PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 [238] 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. QTP header and kooks y
  2. BEST HEADER & Y FOR YOUR $$$
  3. Weird Plugs On Hood?
  4. OIL IN Manifold
  5. Where can i get some O2's?
  6. HELP...RPM's "sticking"...IAC valve???
  7. Looking for an LS1 Motorsport lid
  8. Ignition problem..?
  9. coil pack relocation wires
  10. anyone have any knowledge on this
  11. SES Light (AIR System) any ideas?
  12. No power pump, Which belt??
  13. Good exhaust info....
  14. Put on the new exhaust. Soundclips with open and closed cutouts :)
  15. o2 simulators
  16. Cats or NO Cats???
  17. What bellows for FAST 90 mm?
  18. Exhaust backfires, running rich, poor mileage....come in! (AIR removal)
  19. Is the 3.5 inch mufflex overkill enough to hurt?
  20. spohn solid motor mounts
  21. tb port & polish???
  22. Dancing sparks
  23. pcv
  24. TSP Y Pipe owners in here....
  25. Problems after Hookers/Wires/Plugs
  26. Car cranks...won't start unless jumped
  27. LMI or LMII ???
  28. Longtubes with Lowered Cars
  29. Plug wire dilema
  30. Exhaust question.
  31. FlowPac Opinion
  32. Air pump belt squeak?
  33. Bad misfire or back fire. Check valve?
  34. people who ported there own TB's
  35. Best CLEAR lid?
  36. QTP headers owners inside!
  37. Does anyone have a soundclip of a cutout with gutted cats?
  38. A/C Compressor install help
  39. Bolt on's?
  40. would I lose any RWHP going from Dynomouth to Hooker? is it quieter?
  41. Hooker stainless headers
  42. QTP LT Heads
  43. LTs into purple hornies hedder mufflers?
  44. Kooks Stepped 1-3/4 to 1-7/8 vs QTP 1-3/4 HVM
  45. PCV System ?
  46. Cutout idea like on GMMG cars
  47. How much quieter is the non SS exhaust?
  48. The bolthole for my EGR tube is broken
  49. Newbie QUestion...Exhaust
  50. i need a link to an install page
  51. about to put newplugs in, are they all easy to get to??2000z28??
  52. confusing MAF question
  53. pacesetters and tsp y
  54. can I D.I.Y. ,adapt the 90mm NW t.b. to a LS6 f-body intake ??
  55. exhaust question
  56. Where are the front 02s
  57. Need help ASAP, please!!!
  58. Battery ground
  59. How hard is it to repair broken bolts on stock manifolds?
  60. They installed 2 1/4 cut-out in my I-pipe!!
  61. LS6 Intakes
  62. anyone use this t-stat?
  63. Coil Pack Signal wires????
  64. Air Conditioner dripping H2O in car....WTF?
  65. EVAP System Removal
  66. Pacesetters w/GMMG!
  67. FTRA or SLP cold air induction kit?
  68. 15+ horsepower from a resistor?
  69. headers and emissions
  70. Custom exhaust woes
  71. Which is Louder?
  72. Air Removal Question
  73. ATI bellows?
  74. Y-Pipe Options ??
  75. LT's on a vert
  76. FLP headers
  77. quieting exhaust
  78. removing traction control
  79. TB porting
  80. catted y?
  81. Speed Inc Race Exhaust
  82. Back pressure...
  83. LSONE - clean out mailbox
  84. Choose the best catback ??
  85. emmisions stuff..
  86. Belt For water pump only
  87. anyone running their LS1 without a muffler?
  88. March pulley dyno results yet????
  89. Anyone Running MSC Coil Packs?
  90. replace flowmaster with straight pipe, or just buy QTP cutout
  91. Weekend sale - 10% off all headers/exhausts!
  92. benifit to just taking off catback?
  93. Gmmg Or Magnaflow W/ No Cam
  94. Installing A Ls6 Intake
  95. QTEC install
  96. Best muffler?
  97. Headers
  98. Do you have to get a tune after LTs?
  99. quick question
  100. Belt coming off with ASP Pulley?
  101. open headers on stock engine
  102. Catch can ? and some install pics
  103. Bo White Tb
  104. What is the best and cheapest o2 sensor to run???
  105. Help!Ram Air question
  106. air lid
  107. Borla muffler ? for LTs, OR/Y....
  108. Dr. Gas X w/pipes
  109. lid change..
  110. Where do you guys get your PCV valves?
  111. I Need Ground Clearance!!
  112. gutting out my cats on 2000 z28/what i need to know?
  113. Better flowing muffler?
  114. Loudmouth 2 with LT headers and no cats?
  115. no cats no o2's no egr.
  116. O2 sensors help asap.
  117. Intake install, where does this connect?
  118. starting car without lid?
  119. Weiand intake and fuel evap line
  120. Anyone have an SLP Loudmouth?
  121. 3" Duals under axle 1 Chambers Pics/Vids Inside
  122. where can I find header install DYI??
