View Full Version : Generation III External Engine
- which sounds better
- PS pump issue
- is this normal (pic inside)
- need help pinpointing sound from front of engine
- How much HP did u pick up from cutout?
- help with Y pipe beating the **** out of my car
- camaro ss ram air box on a transam?
- quick slp lid question...
- Wix air filter vs Fram vs dirty K&N flow results inside
- Which Loudmouth is which?
- Is this MM package a good deal?
- 1 7/8 headers?
- which heads?
- accessory set up
- Is there a big gain from LS6 intake to FAST92 on a H/C 346?
- new single 4" setup dumped
- slp maf
- will i need to flycut?????
- GREAT DEAL on revXtreme catch can going on now!
- Tune or not?
- replacment mufflers?
- Victor Jr or Super Victor in a F-body? Post up some pics installed
- exhaust.. will this work?
- ls6
- CME test fit
- !air/!egr
- TSP Rumbler catback
- band clamps
- kooks quad core race mufflers?
- Plug wire shorted out
- C5 guys vararam vs ????
- what would cause this?
- Anyone running a carb and a 6ls box
- What's all needed for LS6 intake swap? Ya, I searched
- FAST Valley Cover Bolts?
- Why doesn't the 2001+ LS1 have a 6500 rpm redline too?
- ported ls6 to fast 92??
- hooker super comp Longtubes headers
- 2OTL Exhaust Different Design Question
- changing throttle bodys
- Muffler removal
- HOOKER Headers
- dual exhaust pics
- Headers/Spark Plug Question
- magnaflow anyone?
- Exhaust options, gmmg? magnaflow?
- Truck oil pressure sending unit?
- O2 Simulator help!
- Red fluids....?
- thread in injector bungs?
- GMMG's in, fitment problem
- Help with Kooks install
- trying to build a stealth exhaust...help plz
- finally
- Need the thread size of an oil sender
- coolant sensor placement?
- Do intake gaskets swell?
- People selling FAST intakes?
- Removed air/egr... use mini breather or seal up?
- Upgrading intake, suggestions?
- wanting 11:1 wit 243 on stock ls1
- Fast 90/90 Vs. Victor Jr setup - Need opinions!
- Pacesetter Headers = Poor Quality & Warranty
- O2 sensors?
- cut out issue
- Qtp electric cutout issue
- anyone know if c6 z06 manifolds will fit gen4 f body?
- Shorter o2 sensors?
- Serpatine System?
- Which way do stock intake gaskets face??
- Front cover install procedure?
- Long tubes for 2002 SS
- victor jr/ super victor fuel rail question
- quick cutout question
- MSD Digital ignition? any real gains or is stock ignition good enough???
- Gto Help
- *VIDEO* Camaro catback swap, before and after with Magnaflow then SLP dual/dual
- Determining ls6 block year for head studs
- Need Help with gauge install
- Oil Pressure Sensor
- Stock or underdrive?
- Wrap results??
- catted Y pipe for 02 SS
- Alternator exciter wire off PCM
- ls1 oil pan BOLTS part number
- Throttle Body Question!!!!
- Throttle Cable Bracket
- Another LT cat back question
- My IAC is F****D
- Fernco, home depot, lowes, etc, smooth bellow's. Pro's and Con's?
- Drilling the throttle body nessecary?
- Header & exhaust
- Which long tubes header have most clearance?
- Solid mounts need poly trans mount?
- Need pictures of front bumper support on 98-02 camaro
- Exhaust Leak
- loudmouth
- Home made GMMG cat back?
- Opinions please...
- Who Has ported Stock 00-02' Exhaust Manifolds?
- which lid??
- 6.0 problem.... Need help in paducah ky
- Different kind of Ram-Air
- What sensor is this?
- SLP "NEW" design headers
- valve cover spacers
- hoses on valve covers?
- SS Airlid needed
- which densos?
- 160 deg Therostat doesnt fit in stock housing?
- 6.0 Oil filter Bypass
- need some part numbers please
- SLP MAF Question
- Magnaflow or Loudmouth 1 or 2
- help me decide on exhaust
- Exhaust cutout turn down
- Car won't start up after rebuild. What to do?
- FAST Intake and Coolant Rail Question
- Anybody have picture/diagram of '98 PCV setup?
- Slp underdrive pulley
- 1998 f-body LS1, Rebuild, need some assistance.
- Anyone have a ls1 on the stand with the pan off?
- Make your own oil cap breather ~$20 *Guide*
- All F-Body TBs interchangeable?
- throttle body ?
- power steering pulley
- Stock Cat flow-through pipe
- TD people with lowered cars - would you do it again?
