View Full Version : LT1-LT4 Modifications
- Completely Lost Help
- cam question
- What is required to swap in a LS1 rearend?
- Front plates on LT1 cars
- Installing motor mounts.
- why would my rpms change after cam install?
- replacing the clutch...
- headers and y pipe installed, but as usual...problems
- M6 Swap
- MSD opti?
- LT1 still overheating at idle
- Burnout/Donut (PICS)
- Best fitting Rad
- i hate optis
- LT1 selling price????
- whats is this???
- Lt1 tranny
- Electrical boogers
- my car is too slow. help.
- too many miles??
- Pace Setter Y-pipe..
- Z06 85MM MAF, who is using it?
- differances in LT1s?
- Wow its gone for the moment.
- Could you guess from this picture?
- Ok, the rear main?
- Newbie to the LT1 world! Need some help
- Need some help
- LT1 swap
- Shaking
- msd question?
- What's up
- 93' 355 Dyno Graph And Vids
- Vid: 93 LT1 Burnout
- i found this odd
- Need more power in the higher RPM range
- adj. tourqe arm
- 1995' 5.7 in a 1999 Escalade??
- drive shaft
- Have we come to the conclusion that the air gap intake is a dud?
- Car hard to start after sitting one day
- got a question
- My Guages Going Along With Cam
- Why do some people say you can't run Bosch O2 sensors in LT1's?
- Long Tubes tuning effect
- o2 sensor ?'s
- Rip Off
- how to put the opti on
- Oil pres drop at high rpm??
- AC Problem
- canton
- who has a be cool ?few Q's
- Infamous Low RPM Stumble. Need Help!
- Coolant temp sensor location
- assembly lube + hydraulic cam = okay?
- gear ratios and mph q. The site may be wrong.
- Pacesetter LT people, come in here!
- help exhaust problem
- Blown Head Gasket??
- car wont start
- LT1 intake porting
- CAI for 97 z28 WITH TRACTION CONTROL!
- any info on the new HOOSIER DOT DR"S
- Rip In Peace Trans Am
- cranking slowly
- What is a total cost of CC306?
- One step closer to the Bolt-on LT1 record
- Free mod/ IAT Timing Tricker
- Lt1 timing chain
- 94 Z28 no power need help !!.......
- 93 and 96 lt1 pinouts
- any camaro's around arkadelphia, AR?
- couple engine bay pictures
- moroso air filter cleaning?
- What start y'all use?
- Hotcam LT1 dyno sheet
- Best ignition box for LT1
- bucks and kicks, rpm and speedo needles go haywire
- went and made a baseline pull today
- A/C Delte for a corvette LT-1??
- manual rack or UMI k-member, weight loss?
- Rcaetronix 32lbs flow specs in Tunercat
- H-pipe no cat exhaust?
- Code help: secondary air pump
- 97 lingenfelter hurst bird
- adj. timing chain
- Will a LT1 run without the O2s hooked up?
- Average Temp for LT1 engine?
- dual exhaust
- 95 Z28 6speed - need mods
- best sounding true duals
- o2 sensors
- Can't get my car to launch right at all
- Big problem after o2 change
- 383 Crank???
- Why won't these work on an LT1?
- What injectors should i run??
- lt4 kit upgrade?
- a/c line in the way of strut tower bar - can I bend it?
- stupid question?
- Will an oxygen sensor from a '97 LT1 fit my car?
- Lt1 Needs Help
- 4.000" stroke??
- what cam for 383?
- I got screwed on these rockers
- Who's the best mail order tuner?
- whats your fuel pressure?
- Engine Mount
- Any LT1 Stock Eliminator, bracket racers?
- This RPM right for 2.73's???
- mean street
- LT1 Fbody=PITA!!!
- Monoblade
- Lt1 tuners in Houston?
- oil pressure
- stock tranny
- o2 trouble
- 96 ws6
- stock lt1 e/t's
- LT1 or 502bb 67 camaro?
- who makes a lt1 carbuates manifold.. single pane?
