View Full Version : Generation III External Engine
- Power loss going to Macs?
- 97-98 -> 99+ Valve Cover Conversion
- E-Brock headers and ory, and Dynomax Catback...Pics inside of the install
- Will AMG Catch Can bracket fit a Greddy Catch Can
- I think I'm going to try to make an oval electric cutout...
- What Will Make More Power?
- Wanting to adjust idle?
- LS2 intake manifold
- Question bout tips with the TSP Rumbler
- coil relocations
- How much louder? (Neighbors and exhaust)
- Thread pitch and size of small starter nut
- BBK throttle body butterflies...
- C5 4" airbridge custom pics...
- Torclite formed clamps with Kooks headers leak?
- True Duals... How streetable?
- Air lid install?
- Confused; header bolts - antiseize or thread locker or nothing?
- Another TB?, this one different
- Oil sender.. where do i tap into?
- open headers
- best Y pipe for pacesetters?
- I F-ed up!
- slp bellow is trash
- ls6 part number
- ? about TD's and GMMG
- Louder than my set up
- Louder exhaust?
- exhaust pics
- Ory vs. TDs
- will a truck oil pan fit in an f-body?
- Powermaster XS torque starters???
- asp underdrive pulley
- Jet hot long tubes and fab y
- help! 01 midlengths on a 98 car??
- Fast 90/90 w/NW TB
- do you like it smooth or a little rough?
- Rumbler/ST vs. GMMG
- Lt1 Header Experts inside please...
- guys with headers that have air and egr...
- sweet thunder in loudmouth
- LTs and Y
- Bullet muffler power loss?
- texas speed catted-Y + lowered car?
- anybody got this underdrive pully
- stock t-stat temp
- NGK Iridium Plug Users Please Step In..
- true duals or catback
- Another headers question...
- ***QTP Electric Cutout Controller***
- header install kits.....
- Stupid question.
- bad cat(s)
- Can I delete the evap system? yes or no?
- Radiator and cooling on an LS1
- qtp off road y pipe
- Ls6 intake manifold..
- Tsp Rumbler reviews?
- What is the best way to repair stripped spark plug threads?
- H-pipe
- drivers side 2.5", passenger 3"
- Catalyst efficiency????????
- fast toys ram air
- Where do you guys cut the SS hood for more air flow ?
- Ignition and header for 5.3 vortec.
- New gaskets and bolts for headers ?>
- Tsp Duals
- Sweet-Thunder TD
- Anyone know about the TPIS spider intake???
- Nick Williams TB question
- FAST LSX 90MM System
- cutout switch mount
- GMMG true duals?
- Engine oil leak - typical?
- stalling
- Installed Long tubes and now...
- Pass O2 pops and fries wires
- Catch can pics Please
- need some answers
- motor mounts 4 LS1
- 3" muffler vs 4" muffler...
- Long tubes, no cats...
- does anyone have any experience with the 300 11p polished intake?
- Magna-flow with LT'S, and ORY good combo or not??
- true duals vs. ORY
- So I tried to make my own 2.5 TDs....
- under teh axle TDs
- 60$ for a 160 thermostat!!!!
- which maf?
- Question about TSP Catted Y
- pacesetters on a VERT?
- Anyone ever go back to factory exhaust manifolds on H/C car
- Custom True Dual?...
- Ls6 intake....
- Where to find parts for LS6 intake swap?
- Greddy or AMW Catch Can
- What are these headers?
- Rasp with GMMG and LT's w/magnaflow cats!
- ported throttle body?
- motor mount install
- Cheapest place to buy cats??
- Anyone running cutouts on TSP catted Y-Pipe?
- Underdrive Pulley Wobbling
- AIR block off plates.....
- Did base vettes get the ls6 intake?
- oil cooler
- Anyone using Magnamouth?
- Anyone use Race Ready cutouts?
- Is there a 3" inlet x 2.5" Outlet X-pipe?
- intake
- exhaust ??? whats up
- Ballpark price on Edelbrock carb intake w/fuel rails?
- header help
- QTP w/HVMC or Kooks?
- is tsp rumbler a good one
- I want it LOUD!
- going to swap ls1 to ls6 intake
- Holy Cow, I crapped my pants!
- Throttle Body ?
- Edelbrock Tubular Exhaust
- Thoughts on Fast intake manifold?
- Header gaskets
- What is the OD in a Y setup
- valve cover ?
