View Full Version : Generation III External Engine
- header install question
- X-pipe exhaust ????
- god damn cylinder #8
- 8.5 Mm Msd Wires
- About to flush radiator, few questions.
- Problem after LT install??????????
- question about Air Fuel
- Getting ready to do new exhaust
- Sweet Thunder/X-Pipe Part#
- MTI headers and catted y
- exhaust on collectors ta need help
- MTI Billet TB Pics/More Kook's Ckearance Pics Too
- Everyone with Borla....
- Heater Hose OK for TB Bypass?
- How long does Pacesetter ceramic coating last? Ceramic coated headers in general?
- New radiator?
- One Muffler In Place of the Cats
- Free Ram Air + Scoop = ?
- how does this exhaust set up sound?
- Air/Fuel after headers????***
- What is the diameter of the press fit center of the Power Steering pulley?
- Y-Pipe w/CATS & cut-outs?
- got a question on SLP dual/dual to SS exhaust
- crappy idle after race gas
- Need help..............Dealership is acting shady
- LS2 TB Help
- need help with o2 sensors
- Flowmaster delta force one chamber mufflers
- Would this combo work?
- Sheet Metal Valve covers??
- Which magnaflow muffler?
- MAF Sensor? Fuse?
- Gonna start longtube install this weekend
- installed WHISPER LID and no SOTP
- I know you cant really tell but does this look like an ls6 intake?
- Another ASP pulley?
- water leak
- Help
- QTP headers and y
- crooked magnaflow muffler
- just got my headers in
- kooks headers
- What Tstat to get???
- looking for a good write-up
- Did a search, no help need gates part #
- How to fix faulty cat?
- Finished LT's, FAST 90, NW TB on stock heads/cam
- underdrive pulley question??
- BEST INTAKE FOR YOUR BUCK for ls1
- what does the catback really do????
- Mufflex 4", GMMG, Corsa, Or True Duals
- !air!
- Not the Tstat!!
- Fast 90/90 over an LS6/ported stock TB worthwhile?
- Headers...
- 160 degree Thermostat
- 02 sensor
- Fuel Pressure
- where can you get just the blade for a throttle body
- T-stat ?'s
- New cats/headers and clearance
- Spark Plugs
- HOOKER HEADERS LTs
- Magnaflow HP Gains
- longtubes and exhaust installed, now problems
- Boltons Finished this Morning - MTI Billet TB and LS6 Intake
- Question On Kooks Headers Install?!?!
- Can I remove my TCS?
- Catalytic converters Dynomax clones??
- SLP LT clearance pics inside
- replacement muffler or cat back?
- Header clearance with SLP sfc's....
- HELP! Putting motor mount bolt trough....
- Anyone done exhaust like this?
- Thermostat???
- cheap offroad y pipe
- Advice on air filter
- Longtube/Stcok header swap...
- Is it just me?
- Broken Starter Mount
- Pacesetter quality...
- !AIR question
- Slp?
- FIPK and Air Temp Sensor
- Exhaust Help!!!
- GMMG w/ what headers?
- FAST 90 Manifold and NW TB ?
- filter for SLP lid
- FAST 90MM intake and Nick Williams TB ?
- Lid or FTRA???
- bosh o2's vs GM's
- Thermostat??
- change magnaflow or kooks
- torque specs
- NEED HELP...pls!
- Does anyone believe in emission control?
- torque or limiting strap?
- Battery Relocation - Aluminum #00?
- throttle body spacer???
- LS6 intake identification
- a lid is a lid. .
- TB half shaft?
- Ngk Tr55ix
- CME install
- youd think for $1000 youd get headers that wont lay on the damn kmember
- MAC headers?
- Header Wrap
- Possible coil pack problem
- Smoking after LT install???
- Shot Plugs........
- Granatelli MAF
- flowmaster to hooker catback DYNO results
- need some info/help on new intake/exhaust set up
- Putting the cats back on
- Symptoms of Throttle Sensor BAD?
- Loudmouth II....
- Corsa Power Pulse or B&B Tri Flo?
- Ported TB pics and info for those who need it
- Part # needed for this thermostat please
- Td Vs. Cat-back
- I think i finally have an exhaust that i like
- KOOKS Headers
- LS1 vs LS6 exhaust manifold gaskets
- Shorty headers?
- no tail pipes.
