View Full Version : LT1-LT4 Modifications
- Guess what comp cam just came up with!!!
- E-mail tune - who does it best?
- How do u remove/install the Dowel Pin ?
- swap worth it or not
- Need help identifying this procharger bracket, QUICK please
- Rocker studs
- Gear/speedometer/calibration Problem
- newb needs ltx trans help 93 z a4
- ABS inop after led 3rd brake light
- Here's a vid..
- question about exhaust
- opti/distributor problems in 83 regal any help appreciated?
- want trade your m6 for my A4?
- Started the tear down!
- My new car!
- Codes that I are tripping my car out! LT1 POS, lol!
- Stock or msd optispark?
- Finally 10's pumpgas 383 LE3! all motor.
- What's your fall/winter mod plans?
- Cracked stock elbow.
- Selling the LT1!
- Track results! Think I can pull a 12 next time?
- Dumb question but, does 94 Z/28s have Traction Control?
- New best w/ AI setup.... Barely lol
- OTVC wires
- Bunch of Go fast parts from 440 rwhp setup for sale
- Couple ?'s with regard to finding parts.
- what is wrong with my car
- Finally in the 10s! Wahoo!
- HID's on a 97 Firebird
- So after almost 2 years I get a call about 9:30 last nite
- How much room above the front tire is needed
- PCM ground cable bolt
- oil pan gasket
- a/c pump froze
- AChotrod just spoke with LE
- vids from the track 31 Oct
- need desperate help
- crank problem! Help
- Need some help
- Well, bought a used set of LT1 heads and got 561's!
- 1.6rr on stock cam
- 93/110
- Is there an advantage switching 93 to 94 computer?
- Another Exhaust poll! help me out!
- For my t-56 which shifter is the one....
- 355 suspicion
- comp 987 springs...MAX LIFT?
- going for an opti change record
- Bolt size to coolant reserve?
- 1996 Corvette LT1 power issues.....
- Where did they all go?
- Questions about future mods
- 93 z28 off road y questions
- LT1 SS spoiler guys come in!
- 93 Camaro z28 PCM
- I think i have the fastest stock LT on spary
- Quick question on 93-95 gauge clusters
- Need Help. Trouble pulling motor from top
- Modified LE2 Having problems starting.....
- 97 LT1 Cooling Issue. Please Help
- Fresh rebuild, no start
- How much timing chain slack is O.K.?
- Caprice goes 11.5
- 95 LT1 Firebird, Extremely low cold idle
- head gasket and pushrod question
- Timing chain replacement help!!!
- Motor Mounts
- you gotta check out my new ride
- Datalogger and chip burner help
- 94 Vette 6 speed feeling a little jerky when warmed up
- What did you pay for your 383 rotating assembly?
- Opinions of what this is worth?
- mcleod street twin question ( i may have f-ed up...)
- Who is thepartsladi????
- 97 formula misfiring
- Where to find LT1 clutch master and slave???
- obd2 --> obd1
- How to drain gas tank
- FS 93-96 Camaro Dash
- Two LT1 formula hoods for sale
- Victor intake for LTx
- car wont start w new cap n rotor.....
- Upgrading MAF. Which one?
- EFI Connection 24X makes 700RWHP!!!!
- idle problem
- Shift light seems to not be working correctly till 3 to 4th gear shift
- valve stem seals and 918s parts question
- arp rod bolts? stock bottom end
- fuel pressure regulator?
- out with the old in with the new
- how to make my LS7 lifter a solid lifter for measuring pushrod length
- DO I Have a hypertec Tune already?
- Rebuilt motor not starting, thinking bad gas?
- VERY strange problem with 30th LT4 Z. HELP!
- Help with a coolant leak
- $300 for mods
- will my TB be holding me back?
- Need some help...
- new PB...sooo close to the 9's
- my video b4 mains went down
- Going for 11's tomorrow night
- Lt1 smokes on takeoff from an idle
- Single plane owners...
- 383 stock heads decent size cam
- Can somebody show me pics of all grounds on a Lt1?
- Please help me with a direction for my car
- Isky Adjustable Guideplates - What joy...
- Stock z
- downshifting on dyno
- LE1 Heads LT1 11.6's with a 6 speed. Video inside.
- Camaro Handling
- Optispark electrical connector
- 94 Z28 running bad
- New Best on E85 for the T-56 N/A T4P car
- First trip to the track
- TPS question i think....
- almost beat the world record... almost..... new PB tho!