- 01 Z06 Serpintine and A/C Belt Length
- alternator swap info
- post pics of !muffler setups...
- 00-02 LT's have EGR provision?
- new y-pipe
- exhaust making a weird noise...
- Cleaning Intake Manifold
- LT'S cut outs o/r ypipe
- MAF question
- LS1 or LS6
- Anyone bought these TD's of ebay ???
- Those with big cubes, PLEASE post exhaust sound clips...
- Steering shaft problem
- Dumb question but..
- 98 to 99+ PCV System
- any one running this
- What are these peices I have left over from my manifold swap
- Cutouts
- underdrive pulley
- nitrous warehouse intake
- Hi-Flow Cats/more TD questions haha
- Coil relocation...Hope this works....
- holley/Weiand intake good or bad?
- FAST LSX and 90mm TB for my H/C Car...
- hello tsp x pipe goodbye clearance
- A couple of questions.......
- please post Dynatech pictures...Please
- Exhaust install
- cats?
- Noisy fast 90
- Any exhaust systems sound good with ORY?
- Idle problem at start up after changing T.B.
- Coil Pack Re-Location Kit
- what Y pipe with edelbrock long tubes?
- Intake or headers?
- Side vented Exhaust
- Exhaust decisions
- Clicking sound?
- how long can I go with no o2's?
- Informative Merge Collector Article
- Meizer electric WP thermostat location?
- qtp vs edelbrock fully welded lt headers w/ ti- tech coating
- Plugs & Cutouts
- Long Tubes Installations
- true dual x-pipe?
- Tech Question on X and H Pipes.. why do pipes meet?
- Rattling from y pipe (drivers side)
- Post pics of your homemade or aftermarket smooth bellows? Please.
- does FAST 78 mm. intake bolt up to stock tb?
- Kooks Slip on Collector vs Weld on ?????
- THrottle body porting
- need help w/ 98 to 99+ ignition switch over.
- converting ls1 intake to fast intake????
- Kooks 1 3/4 w/ 3 Cutouts?
- Intake Manifold Help
- FAST manifold ?
- what can i get rid of?
- Catback/TD, legal question
- QTP ORY 2" clearance??????????
- Wire harness?
- Crank Pulley removal??
- Ported TB ?'s
- Starter question...
- Throttle body Bumpstop mod?
- Magic Self-Healing AIR System?
- rear pass manifold bolt
- TPIS Oval LS6 and Throttle body
- TSP duals installed, where did my ground clearance go?
- what can i gain in 1/4 mile with Longtubes & ORY on my LS1?
- !Air !EGR w/out ses light?
- Burning Oil/ Oil around throttle body
- headers
- modifying/custom ORY
- Open Headers Question
- what plugs?
- SLP radiator ?
- SLP Radiator
- TB bypass
- Finally got my Kooks 1 7/8" headers installed...
- what's the best tb for ls6
- the best combo intake/tb
- power steering howling
- salvaging headers
- vacuum leak around pcv valve boot
- LS-6 intake worth it?
- AIR/EGR differences from 98-99 to 2000
- time to change the plugs?
- O2 Sensors
- Edelbrock Headers
- Alternatives to welding my entire exhaust together.
- LS6 Intake?
- Sweet Thunder vs Moroso Spiral vs Dynomax
- What is the difference between 98-99 lid and the 01-02 lid???
- anyone have the Rumbler with LTs/ORY?
- Motor mount write up?!?!?!
- which header is better for the money
- Pacesetter/TSP X mixed thoughts + Flashing SES
- need help with CME... im takin it out!
- Which Motor Mount?
- lt1 catback onto an ls1 car?
- O2 sim questions
- Pics of Center Mounted GMMG?
- No Cats = Illegal!?
- Power steering pump bypass - belt???
- Borla
- Motor Mount write up...
- Cheapest place to get V-Band Clamps?
- Idea I thought of for ftra/ssra owners
- 01 ls6 tb and injectors...
- LS1 vs LS6 intake.......
- Pics of my 2.5" duals w/ sweet thunders
- Hedman Headers
- Thunder Racing Header Speacil: NEED HELP!
- emissions
- good deal on True Duals (TSP)??
- Run Straight LT's?
- Installed TD's, SES light came on....
- Over The Axle TD ?
- *******Need Help Asap???******
- Valve Cover Differences
- Hole in lid for AIR
- Just installed the lontubes got a few ?s
- advice or diagram's on hooking up guage's....
- Ls6 Intake Vs. Slp No Egr