  123. TB Gear Grease for Vette
  124. What is the size for stock TB?
  125. Left fan switch on.Bad for fan motor?
  126. Whats that noise?!
  127. Poly motor mount impressions
  128. MTI lid install
  129. Squeaky belt
  130. FAST Fuel Rail Connections
  131. Exhaust cut out questions
  132. Question about Labor $$$
  133. how to unstick a stuck O2 sensor?????
  134. TSP Lid
  135. Mass Air Meter?
  136. newbee q's for some mods
  137. Any advice for LS6 Intake? Do I need to tune?
  138. header gaskets???
  139. Mandrel versus pressure bending
  140. ngk tr55
  141. anyone with edelbrock lt's
  142. Open headers??
  143. Is this the right X pipe??
  144. The JetHot & TSP Y-pipe setup
  145. 98-->99+ Valve Cover Question
  146. Power steering leak
  147. Anybody have pictures of a Hooker cat back installed?
  148. too good to be true?
  149. SLP Center Exhaust
  150. couldn't install thermostat :( HELP
  151. please help 2 with pix
  152. slp ls6 intakes is there any difference
  153. question on the loudness of my setup...
  154. What is the diameter of the opening on the aftermaket lids?
  155. Flowtech
  156. FAST 90 Lsx Intake Help, Whistle?
  157. High Flow Bellows
  158. Ported TB
  159. Who has the best Y-pipe?
  160. Hooker with dumps
  161. where are common lsx leaks at.....trying to find where a buddies intake is leaking
  162. Question on FLP's LT's and Y pipe
  163. QTP y pipe
  164. how do you change cam/crank position sensors?
  165. Clever way to keep Lid tight?
  166. Ory?
  167. Edelbrock victor Y to GMMG I no worky
  168. anyone know a website where i can buy exhaust tubing??
  169. Protecting True Duals: POR15 or High Temp Paint?
  170. Jet-hot LT w/ wat y-pipe???
  171. Possible budget exhaust...
  172. Cat question
  173. #4 misfire post header install. please help.
  174. FAST LSX intake with stock cubes?
  175. Power Steering leak blows, Alternator, ECT Sensor, and eats away wires for B1S1 O2
  176. Dual Cut-outs
  177. air tube removal?
  178. TPIS oval port TB and Manifold
  179. TSP rumbler catbacks
  180. Exhuast Setup
  181. any of u guys run the painted on headers?
  182. Who sells the K&N conical air filter with the IAT hole in it?
  183. Loudmouth sounds like crap
  184. New ram air
  185. QTP Headers are installed! Have some questions...
  186. 160* Thermostat, worth it? Still confused..
  187. help: problems installing ls6 intake
  188. Which Spark Plugs should I buy?
  189. Vaccum routing
  190. Magnaflow or Hooker ? ...
  191. New Sweet Thunder Setup
  192. Ahhhh... o2 sensor seized... ideas?
  193. QTP LT's and Kooks y pipe
  194. tensioner pulley
  195. Ory
  196. power steering pump
  197. Percy's Header Gaskets . .. About to install
  198. PCV tubing question?
  199. True duals
  200. why isnt my car staying on?
  201. NEED HELP...pls!
  202. Quick Air Flow question...
  203. What would you choose???
  204. ??Where to buy 45° bend for driver's side header??
  205. How often do you change air filter?
  206. Different muffler on catback
  207. Rattling Exhaust!??!
  208. Tuning????
  209. ws-6's & damn rainshields.... lol
  210. write up on replacing motor mounts?
  211. 98 camaro can i use 2000 maf
  212. where to get misc rubber lines on motor
  213. questions regarding TSP true dual set up
  214. Parts for Installing True Duals and Headers
  215. Need HELP ASAP!!! Window Motor doesn't work after new install!!
  216. my slp lid rubs the hood, is this common?
  217. i think i messed up the free ram air mod.. someone please host this pic
  218. Please Help!!!
  219. TSP TDs
  220. How do you take out the oil check tube
  221. Question about Ported TBs
  222. Header install HELP
  223. Glass pack question
  224. Do shorter dynomax bullets rasp more than longer ones
  225. problems with my horns.
  226. Mufflex Hanger install
  227. True duals with Hooker mufflers?
  228. Which Dynomax muffler is quieter ? The UltraFlo or the SuperTurbo series ?
  229. Heres what i got. what should be next?
  230. new member of the " I broke my oil pressure sensor club on ls6 install"
  231. Finally fixed my exhaust rattle!
  232. ASP Pulley
  233. A few exhaust system questions
  234. Which airlid has the shortest neck? (Vortech mod. ?)
  235. ??what intake to get ls6 or f.a.s.t. ? please help
  236. Intake question.
  237. Need More Help..
  238. need help ASAP...PLS..
  239. Man, Mustangs with the 4V engine and duals sound AWESOME!
  240. power differences between catback and true dual set ups
  241. Is the corsa muffler chambered like the New EDelbrock muffler?
  242. Help w/new air box lid
  243. !EGR !AIR Writeup?
  244. What brand of y-pipe with corsa?
  245. Trans fluid dipstick
  246. Mini Alternator
  247. Free Mods: Worth it?
  248. Cutout or Bullet
  249. those with qtp headers....
  250. Questions before header install
