View Full Version : Forced Induction
  1. front mount turbo ac question
  2. 4500 TB and boost with hat ?
  3. Best machine shop near sacramento???
  4. 5.3 turbo question
  5. spec my s480 :)
  6. Procharger with 11+ compression
  7. lt1 procharger
  8. boost non I/C 5.3
  9. ****LMR 2013 ZR1 Video****
  10. Which is better for boost L33 or LQ4. S475 Turbo
  11. 2.3 whipple
  12. Intercooler question
  13. tuning and what octane fuel to use / its limits
  14. AES 390 w/F1A IS FINALLY ALIVE!!!!
  15. ms4+boost=???
  16. Can 304cfm heads make 900 RWHP......single turbo....
  17. Rebuilding APS Turbos TD06H or TD06???
  18. stock vvt cam and forced induvtion
  19. 5k rpm wall t76 370ci
  20. Hp twins or supercharger???
  21. New engine and turbo break in?
  22. Overtorquing Head Studs?
  23. thoughts on my cam.
  24. 2004 GTO Turbo Build
  25. LIMITED TIME. Huron Speed front mount single kit with fuel pump!!
  26. most compression with boost? (success stories?)
  27. TT 5.3l A/R selection help.
  28. Problems with 99 ls1 block?
  29. 87 IROC with a Magnum t-70
  30. Belt length
  31. Is a .623 intake .623 exhaust 112 lsa cam to much cam for....
  32. what size are the aps upgraded lg turbos?
  33. blow thru carb guys cfm question
  34. Slow spool
  35. 6.87@204mph drifting:)
  36. gears selection on an F1A.?
  37. Wideband bouncing around while cruising
  38. question
  39. JY 5.3 w/gt42 in foxbody
  40. What rings for high boost and big power?
  41. 4.8 and turbo from 6.5
  42. need advice on this cam.
  43. supercharge it or not?
  44. Sdce bracket
  45. 95 Z28 TT 5.3 true street. build
  46. Update on my whip
  47. stock exhaust manifolds are seriously this thin?!??!
  48. how do i get more boost out of my p1sc? *CAUTION* more info wanted inside
  49. Stock 6.0 crank and procharger guys inside
  50. FAST 102mm TB and intake, injector/rail question
  51. eBay head studs with ARP specs... ? Comment please...
  52. Where do I put the 2 o2 probes on my turbo conversion?
  53. New turbo design
  54. 6.0 truck 04 gto mp112 supercharger
  55. 2010 Whipple Camaro w/ 4L80 Swap
  56. Maggie Experts Please chime in
  57. Switching from 853's to 317s, worth it?
  58. How to: Adding Idler Pulley to Modular Turbo Alt Relocation Bracket
  59. Huron Speed turbo + PT7675 WS6
  60. Twin Borg Warner S472s?
  61. Turbo 5.3 RX-7 First Start Up!
  62. 6.0 cam/intake only and turbo ?
  63. My 6.0 front mount build
  64. custom grind cam not ao custom
  65. 2.5" or 3.0 ic pipe
  66. will my cam work in a turbo build?
  67. Messing around in my turbo car before teardown
  68. how to reduce stress cracks on twin mid mount setup
  69. Turbo 5.3
  70. Turbo and S/C guys, let's hear your 4l60e issues
  71. Boosted 5.3 Coupe New PB
  72. Explain this TT 375ci set-up...1100+ HP....how hot is this charge air...no IC.....
  73. Simple LS Swap Gone Awry (370/LS3 heads/PT88) *Dyno #'s Page 6&7*
  74. How much boost?
  75. Intercooler?
  76. crank case pressure under boost
  77. 600rwhp goal with my new d1sc
  78. Trying To Build Ls1-ls3 or LQ4/LQ9 Street/Strip Motor Hopefully Boosted
  79. Turbo LM7 advice
  80. 4.8 on3 turbo
  81. what is the best radiator and cooling fans for a vertical setup
  82. Truck manifolds? Really?
  83. Green tops enough for D1?
  84. eBay twin turbo kit?
