View Full Version : Forced Induction
- another guess HP and ET thread...
- Procharger F1-A on stock A4 LS1 GTO??
- Precision 39mm wastegate
- What throttle cable do i need?
- synapse wastegate owners
- min. valve-spring open pressure for 25psi
- SC guys... Looking for exhaust ideas
- How much do you pay for YOUR SC pulleys?
- Can gm multi layer ls2 head gaskets handle 15-18 ps1
- E85 , Turbine housing and camshaft
- twin turbo material build list
- Anyone used 928motorsports for SC rebuild?
- '91 Mustang LS Coupe, single turbo
- Flipped truck manifold question
- T6 turbo & 6L manifolds without standing up radiator?? Pics?
- maxed MAF, options?
- Cam Recomendations For FI
- Which intercooler? Top or cross flow?
- Rear mount turbo- What are your EGTs at the header?
- 93 Mustang Notch 5.3 TC78 build
- Gauge Pod and Gauges
- My new build. S475 with truck manifolds
- Twin Turbo A2W Intercooler Set up
- how to keep a/c?
- Will gm replacement head gaskets be fine on my build?
- Low compression forged ls2
- Reason to solid roller ? For a higher revving motor
- What are these called?
- Mpt76?
- boost, compression and pump gas
- turbo exhaust routing
- GT-76 TT Setup
- boost, e85 injector limits?
- Looking for build advice...turbo, cam, etc
- **LMR Outlaw 10.5 Viper**
- What else will i need? sts kit
- **LMR Twin Turbo Camaro makes 1050rwhp**
- Winter upgrades to the Tatershack 275 car
- procharger hose
- Hps/proline racing rhs 427 blower buildm
- HPS TBSS Build...
- Quick Turbo LSx RX7 video..
- what diameter pipe for tial 44mm wastegate
- 4.8 turbo: mp t70 or bw s472?
- Tial vs Turbosmart
- precision turbo housing swap??
- Proper place for BOV
- TT 61mm 347ci?
- Have questions for boost
- new to forum have some questions
- Wanting to buy complete turbo kit
- Vid of new best 4.82@161.30
- 317 heads, meth, 20psi..what spark plugs?
- Question about oiling
- Help, need more boost!
- Where/how did you mount your meth pump/tank
- Aps twin turbo?
- which direct fit procharger fan
- COT as a Meth Fail-Safe Opportunity
- Another front mount thread.....help
- What muffler/bullet for this .....
- F1-a procharger
- Turbo and cold air, how important?
- meth question
- fbody procharger belt slip fixed custom tensioner
- Another Turbo Cam Question
- Boost and vacuum operated gauges
- Intercooler mount pics
- Aftercooler or Intercooler?
- What clutch to use
- Cost to rebuild a d1?
- I need help with cam selection please
- first time turbo guy
- 98 Camaro-Supercharging
- some fuel questions on lt1
- Stock LS1 with twin TD06's?
- 370, Garrett GT55-94, truck manifolds build thread. ***UPDATE 12-10***
- My setup
- Lsa crankshaft
- New Virginia Speed supercharger cams
- Turbo information needed.
- 600RWHP Maggied LS2 GTO
- Looking for Procharger 4.50 6rib pulley
- Guys with big air to air intercoolers
- 07 Silverado with Rear mount TC78 on a LQ9/LS3/LS7
- Difference in LS1 vs LS2 Magnacharger Kit
- maxing out a F1 blower, aluminum or iron?
- LPE GT-11 camshaft
- Boost tolerance per c/r? (408 build idea)
- Help me pick the best converter
- **LMR Twin Turbo Camaro Initial Start Up**
- vortech sc help
- Truck manifold Gaskets?
- 15-17lbs boost and mass airflow?
- Re-using FMIC after blower breaks?
- serge tank
- '98 Boost limits
- sts for lt1 - how can you tell the differences?
- stock 6.0l crankshaft max safe rwhp
- Check Valve Question
- Turbo 5.3 in German Iron?
- 02 LS1.... Build for Boost
- Pump gas 347/346 guys come inside
- Most Popular Turbo Physical Dimensions
- National Speed: 2008 Chevrolet Corvette Z06 - Edelbrock E-Force Supercharger...
- Help with blower pistons??
- motor advice for my truggy
- need some help with picking a turbo for a 418ci
- Who Spec'd your FI camshaft?
- need a new manifold
- Procharger PCV Solution Needed
- intercooler piping
- S10 Front mount turbo.
- 4.8, what budget turbo/WG/BOV to go with
- Fill in the next item, 408, 235 TFS heads, ____
- What is a ST80 turbo?
- How Much to Sell a Blown Turbo For?
- Oil cooler for a Procharger?
- rearmount owners chime in
- questions about C6 manifolds for LS1 turbo build
- another noob turbo question about turbo downpipe
- My ZL4????
