View Full Version : Forced Induction
- L76/LS3/L99 vented catch can setup?
- Stripped coolant sensor
- 1966 velle twin turbo 454 or LS ?
- opinions on piping?
- .68 or .81 a/r exhaust for rear mount
- Spool and power difference w/twins pt6765 vs tc76
- Gt4202r
- RPM, boost, and engine life
- 30" tires now working on my LSX Drag Radial Vette
- I better upgrade my fuel pumps asap lol.
- Boosting lsx376
- Copper Head Gasket O-rings
- 2-bar MAP sensor not reading above 105kpa
- Turbonetics T76
- those running 5.3's
- 408 Twin Precision 6765 V&P Racing LSX Pinto
- FAST and 2 step.
- ProCharger Video Challenge 1st place $5,000!
- 427 F1C build
- AN fitting question
- Signs of a bad Procharger?
- rear gear- boost- t56 ?
- your timing and A/F increments from 1lb-20lb of boost?
- ls2 rails on lq4 intake?
- Thinking about going FI
- What plugs for ls3 twin gt35s
- 6.0 lq4 turbo?
- Turbo Guys! Exhaust question
- which oil pump?
- i need mild steel colector flanges for ac mani build
- turbo ls2 in a 245" top dragster
- Which large frame turbo for a 5.3?
- Procharger Help!
- rear mount guys
- How'd you bend your PS lines to clear turbo plumbing
- Suggestions on build....
- Diesel vs gas engine?
- My Forged LS1 KYTP TC 78 Header build
- Best exhaust manifold bolts/gasket combo?
- 16" Zirgo pusher / griffen /160 therm keep me cool ?
- 150/160/220 natural gas injectors?
- LQ4 Tuning/Timing opinions wanted
- FAST LSXr vs LSXrt
- Got started on the 20psi tune last friday, dyno and video inside
- Wiring woes
- 02's stoped reading in HP tuners
- lets take a vote on turbo selection.
- building ls1 for boost.help
- need help bad
- gear ratio? for my 5.3boost camaro build.
- ran friday!
- help choosing a turbo
- Well car is running with the D1.
- I need clarification please
- Single or Twins and what size?
- Finally dyno'd my turbo LT1
- Holden WH Statesman, 390ci + S400 build
- Eboost2 setup help
- new record: stock longblock 4.8
- STS turbo
- Meth Troubleshooting Help Please...
- Brute Speed Blower Cam
- Just my luck, D1 installed and now the alternator isn't working.
- The latest technology Turbo Charging!
- S91 Turbo Problems Again. Or I'm Wrong? I don't Even Know Anymore.
- help what springs should I get?
- Same WG,differant ci,turbo,cam,lower boost??
- Most power with a 5.3
- anyone here ever hurt an e85 engine?
- arp head bolts.
- Turbo ls1 Horsepower estimate?
- 99 Procharged ls1 with part throttle knock
- Rear mount turbo- Should I run a pre-turbo flex pipe? Do you run a flex pipe?
- methanol injection
- .120'' Head gasket for boost??
- Heading to Milan this weekend...
- O-ringed block for use with MLS gaskets
- sts turbo problem need advice:/
- 89 octane with meth
- truck manifold questions...
- Safe octane level/timing for 20 psi?
- Procharger with Wastegate
- Turbo craped out, so what size should I get now?
- My TT Vette 930/870
- best streetable twin turbo kit for C6 corvette
- coated intake?????
- 9.2 compression and ? Boost
- rearmount help
- yes the question again, what turbo to use??
- Magnacharger tvs 2300 or go with kenne bell???
- Turbo oil leak problem
- Twin Turbo's
- RHS 427-F2 Cog-Stock Susp C5 PICS...
- couldnt find the anser to this
- intercooler size question
- Procharger P600B Kit - Stock LT1
- True duals with a single turbo/Brutespeed cam questions
- procharger open race valve
- Magnum turbos going 9's again....
- Magnum t76 group buy
- Procharged 383 C5 ZO6 Build
- Get a procharger or go turbo, help?
- TVS 1900 09 Avalanche by AMS
- The Manifold is done!
- before procharger header?
- valve cover breathers ok?
- HELP! engine issues
- New look of AtomicFusion LSX Drag Radial Corvette
- 10.30-10.50 stock block no weight reduction convertible possible
- 02' Pewter Z-28 Get a Custom F1-A Kit Thrown in
- A LS Procharger hub that can take it.
- gts 76 vs tc78
- c5 sts turbo question
- What heads for forged Ls1 with 15lbs boost
- aster bracket
- smokinghawk alt relo.. what am i doin wrong?
- tuning a turbo 2006 gto 6sp. knock only in 4th?
- I must know
- Nitrous guy to Boost guy. Spark plugs.
- head gasket thickness
- speed inc alt bracket, belt walking off crank
- need a different oil feed source for turbo
- How are magnuson tvs 2300???
- Best intake for forced induction...
- magnum turbo's
- intercooler install
- Remember me? I'm still alive...actually :)
- GMHTP - Standing Mile build (88mm, 370... 200+mph)
- Race vs standard plugs?