  85. Vacuum line Help
  86. Which 1000hp rotating assembly? (6.0L)
  87. What radiator to buy?
  88. Valve float 52-5300 rpm. Than no issue.
  89. do heads make power with boost?
  90. Ls7, Beck vs carys.
  91. Huron Speed TC78 Trans Am Build
  92. supercharger help...
  93. what cam w / blower
  94. Tuned my car yesterday! Turbo got damage
  95. ring and cam question
  96. Who is using these 160# injectors from Bosch?
  97. Can I use this old intercooler (PSJ style)? Change to newer? Chemical cooling?
  98. 454 LSX - Need help picking a turbo
  99. Need some advice - 6.0 and twins..
  100. I plan on turboing a stock 4.8 with stock 243/799 heads with a 76mm turbo.. CR help.!
  101. Add 100-150hp ... Information overload. Best way?
  102. Crap! Still overheating
  103. Killed it
  104. Welding vband to stock manifolds
  105. Warning
  106. sleeper turbo build
  107. Turbo to small questions
  108. ProCharger 3D Supercharger Animation and chance to win a prize
  109. which turbo to get? step inside
  110. ls6vsls2/ 04gtovs06gto
  111. Turbo fuel pump woes...
  112. lsa parts
  113. 5.3 truck manifold for turbo question
  114. Best place to buy LSA heads?
  115. Ebay Turbo Kit
  116. H/C/I guys wants to go procharger
  117. 5.3l lost oil pressure
  118. Head bolts or head studs??
  119. what to do for a cam?
  120. anyone ever did a custom intercooler setup on a aps tt kit?
  121. cant get my turbo car to cool, what kinda cfm do i need?
  122. Harris Speed Works
  123. shimming valve springs for more seat pressure and boost.
  124. LS1 STS Kits??
  125. 05 up LQ4 boost limits
  126. I know it gets old but goin crazy lol help
  127. will the turbo spacer and waste gates be an issue??
  128. ls9 cam + pac 1218 + 14 psi
  129. Maggie cog belt
  130. FI PCV System
  131. Critique this custom cam- turbo 6.0
  132. Attention E-Force dealers.....
  133. Opinion on a cam please
  134. Toyota Truck, different LS1 turbo conversion
  135. 5.3L boost ?
  136. T4 vs. T6 Which is more beneficial
  137. Turbo S-10
  138. blow through carb
  139. Pontiac G8 GT going under the knife for an F-1D!
  140. 5.3 sts???
  141. May run into some issues (Injectors & Map Sensor)
  142. Cheap good Electronic boost controller?
  143. What turbo kit would suit me?
  144. What do I need
  145. ***LATE MODEL RACECRAFT NEW Website***
  146. 370 or 408 and what internals??
  147. TT C6 ZO6 vs 91mm WS6 vs UGR Lambo
  148. Turbonetics Racegate sticking/rusted shut, need recommendations
  149. building my 1st turbo motor need your head suggestions
  150. d1sc question's
  151. turbo exhaust
  152. Magnacharger,, help with Cam?
  153. entertain me this, boost cam for N/A Car
  154. Borla or Magnaflow or ? on turbo
  155. Wideband before the turbo
  156. Turbo Foxbody fuel system ?
  157. I'm having boost issues
  158. what converter stall speed for a turbo 4.8?
  159. anyone running fans on the front AND rear of theyre radiator???
  160. spark plugs turbo drag race on E85
  161. Procharger bypass valve removal
  162. supercharger
  163. ls9 valvesprings and turbo?
  164. Need some help with fuel system (fuel cell)
  165. Anyone have a TT manifold kit like this??
  166. anyone turbo'd a 6.0 with a HX35w?
