View Full Version : LT1-LT4 Modifications
- Preparations
- Help Removing 1996 TA Trunk Struts
- Long Tube How-To
- LT4 10mm rocker studs??
- fuel gauge an sending unit ?s
- What anifreeze?
- New to forum...just saying thanks...
- new to the lt 1 game
- Stock Exhaust
- Auto LT1 Camaro vs. Manual LT1 Camaro...
- Specific oil pan removal question.
- how to read a wideband?
- A/C system
- Simple Vacume Line Question
- Factory cam, 2800-3200 stall too big?
- 30lb injectors
- For sale Hughes 4l60e and vented opti conversion Cheap!!!!!
- LT4 Edelbrock intake ?
- Need advice for my new lt1
- BBK Shorties
- banjo bolt on crossover tube
- looking for nitrous plate for lt1
- 2 quick questions
- LT1 cold air vs LS1 lid swap
- Wide band O2
- Exhaust Ideas
- AR3933 plug question for lt1 with nitrous use
- Head casting number help
- Starter Died :(
- Anyone have pics of UMI's tunnel brace/safey loop installed?
- SLP Cold Air Intake?
- Headlight Mod
- Engine/Transmission Heat
- what should i do for performance???
- bought my old 94 lt1 back
- EFI connections Porn
- LT1 Gaskets D@MN Pricey
- March Engine Build!!!!!
- What valve train parts for cc503
- Shift Kits
- R&R kmember...now brakes don't work.
- THIS F*CK*&G Pulley!!
- Oil Weight on 138K LT1
- another lt1 has me stumped its surging
- Consistent backfire out exhaust?
- A noise, then zero oil pressure
- Nitrous Dave elbow and a Super Victor questions?
- Pix needed to help me make up my mind.
- Power steering pump pulley
- Fs/Ft : 93 Firebird Formula V8
- Where to Dynotune?
- Having a hard time with start up.
- Headers
- Pushrod length
- were to get best 383 shortblock
- New 97 z28, needs help.
- Friendly Debate
- Battery Tie Down
- Trifecta Tuning and wide band questions
- EFI Connection LS1 coil conversion for LT1?
- hydro booster. has anyone seen the setup?
- Lt4 tob
- scanned my 94 z28 today need some help identifying codes
- Datamaster Results
- which would you do??
- arp head bolts. what sealant?
- How much power will lt4 heads provide over stock?
- Exhaust install question
- MAF and VE Tables Question
- Hypertech or PCMforless?
- 0 oil psi at idle
- Pacesetter Header Question
- Time for some serious spark plugs!!*!
- Why are my fans being retarded???
- Head gaskets failed on my LT1
- I hate my LT1.
- UPS guy came by friday
- 93-97 Camaro HID kit need some help
- 4,000 rpm rev limiter symptoms
- Lt1 Turbo Motor, Turbo system, DFI for sale
- easy and cheap mods???
- is lt1 worth it?
- slave cylinder question (sorta urgent)
- efi conn. 24x Q...
- Any input on this rear?
- 2010 LTX Shootout Registration is now Open!!!
- Max compresson for 91 octane?
- So I think I diagnosed my problem as the WP
- Suggestions for car...
- Compression test. Should I be worried.
- Oil, Oil, Everywhere And More!! L@@K!
- 95 B4C With upgrades? Should I buy it ?
- Lt1 brakes to ls1 brakes. Stops the same?
- Compression question
- what headgaskets?
- Anyone using Tunerpro
- Is My Oil Pump Bad?! Video!
- skip shift delete
- Trouble Replacing Valve Springs?! Help!
- What you guys think
- Got my heads back.
- Is this the impala Head Gasket?
- Gaskets
- Who will win
- Getting occasional backfiring...
- SLP Loudmouth Cat Back
- where to buy rear end gears for my 95 t/a
- SLP LM2 Tubing
- Problem with Injector
- engine wine?
- Problems? Overheated top end rebuild
- what rods pistons for 355
- Please help me get these rockers set!!!
- Engine bay rebuild thread..
- ARP Main Stud kit for LT1
- Need a little help please.
- Torque converters??
- Trick Flow/383 Build/T56 Swap+PICS & NUMBERS
- Magnaflow Mufflers on 3" xpipe dumped question?
- It's Nearly Install Time!
- Need a bolt size anyone?
