View Full Version : Forced Induction
  1. STS Turbo on built 383
  2. Evans Waterless Coolant
  3. how realistic are my goals?
  4. front accessory drive question
  5. turbo for max effort stock shortblock 5.3?
  6. 61 chev 383 LS1 S475 build
  7. can I push it even further!!??
  8. Another LS6 cam question...
  9. should i go vortech v9 or turbo
  10. Vortech for fbody?
  11. anyone running an electric water pump on the street?
  12. supercharged 5.3
  13. Turbo in my 93 Z28 Camaro?
  14. Good bye Twins hello Single front mount!!!!!!
  15. 1954 Studebaker LM7/T56 MP76
  16. looking for dyno# 370 0r 383 s475 83mm 110 ar
  17. Turbo Vs. Supercharger (Cliche Title)
  18. turbo setup help
  19. looking for pics and ideas on how to move the whole radiator forward for clearance
  20. turbo build
  21. "turbo guys"
  22. which heads for boost
  23. 6.0l turbo stang project coming along...
  24. TT LS2 dyno - power falling off
  25. Everybody and their mother has a tur-blow....LETS SEE SOME BLOWERS!!!!
  26. Gm screw in IAT
  27. So I am confused as to what turbo to move up to....Help please
  28. Vertical Radiator Fan Average CFM rating
  29. 2004 GTO - from STOCK to NOT - a Tick Performance ProCharger Build!
  30. Stick with LS1 or go LQ4?
  31. Winter 2011-2012 turbo build
  32. Help me decide on the induction side of my FI build. Holley+PRC LS3 or Edelbrock+AFR?
  33. Magnum Turbos
  34. Magnafuel 4303, E85, 1600cc injectors..will it work
  35. why is my boost falling off?
  36. Anybody Running 5.60's or Faster At 3300lbs?
  37. 370 or 408 ?
  38. wastegate 38mm tial
  39. Tial WG diaphram crimped/ Is this causeing boost taper?
  40. Dear Santa, please have Burkhart send me...
  41. Can I use a 6 rib belt on a 8 rib F1 Procharger?
  42. 9.5" or 10.25" TORQUE CONVERTER FOR 1000HP TURBO??
  43. can i put boost on a carbed 370
  44. Ati damper install help!!!!
  45. can i pull a 02 sensor to check back pressure
  46. Can someone help me pick a new turbo out?
  47. Which GT45s turbos do I purchase?
  48. Alternator on the Ac place?
  49. 5.3L build 862 vs 317 heads (compression)??
  50. S400 T6 LQ9 Mustang Turbo Build (5.85 @ 118mph)
  51. Can I run more boost??
  52. Wastegate ?'s..Can U manually open valve?
  53. Well I finally got some pics of my 370 and its ready to go in
  54. New PB..6.0@116mph....9.6@126mph video!
  55. First F1R LSX in the 7s
  56. Any one with a turbonetics t76
  57. Yet...another reason to run a got-dang INTERCOOLER!
  58. pics of turbo build.
  59. Strange cooling fan electrical issue
  60. new set up ??
  61. spooled up, whats up
  62. Considering Procharger
  63. cog
  64. recommend a gear ratio for my procharher combo please
  65. Vac line question and more
  66. supercharger boost leak?
  67. 7.4L exhaust Manifold ?
  68. 6.0 turbo 4l80e harness ecm suggestions
  69. With the right stall and cam would I notice any lag from a 91mm?
  70. lq9 with t6 turbo.?
