. v7 ysi not making boost
  6. alternator mount
  7. bulleye 94mm batmowheel or pt98?
  8. Horsepower guesses...
  9. Boost Falling off at High RPM & Dyno Graph looks Weird?!
  10. post pics of your LS turbo mustangs/Notch engine bay setup
  11. Turbo hot side questions
  12. turbo advice (trying to learn)
  13. 347 turbo batmowheel
  14. Where are you guys getting your LS9 head gaskets?
  15. Jax04's 1991 Rx7- 5.3-PG-8.8- S475- Street Machine
  16. converter help
  17. Manifolds VS Headers?
  18. 402ci pt88 build video...
  19. Turbo 6.0....will XER273=14 cam work ok?
  20. Mayhem Motorsports goes 5.44@129 stock 5.3/s400
  21. Twin 67 5.3?'s
  22. new to LS1 tech
  23. f1 start up
  24. th400 or PG/3.23's or 3.42's/28" or 29" tire? high 8 second car at 3600lbs
  25. 370 ls1 or 6.0 truck crank or 5.3 for boost
  26. The wait is over...TTI twin turbo F-body kit finally available
  27. maggie/magnacharger 122 for sale anywhere???
  28. Spend my money
  29. kits that keep radiator in place???
  30. Diesel vs pump gas and boost
  31. Turbo Technology Turbo Kit?
  32. TC78 Oil screen.. oil restrictor needed?
  33. trapped 150 tc78
  34. 5.3 turbo questions?!?
  35. quick question about turbo mock up and K member.
  36. LSx turbo mustang 8.93@157!!!
  37. help me figure out my turbo setup
  38. Precision Turbo Problems?
  39. How much to gain from S475 to S480?
  40. Heat shields
  41. Boosted stroker motors, yes or no?
  42. Adding a catch can to my procharged ls1
  43. Procharger F1-A Head Unit For Sale
  44. 2006 GTO Almost done
  45. TC78 on a 4.8/5.3- Horsepower/Backpressure
  46. Turbo lq4 fuel questions
  47. 100% stock motor + boost TIME SLIPS!!!
  48. 706 heads on a stock 5.3L ported or not?
  49. Building a manifold flip kit for a 2008 4.8 silverado questions.
  50. Building a manifold flip kit for a 2008 4.8 silverado questions.
  51. Got the hot side to the turbo started today.
  52. Turbo 5.3 valve marks on pistons...LS6 springs not enough??
  53. Copper coating ls9 head gaskets
  54. oil feed and return line size
  55. Is there a 6 bolt head for big boost/power that works with only a 4.070 bore?
  56. Im going bonkers (5.3 Sonoma T70 build)
  57. LQ 6.0 built for boost but NA for a while..
  58. Oil Priming Problem
  59. APS twinturbo question
  60. Procharger mpg effects?
  61. Cost for power
  62. need your help of Turbonetics
  63. Thinking of switching blowers
  64. My budget Twin Turbo 383 build
  65. fast 102 intake
  66. JY 4.8 builds
  67. Confused on which block for boost?
  68. Those with Griffin 1-25241-x
  69. twin turbo opel, lots of questions
  70. How do boost contollers work without tunning?
  71. ls6 cam
  72. New turbo not spinning at idle
  73. Turbo Cam Discussion
  74. Stock short +63cc heads + D1SC =?
  75. Noob turbo question, Rear vs Front
  76. Detailed Info on twin turbo setups, especially pictures!
  77. Lets Play "Name That Cam!" And the Winner Gets A Free Camshaft!!
  78. 5.3 Junkyard Build - Cam suggestions?
  79. Huron Speed Turbo guys, what are your plans?
  80. Does the truck hat on prochargers rob horsepower??
  81. It's Alive.......
  82. T4 divided flange
  83. turbo Tahoe pics
  84. Poor mans LSX Real Street.......
  85. First time at the track with my turbo C6(forced inductions gt91)
  86. vortech v9
  87. use my 226/234 113+3 cam for my turbo motor???
