View Full Version : Generation III External Engine
- If you've ever wasted money and time come inside
- stock y pipe and dynamax bullit
- Fast 90 vs Typhoon 96mm intake
- Taking Time to vent
- Bassani TD owners...
- EGR Removal question
- AC Question.
- Deciding ON Exhaust
- carbed ls1
- Check out my port job, LS2 TB
- Header rattle
- Exactly how much would a true bolt-on LS1 gain from a full dyno tune?
- I-pipe
- HELP! Cant get head bolt in rear passenger side!?
- Need advice: Noisy air pump?
- New Dynomax "Bullet" Catback
- Pics of GMMG w/o oval tips...
- finally got my lt's and td's installed
- What length muffler for td's.
- Exhaust Hanger Part #
- air lid help
- Video Request: Magnaflow 14211s
- Twin cone Volant intake
- typhoon
- broken oil pressure sending unit
- Thoughts on this exhaust idea?
- New goodies for next weekend...
- is the y-pipe hitting the floorboard dangerous
- Open headers for long periods...
- Is this a good oil pump?
- tb bypass mod
- REAL difference in power between these two exhaust setups...
- 90mm Tpis Tb???
- Strange "whizzing" noise
- ORY VS. Magnaflow Cats.....How much of a sound difference?
- New x-pipe out the back, $500
- Help with o2 Recommendations
- TSP TD's Anyone have on order?
- Installing Race Style LT's & Have a few questions
- True duals and exhaust set up
- SLP loudmouth 2
- Ls6 intake............
- 5.3L Bolt Ons
- True duals or GMMG/Borla setup
- pacesetters came damaged
- Overheating After Turning the Car Off
- pacesetters leaking
- Seafoam Treatment
- New Magnaflow Tips?
- shop charges $250!!!!
- camaro headers
- LS1 swap conversion
- need k&n replacement
- Had Jethot LT's on last car, should I consider another brand this time?
- Flowmaster round race muffler look like a cat???
- Selling Car, Which Catback?
- Nick Williams 90mm TB Top Bolt ?
- help me decide exhaust
- Mufflers
- slp headers dont fit convertibles ?
- New exhaust system...
- My custom ported FAST 85/85 - *PICS!*
- kooks LT and ORY am i supposed to smoke this much?
- Intake time?
- Cleaning engine bay?
- fixing slip on header style leaks!! ??
- Just bought an 07 Silv- what intake/headers?
- Are TSP TD's with Pacesetter LT's to much noise for a DD?
- Why did GM not build a Computer Cover?
- LTs & ORY have arrived. How long to install?
- WS6 - Help: Raspy after header install - What Muffler To Buy?
- Factory Tunnel Brace
- will 98-00 lts work with 01-02?
- why is my temp so high
- looking for a bullet muffler need help
- What O2 sensors do I need and where to get 'em?
- Would an 96-97lt1 muffler fit an 2000 ls1 car?
- Question about QTP headers and TD's
- wierd starting problem after headers
- What bullet should I get?
- Need A Quick Answer!! Egr Question
- HELP! I broke something by my intake manifold...
- Flat or Square o2 extensions?
- Anyone run a sheetmetal intake?
- Vic Jr + Air Cleaner
- Plugs.....
- what lt's for the best groundclerance?
- Worth pullin the Pacesetters for Kooks lt's ?
- Ordering pacesetters, do they have o2 extensions?
- victor jr. guys.... how did you mount your rails?
- Best Fuel Pressure
- part number - ls1 stock serpentine belt tensioner
- !PCV and Oil life question
- Can't make up my mind on which exhaust
- Both 02 Sensors Bad...
- Squeak
- Cat Back Question
- Helpp! Installing My Td's
- Broke Dipstick tube.
- Intake Manifold suggestions?
- ls2 intake
- Dynatech Header Owners/Exp. inside pls
- Modifying a FAST 78 for an 85MM TB
- Higher Ratio Rockers and Uprated Valve Springs
- Is the dual/dual still available from SLP?
- Bangin'
- Tick tick tick....pissing me off
- will my loudmouth connect to the QTP ypipe without modification?
- Don't know what to do next.
- Easy band clamp question?>?
- AN fittings for radiator hoses...anyone?
- exhaust y/i pipe
- Solid mounts + LT's + DD ?
- StealthPowerSports Airbox Lid - Having trobule installing!
- Currently Have Borla, want a new sound.
- Anyone polish the outside of the Throttle Body?
- ? Is a ported LS2 as good as a LS6?
- decisions decisions.....
- catch can and oil pressure
- Kooks header install thread?
- Jet Hot/Hooker ORY owners inside
- height issue
- cheapest place to buy NGK Tr-55's??
