- which one's
- Mufflex 4" catback
- oxygen sensors
- where to get hi-flow cats?
- Whos got headers, no cats, and a GMMG "chambered" cat back??
- Sparkplugs for T/A
- y-pipe versus true dual sound?
- Whats the best catback for a F-body Ls1 H/C M6 w/ OR y-pipe?
- Fuel Pressure Drop On Acceleration
- Borla muffler???
- Intake Warranty
- Hotrod at MMs tested Hooker LTs
- In 3rd & 4th gear around 5k rpm, the car feels like its loosing power! Please help!
- What do I need to do next???? For more horsepower!!
- Extra Fuel Tank?????
- New Dynomouth!!!
- Whats up with my 02 sims?
- Casting # on a 01 LS6 intake manifold
- MAF Sensor
- balancer position.
- Anyone have any GOOD install instructions for a SLP CAI?
- service engine soon
- Stock car , better get Short headers or LT headers ??
- GMMG, LT headers, and highflow cats Come Inside for Sound Clip
- Project Car Question
- Lifters
- Another true dual question
- intake manifold
- intake manifold
- Fuel tank on a 3rd gen
- tr-55's
- AIR for ORP?
- AIR for ORP?
- Choosing the right headers
- lid problem... help!
- Can i swap a 98 camaro LS1 intake and a 02 LS6 intake across??
- IAC motor becomes a projectile!!
- Ls1 intake with H/C..vs LS6
- Fuel pressure is droping during acceleration
- Oval exhaust, true duals. Anyone try this yet?
- True dual question
- At what point do you upgrade fuel system?
- WHat is an LS1 intake worth???
- What is the RIGHT part number for poly motor mounts?
- Adjustible fuel regulator LS1
- 2nd Fuel Pump ON Switch Trigger?
- Hooker LT on stock internal, Befor 13.98@110 After 13.50@114
- comments - suggestions WANTED! on installing MACs
- good bolt ons for 02 SS
- CME with "loudmouth," possible?
- what sparkplugs are best?
- Diagnostics Code P102? Has my MAF Sensor Gone Bad?
- Loudmouth vs. Hooker catbck
- do 98's respond to MAF different than 99-02?
- Do you have to change the oil after spraying AmsOil Power Foam into your engine?
- Hard to put this in a sentence
- Car feels slower without cats...
- Mac headers on my 2000 Z?
- Paging Colonel...
- MAC True FitŪ Header Systems
- SLP LoudMouth too loud?
- Any Help Appreciated
- LoudMouth to Dyno Mouth conversion
- Throttle response?
- UH OH!!! I got an SES light this morning!!!
- I got an SES light the morning(after spraying it last night)
- Factory Y-Pipe
- Screeeeeming pump
- Where to get the cheapest fuel pump?
- Not sure bout Radiator
- Exhaust
- Gain from mac+cats to TTS Lt's with off road pipe
- Tick, tick, ticky-tick of my lifters...
- LS6 Manifold Question.....
- Throttle Body and MAF Air Sensor
- 00-02 lids require a breather filter? What is this all about?
- Where do I need to go next
- Since the FTRA is made of stainless steel...does it have the heat soak issue?
- Drill Mod Question
- A way that might stop PCV oil problem!
- macs?
- Does anyone make a x-pipe for the LS1??
- GM top end cleaner?
- PCV valve??
- Who has run a short belt on an ASP pulley???
- Filter Oiling Question
- Educater guessers chime in...winner gets a cookie.
- Where to buy collector for custom y-pipe?
- I want Loud mouth but I have CME any ideas?
- I had true duals installed yesterday!!!
- WILWAXU
- Clunking sound from rear over bumps...
- Opinions on Magna Flow cat back???
- Idle Question After Boltons
- Help!!!!
- Hooker y-pipe banging floorboard?
- who ports throttle bodys
- Borla: No plate vs. Capped off
- Easiest Way to clean the MAF?
- for guys that did all the "mac mods"
- Injector Requirement Formula
- which spark plugs?
- modifications for fuel pump?
- Has anyone changed from FLP's to.....
- Porting Maf Ends and Throttle Body
- Need Help Diagnosing a Problem!!
- MAF question????
- ford racing injectors or..?
- So is a lid a lid, or what??
- what is the next mod??
- PPC Headers?
- Which belt??
- What's the short belt mod?
- Holley Filter Oiling Question
- Broken Wiper Arm.......Help
- Inline v.s. intank...
- Please HELP!!! Fuel System
- Short Belt Mod?????
- Y-Pipe Comparison
- Ran FLP open headers today; results
- Throttle body hole size help
- Which Headers?
- stock cats on MAC ORP
- TBB equipment
- 15W-50 oil too thick??
