View Full Version : Generation III External Engine
- For 422,427 & 436 c.i. , Do we need to modified the fule pump and line ?
- Cartek long headers , any one is using it ??
- what spark plug wires for 98 head and cam car/headers
- 99 LS1 GUYS INSIDE PLEASE
- 3/8" Fuel Disconnect Tool
- Exhaust Question
- QTEC Cutout Questions??
- A4 and ported MAF Ends...
- Please help ASAP!! part # needed for kn fipk filter
- FLP's and 20K miles
- Which spark plug should I go with? NGK TR6 or TR55?
- ported maf ends
- Has anyone enlarged the TB opening on the intake?
- My new web page (not done yet)
- Some smoke at WOT after header install & O/R pipe?
- Is it a direct bolt in swap of 98 to 99 fuel tanks?
- Homemade shift light???
- weight difference between the 99 plastic fuel tank and 98 steel fuel tank??
- GOT NEW DYNO NUMBERS BUT QUESTION??
- I know everyone hates these.....
- Need Pics Of Back Calipers cut to fit 15's
- Mobil One Oil Question
- Best ORY for FLPs and B&B?
- Please look at my dyno #'s and tell me what you think
- A4 with SLP maf 85mm?
- F-Body Condenser Leak, how to fix?
- Sounds and pictures of spintech exhaust???
- where to get O2 sensors
- Walbro inline fuel pump directions ?
- Remove 2002 Z28 MAF
- Halfway through my header install..this pic says it all. *mdl finger warning*
- What Kind Of Rear Wheel Horsepower???
- Install Header Question????
- Need sound clip! Flowmasters on X pipe
- Effects of burnt front O2s
- Spintech??
- upgrade to ls6 pcv? what's needed?
- Wow! Actual gains with MAF ends???
- quick and easy header install question
- Anyone pleased with their flowmasters?
- egr removal
- HP Gains on Electric Water Pump
- CNC Ported heads
- Headers
- WS6/SS part numbers?
- Solved My "Header Banging" Problem!
- Do any long tube headers have a straight Driver's side collector?
- 6.0 truck intake question?
- FIPK vs. Volant
- Is removing the AIR system worth it?
- Buying QTP headers. Should I? Come inside PLZ.
- What is needed to install Hooker LT's on a 01 Ws6?
- What Does LS1 mean
- Deleteing cats...have a few ?'s
- What would you do?
- Will '96 Z28 overflow resevior fit on 98 Z28?
- Cat failure after Header Install?
- K & N FIPK
- Awesome Idea for K&N FIPK Owners
- little add-ons
- Maft translator
- Is a 00-02 Stealth airbox ok on 98 T/A?
- throttle plate hole question
- How should I connect my X pipe to my headers?
- Which wire for Tach signal on 02'?
- ls6 intake........ injector question
- Avg. Install price for Headers and ORY????
- Tach And Shift Light
- shift lights
- Jeckel/Hyde dual personality exhaust system report...
- LS6 INTAKE PICS
- Fried wires :(
- Cutout result!!!
- How can you determine if an F-Body fuel pump is dead?
- Fan Switch Mod
- Open Challenge for a Ported TB Shoot Out
- SLP Cold air intake question
- ASP Pully Install
- Quality ENGINE TORQUE STRAP >> Ramchargers selling one yet?
- Alright guys, need help...Whining Noise after Moser 12 Bolt Install
- What size screw in the TB blade?
- Popping / Banging Near My Feet??
- Trouble shooting Code P0160 ?
- How Loud is Dynomouth
- Battery Cable?
- flp clamps for cats
- Anyone know or heard of any...
- Headers Glowing Orange!!!
- injectors?
- Do I gain anything by dumping AIR and EGR stuff?
- Mod questions
- New exteranal peformance
- Fan Shroud
- does the hooker catback need coating?
- Anybody done BACK TO BACK testing on the stealth lids?
- PRO 5.0's installed!
- Will I notice a differance in sound between Hooker LTs and MACs?
- 2.5" duals out the back?
- Why did my battery die?
- incar wideband O2 ??
- Y-pipe
- Quieter exhaust muffler
- Need info on whisper headers
- Anyone in Virginia have ATAP?
- New Edelbrock longtubes for F body
- LS1 Cold Air Lids
- stat mod
- Good shift light?
- Exhaust clips please.
- LT+LM= NOISE :)
- how to set idle up????
- Upgrading to LS6 PCV system, a few questions
- Cats or orp on mac's how much difference?
- True duals, what all do I need?
- Apologies to all...(PPC Headers) >>
- magnaflow catback
- spark plugs and spark plug wires with head cam swap?
- true dual wavs
- fuel pump time.....
- PCV Ground
- advice on generation 2 "fipk" filter set-up from k&n...
