PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 [147] 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Jegs underdrive pulley
  2. throttle body bypass
  3. headers?
  4. where to buy ARH
  5. SLP Headers. Are they reallly that bad?
  6. Will this cam lope through cats/magnaflow?
  7. Whats wrong with my car?!?!
  8. 98 Tcs??
  9. Shaner S3 Tb!
  10. what ever happend to FLP headers????
  11. PCV valve
  12. Electric water pump install question
  13. Kooks header question
  14. Will a 99 5.3L starter work on a 2001 z28????
  15. Magnaflow Quad Tip Exhaust Pricing
  16. 1 quick ? about pacesetter bolt holes
  17. Throttle Body Bypass Mod..
  18. header question
  19. Alternative To Magnaflow Tips?
  20. Which fitting to use when recharging AC?
  21. GMPP LS1 Carb style Intake Taller than Vic JR??
  22. MSD blaster coils
  23. Port and polish throttle body?
  24. Anyone Know How To Install A Monster Tach Without Using The White Wire From The Pcm??
  25. XS Y question
  26. Custom Y pipe
  27. Underdrive install ?
  28. Crazy looking Headers
  29. Stainless mufflers for TD's
  30. will the flp headers work with tsp true duals??
  31. egr removal
  32. Installing a set of Macs in a car right now...
  33. please help
  34. '00 SS Cold Air Intake ?s
  35. Throttle Body Spacers?
  36. Pick my Headers
  37. Where to get the cats only for the JET-HOT y ?
  38. Y pipe merge collectors
  39. Exhaust shoot-out!
  40. ORY into a Borla XR-1???
  41. need extensions for my o2 sensors
  42. What do you consider the best intake/TB for the money
  43. Which way to go? Little help please...
  44. upgrading tb ?
  45. TURBO or Stoker/crate motor?
  46. 98 PCM Wiring guide???
  47. Exhaust
  48. Fast 90 to much??
  49. who has the best deal on...
  50. slp air lid fitmet
  51. true dual question
  52. ASP pulley bolt size/thread pitch
  53. spark plug defouler?
  54. stock manifolds or pacesetter lt's?
  55. o2 extensions
  56. So, just did the Home Depot "Husky Red" catch can mod, along with a new pcv valve
  57. Any ideads for the next step.
  58. Exhaust TO LOUD/ Getting Pulled Over?
  59. 02 sensors!
  60. Headers coated or uncoated
  61. Installed electric cut-out and now..........
  62. MAC ORY Question!
  63. Exhaust difference
  64. SLP cold air intake
  65. Ls6 intake install how hard?
  66. air removal
  67. Anybody Run Magnaflow Race Series Muffler?
  68. misc parts list???
  69. Need Help Loud Noise!!!
  70. Are they worth it?
  71. Am I hurting performance with my 2.5" duals?
  72. New Corsa cat back is on!
  73. Quick Ques. about block-off plates
  74. What Headers Will Be Best For My Car?
  75. Starter trouble - help!
  76. catch can issue
  77. Lid sealing against hood
  78. What should be my next mod: headers, intake, gears, ???
  79. Spark plugs
  80. Manual or Electric?
  81. xs stainless y pipe & O2 extension wires ?
  82. 806 heads, any good?
  83. Just installed a cut out.....
  84. Underdrive Pulley + or - ????
  85. Backfiring after headers install?
  86. Is this a good deal on slp dual/dual?
  87. O2 sensors
  88. Opinion on best place to buy
  89. is the slp undrive pulley good
  90. FAST intake/ extra electrical connections
  91. Final O2 Sensor Code verdict? Delete and Forget about it?
  92. Need HElP asap
  93. CME or Dumps?
  94. ORY that won't hit the floorboard with XS LT's?
  95. pacesetter y pipe hitting floor
  96. spark plug wire touching header.HELP
  97. front mount distributor and carb
  98. Electric Cutout Problems?
  99. PCV Delete on 02 car
  100. ENGINE SMOKING PLEASE HELP QUICK!! (possibly AIR system delete problem)
  101. LS6/LS1 & Fast 90 Material Composition??
  102. Engine Reving high
  103. qtp Y
  104. Best exhuast Connectors
  105. Exhaust Question???
  106. Intake, cam, heads? researching...
  107. Looks like I am going to need a vacuum pump, any suggestions/leads?
  108. what yr did f-bodies go to a single cat?
  109. removing I-pipe
  110. Missing a Borla Quad tip
  111. changing ngk tr55 plugs at 3 years/10,000 miles?
  112. ARP Thread Sealer?
  113. Dynatech Supermaxx Hdr System?
  114. Car won't start, SECURITY lights stays on with key on
  115. anyone have dynomax x pipe and dynomax bullets???
  116. UPDATED W/ PICS: Install and Review of Pacesetter ORY
  117. Engine Mount Q.
  118. ls1 427 carb
  119. FAST intake guys....got one question
  120. Teaser
  121. TYPHOON LS1 intake versus other aftermarket manifolds
  122. Anyone running Dr. Gas Boom Tubes?
  123. Worth buying 1 7/8? Already have jet hots 1 3/4
  124. First Time Throttle Body
  125. plugs/wires install help needed
  126. 1 3/4 x 3 or 1 7/8 x 3
  127. ignition question
  128. What's the PN for the coolant crossover bolts?
  129. pacesetter headers and SLP Loudmouth?
