- How to fix SLP LS-6 EGR Modification!!!!!!
- Off road Y-pipe O2 hole question
- Header gasket recommendations?
- Red Baker silicon hose??
- Window Switch hook up
- tech question?????
- Weighed a PA k-member today (mild steel)
- What's the deal w/ SLP exhaust components?
- Exhaust system questions
- Dr.gas
- Remove EGR on 2000 TA?
- Flushing the LS1 Coolant
- $400 dollars for Nology Ignition wires
- B&BTriflow quad tips
- Headers
- FIPK guys inside...
- Short belt tools required?
- Who sells a good off road pipe for grott headers?
- offroad with y-pipe???
- Is this ok?? HELP NEEDED!!!
- Rasp with Mac w/ ORP, Magna flo?
- side exhuast?
- Newbie help on gapping spark plugs.
- Ported throttle body..worth it??
- MAC HEADER QUESTION???
- painting intake manifold
- HP from MAFT....????
- valve covers and coil packs
- Best flowing catalytic convertor for the $$$ ...?
- Rear O2's or simms with new Y-pipe (and cats)?
- anybody else idle funny after pulley install
- paging wizkid
- Paging Psycho Dave......
- How do you cut off the plastic post that holds the MAF electronics in place?
- Pics of the ultimate LS1 exhaust inside...
- Hooker Headers, EGR, Air tubes???
- Catback banging ??
- I would like your opinions please.
- fuel cell vs, gas tank
- People with traction control
- Wanting more low end and throttle response
- EdelbrockRPM series muffler....???
- Hooker LT owners......
- header and cat-back question
- pics comparing stock manifolds
- Anyone ever tried Rapidfire plugs?
- Dynatechs / Hooker Longtubes .... ?
- Is this walker "bullet" the same as dynomax
- straight duals or x / h pipe?
- ls1 computer
- pulley install today . . . have a question
- Gates part# on the short belt mod....
- Headers the age old debate
- Mufflex y-pipe
- What is the fuel pressure for a 2000 LS1?
- Who makes True Duals for our cars?
- any gains with Bassani's [I]yet??[/I]
- Mufflers striaght off LT headers???
- Chip and exhaust?
- Help - scared to death of changing plugs myself
- So what is needed to install the Hooker headers?
- Grot headers?
- true duals
- Headers worth the $$??
- Calling all guys with a Pro-Torque Converter!!
- So if I rent a lift how hard is it to install Headers?
- Short belt clearance issues???
- Size of stock I Pipe?
- Do the heat shield covers(manifolds) need to be removed during a spark plug install?
- Bolt-ons What am I missing??
- Fuel pump replacement question
- Volant????
- SLP CAI Vs. FTRA Vs. FRA
- Ported TB and Epoxied holes, now car won't idle?
- HOW DIFFICULT TO INSTALL GAS TANK???
- Catback hitting upper panhard is their a fix?
- FLP headers rusting and pipes touch the car w/ORP
- help.....Just Got Done Installing my SLP LT's
- Another hesitation problem...
- *PLEASE* SOMEONE TRACK TEST THE FIPK vs. LID vs. LID/FRA vs. LID /FTRA
- Screen or no screen
- Anybody installed the Holley Intake manifold yet?
- SLP LT's
- do I need fuel injectors or more?
- Some LS1 Questions..
- SLP Ram air kit????
- Loudmouth with Cats and Hooker Headers Too Loud???
- Need headers!!!
- Best thermostat??
- B&B quad tip catback for a TA..who's dunnit? how hard how much to cut?
- Am I killing my bottom end?
- Anybody dyno tested 3 bolt flanges on Mac headers?
- bassani or whisper agressor catbacks
- lazy 02 sensor?
- Need new slicks... What to get?
- Can the G2 y-pipe bolt to LT headers(Dynatech)
- What do you think about this setup
- Y-Pipe or muffler?
- Best offroad y-pipe for stock manifolds.....
- True dual exhaust vs. y-pipe exhaust
- installing Hooker LT s
- Hp on WS6 or SS with aftermarket exhaust?
- What length O2 simms do I need for a custom ORP?
- Anyone have pics of Mac headers with 3 inch 3 bolt collectors installed on the car?
- LS1 carburetted
- Anyone know where I can purchase a pulley puller online? (and a few other parts)
- headers and exhaust??
- True duals through X/bullets, too loud?
- Terrible FIPK dyno results on the 422!!!!!
- De-Screening MAF
- fan switch install
- What should be my next mod?
- Do ORP's make all LS1's smell bad?
- Just Done True Dual Setup Pics, Tell me what you think....
- electrical problem
- Where buy Whisper Aggressor exhaust??
- Differences in Gen III truck intakes?
- Fuel pump hum
- Exhaust smell:
- Help with stupid fuel pump
- Bolt-ons w/ cam vs. Bolt-ons w/ Heads and cam...
- Thermostat ???
- threw a code
- Fuel Gauge problem, help if you can please !
- Cutouts: Street Legal?
- Which will make more power? Cats/cutout or ORP/muffler?
- Will dyno FIPK versus Lid/FRA on 422 today
- Mac Headers question
- Who sells Carsound cats?
