View Full Version : LT1-LT4 Modifications
- 3 Cams????
- The radiator blues...
- draging starter car wont start
- 02 sensor question
- pics from the other day
- LS1 vrs. LT1
- 94 Z28 but 97 LT1 Engine.
- Blower Assembly
- Filling the tranny?
- What heads should I go with?
- dissapointed at track..
- Cats meow..not really
- just a little more
- for those of you running SLP CAI help needed
- exhaust question
- o2 sensors cut off!!
- Running Rough / Reduced Power / Poor Mileage / NO DTC CODES
- Smack talk from a 5.0
- keeping the lt1
- Does thermostat cause SES light?
- LT1 tuner needed in CT
- LT1 Vette vs. LT1 Fbody
- Just a basic Lt1 owner question...
- XFI cam vs. GM847
- can you tune for a custom cam
- Need help fast guy's
- 3:42 blues
- LT4 identification
- Seen This Anywhere else cheaper?
- Car is going to 260+ degrees!!!!
- Crane Cam
- MSD Opti Vs. GM Opti Vs. Coil Packs
- emmissions delet causing limp mode?
- Crankshaft tech needed
- Serious electrical issues
- Under The Axle Td's???
- What hood for ls1 intake setup
- Help with ABS delete!!
- new motor good, old trans bad..
- Any TPI Gurus in the house?
- GM847 DONE!..now what size stall?
- Need some Advice FAST!!!!!! TRADE OR NO TRADE
- Lifter Spun! Need Help...
- Fidenza flywheel, worth it??
- ram HDX clutch or zoom MU clutch
- True Duals with tunnel mount Torque Arm??
- Heater Box/Core/Unit Questions. Pics Inside.
- Stock '93 LT1 times?
- new to the board,help wanted
- quick octane question
- MAP 2-3bar sensors
- crane hi-6: what do i need?
- Your opinion please? VERY interesting ques.
- this is going to sound totaly noob
- Tune Up Recommendation
- Any test results for the Edelbrock intake yet?
- Governor?
- ls1 engine
- I am a noob and I need help
- Too old to mod?
- High flow cat or tune?
- changing out valve springs
- MAF Screen
- valve covers
- dumb question on guideplates
- Tune!!!!
- ac delete
- ignition problem guessing game.
- Hypertech On a 94 Z28
- Are O2 sensors universal
- Targa top/Hard top Fbody???
- Finished header install
- oil in trottle body
- Pics of my alternator relocation setup
- New parts to play with..
- what length pushrods
- Gm 847 Cam What Else Is Needed?
- Shootin flames????
- Rocker arm part number for LE2?
- change cam or no?
- Do I need a tune?
- 383 Stroker LT1??
- Started up perfectly on the 2nd crank!!!!
- 383 Stroker??
- No electricity....
- Rocker arms adjustment question.
- T56 Q's???
- Anyone get a Carbed LT1 intake manifold..
- Idle 1k and Fuel smell??
- Looking for an engine builder.....
- MSD 6AL took a sht I think?
- PCM 4 Less tune on 94 Camaro Z28
- Lloyd Elliot has my heads baby!
- idle
- le2 package cost ?
- exhaust manifold question
- No muffler?
- lowering springs dilemma
- 94 Camaro Z28 Dyno Numbers
- bellhousing
- Who makes stock replacement lifters?
- 97 LT1 wont start PLEASE HELP!!!
- Factory rocker and valve springs ok with cam
- New engine startup questions..need answers QUICK!
- LS1 Into a LT1 Car, complete Harness
- Electric Power steering pump
- bored lt1
- edelbrock heads
- Ease of Installation?
- LT1 vs LS1
- Camaro SS 10 Spoke wheels on a 94 camaro z28
- New Wheels
- header bolts
- Video! check it out!
- Volts
- Accel Opti Or stock Gm vented opti ?'s
- Valve Spring Help!!
- Ram Adjustable clutch master cylinder
- HOw long will a Supercharged motor last?
- Flashing Check Engine Light????Missing real bad
- Want a bigger cam for the LT1...
- New Rims
- Head work? Porting, big valves? More go fast parts. Which ones should come next.
- Opti Rebuild ?!?!
