View Full Version : Generation III External Engine
- New Kooks Ultra 2000+ Degree Carbon Gaskets
- Question about CUTOUTS
- any th400 guys with an x pipe?
- Ported throttle body
- MAF free horsepower?
- Corvette Rear 02 Sensors??
- Confused about o2 sensors
- QTP cutouts..............
- Replacing valve cover gaskets
- Big cam on 115 lsa with lope through TD's *Video*
- corvette heated O2 sensors
- Exhaust
- qtp y pipe
- TPS voltage??
- Please give me info on true duals ????
- My Custom True Duals OTA (pics inside)
- Where to find Throttle bracket?
- True Duals and the fuzz...
- Putting A Muzzle On The Loudmouth
- pacesetter LT's, catted y, cutout, hooker CB soundclip
- Poll: should i take my cats off?
- year 2000 long tube header
- will an 00 throttle body fit on an 02?
- Hooker LT Bolt Torque specs
- Throttle Body
- Which O2 Sensor
- 5 hours with open headers
- Fast 90mm bolt torque specs
- TSP y-pipe will not fit with Spohn Torque arm
- Need Some Quick Help With Intake Manifold
- The quest for M1 5W40....
- Airflow?
- Will a4in mufflex fit a lowered car??
- slp loudmouthII exaust????
- QTP's tuck?
- Header to y pipe Exhaust leak, clamp question
- Where to find K&N breather element?
- having trouble getting flowmaster x-pipe to fit
- MSD ignition coils malfunction. part#8245
- Ceramic Coated Edelbrock Headers
- Is this balancer on all the way?
- PICS of TD mounting
- Ported TB making gas pedal stick?
- coolant plug and pipes?
- good sleeper idea?
- Open Headers VS TSP duals
- Y-pipe doesnt fit...
- Need help with belt slippage and ASP
- LT's > Bullet Mufflers > Turndowns?
- GMMG Just installed
- Motor mounts or TR Ypipe hanger?
- electrical problem at WOT
- Need Your Input/Help Valvecovers *PIC'S*
- need quick help on buying motor mounts
- Egr
- TB is this the same
- Anybody wishing to by pass their heater(pic)
- Help me decide what to do for exhaust ?
- Need some help here.
- where can i get a shayner tb?
- For those that have remover your air injection system ?
- Best Place To Buy Borla XR-1?
- no cats
- New Gasket for Cutout?
- What size/kind of LT's, and exhaust system for this type of engine
- Pacesetter question
- need advice before i purchase 80mm tb,85mm mass and 85mm lid
- oil change light?
- TSP True Duals
- intake manifold to TB to MAF to Intake
- ls1 poly motor mounts
- Just took off stock muffler, open Y, wow!
- correct gap of autolite 104's? for n/a
- cant find air filter setup
- BG Ram Air???
- Open header question
- Help!!! Car won't idle after manifold swap...
- Mufflex W/spintech Dual Outlet
- why did all those ZL1 cars come with aluminum intakes?
- Guage Help Fast!!!!
- cutout before cats
- Anyone else seen this before???
- help, need 02 sensors, autozone wanting 150$ + tax.. that high?
- cutout help
- what to do next
- DIY cooling fan switch
- True Duals To Clear Trak Pak
- Ceramic or Metal Matrix Cats
- Anyone fab coil pack brackets
- Velocity Stack Vs Ported
- How can I get my Pacesetter to not RATTLE!?
- Anybody know anything about the sweet thunder tips/mufflers?
- OK to run a catch can like this?
- what the best set up here??
- Finnaly a DEAL
- TSP TD Questions
- Dual turndowns to out the back
- hooker or corsa
- Nick Williams T/B black anodized
- Royal purple almost 9HP gain on LS1
- LSX90 VS electric h20pump?More gain?
- Exhaust flow rate???
- True Duals And Tired Of Searching?
- Bassani true duals
- goods headers
- motor oil
- where can i find..........
- FIPK help<^>
- corsa exhaust oppinion
- Question for true dual owners.
- 2.5 VS 3 inch power gain/loss
- breaking the sound barrier!! legally though
- throttle body "Q"
- IMCO single chamber muffler
- car sucking air?!
- meanest loudest exhuast???
- looking for help picking a catback
- Same coupler for LG90TB?
- best intake/throttle body setup?
- Belt Size for ATI Ballancer
- Exhaust Help
- Who sell's stock TB blades?
