View Full Version : Forced Induction
- Cheesball meth injection?
- How much boost is safe? gen4 6.0/l92/7875
- 83 mm t4 to 96 mm t6 change.
- Catch Can Selection
- Ring gap on stock 5.3
- Another help me pick my turbo/setup thread - 6.0/80e
- MAxed out s480 new turbo recommendations for 4.xx pass
- Low Boost 416 Single Turbo Selection
- TBSS/NNBS factory return style fuel rails
- Let's beat a dead horse and talk intakes
- Oiless Comp turbo?
- 12 to 1 compression, boost and small cam
- Billet 7875 problem fitting
- cylinder wall discoloration
- Added meth and now too rich!
- 7.0@199 goal for 2019 Street driven turbo 4th gen
- Do I need to retune if changing pulleys on procharger
- Ls Holden Stato
- Mild low 10 sec. setup advice
- Non OEM LS9 gaskets ?
- LSA supercharger snout bolts???
- Spraying meth pre-turbo discussion
- LSA snout bolts PN?
- 706 heads vs 317 heads using twin turbos?
- Budget wastegates, surge valves
- 2000 SS D1sc
- How much can you get from a T3?
- Drag purpose 5.3 build recipie 2018/19
- What will it make? Old school combo in 2018
- METH Tank Rusting Bad - Solution?
- Budget 6.0 build how to remove carbon build up
- Boost referenced FPR or not for my setup? Yes, I searched.
- I need some technical help
- 6300+ rpm, a death wish for a sbe turbo LS?
- Jeep Comanche 5.3 TwinTurbo
- Teach me the ways sensei! 5.3 Turbo Build 240SX
- C10 stock 5.3 twin turbo build
- Full-length Exhaust for Turbo 4th Gen
- Funkster's 2009 G8 GT
- Neglected 5th gen build
- LQ4 with powerdyne supercharger?
- Caprice PPV....new project
- Twin PT6266 or TC7068 for an LSX427?
- HYBRID THEORY! Gen 4/5 LT1, LT4 and LS engine compatibility
- Question about meth system filter
- Where to get acdelco d585 coils?
- 98 camaro, street to strip overhaul
- S366 ebay clone - anyone run this specific one?
- turbo narrowband 02 sensor placement on turbo colorado
- K member and ac.
- Turbo log/mani/xover
- Chinese 78/75 vs. Borg S475/S480 T4 physical sizing
- racetronix fuel pressure regulator
- Aster bracket
- Pistons with too much dish?
- GM LSX 4.185 Bore Block
- 122 Supercharger intake for Cathedral Port
- Hotside primary cracked 3/4 way around wtf
- Is backpressure not an issue if power goals are low?
- Is this motor plate wide enough? I cut some out.
- Should it be clattering at this low boost?
- Forged & Turbo Daily Driver
- You guys welding your own SS V-Band flanges. How do you keep from warping?
- s475 turbine size spool characteristics on mild 4.8
- 7875 Turbine OD
- Hot side from merge to turbo on promod style turbine housing
- What psi to turn on the meth?
- Hit over 700whp...with the help of a Loudvalve
- need pictures of others set-up
- Wastegate size?’s
- Huron Speed 18'-19' Group Purchase ~ BIGGEST SALE OF THE YEAR! ~
- Where to start? 5.3 iron block build
- I've hit the limits of my 3 450s. Going cable, looking for gas tank advice
- Vortech “Maxflow Power Cooler” LS1 Supercharger
- LSA supercharger on '99 Z28 (possible) build thread
- Sold my X275 car and going no time with stock block...
- well it fits. but not easy.
- 2001 trans am manifold turbo kit
- LT - to LS1 76mm Turbo build
- Converter?
- Vengeance Racing built C7 Z06 headed to Miami making 732rwhp on E85!
- XS power Top Mount T4 Manifold setup/review
- Frozen Boost A2W setup
- Where can I find a nice looking ~78mm throttle body
- Aster bracket and alternator pulley
- Dart 388 S491 Turbo Fox Mustang
- Holley sniper throttle body
- Misfire after WOT Pulls
- 7875 exhaust flange
- Fbody - On3 76mm winter build
- boost loss
- Engine Builder Recommendations
- Rusty chevelle big changes
- New cam for LSA blower
- ECT...aluminum vs iron block
- Huron Speed 5th Annual Turbo Kit GROUP PURCHASE ANNOUNCED! ~11/23~ Black Friday
- Turbo exhaust through hood to keep a/c?
- New mods and results for Detoxx with the D1X
- Fuel usage math, intank pumps
- S400 88mm + ls2 + pump gas
- Twin 67/66 .96ar on a 5.3?
- good budget coils
- How much power does your setup make on 91 octane?
- BMR Turbo K users
- Found a good location for a vacuum block
- 5.3 to 500hp at the wheels?
- Going rate for used blower?
- Engine Masters 5.3 turbo
- Forged LS2: which heads for boost
- Ebay gt45
- 416ci LS3 TT 6266's
- 2.9 Whipple
- What wastegate is this a knockoff of?
- Plugs?
- So i was given a 471 supercharger and i have a 2004 Sierra
- Single 66mm Turbo too small for LS1?
- Fox body LS turbo guys, come in!
- Creakote, zycoat/ZyBar or something else? Hotside coatings
- Wanting some opinions on my boost set up.
- D1SC Maxed?
- Cortex boost by gear EBC electronic boost controller
- [VR] Build Video: Mr. Anderson’s 1,300+rwhp C7 Z06 by Vengeance Racing
- Boost and dual tanks
- Twin turbo, LSx, built, E85... 917rwhp
- PRI anyone?