- Intake elbow pics please
- 96 WS6 Cam setup info
- 1994 Z28 camaro and have no clue what to do please help
- 4.125 Stroker crank
- ls1 strokers ?
- lt1 springs
- no spark, any ideas?
- bouncing in rear
- Idle's really high after low oil pressure and SES light comes on!!! LOST
- comparison of turndown tip or no turndown tip???
- Rear Main Seal
- Idle problem
- stock stall w/cam
- Bought the Ebay stainless pacesetter knock-offs
- $$100 dollars if you fix it....
- picked up some goodies today
- Throttle Body question?
- Opti fastening bolts
- Halloween 93-97 NastyPerformance Race fuel tank SALE
- Went to the track last night...
- Ls1 lid on a firebird with a harwood ram air hood
- 93 formula, possible buy
- Starter just spins...
- 223/230 .565/.565 112 LSA cam
- .060 over on an LT1 block
- Going to the track for the final time of the year...
- Compression
- Quick cooling questi
- Need help, losing my mind!
- gearheadengines.com?
- LTX block is cancelled
- Suspension issues in rear
- fuel rail covers ?
- converting to e85?
- lt4 heads question
- Any gain to 'cleaning up" ports on heads?
- Friends 94 Camaro Dyno Run Flat HP Curve?
- 355 compression
- Vibration in Driveline
- Rebuild tune?
- Going to the Dyno the day after tomrrow, What you think?
- wat head bolts?
- Help with reverse lights
- lt1 guys
- How does one go about this??
- build question
- 1994 LT1 sucked up plastic bottle cap into the intake!
- ls1 lid on a lt1
- Having Trouble with my 95' Formula
- X pipe location
- put my first performance mod today
- Better true dual w/ shorties and stock routing pics...
- Cracked flexplate symptoms?
- Realistic
- who built & how much for ur engine?
- New to the site 1st time f body owner
- finally took 40lbs off the rearend...
- Custom grind Solid cam question?
- cam rust
- Good LTx article in the Dec.09 issue of Popular Hot Rodding
- Some goodies came in...I've still got a lot of work to do!
- Xfi 276???
- 355 Random Q&A Thread :)
- I need a 95 pcm pinout diagram
- Places to get good LT1 Short Blocks
- Moroso cai ???????
- '96 Z28 A4 Vert. bolt-ons new best @ATCO
- FAST TOYS LS1 LID, FTRA, JAAM for LT1?
- advice on a 97 z28
- LT1 cutting out
- true duals finished for now!
- lt1 no fire
- Pistons, Dynamic CR + 91 octane =???
- low coolant light?
- lt1 exhaust manifold
- EWP and fan clearance
- measuring pushrod length
- First time on a dyno (mostly stock)
- Stock rods with forged pistons yes or no
- Fontana Street Legal drags this Saturday, Oct.31
- Trans mount prolem,...Asking for pics///
- Trackday, Stock LT1
- Popular Hot Rodding Article...WOW!
- cammed lt1 on spray today
- ???s on my build
- simple question..
- LT1 rods in sbc
- Wierd module, need identification
- Lt1 vid. 1.33 60'
- Opti failing at 6500rpms
- What could i add 2 my car 2 make it faster???
- reusing engine bearing
- optical sensor
- heads/intake question
- obd1 to obd2 adapter ready made for obd 1.5
- Copper head gasket or what?
- Complications with 95 swap into 94 Z28
- How to remove impeller from Electric Water Pump?
- lt1 valve hitting piston
- my ai cam start up 22x/23x .574/.577
- plan on going auto. Will a low 3600 stall still be faster than current m6?
- turbo ?
- GMMG Review
- Head gasket question
- Questions about the LT4 cam kit
- Got The Car Painted
- Nitrous and Cam Only?
- need advice
- After market oil pans
- Tranny questions and help
- First time engine build, I have detailed questions
- Went to the last track day, new PB!
- question about true duals
- Very strange ignition issues
- LS1 Lid vs K&N CAI
- whats makes a 388 stroker?
- 350 or 383 LE 2 rwhp?
- Thoughts/Predictions: LT1 WS6 Airbox vs. LS1 Lid
- need some good lt1 pictures!
- Which Engine Rebuilt kit is the best for LT1 Transam?
- Best Camaro video EVER!
- 1993 LT1 forged rods
- Intakes
- Who's used a non F-body rear?
- ok big problem here....
- stock headbolts
- 2 quick questions...
- It Happened Again...(Kinda Long)
- Blown Head Gasket..
- braided lines for 1993 rails?
- For the LT1 lovers
- Car Weight