- will i loose any power going from gmmg to hooker?
- Air/Fuel Ratio Guage Question
- weiand intake
- New IAC
- how do you get the Power steering pulley off the PS pump??
- difference between 98-02 throttle body?
- my car is possessed
- Need custom induction sizing help
- Guages???
- Weiand intake ?
- what do need to put on a corvette 85mm maf?
- Pics of installed Summit X pipe.
- opinions on a legal exhaust setup
- centermount exhaust tips
- Did 98's have different Valve covers?
- Ported TB or Aftermarket
- Will removal of egr increase oil consumption
- CAT Delete Pipe Dimensions SLP Headers/Y-Pipe
- Need Help! Running RICH
- Underdrive pulley users
- true dual kit?
- no tach/not speedo????
- What are all my options for valve covers on top of ET Heads?
- O2 Sims installed, SES light still on?...
- TB Sensor
- ramps to install headers?
- edelbrock rpm intake part #??
- HElp with TB!!
- 01-02 corvette ls6 intake question
- QTP HVMC Headers
- FLP Longtube header V-clamps
- free ram air mod worth it?
- What size O2 extentions with QTP headers?
- Transmission cooler install- Pictures
- Hypertech 160 Stat in 2002 Camaro, IF you have one come in??
- what do you think about heat wrap on headers?
- no gain from headers
- lots of exhaust questions
- flows with LT's and ory
- header install gas mileage tips
- Two Step == Flam Thowers??????
- Look at my headers, tell me if they are mids or shorties!
- ported throttle body/maf gains
- Symptoms of a bad PCV valve...
- Help me stop my droning!!!!
- Is GMMG really worth it?
- Hooker too quiet? On a relatively big cammed 408? I'm doubting that...
- Electric cutouts
- would this exhaust fit?
- New Duals!
- bnb triflo vs. corsa
- air lid options (ram air)
- Header Install..Dyno Results!
- What do you do with oil in catch can?
- my exhaust is way louder with ac on why?
- PICS...of my tensioner pulley after it decided to leave my engine
- b b triflo
- Electric water pump belt routing question
- Oil catch can, anyone use them
- hooker/magnaflow cannot decide
- Stock intake and TB-> 90 mm
- AIR tube bolt problems
- March U-drive pulley belt size
- Took off the cats and added ORY pipe = Pimp
- Help Already rejected --need information on cats that i should buy
- The Tornado
- Header install question
- selecting Kooks headers
- good or bad?
- dirty MAF = running to lean?
- BorlaMouth & DynoMouth Back Pressure
- need true dual pics
- FAST questions
- Forum Director - Marker
- Adding bullet muffler to my slp loud mouth
- Headers install questions
- MAF restriction on 90mm TB
- OEM Replacement ORY
- Exhaust banging
- header installation
- headers
- Magnamouth
- Ported Throttle Body Question
- what kind of exhaust is on factory 02 ws6?
- Powerstick Cutout?
- Bank 1??
- New Lid or K&N FIPK???
- LS6 intake vs. FAST LSX
- what mufflers with TD's???
- '98/'99 Lid For '00 T/A
- What Torque Arm with TSP True Duals
- Anyone know a thing or two about compressible fluid dynamics?
- Crank Pully Questions.
- ORY pipe
- How will this sound
- A question about an ORY pipe
- Intake ideas??
- Free Ram air mod? does it work?
- 1 3/4" Kooks headers with cats, kooks y-pipe installed
- open headers
- o2 simms throwin ses light
- Help with TB
- Dynomax bullets vs. Sweet thunders for TD's
- exhaust cutout question
- Y pipe/headers info
- 02 sensors
- need a part number pleaseeeeeee...
- Loud whistle/ 90mm fast
- loudmouth, lt, tsp catted y, ms3 sound???
- anyway to fix y?
- how can i be emissions legal with an ORY and no cats
- what is this part?
- Battery Tie Down
- TD's out the back...PICS!
- TSP y pipe ?
- Exempt sticker
- PCV part number
- Are LS1 & LT1 IAC's the same?
- Sick of the Loudmouth...going LT
- Kooks and QTP dillemna....
- Which High output ignition is prefered?
- Alternator Overdrive pulley Questions..
- where do you put the oil temp sensor?
- horsepower loss swap loudmouth 2 hooker
- weird noise coming from my camaro.....
- Standard motormount bolts and transmission mount bolts, and OBDII scanner
- plugs