  167. My engine doesn't like NGK TR7's
  168. Compressor wheel rubs inside of housing
  169. Anyone have dyno / times at 10 PSI
  170. procharged ls1 running slow
  171. holset hx52/hx55
  172. Need suggestion for down pipe clamp or vband for percision 6265?
  173. c5 vette alternator bracket
  174. My 1969 Camaro Prostreet Twin Turbo Build!
  175. Supercharger..
  176. L92 vs. 317
  177. Turbo too small?
  178. Turbo Advice. Looking to upgrade from PT88 *COMP TURBO RESULTS*
  179. BruteSpeed / EPP blower cam - users!
  180. Supercharer or turbo
  181. LSA head for under $200
  182. Any 5.3's out there with Prochargers?
  183. Found an old video of my Camaro back when it had 120,000 miles on original engine
  184. which intake to go with? vic style or the pro flo?
  185. Thoughts on this Futral Cam 5.3 tt
  186. !Help me pick between 2 blower cams!
  187. My forged LS3 is a go.
  188. Heads L92 vs LSA
  189. Catch can idea with ls9 cam?
  190. Daily driving 60 lbs injectors with a TSP tune?
  191. cam swap advice
  192. New to FI...Critique my combo
  193. ? Re: rear end gear ratios and rear mount turbos
  194. why is everyone choosing a 5.3 over a 6.0 lq?
  195. Brute Speed cam or Hold out
  196. My tt "budget" 6 speed build Now with BA 2-step vid (pics back up)
  197. Any Procharger guys have main belt problems?
  198. Recommendations what's the best cat back for big boost application on a F-body
  199. 60lb + injectors for LS1 plug and play?
  200. procharger friendly cams?
  201. What is the difference between a .81 AR and .96 AR turbine housing?
  202. Well, DKT did it. C6 Twin kit. well sort of.
  203. d1 procharger kit for sale
  204. My 5.3/F1 GTO
  205. Fuel Injectors......20psi boost.....but will run NA for a little while. What to get?
  206. LSA heads 2 differnet part numbers???
  207. Methanol nozzle placement in relation to bov and iat sensor
  208. how much boost can you build off the foot brake? VID inside
  209. LS9 cam not good with turbos???
  210. what heads for a boosted setup. Poll inside
  211. Turbo Comp Cam LSR 277, will the valves hit the pistons?
  212. Big Red Bov with turbo
  213. '95 TA LQ9 intake questions
  214. MAF, METH and IAT with Twin intercoolers
  215. Rear Mount Tubro, why and why not? Gurus on the subject appreciated
  216. Holley Hp Efi VS HPT/EFI Live??
  217. LQ-9 370ci with LS-3 Heads and Intake Swap
  218. Procharger and stock 5.3?
  219. 4.8L Turbo Tahoe Sputtering? Q/A
  220. Turbobocharger Gurus Needed.
  221. Not an LS... Hellion Twin Turbo Results 941 Rwhp 915 Rwtq
  222. 76mm and 408ci too small?
  223. piston slap problems
  224. 8 second stock 5.3 THE GRENADE
  225. Question boosted 5.3
  226. Am I wrong for going with a 3.90 pulley for my F1A?
  227. Rear Mount Oiling Help
  228. Someone to tune?
  229. '95 TA A2W intercooler
  230. High idle and backfire after sc install
  231. Turbo Silverado | Turbo Camaro | Turbo Fox | Turbo bike
  232. Horizontal Radiator
  233. Holley fuel pump
  234. swapping from nitrous to a blower
  235. FM Turbo and emission testing?
  236. Meth and twin 4.5" intercoolers?
  237. Rear Mount Turbo
  238. Another STS Turbo Question before I jump on it
  239. Maggie 112, valve float or out of blower ?
  240. Mondo, Big red etc differences ?
  241. diamond pistons? can these be used
  242. 370 forged motor on 15psi breaking up high rpms
  243. Accessory bracket for LQ9 408 w/ F1??
  244. UMI K-member Turbo Clearance
  245. procharger guys, who long does it take you to "spool" your centri?
  246. High CR question
  247. Turbo Blanket/Wrapped DP Q's
  248. How to modify PTK kit to install bigger turbo
  249. Just pulled the trigger on an F1A
  250. Who said turbo cars don't 60'
