View Full Version : Generation III External Engine
- Gaskets needed for LS6 i ntake install?
- spark plugs and wires question
- How Many Rwph???
- header install advice. please head
- Thoughts on new LS6 intake+Pace+PTB+ORY+APHR-EGR-AIR
- TB Removal
- Looking for belt spacing specs/diagram
- How much for true duals?
- Pics of my new LT's and magnaflows
- O2 sensors that can handle race gas
- XS Stainless Headers with TSP True Duals?
- dual cutouts
- I need some opinions.
- No cats = always smell like gas?
- does a cracked spark plug hurt anything when driving the car?
- Spinning Crank Pulley...
- Help with Y-pipe selection
- Mods Mods Mods...
- IAT Sensor
- powerpacks mufflers=Glasspacks??
- Broken AIR/EGR tubes...
- Someone help me out here
- F-Body Manual???
- Installin cat-back....which one?
- Underdrive pulley/Elec water pump question...
- Exhaust question
- O2 sensor question after header install...
- Ignition questions
- Mail order tune for LT's & ORY ok?
- ses exhaust question
- corsa owners-good news...
- How to port a Fast 90 intake
- Will a TSP true dual system fit through a BMR crossbrace?
- HELP!!! Power steering pulley!
- help me!!! idle problem
- flow tech?
- Hooker or TSP off-road y-pipe, Which is better fitting?
- Will fast 90 and NW 90 kill my low end on a cam only 346?
- Catted Y-Pipe vs ORY?
- over axle pipe?
- Y Pipe
- Y-pipe question
- sealed hood
- What mufflers to quiet down TSP duals?
- question about GMMG exhaust
- Quick question???
- Fk'd Up Prothane Motor Mounts???
- PCV fresh air line: ok for breather?
- Header compatability
- porting dart heads
- bassani headers?
- after bbk intake
- question about putting a ported ls2 intake on a ls1
- volant intake on ramair t/a
- What are the inexpensive cat back systems?
- LS1 mods with a grand
- Somethings not right after header install
- XS headers installed no problem....
- Best Exhaust Tips!
- Free ram air mod ???????!!!??? COME IN PLEASE
- Fitting size on Victor Jr. intake...
- cylinder misfire resolved
- Wideband O2 Sensor...
- Immediate exhaust removal advice needed!
- Do I Need This??
- FTRA vs volant vs factory Ram Air vs ???
- Are these the correct O2's?
- @#^& BROKEN HEADER BOLT
- How do I install this SLP ramair?
- exhaust setup.
- can you solder O2 sensor wires?
- Fel-pro head gasket confusion
- Can you tell me what this plug is for??
- Any ideas to fix my exhaust? got new exhaust and don't like it
- Pacesetter Y Pipe?
- 400 RWHP range... anyone go from 3" to 4" single exh and measure gains???
- cleaning headers question
- POLISHED & ANODIZED MAF ENDS?
- Finally got the full exhaust installed
- Broken header bolt
- 80mm BBK or 78mm FAST throttle Body?
- Sound difference between Powersticks/Powerpacks?
- Help!!!
- Cai
- Locking stainless zip ties....arghh!
- wrong gap on plugs.should i change them?
- Adapter for autometer electric temp gauge
- FTRA and AC performance...
- Stage 8 Header Bolts...
- Borla Cat-back system
- plugs !!!
- Need a little help understanding.
- What kind of idiot screws up a battery install??
- powerpacks same as glasspacks?
- O2 Sensors/Extensions...
- HELP ! car wont start after ls6 intake
- what exhaust to go with my kooks?
- engine sensor
- 2 cats, 1 gutted?
- Official ARP balancer bolt torque
- anybody know what the resistor on the a/c connection is for
- I've created a monster
- Y-pipe Argh!!!!
- Best type of mufflers
- 2 stage rev limiter
- crank pulley go on a certain way?
- Vette Slp Pulley on a t/a?
- OBX Headers Install
- Will this work???
- got my "new" slp lid 2day...
- LQ4 Intake Question
- cam bearings
- Resonator Q?
- Resonator Q?
- Exhaust shops in allentown area
- Porting MAF, does it run rich or lean?
- Guages Question.
- SLP D/D Tailpipes on sale.. great deal
- A/C Questions
- so i finished my headers but..
- Egr?
- O2 sensor simulator problems
- AIR/Free mod help!!!
- No Muff.or Can I Gain POWER With A Muff?
- What next?