- is this a good price for a reman LT1??
- What you guys think about this 1/4 time?
- K&N oil filter part#
- crank pulley vs. complete set
- LT1 Tuning
- OBD I question
- hmmm......low trac light?
- Oil pressure swithch
- LE2 Heads/GM-847 Dyno Numbers
- Moving oil pressure sender to back of intake>>
- Where's the cheapest place to buy a GM Vented Opti?
- LT1 Fuel Pressure? Fuel Pump?
- stock fuel pump limits?
- Need help about what cam for a s/c lt1
- Pinion Slop
- LT1 Retainers/Keepers
- Need help! Problem installing MSD opti
- LT1 Tune
- where to buy?
- Running spray!
- pics of the new set up.
- LT1 rebuild, Guys pls help.
- LT1 Retainers
- high rpm's cut out problem
- tuning
- Power Loss through a stall anyone?
- Electric water pump
- Strange Clicking Sound
- Clutch disengagement
- bought a D1SC for my LT1!
- RHS solid roller 383 progress *PICS*
- Ford 9' or Moser 12 bolt?
- Any one in here from VA?
- Descreen MAF Sensor?
- headlamps
- Christmas in march *pics*
- Moroso, Sweet Thunder, Dynomax
- MSD 6A Box
- Those of you with Converters
- Machine Shop
- What kind of LT1 mileage?
- 1st pull w/Phatkops 383....
- Do these look like a $2000 set of heads to you???????
- How you Relocated your Battery to the REAR
- Cam Suggestions, LT1 Into RX7 Swap.
- Aftermarket head questions
- lt1 block shipping question
- Which Cam?
- no point for a 4 bolt lt1?!?!
- Please help me out here all you LT1 guys
- Help...
- ok posting prob again and seeing
- Cost for y-pipe install?
- oil pressure
- Compression on a LT1?
- coil ???
- Well after the long wait and anticipation this is what i was greeted with today.
- The build is underway...
- Need some help for a friend
- i MAY have a leak.. *pic*
- the car stu stu studders on start up
- Need help/advice
- Factory Oil Cooler
- Lt4 km
- Need pics of ABS Delete
- True Dual setups for LT1's. need pics!
- Advice on Cam swap components
- O2 Sensors...need help!
- Will my flowaster hurt hp with headers and a cutout
- parts needed for fuel line relocation
- Best Cut-Out?
- 4L60-E Stall Converter needed
- Deleting TC
- composite intake manifold
- should get my LT1 back any day now.
- 383
- engine problem
- 396 is here............
- will it run for a little without a tune
- Dyno #'s for my LE2 cam/stock head combo
- help w/ pushrods/guideplates, etc
- Question about the EVAP line and Can
- cam help and suggestion
- LT1 Intakes
- Fuel Pressure ?
- what could be wrong
- For anyone looking at doing headers
- Need Help Quick w Code
- old procharger?
- How much are the parts for this?
- Oil Pump?
- A weird problem
- Will my car run un-tuned?
- casting numbers?
- Hoping my opti is bad
- LE2/LE1 Emissions Cam Dyno Results
- Pcmforless ...
- custom plate idea thread
- Cai Help??
- mid or long
- Help LT1 Tuners! 248/254@.050" too big for stock pcm?
- LLoyd Elliot any one?
- Ground issue. LT1
- What Else do I need for a cam swap/engine install
- Is there a difference between the 97 lt1's valve spring caps &
- Rough idle and misfire
- Strange ticking sound
- Fuel Startup Problems
- 95 LT1 m6 Trans Am with Vortech V1 charger- Has rattling noise?
- trans am problem
- Stock lt1 CAM powerband
- Where does this wire go...
- Weird electrical issues
- How big should i go..?!?
- Crankbolt Auto car
- Slight knock from the timing cover.
- anybody running TEA 220CC CNC PORTED lt1
- Cut and Frayed Wires?
- who has removed their windshield wipers??
- need help with opti install
- Anybody Install Gears Around The San Marcos, Austin,tx Area
- ready to build
- Hotcam Torque Peak
- 94 LT-1, Firehawk
- ordered parts of the new exhaust
- What is this orange & purple crap in my engine?