- im depressed
- temp gauge going crazy! HELP
- how to change lt1 head gaskets??/
- 94 Lt1/a4 Pcm...
- How much gpm does stock water pump flow?
- Are PCMs compatible?
- Tach install?? I need help
- Intake
- How quickly will fuel go bad???
- converting from lsx to ltx
- Car falls on its face off the line, how to set idle?
- Coolan crossover tube in back...
- feedback on delteq system
- 355 cylinder volume?
- Dyno'd today
- Speedometer ?
- Intake hoses?
- What to clean the exhaust ports off with
- Car wont turn on help
- what else could I have Tuned to the ecm??
- Cheap good clutch
- Ram Air owners...
- my car let me know what you think!
- Injector Size?
- idle issues
- Good headers
- Anyone know what these plugs are for?
- 700R4 took a nose dive
- need to know the year of this ecm
- What forged pistons are you guys using?
- spark plugs?
- Golen 383 Dyno results inside
- Great News!!!!!!
- Code 53/SES Light
- Wont run long...
- 98 Chevy 5.7 pickup
- Installed cam, car idles well, shuts off at stop sign.
- My CC503 Dyno #'s
- 4in. mufflex
- how much for rear gear install
- Need help finding a Trans Am GT badge
- True Duals... How/What...
- Checkout this bad boy
- Washed my car, they tar and chip my road
- After vortec elbow install, what to do w/ this?
- Bought me a Trans Am yesterday!
- ecu?
- Injectors
- Timing chain
- Header Bolt Threads In Head Stripped
- opti or wires ?
- Tool used to remove plug for coolant temp sensor...
- car still overheating
- TB Z28/LT1 plate
- pcm problems
- Fuel Pressure ?
- valve spring question
- Anyone DD dumped true duals?
- This is "GOOD" deal or a "NO" deal?
- i need a crank key! where can i get one?
- What is GMMG?
- ignition box
- Ford ?
- oxygen sensor
- Trans Am Decal?
- Just bought injectors...
- Pacesetter lt's and Plugs?
- Newb: "how fast am I?"
- 383 LT1 Stroker coming soon.....
- what kinda numbers?
- anyone run true braided rad lines?
- About to order pistons
- lookin for 300-350 hp???
- Oil Pan issues?
- how to achieve zero-deck height?
- Went to the track on Friday
- Drop Shocks
- Golen engines 396
- HP and ET guesstimates w/ LUNATI 232/242
- building 383 need help
- In need of some help in Pittsburgh Pa
- Best/Cheapest place to buy.....
- How to change struts?
- vibration?
- Is this intake kit worth 75$?
- 1.6 RRs on 93 vette heads...
- need an opinion
- car took a dump today! need help
- Cam suggestions?
- Front engine oil leak please help.
- cat inlet/outlet sizes
- high rpm "popping" on nitrous
- 93 to 94 LT1 Conversion, No Comunication Through Diagnostic Port
- stance question
- finally running again!
- Anybody need a spare hood, i got one.
- Rocker help
- 2.5" or 3"
- LS1 manual alum driveshaft fit in an LT1 auto Z28
- LT4 Heads!!!
- Breaking Up At Wot
- Wot Breaking Up
- Seafoaming an LT1
- pass side plugs and wires
- Bolt on Lt1 Trap Speeds...
- Spark Plug Re-Thread Tool
- Throttle Body...
- Hose mod?
- LT-1 Rod???
- Engine tick?
- Est. Horse Power?
- throtle body
- Wheel Spacers
- Figuring out exhaust
- HOTCAM + headers + borla
- Broke header bolt off in Head on Cylinder 7...help
- cam help
- LT1 tuning, logging in Ct. ?
- Who does the cheapest tuning?
- Bent pushrod
- shock tower braces
- Spark plugs on an Lt1
- O2 Sims and EGR
- electric water pump in car slowed down
- 2 things
- oil level sensor
- radiator question
- relocating air bag sensor?
- stock LT1 intake manifold opening