- MAF
- Part number for gm tri-metal head gaskets
- Does anyone elses car smoke at WOT with headers?
- does you LS1 smell when you turn if off?
- what sounds better w oryp gmmg or borla
- Did some dyno runs.. wrote small reviews
- who has installed a intake fuel pump on a 2000?
- Ported TB ported massair, ASP worth how much
- Stock crank pully Q
- Reinstalling stock pulley...
- Is it possible for headers to cause oil consumption?
- mufflex 3.5" catback
- pics of true duals
- Donaldson vs K&N?
- 30lb inj. yes or no?
- do ls-1 use a different kind of pully puller? Where can i get one.
- Got some new Stage 8's
- Pinging
- My supersucker is different than my friends?
- spark plugs
- should i get asp underdrive pully with my heads and cam
- Questions about stock fuel line and 50 lb injectors
- Replacing knock sensors
- Battery
- Help with removing crank pulley
- Fuel Fitting Adapter?
- Lakewood driveshaft loop for Camaros
- 160 thermostat what should....
- Ported TB on stock LS1????
- Underdrive pulley????
- What thermostat should I go with?
- Faulty catalytic converter causing detonation?
- 02 ss warranty
- Anyone that has had their master cylinder off on their Clutch, I need help!!
- Random Tech or SLP Y-pipe ?
- Another place to re-locate coil packs...
- TR 230 guys which exhaust twin 2 1/2" or twin 3"
- Who said you can't change plugs from theTOP?
- bought hooker lt's and i need a y-pipe i dont want to use theirs
- Ported Holley or LS-6 intake???
- What are the flow numbers for CNC stage 1 LS6 heads compared to Stage 2 LS1 heads
- Jet Hot LT Dyno #s in here!!!
- BG Ram...do I also need a lid?
- How much does an LS1 aluminum long block weigh?
- 1 7/8 grotts or stepped dynatechs for 422
- Hooker shorties
- Electric waterpump?
- LCA Brackets (bolt-ons)
- How to disconnect FUEL EVAP connector?
- How do I get rid of the EGR valve error code ?
- LS-6 or Holley Intake, opinions needed!
- Oil pressure guage, factory sending unit ?
- what should i do??
- Highest flowing yet quietest muffler on the market?
- If you've installed Grott's or QTP's...Inside please.
- Help plz...
- Defective Hooker Long Tubes??????
- Over-oiled K&N filter, what problems???
- Oil change light won't go off?
- TTS header install notes, and a couple ?'s
- Baker hose install w/pics.
- Quiet True Dual Idea!!!
- Random tech y-pipe for Mac headers
- low budget bolt ons?
- Pictures of a borla X R-1
- New catback rattling
- I installed my Fernco and I have a couple questions.
- Dual Exhaust Price
- Random Technology Y-Pipe For Hooker LTs
- When the car is in 4th & around 5k rpm and climbing it starts to......
- Would an exhaust leak cause a very rough idle?
- clicking noise???
- has anyone used the brian green ramair kit?
- would this get me in the 11s 99SS
- Header tube length
- Stainless vs. ceramic coated headers
- Installing a LS6 intake
- cut out an QTEC question
- Does anyone make "replacement" poly mounts
- Jet Hot Headers: Post your Dyno or Track Results
- Should I buy the Fast Toys add on for SLP CAI?
- header install questions??
- How light is the hooker catback system compared to borla?
- Anyone make 3.5" cutouts?
- What gap should I set my new plugs at?
- Poly engine mount?
- what kind of fitting??
- ls1 vs ls6 intake
- Does the Fast Toys ram air kit really work?
- what do u think I should do with this set up
- Holley 80mm
- Putting 2 Bullets in the I-pipe?
- Serp belt question
- Ported MAF & A4 trans ?
- Factory Firehawk Exhaust???
- Oil out of Cutout?
- Has anybody tried spiral baffels on a true dual exhaust
- URGENT i am having trouble getting my water pump off
- cat back or muffler (hooker)
- Cut Outs
- Am I doing this right?
- Where to place cut-outs on true dual X-pipe setup?
- Will Trading to True Duals be Quieter??
- True Dual Exhaust
- Diameter of FLP Y-Pipe Merge?
- Lifted Head/Heads?
- Colonel please help..... AGAIN!!!
- dynatech headers
- Problems with cooling system?
- pn for y-pipe hooker
- ? for a friend: What size bullet?
- Installing Dampner Bolt...What's That Orange Stuff?
- gap on plugs???
- Need LS6 Intake help ASAP
- Banner advertising Info please
- Question about Granatelli MAF
- Got a new dual exhaust idea using GMMG's chambered pipes...Please critique.
- Question about the Grott style headers and Cats
- while i was removing......
- More power w/OR pipes and GMMG or High flow cats/cutout?