  130. single dumped bullet
  131. Kooks Headers???
  132. Cop trouble with TD's?
  133. Just finished poly motor mounts! PITA!
  134. Flowtech long-tube header question?
  135. Tired of Being Slow...FINALLY All Systems Go!
  136. Headers ???
  137. Throttle Body Bypass Temp Test.....
  138. anyone have pics of a carb on an ls1 f-body?
  139. Electric Cutout Question
  140. Lingenfelter oil cooler manifold????
  141. no power steering pulley, need a belt
  142. loudest, cackliest muffler?
  143. fast intake
  144. Big problem after header install. Need Help!
  145. mac mids y pipe
  146. cam swap help!!
  147. LS6 Polished Intake Manafold
  148. 1 7/8" headers on a stock car?
  149. cut out loss of power
  150. Which Ebay SS LongTubes should I go with
  151. My car is running like sh*t!
  152. LS1 aftermarket EGR intake plug
  153. Smooth Bellow
  154. Dr. Gas True Duals...?
  155. Cat-Deletes
  156. TD's or CAT-BACK?
  157. Removed A/c Reporting Weight
  158. Fitting question
  159. MTI clear lid clearance issue install **PICS**
  160. PN for the stock Lid sticker?
  161. What's the cheapest why to reach 400+rwhp for 98' ls1 without nitrous?
  162. gmmg questions
  163. true duals?
  164. QTP ORY-Pipe vs. Spohn chassis mount TA
  165. Need Help with 90mm Throttle Body solution for a 6.0L Escalade
  166. Low exhaust (Poor install?)
  167. New Pacesetter ORY Install and Review
  168. headers and x pipe
  169. Anyone have sounclips of these TD setups?
  170. WTF is this part? It's broke, and I need it to finish the car, help!
  171. Motor Mount Install
  172. Neep some advice on how to run my exhaust cutout?
  173. intake install gone bad....
  174. How loud will it be?
  175. 5.3 intake question
  176. Off road Y-Pipe
  177. Professional Products Intake LSX
  178. Help I broke garder spring and GM told me to get F*****
  179. NGK Tr55 or 6s?
  180. ls2 intake on an ls1?
  181. True Duals on convertible Q.
  182. Just put on my new ls6 intake :(
  183. Car has trouble finding idle???
  184. TSP Duals mounting question
  185. Spark Plugs
  186. my true duals video
  187. Has Anyone Tried This?
  188. Need Help Fast Please!!!!!!!
  189. Cat Delete Pipe
  190. what headers with 408 and YSI?
  191. y-pipe suggestion
  192. How to make my exhaust LOUDER?
  193. Mass air flow ends question.
  194. video WITH SOUND of my dual exhaust-no mufflers
  195. holly air filter
  196. Just bought a clear MTI lid, problem?
  197. Ebay cats??????
  198. One Cat in the I Pipe?
  199. Whisper Lid problems
  200. Difference in valve covers?
  201. oil leak after slp pully install
  202. pacesetter header bolts
  203. Have a bad Ball Joint and tie rod bushings, where do I find the OEM part number?
  204. Bellow/coupler for stock MAF to 90mm TB???
  205. How do i stop this.....
  206. Fuel line to close to cat??! advice needed
  207. What crankshaft pulley is this?
  208. LS1Tech LT HEaders
  209. Loudmouth 2 w/ Headers?
  210. Looking for new tips
  211. cam and stock Manifolds..i know i know
  212. california legal cats?
  213. what do i need?
  214. Need feedback about RAPID MOTORSPORTS ability to build good 346 forged LS6 motor!
  215. 500 Rwhp Possible?
  216. Flowmaster????
  217. Electric water pump
  218. LS6 intake
  219. Factory TB...
  220. Jet-hot Y
  221. TSP Y-Pipe Problems
  222. doin a ls6 intake, have a few questions
  223. Trying to find a catted y
  224. Dog chewed my wiring harness
  225. Eng runs BAD, shakes and no power!! HELP!
  226. Is there a way to test coils?
  227. spark plug wire ohms question
  228. lg headers
  229. Free Mods
  230. biggset cam with..........
  231. ARE pumps(Armstrong race engineering)
  232. Fast Toys Ram Air?
  233. ORY Questions?
  234. Magnaflow vs. Magnaflow Quadtip
  235. Can you use stock bellows for 90mm throttle body?
  236. What gap to use on NGK tr55s?
  237. Which TB and Intake?
  238. Will my car pass the sniffer test?
  239. tunning/vaccum question...
  240. got my car runing now runs wierd with new tb
  241. Additive claims 100% hydrocarbon burn, Legit?
  242. AIR removal help needed
  243. Will any of these bellows work?
  244. Motor mounts
  245. DIRTY throttle body?? Oil?
  246. Interest in "BGRA" type mod
  247. True Dual Help
  248. Just intalled ported and polished TB HELP!
  249. Identifying Heads LSX
  250. MTI or Ported ls6 throttle body?