- what engine to go with
- t4 flange question
- head gasket designs
- 1998 Pontiac Trans Am Fuel Pressure & Vacuum Questions.
- Big hp build ???
- My first F.I build. 02 Z06
- dmax 3.3 map sensor
- melling 10296 w/ red spring. What weight oil for turbo?
- PCV Delete Questions
- Sholud I or should I not
- turbo guys oiling question
- Boost issue
- Tu1 cam?
- harmonic balancer options for d1sc procharger
- Turbo Blankets
- exhaust manifold for turbo build
- GMPP LSX376 and TVS 2300 combo…
- TC78 with a 38mm wastegate
- Intercooler opinion
- Boosted Build
- ProCharger F-2 on C6 Z06 Corvette
- Garrett PT67 or Master Power 70
- wastegate mounted
- which turbo or turbos
- Head Studs vs. Head Bolts
- Temple of Forced Induction
- 9.81@145
- cheap turbos?
- Will C5 manifolds fit an F-body turned forward?
- through the bumper
- help with hotside pipe
- twin 80mm x-275 class question.
- Help! Fan options
- 10:1 Compression?
- Where to plumb boost reference line from Procharger
- 80mm + 365ci + 22lbs
- Does exhaust tone change after supercharger.
- E85 and Back Pressure on Turbo Setup
- maf vs map
- What Alternator Bracket is this?
- supercharger belts? HELP!!!!
- GTA42 on a 383 Lt1?
- budget 4.8 turbo build questions (317s? turbo ?s etc)
- E85 and Spark Plugs
- Turbo Cam Help
- anyone use hydrolic line as return?how hot is the exhaust
- Injector size?
- sponsors selling flanges/fabrication supplies
- cam good for turbo?
- Pusher Fans on A/C Condensor
- sleeve length on an lq4
- if yall get bored, take a look and gimme a rough hp estamite on this deal
- tubular K member / turbo plumbing question
- need opinions t76 on l92
- Truck manifolds, accessory options
- My version of ChevyChad's mod
- What spark plugs should I use??
- 11:1 327 on E85 vs 370 on pump?
- E85 with no intercooler
- Want advice on spooling a larger turbo.
- turbo downpipe question..
- Anyone used a comp turbo?
- What size turbo
- What puller fans you guys running?
- Best C.I.D. for a TC78...?
- 150k dd
- procharger/ Head Help?????
- typical cost of turbo charging?
- Possible Valve Float
- Build Thread For New LS BMF Outlaw Drag Radial......
- Big time Turbo cam- you spec it
- Need a good tuner, Tulsa OKC KC
- Speed Unlimited President's Day Sale This Monday !!
- sts turbo build pics
- 2" vs 2.5" turbo piping for truck manifold build
- log headers
- tial 44mm and 60mm wg questions
- Twin Turbo with Twin Tial Wastegates Help ?
- ...anybody using stock head bolts with boost?
- +First build- 404+GT-91 **Updated Track results+VID**
- carb blower fuel question
- On the Fence Boost long block+ i need a vendor.
- TC78 + stock radiator location - doable?
- 3.5 inch dp on pt88
- Alky kit
- Garrett ball bearing turbo question powerstroke 6.0 turbo
- D1sc with pro flo valve need help
- Valve train question
- Another Poor Mans Belt Wrap Method
- Cheapest combo for 900-1000rwhp...
- need help from the turbo guys..what turbo?
- downpipe pix
- methenol injection
- D1 Procharger Help
- anyone have a used turbo cam for sale?
- EFI Live FI Users..2 Bar Sensor Help
- Time for change...Max effort iron 346...
- Procharger Installed..Oil Leak Now. Please Help!!
- LS2Formula New Personal Best 7.87 @ 179 @ #3695 Raceweight
- please give some advise
- Thinking turbo..
- which heards for 5.3 turbo
- Which heads TFS 225 or AFR 230 or ????
- Msd bap 2351
- 408 ls head suggestions and comments
- F1A vs Twin GT35 turbo setup
- 91 Z28 370/ST80/4l80E Build
- any trick to building a/w intercooler
- C6 manifold on passenger side = keeping AC on turbo setups?
- Stock crank/main saddles/bearings.good til?
- Twin Turbo Sizing Question
- Twin TC76's GTO
- Bent turbine, what do you guys think??
- pt-88 housing ?
- 100% turbo noob, admitting it ahead of time~
- Turbo Camaro build - TC78 + 4L80e + E85
- My new x275 legal turbo has arrived
- 04 GTO Maggie on a 02 Trans Am???
- 02 Z28 Turbo Project...
- What do you guys think about this cam for a pt88 370.
- P1SC Oil Change
- s-trim on a 383 ?'s
- Dyno shop in new york
- who all has turbo headers that keeps the alt. in stock location?
- cam to big??
- st78 or billit gt 42-76 for a 370
- Custom Twin Turbo Dilemma
- Started my custom rear mount