- Having touble starting Hot
- Best power gaining/sounding exhaust system...
- Post pics of yuor Shaner or Bauer TB
- Easy way to lower rev limiter?
- pics of cars and girls
- catback
- Ported Throttle Body
- cam or ls6 manifold which 1st?
- Will cats strike the floorboard with FLP headers?
- I need the belt size with out the power steering>
- Anything else recommended???
- Mac Headers and flowmasters
- H/C guys with an X pipe inside
- O2 sims question? How do they install?
- Sheet Metal Intakes - Who makes'em?
- ticking sound??
- First gen LS1 headers
- flowmasters in true dual setup??
- Magnaflow muffler and droning/resonating sound
- New intake lid on !!
- Performance and Quality only: which calibrated MAF is the best in your opinion?
- Bassani X-Pipes for LS1's
- Correct Belts for ATI Dampner
- Very Disappointed In Hooker LT's!
- WooHoo, Finished Installing the 2001 Intake
- How loud is true dual INSIDE the car? and a couple of clearance questions.
- Who is the original supplier of the Grott,QTPs,and Thunder Racing headers?
- FUEL RAIL COVERS
- Where to buy TR55's?
- polished my drivers side coil rail today
- Should I get a MAFT(translator) or MAF ends to help lean my car out?
- Part number for belt to bypass power steering?
- Mod time
- GMMG installed!
- Cut out location
- ! AC belt..
- Belt # / Length for ASP Pulley to Alt Only...
- Hooker Catback+Hooker LTs+ORP=Drone?
- Questions on installing Walbro intank fuel pump?
- SES light after Duals !!!
- FLP questions???
- what is an average dyno???
- Guys with GMMG? Please Help!
- help, just changed plugs fri , studdering at low/high rpms
- True Duals have a droning Question..
- cutout size
- Jethot vs Hooker headers...
- exuast for the LT1
- My first Check Engine Soon Light, Need help please.
- bassani ory any good?
- LS1 vs LT1
- Who makes the best throttle body mods?
- Mac headers
- asp pulleys
- 2OTL wav files are done!
- mac headers
- LS1 to LS6 Heads - Different Headers?
- John Brown(WILWAXU)GREAT to deal with!!!
- MAF?'s
- Anyone installed a MEZIERE E- Water Pump?
- Car feels much slower after header install
- need some headers
- need some headers
- is the LS6 intake worth it?
- LS6 coolant lines
- 99 TA Convertible in tank fuel pump assembly???
- Need Bullet Part #
- !FRA causes pinging?
- Anyone know how much new coils cost?
- Headers
- FOR SHAMROCK 98TA
- Pulling the motor thru the top???
- Cat-Back+gutted Cats in California
- Dyno Results from ASP Pulley & Cartek TB
- Off-Road Pipes
- Those with hooker LT's and X pipe, got a question for you.
- FLP headers - burning tar-pit smell now
- How much hp gain?
- How much.....
- stealth airbox
- I NEED 26 LB INJECTORS PLEASE HELP
- STILL miss firing!!!!!
- SLP Loud Mouth ?'s
- FLP header dual cutout pictures and dyno numbers...
- Help needed with LT1
- Is LM to loud inside interior?
- Whats up with the B&B TriFlo Catback?
- Motor Mounts
- Stock Exhaust? But it is too quiet!
- Edelbrock catback
- ----How much could I sell 28lb injectors for???????
- LG Motorsports Y pipe
- Walbro 340 OR 342???
- X-mas buying help
- mac mid length headers install and power
- Mileage ?
- Crazy Idling
- whats SUSPENSION mod would you do first ?????
- SES diagnosis
- LS6 Intake and Cam ????'s
- EXhaust which one to get
- Anyone have a write up for the TB bypass mod??
- Just ordered QTP headers. Do I need an MAFT?
- x pipe soundclip... plz
- cat-back install time??
- Got the T/A to the Dyno
- Help. Just got the engine coolant flushed and fuel injection cleaning
- Jet Hot LT install notes.
- What fuel system to support the superstrokers?
- MAF, SLP v. Grantelli
- ZO6 manifolds..
- CUSTOM DUELS THUMP-JUSTIN SUTTON
- 99 Z28 exhaust ?
- What size cut out??
- true duals for a mild bolton car
- Y pipe question?????????????????????
- Deleting the AIR system...have ?.
- Weight question: true duals vs. y-pipe
- 3 Inch or 2 '1/2 inch Dual pipes??
- Capped cutout for the first time
- Hard to explain question?
- Stock Fuel Pump Limit
- just changed plugs for first time
- QTP/Grot Headers Before and After coating pics!!!
- bolt-on car and duals..2.5in or 3in? people who know help me out
- I'm going crazy!! FLPs or QTPs(Grott) ?