- Boost problems. Any suggestions?
- self contained oil system?
- Meth inj ? best kit for a street car 15psi
- Which cam is better for my 5.3/mpt70?
- Who has the fastest stock 6.0L here
- 88mm or F1 in 275
- Stay Procharger or go Turbo?
- turbo sizing help
- tig or mig
- Champion aps 921 dyno
- Turbo off of a turbo coupe?
- eBay Turbo Kit - Sticky please
- Has anyone run one of these???
- Updated ProCharger Model Specifications
- Gettin a cam spec'd
- "New" eBay Stainless Truck Manifold Turbo Kit for $595?...
- Ideal e85 compression
- Post your PUMP E-85 boost combo
- E-85 and 11.3:1 compression
- 347cu ~9.3:1 compression. 93 octane No meth. How much boost safely?
- APS Fbody Kando water lines VS stock APS
- anyone willing to share their fast XFI program...inj size does not matter
- what stall with procharger
- turned up the boost, but don't feel it
- What reducer coupler for LS1 TB and 3" intercooler plumbing?
- Co2 Help... Need the right bottle
- procharger and MS4 cam??
- turbo
- Front bumper trimimg for FMIC
- eBay fmic setup for p1sc Procharger on 99 ls1 formula
- Anyone running two fuels/tunes?
- 95 TA rear mount build thread
- magnacharger 5.3L truck tune
- Turbonetics T76 AR housing????
- 370ci e85 1100-1200rwhp
- lm7 turbo question
- front sway bar question
- Green top 42's how much rwhp
- Procharger BOV flange
- Forced Inductions
- Help with SDCE Tensioner
- Those with Griffin 25241-X...radiator hoses?
- 891 RWHP with Vortech & LTX
- NHRA turbo ProMods at Bristol Saturday in a "strange" DA.
- Looking for D1SC Cam Specs for Street Car
- 2003 zo6 v2 sc kit
- LSX alternator relocation kit
- High Compression FI 408 on E85???
- d1sc 359 cam ?
- What do you think. Am I wasting my time?
- Our Turbo 5.3 and new stock bottom end record attempt (video)
- Need a specific Hobbs switch
- Idle Video 6.0 EPP Cam
- Need advise on what heads to go with!!!!
- e-force supercharger
- Turbo Virgin
- Vacuum Line Diagram
- What are the biggest injectors the stock computer can control?
- Can the stock or Fast polymer intake be used with a turbo
- TVS2300 With a Twist! Flywheel dyno results attached.
- Overheating f1a 408 2002 t/a
- Champion ttix camaro dyno
- 402ci d1sc only makes 5 psi.. Help
- 408 cogged F1c Procharged Camaro 796rwhp/707rwtq
- 91mm 2 step timing on e85
- 5.3 turbo with room to grow?
- gt35/80 turbo
- will an ECS blower cam do well in a turbo app?
- i wana start a turbo build for my ls1 camaro
- low HP/TQ on STS LS2 GTO?
- Dyno Results and Video - 847rwhp
- LPE + MSD 2-step GROUP PURCHASE IS A GO! PRICING INSIDE!
- Paxton S/C Question
- Turbo motor BS3 issue
- Building a a/c turbo kit with manifolds need pics guys.
- ls1 stainless works headers
- custom "APS" style turbo kit
- Electric Actuator?
- My custom C6 91mm turbo build thread! DYNO VIDEO ADDED!
- Pumping Losses question
- Eboost 2 can I get to 20psi on 7.5 psi gate springs
- stock water pump and high hp?
- What's the best way to hold the MAP sensor in a FAST 90 intake?
- Magnacharger MP112 + low mile LS2... What heads?
- S475 Turbo LY6 '69 442
- goal for 2k11, i want to hit 1000flywheel. do able?
- Where are the big dogs at?
- Catch can
- S/C Intake?
- what turbo to go with ?
- few noob questions
- Crankcase Ventilation on LT1
- Are 60#ers enough for this setup?
- Cam imput needed on 408 F1C
- What compression ratio will I be at?
- Build thread: '98 Firebird: '02 LS6 +E85 +Turbo (c6 manis, keeps AC/radiator/Ram Air)
- Turbo FMIC people...where did you mount your trans cooler
- e85 timing
- Dilemma with 4.5 intercoolers
- Selling my Turbos
- Size question HELP!!!!!!
- Best place for S85 rebuild??
- Newb to F/I
- Building boost on line??
- Race Proven Motorsports Escalade
- What kind of rods are these and will they work for my setup?
- Cofused about turbo sizing
- Turbo Advice Needed...
- Considering FI..
- Turbo vacuum lines HELP!!!!!!!!!!
- Where to buy a super short 6-rib belt??????
- I have three short questions
- Which Spal Fan to Replace 16" Procharger Fan
- what 2-step?
- WB bung too close to turbo?
- Turbo advice
- Enclosed Race BOV Procharger, vid/sound wanted!
- TU1 vs. TU2
- Best belt for Prochargers.
- Vibrant Performance Vacum Manifold
