View Full Version : LT1-LT4 Modifications
  1. 4l60e problem
  2. LT valve clearance
  3. Bulb sockets
  4. Car has keless entry- can I make the lights flash or horn beep?
  5. I hate my car, 2 Optis still no spark... WHY!!!!
  6. signs of failing opti...
  7. OBD 1-2 connector swap
  8. wiring
  9. Whats the lightest aftermarket 93-97 Camaro hood on the market?
  10. finally its all coming together now! winter work thread
  11. starter problem
  12. spark plug wires???
  13. I want this car!!!
  14. need help choosing a throttle body
  15. What does this button do???????
  16. Looking for a LT1/LT4 Heads and Cam Kit (besides the hot cam kit)
  17. lt1 dual nozzle 325 and 350shot jetting
  18. 96 motor in a 94 car, cps sensor on 96 causing 94 not to spark with 96 opti??
  19. just a little excited today
  20. crank but no start.
  21. Pushrods help
  22. rare?
  23. Tell us about your budget stroker build
  24. Is there a benefit to running 1.6 Roller Rockers
  25. Exhaust clip finally. Hooker aerochamber with longtubes
  26. tuning software... Innovative Motorsports LM2? LM3?
  27. Air conditioner, Need Help?
  28. "Help" MAF question??
  29. kwik ?
  30. 2 bolt with a girdle or 4-bolt conversion?
  31. comp 983 question
  32. what is the stock 350 LT1's head gasket compression thickness?
  33. est. my numbers
  34. converting SBC heads to LTx?
  35. Header Bolts For The LPP's
  36. DART PRO1 set-up height?
  37. NEW Summit Stars are on!
  38. WOT, nothing after 4000rpm....
  39. 383 stroker motor ?
  40. First 1/4 run w/ 383
  41. 399ci at startup/idle :)
  42. tune needed with headers??
  43. keyless entry question!!
  44. ect codes
  45. Let See Your Pics Of Your Custom Alternator Braket
  46. what power steering pump do i use with the Alternator Relocation Bracket
  47. What next with 93 T/A?
  48. How long can an engine sit untouched?
  49. Intake Gasket
  50. PCM HELP !!!! Working on it right now
  51. How to retain cats /w headers
  52. LPP Y-pipe question
  53. Bolt sizes
  54. alternator question
  55. Can I run a intake like this on my lt1?
  56. Rod and Cam issue
  57. clutch pedal stuck!!!!!!!!!
  58. 3.42-4.10s(LOL)
  59. lt1 trick flow heads
  60. Cylinder head advice please
  61. TPIS Performance Parts (question)
  62. LT1 cam/lift question
  63. HELP! How probable is it that my LT1 jumped timing?
  64. Aeroforce Interceptor II?
  65. Going back to Muncie Dragway tomorrow
  66. hypertech
  67. Is there a way to test the Signal coming FROM the Opti?
  68. 96 Camaro Z28 Harness in a 94 Firbird Formula
  69. Firdbird Forumla Traction Control????
  70. ORY for mid headers?
  71. did the passenger airbag removal. need help!!
  72. Emissions Help!!!
  73. Head gasket Tests? Help...
  74. exhaust opinions?
  75. rough idle how can i fix?
  76. NE1 got a throttle cable they can send me?
  77. Better Idle Clip B&B Triflow on stock LT1
  78. Couple ?s for you guys
  79. Are one the same?
  80. What kind of crank?
  81. F'ed up optispark on rebuild
  82. Help installing tachometer on LT1
  83. 2.02/1.60 worth it with my setup?
  84. What are these wires?
  85. The "How many mods can you do before your 4L60/E bites the dust?" thread
  86. Fuel Pressure problem maybe???? HELP!!!
  87. Lugs at Low RPM
  88. No O2 sensors!
  89. self porting intake manifold?
  90. Intake Question
  91. What else when reinstalling a motor could cause no spark? Any OBDII to OBDI Causes?
  92. Just Finished clutch
  93. how the WEST Coast gets down....
  94. videos of lt1's
  95. 96capricemgr Call out
  96. Finally killed it
  97. option codes
  98. loss of cruise control
  99. Not your average LT1 :) LT1 240sx
  100. 1.6 rr and valve covers
  101. cam selection help
  102. SES light on... put reader on and no code?
  103. couple questions: High oil pressure/ MSD6al q's
  104. How big of a PITA is it?
  105. sbc/lt1 questions
  106. finally my custom joe overton goes in!
  107. Code 11
  108. new LT1 guy
  109. Head and cam problem.
  110. help car idles like shit.
  111. MadZ28 Mail Order Tune?
  112. Lt1 oil temp
  113. New best...... costly night however....
  114. New Opti Still no Spark... WTF!!!
  115. catch can , vc breather
  116. rear end
  117. NEW CAMARO! (new to me that is)
  118. supercharger problem??