- Can I remove all the PCV's
- Single Plane Build on Advanced Induction 385
- What windage tray?
- R.i.p. Lt1 :(
- clutch pedal adjustment
- Oil catch can set-up pics
- what to do, what to do???
- Help with the LS1 Intake Swap!
- EGR caps
- head and cam lt1 longblock new
- If it were your F-body...
- Changing Bulbs to L.E.D.'s need help!
- exhaust sond normal?
- plugs fouling
- Parts flowing like water!
- Shorty Headers vs Long tubes SLP Exhaust!
- What wheels to go with?
- Oil pressure sensor...
- Cam only now. Heads or nitrous next?
- Oil level sensor thread size?
- 79 trans am/ t56 question
- oil pressure sending unit question
- How do you port a Throttle Body ?
- How to clean the maf sensor
- trickflow 185x heads
- bad misfire/choppy idle when hot, code P1361
- First Mods on stock LT1?
- Starting from scratch *PICS*
- 9in problems...
- Want a new cam but already have a cam kit?!
- cantons and otvc wires
- March Pulley Set?????
- anyone heard of this shop or seen this car?
- OTVC routing?
- lt1 removal questions..
- lt1 has no spark...
- LT1 to LQ9
- High RPM LT1?
- goodyear super hi-miler hose set
- She's acting up
- Clutch options
- Choosing A Cam
- Valve cover issues
- LT1 Intake bolts Torque spec
- Recommendations need for a 1994 LT1 Camaro power upgrade
- got new part today
- How can I identify what heads I have?
- Wiring guru's please help!
- timing cover hitting cam pin...
- New hood
- Pace Setter Header question
- What kind of HP to expect from cam like cc503
- Right rear caliper leak after 3 new calipers
- lt1 fuel pressure?
- td questions
- Lid conversion w/ ram air
- Best location for MSD 6AL box
- Block Tester?
- suggestions on heads?
- What lifters did I buy?!?!
- Ls injector in LT1
- Only 17 mpg?
- LS1 lid conversion with cowl hood?
- ABS light after gear swap
- Comp 918s or Yellow LS6s
- No cover on Tranny
- I need an MSD harness 8877
- Bell Housing Bolts?
- symptoms of leaking intake gaskets
- 292xfi comp cam
- plugs question...
- ignition switch??
- Head light swap..Bulb number question
- Anyone looking for an LT4??
- I'm getting a GMMG catback. A few questions.
- Anyone Know anything about Tom Olsen??
- 93 Z28 Specific?
- CC Ultra Pro Mag 1.6 RR's Question!!!
- Rocker Arm Rebuilds, fyi...
- 383 LT1 SR cam 88mm turbo HD VIDEO part 3 The engine
- z28 too loud..best way to quite it down?
- Cluelesss and new to this
- i messed up
- Weird light on
- GM847 guys come in
- Double roller chain with crank position sensor
- tunercat questions
- OMG new 383 LT1 Not firing..
- 1995 Z28 camaro
- oil pan windage tray
- torque converter trouble
- carb conversion questions about electronic
- lt4 roller rockers
- DMH Cutout --- dont work??
- Worth the money?
- 94 camaro lt1 fuel pump
- 96 vette mods?
- 97 LT1 crankshaft position sensor and wheel?
- ob1 conversion
- Transmission removal issues
- My Twin Turbo start up Video
- !ABS with cruse question
- How does the clutch safety switch work?
- A little bit of a choice
- 93 z28 problems
- Almost Time!!!
- Oil leak from the front
- Sudden bogging :(
- Do i need to have my adjust my tune
- So i Finally bought an 8.8!
- overheating problem
- Evap delete
- 94 ta no start, please help
- How much is it to fill up a 10LB nitrous bottle in CALI? Plus some other Q's
- TB/inake assembly
- Best stall
- Issues running open Hooker LT headers?
- Callies Crank questions
- Help Before I Buy Headers?
- Trade 740i for 97 M6 Trans Am?
- Wtf lt1 problems?
- 93 z28 camaro problems
- Question on Tires and Wheels
- LT1 build recommendations?
- Heads up On LT4 Knock MOd
- Any one know of any LT4 KM in stock?
- Starting E-85 conversion...
- Can I tap into a tach wire from inside the car?
- Odd Fuel gage/pump problem