- Pacesetter question for those who spliced their own 02 extensions
- Are the stock spark plug wires good?
- would i get bette flow if...
- qtp cats
- Removed my AIR and have a question
- I need ya'll's help
- New exhaust setup...
- Which brand electric cutout?
- grinding a weld
- strange problem
- Air Conditioner Problem
- deleting o2's
- how to seal map sensor to fast intake
- De-screened MAF
- Do i need ?
- SLP & K&N intake for LS1
- Pacesetters vs. Kooks
- Fast 90/90 or LS6/Ported stock TB for F13-cam only
- Dual or Single Cutout
- Thunder Racing Throttle Body
- Installed Dyna Tech LT's, NW TB, FAST 90
- catback
- wierd noise either trans or rear end!???
- Yanking the ac.........
- QTP Cutout Opener w/ Borla Exhaust
- Starter relay ?
- *** Serpentine belt experts, please help ****
- Dual cut-outs..immediately after each collector
- ls1 to ls6 intake question
- LS1 sounds sound clip question
- PPL running Sweet Thunders Chime IN **
- Help!! Y pipe banging problems
- Muffler & Gas Mileage
- cut out for dual exhuast
- SLP radiator Bubbling and often steams when i turn off car?
- dynomouth and LT headers
- Air Lid Concern
- other 90mm TB's
- fast intake install Q'?
- Best LS1 Header for under $500??
- ''I had installed my cat-back & air lid"
- header install...reuse stock exhaust gasket??
- O2 sensor durability
- What's on the second braket on driver side mainfold?
- Gauge hook-up questions?
- Header question IMPORTANT!!!!
- Problem with Dual Electric Y-pipe already. any ideas?
- Power Steering Pulley
- headers
- ASP Pulley Install - Pics Too!
- SLP SS Cold Air box for 98SS camaro ram air
- TD's into a GMMG catback.
- Smooth Bellows worth it?
- Hooker catback is very low restriction!!!
- loud squeal
- tell me more about true duals.
- Need some help with header install
- Any one ever tried to port their own thottlebody
- best ported throttle body
- hesitation at higher loads, lower rpms
- Borla Cat Back #140028 -> Great Sound/Quality
- what causes low mpg's?
- Radiators
- Engine oil cooler?
- wow is my car loud!
- not your avg LS6 intake question....
- Where to run wires through DRIVER side of firewall?
- Help! All guages and Idiot lights went out.
- BBK 80mm TB..
- Help! power loss after installing lingenfelter intake
- Best method for cleaning under intake?
- True duals with straight pipes?
- need new exhaust
- New Exhaust
- Anyone else ever have a problem with O2 extensions?
- Cut Out Question
- Cold start-high RPM-ported TB on Vette
- tsp y pipe
- Is this all i need for lt + td install?
- 6.0 in an ss
- installing fast 90mm on sat, any tips/tricks i should know
- another true dual question
- I gust get my order from SLP
- Granatelli MAF
- MAF Ends? Are they worth it?
- Some TPiS Throttle Body install help...
- Could I use a Volant air intake with a BGRA?
- Header install 2000 LS1 !EGR problem
- tsd true duals & Lanes true duals
- Oil pan bolt torque specs
- changing up exghauhst
- heat cycle headers procedure?
- Exhaust
- P0405 thrown with EGR deleted?!
- Cutout??
- Which Y-pipe with QTP headers?
- lowered cars with TD INSIDE NOW!!!...please
- open headers
- Throttle body Gasket?
- Newbe - Need help changing TB electronics
- Exhaust is more important than I knew, lost 85hp from exhaust!
- BEST ground clearance?
- hows this for true duals parts?
- Another Exhaust Tip thread
- What can you use with the BGRA?
- another Idea for out the back duals
- Loudness of exhaust
- QTP Stainless Steel Exhaust Cutouts!
- Know where to find my radiator fluid level sensor?
- Meziere race only electric water pump.
- How loud is...
- best headers????????
- AC question need help Guru's
- Installed LMII today
- bullet muffler on Y-pipe??
- What plugs??
- Rusting Pacesetter Ceramic Coated Headers.
- another exhaust question
- Best way to enlarge hole in QTP stainless headers?
- TPIS 1200 CFM throttlebody
- AMW Catch Can on Vette
- New engine install, cooling issue..HELP..
- Next best thing to Kooks?
- power steering?
- loud mouth or headers?
