View Full Version : Conversions & Swaps
- Dumb Question?????
- Mods before dropping in the motor?
- CTS-V oil pan, pickup and screen for sale for LSX Swap
- ssr rear end?
- LS1 into 1964 Chevy Malibu S.S.
- Z06 motor in an Escalade???
- Granatelli or factory MAF sensor?
- using ls1 headers??????
- Do I need a pressure Regulator?
- ls1 bmw 5 series conversion
- Carbed 5.3, 6.0 68 Firebird
- How to tell if the VSS is working or not???
- Any turbo fox/sn95 out there????
- Fuel pressure regulator plumbing?
- SBC 383 in a 1994 Firebird 3.4 Car
- Wiring harness ?????'s
- Vehicle Weight
- engine/trans angle vs. rear end angle
- Chassis fabrication.....
- Cheap fuel pressure gauge for schrader valve?
- hp tuners flashing problem
- fuel problems help
- No tach signal
- T56 reverse lockout solenoid plug?
- LS2 Datusn Dyno Results!
- LS1 into a 99GT??
- LS4 oil pan
- Walbro forgeries being sold
- BMW Z3 conversion
- how much will i gain?
- LSx Diamension differences ???
- Plug Size
- oil p/u question for gto ls1
- Need some help w/ conversion
- Built LT1 in 94-96 9C1 Caprice or LS1 Swapped in 98+ S10
- Crate Engine -> No MAF-> What do I need?
- What the heck radiator is this? (6.0L Police Package content)
- 2000 5.3 vortec to a 2003 4l60e out of s10???
- f/s lsx to mustang motor mounts
- anyone went the other way with a swap???
- Any way to tell exactly what engine I bought?
- ALT Light for '02 harness?
- Oil filter/Pan flow direction
- Debating about selling my ls1/fox project...
- 97 gmc z71 conversion
- ls1 fairmont part II
- TT Chevelle went to the drag strip. Update.
- Radiator question
- LS1 S10... questions
- duramax wiring ?
- LT1 motor mount HELP please
- considering a tube chassis fox body with a turboed LX7?
- LS1 in 68 Camaro Cooling system problems... runs hot at idle
- ls1 wiring speartech????
- Wiring harnesses
- GTO LS2 engine into a '68 Camaro?
- TB-to-MAF plumbing
- Ls7 Maserati Conversio
- 69 camaro battery hot wire !help!
- What did you pay for your engine?
- LS2 into Gbody update
- 95 chevy TBI
- Finally hit the track!
- Clutch pedal travel?
- pics lq4/lq9 + fox stang + 4.6 mounts = no workie
- Jeff Schwartz- Ultima Twinturbo 6.6i (LS2) in SilverState Challenge
- What are ECU options when using 5.3+ nv4500 or t56?
- No heat what to do w/ ports? Rad hose?
- Converting M6 to AUTO/ AUTO to M6
- FYI - SW Speedo connections
- ls1 into factory five 65 cobra kit
- LS1 Starter
- no spark
- heater hoses
- heater hoses
- 80Z28- Looking for LH6/LS4 swap.
- Fuel rails?????
- oil pressure sensor help
- Another 240sx project slowly beginning...
- LS1 Wiring Harnesses
- Wire Harness Loom protection
- LS4 in MR
- Need part # help
- northstar
- What vehicles does GM offer the 5.3 in?
- Wiring fans
- Newb questions
- Where to find info for Jeep CJ-7 conversion?
- Steam Vents, Front or Back?
- Drive by Wire-Vette Pedal-> '56 Chevy
- F Body Cruise Control - anyone used this on a swap?
- Review The Rookies Work....
- 05 gto fly by wire pedal
- 5.3 in 1966 Mustang?
- Wiring
- Wiring
- Put an ls1 in a firebird???
- k-member
- Looking for cylinder head coolant passage plug.
- any conversions having fuel problems?
- 6.0 engine ideas wanted
- confused, suddenly
- 240sx....not quite ls1...
- I Need an Fbody Oil Pan Setup
- Source for LS1/T56 cutouts
- LS1 Swap..$$$$
- LS1/LS6 intake on LQ4/9
- Vega getting closer but have PCM Question
- 5.3 into 1958 Chevy Apache Pickup- work underway
- v6 to v8 conversion
- It's Alive!!!!
- LS2 in a Mustang?
- ls1 lt1 t56 differences?
- Best place to find a straight water neck
- tach/ls1 help
- mechanical temp sensor
- Another Chevy II
- Newb: School me on LS1/ T56 swap into a Colorado
- LSx swap with mechanical clutch linkage car?
- LS2 exhaust pipe connection
- Ls2 weight
- fuel tank sump kits
- 5.3 stock comp to HRAir - AC fittings issue
- alternative fuel pump...bosch 69100?
- Some swap updates! 4th gen A/C, air intake, brake setup, exhaust issues...Big pics
- Z06 engine
- s10 ls1 fuel lines????????