- Ugh....
- Part # for pulley belt
- quietest TD mufflers
- plug wires
- Long tube install went well, thanks LS1tech
- headers choice
- Any way to quiet down the TB?
- Best bang for your buck headers?
- DMH electric cutout
- Need Everyones Opinions!
- o2 sens0rs????
- My FAST intake doesn't want to fully seat.
- Poly motor/trans mounts in
- opinions on bbk ssi intake manifold
- Aftermarket Throttle body ?
- SLP Cold Air Extension
- Help with MAF and TB
- Egr delete
- How did you guys hook up the brake booster line on Vic jr
- More 85mm MAF really cheap,,,,,
- porting my tb
- Who sells the TSP clear lid?
- dowel pins
- twin engine covers on fast manifold
- Double checking what a LS6 intake looks like...
- water pipe crossover kit,
- LS6 Turbo Recommendations
- MSD 8.5mm spark plug wire gp
- Too much intake throttle body airflow?
- Which Magnaflow muffler fits the stock exhaust?
- best flowing muffler
- 3 inch true duals, x-pipe, borla xr-1 mufflers
- Cam qustion??
- Bangin headers
- Pulley HELP!!!!!
- i am doing my headers right now and have a ?
- FAST 90 swap question
- where to buy...
- LS1 Fbody Catch Can Kit - Who sells?
- Flanging up the headers and Y
- true dual setup....opinions needed
- LS6 Casting numbers
- Underdrive Pulley
- Any info or update on LG headers for F-Body??
- Need some Help, Car is acting up(sometimes)
- wiring question need help asap!!!
- 02 sensor replacement / how many?
- Looking for FAST90 and LS2 flow comparison
- O2 sensor ?
- Last Passenger side Spark Plug
- How to install headers
- Question on changing throttle bodies
- TSP Rumbler
- paging Jag42420
- 01 ss....claiming to have egr???
- ready to buy a oil catch can!! need some help on mounting locations
- Wiring layout
- pacesetter lt coatings
- block off plates with race headers?
- Gutted Cats today
- High idle problem after motor mount install
- FAST 78 to FAST 90???
- SLP Underdrive Pulley on a C5
- When is loud too loud? AKA droned to death...
- Vacum lines?
- Just got headers on, not runnin right
- Part # for asp underdrive belt needed
- SLP coming out with a NEW BLACKWING !!!
- Inside the LS6 Intake
- corsa or magnaflow and torque arm.
- SLP coming out with NEW revised Long Tube Headers !!!
- LS6 intake gasket okay to use with FAST intake?
- Realistic gains from LT's...
- Rad fluid change question.
- Spark plug # Question
- MPG Burning too much Gas
- Spun Met cats who sells them.
- Single Chambers or A Bullet type muffler
- Water pump ports...which is send/return?
- high flow cats
- How much is this worth??
- replacing a factory exhaust manifold?
- best deal on 90mm maf
- clearance for oil cooler sandwich adaptor?
- cutout clearance
- brand new 85mm MAF's for cheap on ebay...found this in our conver. & hybrids section.
- As requested....header install info....
- which is the send/return port on water pump?
- Vacuum source with an LS1???
- Send Bo White Back Your Tb Cores!
- Motor Mounts
- low voltage on o2's????
- New Sounds Clip Magnaflow! TY Richard!
- Anyone use these to help with rasp?? or use them at all?
- 6 bolt ls1 style heads to be used with the warhawk block?
- Who gets o2 problems after header installs?
- american racing headers F-ing rock
- true dual ekhaust clips
- Hanging True-Duals...
- Underdrive pulley
- block mounted SBC STARTER on an LS1?
- What do I need to purchase for LT install?
- Noisey Fast Manifold
- New Lt's -- O2 Sims???
- Just installed ported fast and the idle is all screwed up
- td's again
- Poly/Solid
- spark plugreplacement writeup?
- What size headers?
- manifold studs broke what should I do?
- Is it worth it at this point?
- Exhaust Question
- How much oil is too much?
- Muffler shop - Austin, Houston, San Antonio
- Header install help
- Exhuast
- Video Clips of my new X-pipe setup
- Anyone have this exhaust setup?
- Texas Speed Catted Y-Pipe Clearance
- pulstar plugs? Pulsing spark plugs?
- Looking for the right muffler
- ls1 exhaust flanges
- Header installation help still
- what mod to do next
- Who makes perimeter bolt to center bolt valve cover adapters.