  119. Finally got a vid up of my new exhaust setup. (True duals with knock-off 10 series)
  120. Place your bets !
  121. bell housong bolts
  122. motor help
  123. headders
  124. Has anyone rebuilt an Opti?
  125. Please double check my troubleshooting skills
  126. How to test for Opti Failure with no Present Codes...?
  127. TA Hatch installation?
  128. Unusual Problem
  129. Car won't start
  130. went to the track (times inside)
  131. Impala SS headgasket question
  132. B-Body head gasket confusion... .039 or .028?!
  133. More cam install questions..
  134. Finally finished the Swap... Cranks but does not start.... Damit
  135. why no gain??
  136. Painted water pump?
  137. what headgasket to run?
  138. Oil pan gasket q? Changing out oil pump?
  139. starts runs, then wont start back up.
  140. Oil Pan Access?
  141. Camshaft Bearing Question
  142. vats resistor
  143. requesting pics of single plane intake setup
  144. Pretty sure I broke something......
  145. Oil Leak!!!
  146. $342 to get FLUIDS changed?!?!?!
  147. I hate my life
  148. dfw,tx muffler shop
  149. 95 camaro convertible fuel pump trap door
  150. 9.46@141 advanced induction 383
  151. nitrous ?'s
  152. Hydraulic Rollers How High Are You Spinning Them
  153. urgent
  154. LT4 hot cam kit question
  155. early christmas
  156. ? for a4 guys with a stall
  157. Filter question...
  158. Which IAC motor can go in a 94' z28?
  159. 383 Acting Funny
  160. so i am getting ahead of myself
  161. should i update my opti?
  162. Impala SS basic engine/tranny tuning
  163. need ur reccomendations please
  164. lt1 heads and cam setup??
  165. What is this?!?!?!
  166. what kind of numbers are you making with your 383
  167. Crank hub removal, need help
  168. Pease help this pos wont start!!!!
  169. Custom Cam
  170. raising oil pressure
  171. 270 rwhp 380 rwtq
  172. Where to get a motor?
  173. What size freeze plug?
  174. 1.6 Rr?
  175. Temp Gauge Stops
  176. My Camaro at George Rays
  177. lt1 cylinder heads 93 or up which is best
  178. MSD Pro Billet Distributor. Likes? Dislikes?
  179. No more Catback for me!!!
  180. Lt1 Hot Cam Question?
  181. umi torque arm question
  182. What do you think it is?
  183. AIR/EGR Question
  184. Motor mounts.
  185. LT1 making a ticking noise
  186. LT1 Header Questions?
  187. 1995 obd1 system,obd2 plug,how do i get codes
  188. Master cylinder???
  189. Highest HP Hyd roller guys?
  190. Any Experience With LT1 Patriot Heads 2046
  191. Hydraulic Roller Guys - How fast are you running N/A?
  192. Diff getting weak, opinions welcome
  193. Is the LT1 engine reliable?? Opinons please
  194. MAF and MAP problems
  195. biggest cam for stock stall and spring????? HELP PLEASE!
  196. summit x-pipe???
  197. spin on adpator oil bypass valve
  198. finished with my build :D
  199. EGR Valve Pipe Help
  200. Personalized Liscense Plates?
  201. Smell of Gas
  202. Chevyfest = A new Personal Best for the lil bolt on only LT1! (long)
  203. N20 on Stock LT1
  204. Just have a ? on a mod (FTRA - LT1)
  205. What's the problem?
  206. Does Anybody Know?
  207. Cam swap walk-through?
  208. Chugging Issues...really need help
  209. Missing oil gallery ball, (or plug)? Pressure tested without ball. Results inside.
  210. Cammed LT1
  211. Need Help!!!!!!!!!!
  212. the new car im getting!! what do yo uguys think?
  213. How to reach 300 RWHP on Stock LT1?
  214. header trivia question dispute im battling./
  215. pulley me help
  216. what do you think of this?
  217. what belt
  218. infamous Intake manifold leak
  219. New lt1 owner
  220. Where can i get a stock LT1 flywheel??
  221. What to do first
  222. Did you degree your cam?
  223. pressure sending unit, and opti harness
  224. My exhaust options?
  225. Anyone running a Professional Product Throttle Body 58mm??
  226. see if this works
  227. Got some crazy problem?!
  228. identification numbers
  229. what does a stock 96ta weigh
  230. WTF Is There Really An All Aluminum LT1
  231. CC306 1/8th times and dyno graph inside
  232. knock retard question
  233. I Need Pictures of grindin of pro-star caliper grinding
  234. UDP's Balancers and that ever long Debate... Why not again?
  235. Ring Gap
  236. Please help with injector size
  237. Cam in my LT1
  238. weight reduction questions
  239. spraying an lt?
  240. LT1 tuning Questions 1994 OBD1
  241. Problem near collector?
  242. Waterpump Conversion?
  243. were can I get the info to get a set of le2 heads?
  244. LT1 info
  245. Crank internally or externally balanced?
  246. Went to do the test start and the Oil PSI spiked before starting o.O
  247. will a carbed LT1 make more hp?
  248. 95 Z28
  249. 3.23's to 3.42
  250. weird squeeking sound