- total cost and newbie question
- Couple more LS1 into Z3 pics
- Stock Fuel Rail Question
- my s14 ls1/t56
- First Gen F-body headers
- solid mounts
- reverse hard to get into?
- ls1/4l60e to ls2/4l653 swap?
- ride along video in my LS1 swapped 240sx
- What should I check before starting rolled car?
- 2 dr Tahoe LS1??
- LQ4 into 81 camaro with a th350 problems.
- 2000 S10 Blazer, 6 Liter w/Magnuson Blower
- 99 vette regulator/filter not working?
- ls1 into 65 c10, use old 6speed?
- ls6 in a '94 S10......
- GTO LS1 into a 3rd gen F-body
- Proud & Happy new owner of an LS1/6spd Notchback! (Mustang)
- 98 LS1 temp sensor
- LSX into BMW
- 99 dash harness different than 98?
- Temperature sender
- Temperature sender install
- MIL Issue
- 1987 Supra LS6/T56
- Ls2 motor harness Q's
- oil pressure sending unit
- Going to build LS1 S13....Need rigidity input...
- Radiator sizes you run per Hp you produce.
- Kmember mounting pads.
- Slick LS1 powered dune buggy
- TransDapt Biscuit Style Motor Mount????
- IAT sensor remove
- '63 C10 pick up, 5.3L and 4L60E install questions.
- GTO accesories
- Throttle cable part numbers? Search is broken
- FS: Complete LS1 /w 4L60E /w accessories, wiring harness/pcm everything CONVERSION
- Help, motor won't stay running!
- Hey Pro-Touring A body guys!!
- Need part number for V6 fuel level sensor
- Z06 Header Ball and Socket Flange
- formula functional hood scoops w/ ls1?
- Painless harness (alternator wiring) question
- 1963 Impala - looking to put in a Ls1 what is needed?
- Few basic ? to choose right parts
- LSx into a 944 porsche
- Cruise Control "Cruise/Resume/Accel" arm
- Fan Wiring and Manual fan switch with LED's
- 2004 GTO LS1 into 1986 Mercedes 300 SWAP
- 72 camaro mounts LS1
- LS1 into a 84' 300zx need help please
- Painless harness questions...
- motor mounts ?
- Oil pan cover part number?
- LS1 in a third gen
- Fans Turn Off With The Key? Is This Normal?
- 01 ls6 in a 56 ford p/u... PROBLEMS!
- 5.3 into 58 chevy apache pickup
- Whats up with my oil press SU??
- My 300zx Ls1
- Crank trigger sensor and cam position sensor
- Hybrid cars track video
- 4L80E in a fox chassis mustang
- are gto ls2 and ls6 cts-v oil pans the same?
- widebody datsun
- Dropping an LS1 w/ 460le into 1936 Chevy Coupe
- LS-1 to Datsun 240Z swap
- Ls2 pulleys
- Headers for second gen trans am
- LS2 install is moving along
- LS1 S10 pickup with longtube question.
- Anyone going to Route 66 Rendezvous?
- quick question from a newbie.....240 sx
- Rapid Motorsports 1969 427CI LS2 Camaro
- should i feel special?
- Fs rx7 93 shell w/ hinson parts cheap
- ls1 into first Gen 300zx (Z31)
- Ls2 crate motor
- got my exhaust done
- 77/78 trans am
- Journal of an LS1 FC swap
- finished my project now a few questions?
- LS1 Silverado Swap... NEED HELP! ????
- Pics of my LS2 Project.
- I hate fuel systems
- Where is the best place to get a complete 5.3,
- pics/vid of my ls1 rx7 autocrossing
- Lt1 240.
- fired it up today!!
- Started the first try
- Another LS1 Cobra Daytona Kit
- Cranks but wont start...OHHH NOOOO.!!!!
- 57 Belair LS2
- Disconnected VSS, Pulses from ECM?
- D.S.E. products
- Bought an organ donor today.
- Need a list... LS1 mustang swap
- LS 2 and TFT 727
- ls1 in 240sx? rx7? miata?
- 1993 camaro wiring
- Moving shifter w/ help from McLeod
- AC Bracket help
- LS1 into a Ski Natique
- Autometer Speedo hook up
- Looking for a LS1 conversion project!
- Dumb cooling system question
- does anyone know about.....
- lt1 to ls1 swap question
- LS5 Fiero?
- STAND ALONE HARNESS lS2
- coolant cross over pipe what to do?
- Another A-body mount thread...
- LS1 Mustang For Sale.
- LS1 Monza Picture Story
- What would you do with this...?
- 2 New Classic Update Kits from American Autowire
- 3rd gen LS1 swap...
- Boost VSS High? Speedo? Transmission? HELP!
- Inertia Fuel Pump Cut Off
- 70 chevelle LS & T56 conversion
- Tranny Mount Question
- ECM/Harness won't run, swap question
- trans-dapt swap kit...