  88. f1a blower with custom cog belt set up
  89. Determining the correct blowoff pressure?
  90. Eric Lancaster's bolt on ZR1... 9.679@146.23... Video inside
  91. Incon TTi and 5.3 build
  92. New PB with the JY 4.8L GTO
  93. How fast people been w/ D1SC? Customers stock longblock 9.77@141 so far...
  94. What do I need to put 3700lbs in the 10.50's? 5.3 or 6.0
  95. RPM TBSS Goes 10.47 @ 132
  96. TN550 on 5.3?
  97. Lower static compression???
  98. Looking for pics of s475s in 4th gens
  99. 99 Camaro SS build Thread with Dyno video
  100. Another successful track outting
  101. 3" coldside + 88mm?
  102. tapping moroso oil pan
  103. need help from procharger guys (inlet hat b4 procharger)
  104. borg warner/garrett hybrid t6 85mm 1.32 a/r on a 402
  105. How does this cam look for FI?
  106. Will an AES 410 be able to get a full weight street car in the 7 sec zone?
  107. who has the most affordable sheet metal intake?
  108. F1 procharger trouble
  109. Ported vs Non-Ported Compressor Covers & LS Engines
  110. LSx 6.0 stroker 408 pro charged
  111. Are my TFS 215's OK for TT 402?
  112. Lavoy goes 8.85 @ 153 on stock 4.8 shortblock
  113. Intercooler tubing size?
  114. Compressor wheel Question
  115. Exhaust fumes, cats ?
  116. fan setup
  117. Video of my 6.89@221 pass in eliminations...
  118. Keep a/c with truck/c6 mani's. (come in if you run a down-pipe under stock k-member)
  119. Sloppy Mechanics guide (wire and fire ms1 and MSD6010 LSX)
  120. Intercooled vs straight pipe???
  121. Cranks? And rods? Boosted!
  122. 4.8 turbo
  123. Noob turbo help
  124. 2.9L Whipple Build
  125. Upgrading to a PT7675, what AR should I get
  126. Junkyard 5.3l turbo build, will this cam suffice?
  127. LS in 1st gen with screw blower..advise
  128. procharger questions
  129. ABS Module Delete Guys, Normal Lights on Dash and Does Your Cruise Control Work?
  130. supercharged with a wastegate
  131. POOR man's low slip converter?
  132. 5.3 running Microsquirt 2, waste spark and fuel *1-8-13 updates*
  133. research beyond search -TT 5.3
  134. Opinions on gt4202 for 370
  135. 5.3+76mm
  136. Vengeance built 2009 C6 Z06 TTix Twin Turbo System makes 847/776 on 12 lbs of boost
  137. 2004 5.3 engine ?'s
  138. Mayhem Motorsports / Lucado Racing X275 C6 Corvette at WCF - 7.72@180 - VIDEO INSIDE
  139. Any one use Holley 522-128 Universal Fuel Injectors (8) low impedance 120 lb hr flow
  140. FMIC and pipping question
  141. what do you think about a powerglide on a 1000hp street car
  142. Any 2nd Gen Camaro's with a single s475 post pics please
  143. 408 turbo cam recommendations
  144. best 88mm for under $2k?
  145. My buddy says....."Not possible!"
  146. Procharger help!
  147. Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
  148. New self contined turbo system. You gotta check this out!!
  149. Damber and fuelpump for procharger kit
  150. Procharger rebate - save up to $500
  151. plugs gap change+same timming table=pushing water???
  152. What do you guys think?
  153. I have a VORTECH SUPERCHARGER FOR MY 02 TRANS AM I AM THINKING OF SELLING!!! HELP
  154. Has anyone tried a 70mm turbo n a LS engine?
  155. 7.44@192 with an 88m turbo**new videos added***
  156. Procharger HO kit, P-1SC-1?
  157. Preliminary #s, 402/F1R
  158. Pictures of where you guys mounted your air to water intercoolers
  159. What is the optimal rear gear ratio?
  160. Ls9 valve springs on 317 heads
  161. New to lq4 turbo jy questions
  162. New Maggie?
  163. help all procharged fbodys !! belt slip n low power
  164. CalSpeed C5 427"/TT rear mount best ET 8.9 & 161, 91 octane pump gas, fastest 4l60e ?
  165. Making "log" turbo manifolds
  166. Short deck 427 or Tall deck twin turbo?
  167. GT45 on an LQ4?
  168. Proper tuning sequence
  169. Lets see your exhaust setup Turbo guys!
  170. jy 4.8/5.3 guys come in
  171. We just Sprayed 200shot on C6 ZR1.....
  172. Quick spark plug question
  173. Procharger bypass?
  174. which spark plugs for e85 and mp122 maggie
  175. A&A Corvette Vortech users - post your combo plz.
  176. Magnacharger question
  177. Junk yard 4.8 wheelies and new personal best and stock bottom record. video inside
  178. "simple combo-big power" runs 9.71@146 lifting-rowing gears!