  71. Ls7 lifters?
  72. Trans am 5.3 turbo build
  73. P0102 code after supercharger install
  74. How far would you take a stock crank?
  75. L92/vvt 6.2 motor and boost
  76. Twin rearmount turbo exhaust for S10
  77. TC76 aussi engine '99 camaro
  78. victor jr elbow
  79. modify a DS 1
  80. Turbo Cam NEEDED - 6.0L
  81. 1999 Firehawk Build - 402 and F1A
  82. How do I run vacuum lines turbo motor new style ls6 valley cover?
  83. Supercharged WS6 - Poly or Solid Motor Moutns
  84. Deck height with 6.125 rod
  85. Check out the 5.3 I just bought for $100!
  86. gear drive/crank snout question
  87. ebay vendor---->GT-45's..guesstimate my fwhp
  88. Motor Plate and Procharger LSX Transplant Cog Bracket (Madman's Version)
  89. lt1 turbo builds
  90. compression ratio help please
  91. Fuel problems up top
  92. Guys running Snow kits-where do yall mount the pump/resevoir in fbody?
  93. Tube to replace Mas Air Sensor?
  94. lq4 FI set up?
  95. Our little 370 Paxton powered GTO goes 8.99
  96. 600 hp on stock 5.3?
  97. truck mainfold set, do i have to remover nh sway bar?
  98. truck mainfold set, do i have to remover nh sway bar?
  99. What size exhaust should i run
  100. LQ4 pushed coolant
  101. Procharger Custom Kit Install .... Advice?
  102. Turbo setup..ready to order parts, am I forgetting anything?
  103. HELP! new to FI and i have some questions
  104. anyone running I beam rods at decent boosted power levels?
  105. cometic lsx reseal question
  106. Precision 6266s or 6765s?
  107. Which rockers for a boost application (15-25psi or more)
  108. Building boost off factory rev limiter (pomofo's two step)
  109. Widening ring gaps???
  110. 76mm on a 5.3, but which 76mm?
  111. Compression question
  112. Reasons to not go rear mount / Critique my plan
  113. How loud is open 5in downpipe?
  114. 6.0 single turbo combinations
  115. LQ4 Magnum T72 IROC build. New Track Times & Video Added!
  116. Lingenfelter LNC-002 issues.
  117. Camaro SS 370, LSA heads, 76gts **Th400 swap and dyno videos**
  118. Any benefit to running 317 heads on 5.3 Turbo?
  119. New PB. Finally had a clean pass with the 2 step.
  120. Looking for sparkplug for E85, turbo, high PSI
  121. Turbo test?
  122. is this normal wear for a piston skirt?
  123. Place your bets:160lb high imped stock PCM drivable?
  124. fall new best, 8.53 @ 162.3
  125. LS1 68 Camaro... Turbo? MAF? Fuel Pumps?
  126. Turbo 5.3 build...am I on the right track?
  127. Throttle Body Recommendation
  128. First time fabricator..
  129. Help with T70 on L33
  130. fuel lines??
  131. Intake manifold
  132. New best in the Turbo Firehawk
  133. Head bolts or Head Studs?
  134. How efficient is a VJ in a boosted application?
  135. Blown 383 Questions
  136. Looking for some forced induction advise..
  137. Timing Chain Stock 5.3 twin turbo's
  138. are cometic head gaskets repressable
  139. Just a feeler... Whats it worth?
  140. Twin Screw LS
  141. help with a little blowby not alot
  142. M6 gears
  143. coated bearings?
  144. Lets see some LS front mount turbo pics!!! PLEASE!!
  145. need help
  146. Put my car on the rollers today, timing/plug question
  147. Swapping EPP (brutespeed) cam to what?
  148. 07 avalanche 5.3 valley cover/magnacharger
  149. Spark plug insulator tip broke?
  150. Stick with LS3 shortblock or go iron?
  151. External Waste gate and boost control ?'s
  152. Truck manifold collector gaskets
  153. LQ4 Turbo Build - Looking for used parts
  154. somebody overlook my pvc catch can setup
  155. Procharger P-1SC kit for 98-02 Fbody for sale
  156. What heads for my turbo 408?
  157. journal bearing turbos...what size feed? restrictor? using HP Melling pump
  158. KY turbo kit?
  159. stock shortblock madness! D1+Nitro daves plate kit= 864 rwhp
  160. Does any re-use the manifold flange from the trucks?
  161. Wanting some input/advice! Thanks in advance! FI 370/TC78 setup
  162. Advice on a Forged LS6 build I'm planning, if you would be so kind
  163. 4032 good for 15psi?