- 740 wagon + 6.0 + 80mm = 901whp on pump e
- 4.8 running out of turbo. experts please read.
- S475 goals
- 408 d1sc fmic e85
- g35 + 4.8 + LSA
- Budget TURBO
- Who's the guinea pig in here: On3 94mm/103mm and 107.5mm/103mm
- Project Goldmember 68 Camaro
- Twin turbo size 62/62 or a 67/73
- X pipe on a remote mount Twin Turbo?
- Flexpipe in crossover or na!?
- management system
- S472 limits
- 4.125 stroke in an LSX
- Help with build sheet for procharged 408
- Holley dual plenum
- mustang turbo
- What do you guys think of this exhaust idea?
- V band gasket
- First time build looking for advice
- Thoughts on this Billet intake...
- Help With A IGN Problem
- Procharger F1X on a 2003 Silverado
- Blown 2010 camaro plz look at my plugs I changed
- LS1 boost setup advice
- Boost controller options
- Cut to length plug wires
- anything to be gaied with bigger turbine?
- Boost And Timing
- Winter build, 86 c10 short bed
- Cyl Head Comparison For A Stroker
- My first turbo build.
- LSA blower power potential
- LSA blower question
- Not quite a rheostat with Whipple 5.3 Gen5 GM
- Race MMI turbo help
- Help with reinstalling a squires turbo
- Bad idea for limiting boost?
- Throttle body question
- Help with twin sizing for 5.3l
- Converting from 4L60E to 4L80E Harness
- 1.20 4.90@153 and 7.58@182 street car FI 88/100mm finally taped out. Pump e85
- Dumb question, 02 5.3 VS 06 5.3 for boost
- To the boosted guys that have had a engine failure
- 6 bolt blocks bore vs boost
- Reverse split turbo cam old news?
- 8.76@156 69 Nova 5.3
- [VR] Vengeance Built Twin Turbo C6Z06 runs 8's in the 1/4 and 200+ in the 1/2!!!!
- LS9 vs TFS Head Gaskets
- [VR] Stage 1 to Stage 5. CTS-V's Journey to 800rwhp!!!
- Small frame quick spooling turbo
- BOV spring too stiff? VS Racing BOV
- 1074/917 wheel SBE 6.0 s480 '77 GMC swb
- Any successful LS9 blower installations on Fbodies?
- F1R with 12 rib?
- Dumb D1SC question
- Rocky Mountain Competition Research
- 4" downpipe split into duals
- log manifold and o2 sensors
- 65 C10 - dontbsme clone
- Who has the best deal on a Boost Leash?
- 92mm vs 75mm throttle body and turbo
- Procharger guys, what pulleys are you running?
- s400 on huron speed v1 crossover
- 5.3L LS Whipple belt slipping
- Glazed #2 plug
- LS6 Intake Vacuum Port
- Ls turbo into a mercedes amg
- Only making full boost uphill under load. Why???
- Is this an ok place for BOV vac line?
- Help needed with tune and rough running 6.0ls with gt45 turbo
- Twin turbo manifolds
- 3/8 push rod clearance
- I'm finally going to build my TT 6.0. Have questions.
- High compression & BOOST
- Converting A-A intercooler to A-W?
- Vengeance Racing Twin Turbo C6Z lays down 8.41@166mph
- 1973 Camaro Single Turbo LS Build
- Injector issues
- 180 Headers w/Turbo did it work ?
- One or Two BOV's? How to decide?
- D2 Procharger on LS2 swapped 3rd Gen Camaro?
- Turbo with stock k member???
- 1955 Chevy Roots Blower LSX
- Hooker manifolds and a flexible mounting option
- questionable timing LSA tune
- Boost Controller with NO C02?
- Need help with Centrifugal supercharger, intercooler set up.
- Need insight on issue with A&A C5 Zo6
- Turbo ls2 GTO blowing oil dipstick with catch can.
- Forced Induction Cam questions?
- Nitro or Turbo
- S366 size
- building a dart block 427 what injectors to use?
- Need to know where to get a wastegate spring
- $1 for a C5 TTI X Twin Turbo Kit
- Who has ran a smaller radiator and fan condo on a 1100rwhp car and kept is cool
- Who has ran a smaller radiator and fan condo on a 11rwhp car and kept is cool
- DNA Motoring GT45 Any Good?
- Looking for a 1K HP Fuel System.....
- S483 Turbo help
- Boost build for the street - advice please
- Does turbocharging turn on check engine light?
- VS racing 60mm wg springs?
- Budget Turbo 5.3/TH400 Build
- Help me build my 370
- Anyone using brushless radiator fans out there?
- Vengeance Racing Builds “C7.R” Project for Speed Society Raffle Giveaway!
- whos made big power on a t4 and small down pipe?
- Any experience with 403/408 & SXE S369's or S371's?
- Changed my wastegate spring to 14psi...
- Boost and timing
- [VR] Twin Turbo 440ci Camaro SS makes 1600+RWHP!!!!
- Turbo Camshaft help
- Blower Cam selection.
- Best transmission for boosted application for everyday driver
- Vortech v9
- Procharged/Nitrous Power on Forged L76
- Track guys, how do you keep the iats down in the staging lanes?
- Am I crazy for turning this kind of rpm? And timing?
- First LS to the 5s!!!!
- Dirtybird
- LSX forward facing headers - help
- Variable Speed PWM Fan Control under $25 or less DIY
- Changing turbo, which one now??