  179. Front mount A2A intercooler sizes
  180. Going for MOAR power, new motor and MOAR goodies! gen IV 5.3 & tc78
  181. Fuel Pressure Reg
  182. New Cts-v record
  183. E85 and Non Intercooled
  184. AES 410 whos running this motor
  185. BW s480 build. Ls1 block or 6.0
  186. Fastest bolt on ZR1??
  187. Turbo LSx breaking up in boost
  188. turbo guys------? about crossover and pcv
  189. Post pics of your twin turbo setup
  190. Aps turbo with 427 cubes?
  191. Vengeance built 415 cubic inch F1A ProCharged '12 Camaro SS!!
  192. Crazy wild turbo kit build
  193. Turbonetics good or bad?
  194. Wrong blower in my Goat
  195. whats the better choice to go with, supercharge or tubro?
  196. Mark Carlyle - 6.91@221!!!!!!!
  197. Help me pick the right setup
  198. which mig welder
  199. F1A Camaro SS in GM HIGHTECH
  200. TWINS! School me.
  201. efilive tune?
  202. 57lb Injector vs. 1999 C5 vacuum referenced fuel system vs. Lingenfelter vs. n00b
  203. Cam Lobes for FI
  204. LS1 or LS2 Intake ?
  205. -12 feed fuel cells now available at BD Racing.
  206. Turbo cam?
  207. Why isn't this done more? (Twin screw/roots blown LS1)
  208. Vengeance built 457 cubic inch Twin Turbo C6 Z06- 1055RWHP/1066RWTQ on PUMPgas
  209. Best engine for the swap?
  210. on3 ford headers with ls1 flanges questions
  211. 224R for a LQ4 with a GT45??
  212. 11.3:1 434ci with <10psi twins. Thoughts?
  213. EPP/ Brute Speed cam guys
  214. Difference between "cross top" and normal dished 5.3 pistons??
  215. Finally TT my 2002 firehawk
  216. Twins VS a Big Single??
  217. FORD-TT CobraJet
  218. What size turbos for a rear mount twin, high comp, low boost 434ci engine?
  219. blow off valve
  220. LQ9, D1SC, and 900whp...Is it possible?
  221. 6.2l
  222. Which head for boost at high rpms war hawk or procomp ls3 cnc
  223. questions on my 6.0 s472 build
  224. What is so magical about turboing a stock 5.3 liter LM7??
  225. 5.3 cam
  226. Another LS9 head question
  227. 5.3+turbo+hot cam?
  228. Crank cog for supercharger
  229. 88mm single turbo build
  230. 9.96 @135.5MPH Procharger p600b
  231. '49 5-window Chevy
  232. Instead of cast truck manifolds... Can you use..
  233. Truckin, Big Bang 5.3L
  234. Help me pick a new color
  235. FNG Truck manifold questionwha
  236. LS6 heads and a stock 5.3 compression ratio
  237. Got my LF88 X275 car out to the track on Saturday (pics)
  238. Need some Turbo Advice Please
  239. Plugging or routing heater hoses?
  240. Twins on a 4.8?
  241. ? seen 11.08 psi on a 4.00 pulley@6200rpm
  242. Best stock cam 98 ls1 or 5.3 truck
  243. Silicone hose(s) - Who is using what
  244. how accurate are boost calculators?
  245. HELP!!! Trying to decide on a turbo or turbos... 5.3 build.
  246. took the junk yard 4.8 to the dyno today.
  247. Finally got it....
  248. My front mount set up your input
  249. L33 block strength
  250. Twin 6262 T/A - Turbo Joe/Straightline kit | 370 CID | 6 sp *** It runs!!