  164. Stock TB or Aftermarket
  165. ProCharger Rebate Program!
  166. oil issue with turbo
  167. Opinions wanted on boost/power level capability for my shortblock
  168. Intake Manifold Flow Analysis
  169. Help with lifters
  170. procharger + nitrous question...
  171. Race Proven Motorsports 8.58@165 on Pump Gas
  172. Victor with elbow vs. ported fast 90
  173. Turbo size comparison
  174. Those with F1C Prochargers... what intake are you using?
  175. Made it KCIR, 11.8 at 134 mph.
  176. Pinning crank?
  177. Ohio boys Mike Brown wreck at Imports vs Domestics at MIR
  178. I need some opinions, 408+d1sc w/single255 pump
  179. 6.0 Turbo Cam
  180. What piston rings for LQ4 Turbo Build?
  181. Turbo build
  182. 5.3 rod bolt questions...
  183. D1SC vs F1A
  184. HELP with 8 Rib Procharger Pinning Kit
  185. oil out of breather
  186. Supercharged, or not?
  187. How much CFM will keep are cars cool?
  188. Finally got to track.. Vids. E85 questions also
  189. Testing Eboost2 ??
  190. RMCR High Mount YSI Set Up
  191. SC guys take a looksy
  192. Finally!
  193. RHS new 225 heads any info?
  194. Modular Turbo XT80 Turbo!!!!!
  195. Help with my rear mount setup
  196. p-1sc in ls2 questions
  197. anyone using gapless rings for FI?
  198. Timing chain
  199. Another Vic Jr. Question
  200. What oil and weight are you guys running?
  201. Meth injection on Volkswagon diesel
  202. Turbo size help
  203. New Turbo kit I'm building
  204. First FI Build! Stock-ish 6.0L +
  205. upgrading t4 turbo
  206. Thinking of ditching the twins and going KY turbo kit???
  207. Blew vacuum line off valve cover...etc
  208. Anyone have a 101mm Thumper compressor map?
  209. Question on BW s400-75ett
  210. Hinson hot parts?
  211. TVS2300 Boost question
  212. Starting my LQ9 build, please come in and advise!
  213. Vortech w/ aftercooler - SS fit question...
  214. New to the super charged world
  215. Help me understand turbo compressor maps.
  216. Pt76gtsh billet or non billet for 293ci
  217. Copo camaro supercharger
  218. Turbo sizing help?
  219. God Speed single turbo kit
  220. 2 12' Derale pushers on a griffin rad
  221. TV2300 in a LQ9 4 gen ?????
  222. what heads to run
  223. HKS green "mushroom" filter... anyone used one?
  224. which plugs
  225. Boost Leaks at Intake Manifold Gaskets
  226. Still in mock-up and already want to upgrade
  227. what bearings/rings/gaskets and clearances for rebuild
  228. F1a or F1c
  229. Exhaust flow/size/restriction for a blown 402ci??
  230. Is it better to weld or Tap...Oil pan!
  231. STS Setup wiring..HALP!!!
  232. my corvette in costume
  233. All Pro Heads questions
  234. do i need a power steering pump?
  235. Anyone runing different ac condensors?
  236. piston recommendation.
  237. twin ls1 plans?
  238. procharger timming
  239. whats up with my dyno numbers? peak hp at 4600rpms
  240. **Late Model Racecraft "Twisted" Package Video Inside**
  241. How hot does a turbine housing get?
  242. Beginning my winter 5.3 turbo build...
  243. Question about keeping A/C.
  244. 370 s91 th400 with a 3400 stall?
  245. Hotside Group buy 10 needed
  246. How would this cam do in a turbo application (tsp tsunami -235/240 648"/609",111 lsa)
  247. Good..Bad...Good.. 347 PT88 12psi Dyno Results
  248. Some new times with the Turbo Fox body
  249. Satan z31
  250. stock fans on a griffin radiator