- Whats the box by the AIR pump?
- just passed inspection
- anybody have pics of dynatechs installed
- making you own Y-Pipe
- Dont want to buy a whole chambered exhaust system?
- New C-5 "304" Stainless Headers >>>>
- Anyone want to FAB any type stainless exhaust > look no further >
- Where does the water go?
- The best header for the money???
- Are you satisfied with the V-clamps used on FLP's? Who has them on their car?
- CORSA Exhaust install completed
- ported maf/throttle power gains
- SLP LT install question
- How to check charging system?
- Who knows someone who has blown thier motor when using nitrous???
- The TRUTH about 1-7/8 grotts LT's on a stock motor..are they TOO big? find out inside
- For those with Taylor Thundervolts: Do they interfere with the radio?
- Borla Adjustable
- ASP Pulley question
- ZO6 or port LS1 HEAds
- Cats or no cats?
- Just finished ASP install-120 degrees is over 250lbs!
- Cut out question
- Flowmaster collector mod on FLP y-pipe?
- Bosch platinum plugs, good or bad experiences?
- Hesitation a 3000rpm
- PRICES FOR SLP LONG TUBES
- Bassani Headers (pics)
- LS1 Aluminum Fuel Rails?
- 01-02 Timing being low.. What about reprograming?
- lifespan of original factory plug wires?
- is installing macs on a 2000 a PITA
- Fuel Rail Mod - Surge Regulator
- Stock LS1 WS6 exhuast tip diameter?
- FLP/Carsound Cats to TTS longtubes and Y-pipe difficult?
- Maybe this belongs in the Forced Induction section?
- Baker Hose pics
- For those that asked, sound clip of X pipe/dual exhaust!!!
- What size hole for check valve mod?
- Gas mileage??
- How much rwhp will 38# injectors support?
- Any good shops in Dallas area ? I'm looking for a cutout
- FLP Off Road Pipes leaking
- dynatech 1-7/8" and loudmouth
- SLP, FTRA or Whisper Ram Air kit questions
- i need some help??
- Catback that will make a difference
- Which catback or is cutout best?
- SOLID gains from MAF sensors?
- gas cap problems
- walbro 340 pump info
- Exhaust
- Dealership is jerking me around with easy fixes
- Do all McCord auto-cutouts leak?
- Would the car be quieter with a mufflex exhaust or a slp dual-dual??
- Can stock EXHAUST manifolds be ported?
- Hooker Y-pipe!!!!!!!!
- Cutting airbox & removing ram air baffle??
- NGK plugs
- Throttle stop mod??
- Intake airflow???? PLEASE HELP
- TB Bypass MOD: PLEASE HELP!!!!!
- Shorty Headers ??
- New improved FTRA Photo and link inside.
- Who has FLP LT headers and cut outs ?
- GMMG chambered exhaust...do U like 'em?
- URGENT: Stock pulley wont go back on what could be the problem?
- NEED FAST HELP... NEED TACH WIRE ON 01 PCM SHIFTLIGHT INSTALL
- Larrys or ASP custom tensioner pullies???
- EGR and AIR removal ?'s
- Question about MAC headers and y-pipe
- 85mm Maf work with K&N New Fipk system?
- Shiftlight Help
- Can Hooker Longtubes be ordered without EGR tubes and other things???
- Why should I pay that much for "Name Brand"?
- Hedman X pipe & true duals are on!! (pic's)
- Fuel Injector Cleaner
- Hooker headers or Mac?
- K&N FIPK and ASP Pulley DYNO Results
- I forgot do I need O2's SIMMS
- TPIS Headers
- maft and 100 octane?
- Grott 1-7/8 LT's ORP and GMMG are in!...one word> LOUD!!!
- Question about using sea foam???
- Difference in TA and SS
- GMAF vs. "NOS" GMAF
- Finally Raced.
- SLP Y-pipe
- Best shorty headers?
- Best headers for my setup?
- Quick...anyone know the Fram Air filter part number for LS1?
- FIPK (my opinion and I want to know who has the best price)
- What is the maximum rwhp for a bolt on A4...
- header questions? NOT an opinion post.
- not pluggin up old nos holes on lid, is that a problem?
- asp pulley
- Stainless Hoses
- Injector/timing/fuel pump expertise please....
- slp lt's leak @ y pipe
- Corvette valve covers..where to buy?
- SLP dual/dual--Cost me power w/ heads/cam??
- Ported LS6 intake
- Please Help Diagnose my problem....
- O2 sensor problems
- difference between stepped and straight headers?
- HELP.......Installing new exhaust!!!!!!
- Help!!!!!!
- WS6 exhaust, different?
- Replace seal with ASP pulley install?
- Need Head Gaskets!!!
- PROBLEM WITH MY HOOKER LONGTUBES????
- Fernco coupler = easy mod!
- size of stock Z28 I-pipe
- My New Fuel Rails
- Anyone have a pic of the new FTRA plate?
- Looking for most power out of my car, check my autotap log inside plz..
- Idle problem???
- Headers
- O2 Sensors
- Under Drive Pulley Installation
- 600HP... heads/cam vs. heads/cam/nitrous question