- Is part #19212593 in fact an H3 pan?
- LSX Block
- Easiest LT Headers to Install
- anyone gutted stock cats?? what are they made of??
- switching headers question
- Trying to find plug for factory pcv location in valve cover?
- Dual Dual removal
- Looking for A good ypipe for stock manifolds.
- Need help on AIR removal on an 01 pics inside?
- '99 vs. '02 headers?
- Mufflex -VS- GMMG...
- which header stays cooler stainless or Jet Hot?
- The flat spot.
- Removing engine dipstick
- sheet metal intake questions
- crap! another magnaflow fitment issue
- oil pan removal
- are my mac headers a bottle neck?
- Anyone coating MLS header gaskets?
- Free Ram Air Mod pics
- high idle and surging at low rpm need help
- Ok im stuck and confused need help please
- Catback
- CC Performance Relocation Kit
- Bellow
- pacesetter header info
- Spark Plugs Suggestions
- Problems with TCS mod
- mass air, bellow size question
- Oil cap in place of oil filler tube
- Replacing Rear Main Seal
- what is killing my battery??
- Intake Question??
- Catch Can
- Qtp electric cutout borla?
- Not a regular UD Pulley question
- Catch Can Problem
- tight ls1 fit
- Header Bolts
- ls376/480 pcv
- LS1 Injectors
- heads
- Oil Leak Mystery..
- Does anyone make a 4150 style nylon intake?
- Maf flow question
- pacesetter rattle
- Clicking Sound
- long tube header question
- Whats the difference between 07 and 09 Long tubes on a C6?
- Compare KOOKS 1 3/4" to TSP 1 7/8 Headers For Me
- TB For 92mm FAST Intake?
- Difference of Y-Pipes
- heads for boost
- Stock exhaust on '01 Camaro SS?
- Engine Pedestal Question
- Over or Under axle
- Pacsetters+ory+borla or lpp headers+tds
- Looking for soundclips (Y-Pipe to a bullet w/dump)
- Car bogs after 2500rpm till redline, poor performance
- 2000 Camaro z28 install trouble with SLP Ypipe
- engine covers and cam plate
- Install? To use copper or not on exhaust gasket?
- What Head is this?
- 2 questions
- Modified serpentine belt configurations, please comment
- clean MAF
- Catch Can Obnoxiously Loud at Idle
- -20 an Thermostat Housing??
- Will I pick up Gas Mileage with A K&N Filter?
- Updated!! FAST intake fits like SH!T...whats everyone do to fix this???
- exhaust quieter after cold air install?
- oil pressure sensor
- battery replaced, but volt gauge still in red zone??
- What a great Surprise!!
- Loudmouth muffer clip?
- dump or run them out the back
- quick misifire question!!
- 100MM MAF--overkill?
- Valve breathers that plug onto your oil fill location yes/no?
- Need belt part # for UD 25% pulley, no AC, no PS please
- HELP LS6 manifold install no oil presure on gauge
- True dual performance gain?
- 2.5" X-pipe system to GMMG Catback install done (pictures). New videos
- ticking after TD install
- 98 TA Idle/Rev
- alternator charging issues, any advice would be great.
- Thermostatic Oil Cooler Adapter
- Battery or alternator? Gauges going crazy
- F.A.S.T. 102mm LSXR intakes for cathedral port now available
- where can i get my tb ported?
- How are you guys getting your harmonic balancers off?
- Part # or Dimensions for FAST 90/92 Valley Cover Bolts
- Mac Mids.......
- cammed bassani guys in here........lookin for clips and opinions
- Full Bolt Kit For LS1 Accessories (ARP Or Other?)
- Next.... Installed kooks 1 7/8
- Easy to change O2 Sensors?
- BBK SSI Button Head
- anyone with pace setter ory
- 2010 Vs 2000 camaro serpentine belt question
- Going back together... Ran into a wiring problem... HELP!!!
- cat back exhuast
- 5.7 or 6.0 AC compressor bracket ??
- LS6 Intake vs BBK
- HO alternators....150amp compared to 200amp
- LS1 coils same as LS2?
- underdrive pullies??
- Fast 90/92 Intake?
- LS1 removal
- Anyone have Slp's cold air induction kit?
- what is the most restrictive/quiet exhaust I can get? Stock Z28? Stock V6?
- Headers touching OEM spark plug boots
- Is anyone using this cutout?
- Typhoon Intake?
- is the pulley on all the way?
- ls6 intake ?
- What would TD's be worth power-wise over my cat back w/cutout?
- Need some idea's for exhaust....
- Spark Plug gap question
- Power steering pump issue
- air 2 fuel ratio