- for 00-02 f bodies. where is the breather filter for lid install
- what size cut out??????
- [B]Pacesetter headers[/B]
- Y-Pipe Bump Stop Hanger?
- Just finished changin the spark plugs, time to relax
- LM1 to Pacesetter/TSP
- Loudest Bullet?
- Brake Fluids. NEED HELP!
- Intake Emergency
- what gives here!
- Header Install ??
- Any sponsers with slp lid in stock
- how high is your stck cam producing power
- PICS!!! of victory jr intake w/ air lid set up...
- slp out of stock
- SLP or Z06 Mass Air Flow
- Best alternator
- Need to know if its worth it. (ASAP)
- Yanking out the EGR & AIR, what to do with wire?
- mac mids, ory and ls6 intake
- How do you know?
- Will Hypertech LS1 Thermostat work with a Meziere Water Pump?
- Dual cutouts-HP GAINS DYNO PROVEN
- Quietest exhaust with lt's and ory
- What are the dimensions of Flowmaster 1 Chambers?
- Installed LS6 Intake Yesterday
- cutout question...
- Twin Cone's Vs. Lid
- Wiring harness question?
- 02 question
- diff. between SLP lid and Black wing Lid
- What airlid for 90mm TB
- What pulleys for LS2 402
- Qwik foolish header question...
- Granatelli spark plug wires
- Hope i dont mess this up.....
- Nick Williams Throttle Body?
- Good bolt-on combo to get my C5 A4 into 11's?
- LSx IAC Location
- tying in ORY into stock exhaust mid pipe
- No muffler
- CATS or no??
- problems after header install
- header question
- longetube header install question
- Air removal Help needed asap
- Header tube rubbing steering column??? Need help ASAP
- Mac headers??
- Dyno numbers
- Guys with the high polish QTP headers
- another ls6 intake thread
- Open Headers = Slow
- Rear brake light kill switch
- QTP e-cutout
- Plug wire/keep burning em up
- size of stock tb??
- Need Valley Cover Bolt Size
- Cam Vid
- Loud Mouth Question?
- Damn header gaskets!
- td vs catback
- 402-worth switching from 1 3/4 to 1 7/8?
- Hooker LT's, Comps vs. Supercomps, difference??
- LS1 Exhaust header design question to the pros! (Lou, I'm looking at you!)
- Idle Problem ? H E L P !
- another shorty thread
- ls2 won't work on an ls1 will they?
- I started my Professional Products Typhoon swap today
- putting fast 90mm on need help
- help manifolds help help help
- is 02 sensor needed?
- Question about installing my own exhaust
- throttle body question?
- fuel injector clips
- Dynomax bullet intermediate pipe and over axle???
- Spark Plug gap with H/C/I & 42LB injectors
- New Magnaflow system?
- Freaking dealerships
- Lid problems...
- AIR/EGR question
- New JET HOT Header Coating!
- Looking for a specific sound (I check ls1sounds)
- Exhaust volume Cam vs. stock internals?
- After My Header Install.....
- Installed SSRA a few days ago...
- 853 vs. 241 vs. 243 castings?
- B&B Retrofit?
- won't start with battery moved
- BBK Intake Problem
- wtf is up with my ls1
- slp header install?
- Question about 93 octane in relation to car performance...
- Possible Idle Problem Related to Screenless MAF
- Will 5.3 Starters and MAFs Interchange with 5.7 or 6.0's and different years?
- AIR Removal with PICS!
- Best place to get LS6 intake
- LM1 muffler LM2 muffler differences?
- Backfiring?
- Is it possible to get 12 secs out of bolt ons only
- Cruise Control Cable
- Tb Coolant Bypass Mod
- 2002 ss fact i learned today...
- Exhaust Tips or Info.
- F.A.S.T. intake, LS2 90mm T.B., and Haltech worth it???
- were can i find this damn band clamp part
- Weird noise?
- Exhaust??
- SLP headers guys I need help!
- any decent flowing quiet mufflers out there?
- Check for intake leak?
- Has anyone seen/tried this kit?
- Proper Gap for NGK TR55's?
- Coolant system help!!!!
- 1998 WS6/SS Single outlet exhaust (picures)
- Very high idle problem after motor swap. Please Help!!!
- EVERYONE needs to get one of these!!!
- How long did you wait
- Anyone seen this lid?
- installed ls6 intake
- Help with next mod. LS6 intake?
- How many guys running QTPs and Flowmaster ORY
- Katech valve covers and coil brackets
- I am tanked and out of control1111!!!
- UMI Vs Nick Williams
- Spring mods inside opinions welcome
- Question About Heads & Intakes
- have a dumb question to ask
